Can you suggest an alternative product for the following product features?
thank you
thank you
Welcome to the DigiKey tech forum community.
I did not see that we had ones with similar design in the same DPST NC/NO type.
Some similar ones in regards to function and mounting are in link below.
Regards,
If you have to have green and the power symbol, I was unable to find an alternative, however if your application allows you to deviate from having one or both of those options then you can take a look at these:
DPST-NO/NC Pushbutton Switches | Electronic Components Distributor DigiKey
