I’m looking for Qty 2 replacement PTT switches. Here’s what is currently installed in the yoke with dimensions for the switch and the hole. There are 2 connectors at the bottom of the switch to solder the wires to.
Greg
Agghopp,
Welcome to the Technical Support Forum!
I have looked into this for you and have not been able to find an exact match but you may find the following to be suitable replacements regardless. Please take a look at the product pages and datasheets to evaluate their suitability. For example, I noticed is the threading is different and I do not know how that may effect you in this application.
| MFR PART # | 8732S1HZQE |
| DIGI-KEY PART # | CKN10198-ND |
| MANUFACTURER | C&K |
| DESCRIPTION | Pushbutton Switch SPST-NO Standard Panel Mount, Rear |
| DATASHEET | Datasheet |
| MFR PART # | 8731SHZQE |
| DIGI-KEY PART # | CKN10196-ND |
| DESCRIPTION | SWITCH PUSH SPST-NO 1A 125V |
| MFR PART # | C&K |
| DIGI-KEY PART # | CKN10197-ND |
Link to search results with more options
I hope this helps!
Thank you Aaron. It looks like the opening the switch needs to slide into is .340 and if I read the datasheet correctly these are all .375 in diameter.
Can we find one that has a smaller diameter barrel by chance? Thank you, this is so close to what I need.
I did take another look. We do have another set of options that could possibly work. Please take a look at these from Grayhill Inc.
| MFR PART # | 39-101 |
| DIGI-KEY PART # | GH1369-ND |
| MANUFACTURER | Grayhill Inc. |
| MFR PART # | 39-701 |
| DIGI-KEY PART # | GH7473-ND |
| MFR PART # | 39-102 |
| DIGI-KEY PART # | GH7471-ND |
| Manufacturer Product Number | 39-103 |
| 39-103 | GH7472-ND |
| Manufacturer | Grayhill Inc. |
| Detailed Description | Pushbutton Switch SPST-NO Standard Panel Mount, Rear |
| Datasheet | Datasheet |
Other than these options i am sorry to say that I do not see a pushbutton switch like this that is a match for your mounting hole.
I hope this is helpful!
