I’m trying to disable the energy detect on LAN8710A using device tree. I’m not an expert with device trees, but I found many examples on line and came up with the changes below. My \KERNEL\drivers\net\phy\smsc.c has support for “disable-energy-detect”. See code snippet from smsc.c below:
if (of_find_property(of_node, "smsc,disable-energy-detect", &len))
enable_energy = 0;
In the following device tree snippet, the (-) represents lines removed and the (+) represents lines I added to my working device tree.
&cpsw_emac0 {
- phy_id = <&davinci_mdio>, <0>;
+ phy-handle = <ðphy0>;
phy-mode = "mii";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
- phy_id = <&davinci_mdio>, <1>;
+ phy-handle = <ðphy1>;
phy-mode = "mii";
dual_emac_res_vlan = <2>;
&davinci_mdio {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
status = "okay";
+ ethphy0: ethernet-phy@0 {
+ reg = <0>;
+ smsc,disable-energy-detect;
+ ethphy1: ethernet-phy@1 {
+ reg = <1>;
Now it doesn’t work. Any idea what I’m doing wrong?
HI @dmccalla which linux branch/tree are you going against? The phy_id → phy-handle shows that you are combing the old driver with TI’s cpsw rewrite…
Regards,
I’m using kernel version 4.4.70-bone-rt-r17. Does that help?
Here’s a code snippet from cpsw.c
priv->phy_node = of_parse_phandle(slave_node, "phy-handle", 0);
parp = of_get_property(slave_node, "phy_id", &lenp);
if (of_phy_is_fixed_link(slave_node)) {
struct device_node *phy_node;
struct phy_device *phy_dev;
YEah, that is really old…
At least the driver seems to support it…
https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/net/phy/smsc.c?h=v4.4.70#n55
Hum…
&cpsw_emac0 {
phy-mode = "mii";
&cpsw_emac1 {
phy-mode = "mii";
&mac {
pinctrl-0 = <&cpsw_default>;
pinctrl-1 = <&cpsw_sleep>;
status = "okay";
&davinci_mdio {
status = "okay";
Maybe?
&cpsw_emac0 {
phy-mode = "mii";
&cpsw_emac1 {
phy-mode = "mii";
&mac {
status = "okay";
&davinci_mdio {
reg = <0>;
reg = <1>;
Might be easier to patch the driver and always enable it?
I patched the driver and I’m moving on.
Thanks for your help.
