Ambient light sensors measure the intensity of light in their surroundings. Often, this is done to allow appliances to adjust their own light intensity based on ambient levels. This can significantly improve the energy efficiency of such devices by reducing power consumption. These sensors can be commonly used in wide range of applications such as smartphones, laptops, notebooks, etc.
These sensors can influence the exposure time and other camera settings to improve the quality of photographs in digital cameras and smartphones. In indoors areas, ambient light sensors are used to detect the intensity of surrounding light, and which in turn enables the automatic light adjustments by smart lighting systems.
There are various ambient light sensors available in the market which are based on different technologies.
- Light Dependent Resistor (LDR)
- Photodiode
- Phototransistor
- Integrated Circuit Ambient Light Sensor
An LDR or Light Dependent Resistor is a resistor whose resistance varies depending on the light falling on its surface. The resistance decreases when the intensity of the surrounding light increases, and increases when the intensity of the surrounding light decreases.
The sensitivity of LDRs depend on the wavelength of the incident light. They are more sensitive to visible light than to infrared or UV light. There is some response time required for LDRs to reflect a change in ambient light, making them poorly suited to real-time applications. The resistance of LDRs is also influenced by changes in temperature.
Applications of LDRs
Smart Lighting Systems: LDR can be used in streetlights, garden and security lighting systems. They detect the intensity of surrounding light and trigger the lighting system to turn ON the lights when it is Dark and turn OFF the lights when it is Daytime.
Display Brightness Control: LDRs help in reducing eye strain and saving power in smartphones, laptops, monitors, etc.
Solar Trackers: LDRs can be used in solar tracking where they can help guide solar panels in rotating to maximally face the sun.
Communication Systems: They can be used in optical communication system where changes in light intensity carry the information.
LDRs available with DigKey
| DK Part # | Mfr Part # | |
| 1528-2141-ND | 161 | |
| PDV-P8103-ND | PDV-P8103 | |
| NSL-5152-ND | NSL-5152 | |
| PDV-P8104-ND | PDV-P8104 | |
| NSL-19M51-ND | NSL-19M51 | |
| PDV-P9003-1-ND | PDV-P9003-1 | |
| NORPS-12-ND | NORPS-12 | |
| NSL-06S53-ND | NSL-06S53 | |
| NSL-4140-ND | NSL-4140 | |
| NSL-4960-ND | NSL-4960 | |
| NSL-5162-ND | NSL-5162 | |
| NSL-5112-ND | NSL-5112 | |
| PDV-P7002-ND | PDV-P7002 | |
| PDV-P5003-ND | PDV-P5003 | |
| NSL-6112-ND | NSL-6112 | |
| PDV-P9005-1-ND | PDV-P9005-1 | |
| PDV-P9200-ND | PDV-P9200 | |
| PDV-P9004-ND | PDV-P9004 | |
| PDV-P9003-ND | PDV-P9003 | |
| PDV-P9001-ND | PDV-P9001 | |
| PDV-P9002-ND | PDV-P9002 | |
| PDV-P9007-ND | PDV-P9007 | |
| PDV-P5001-ND | PDV-P5001 | |
| PDV-P8102-ND | PDV-P8102 | |
| PDV-P8101-ND | PDV-P8101 |
Photodiode
A photodiodes is a semiconductor device used for sensing light. It converts the light signal into an electric signal by converting photons into electric current. It is a p-n junction diode which has an intrinsic layer between p side and n side and operates in reverse bias condition. In actuality it is packaged with optical filters and lens.
On exposure to light, the photons which enter into the depletion/intrinsic region generate electron hole pairs. These electrons and holes drift under the influence of electric field which exists due to the applied reverse bias voltage. This process contributes to the electric current which can, then, be measured in the outer circuit. The amount of electric current generated depends on the intensity of the light falling on it.
Because of their high sensitivity, photodiodes can be used across a wide spectrum. They have fast response time, so they can quickly react to rapidly changing light which makes them suitable for real time applications. Temperature changes do not affect the performance of photodiodes significantly.
Some photodiodes are sensitive to visible light while others are more sensitive to the infrared or ultraviolet regions of light.
Applications
Due to their linear response, they can be used in many simple day to day applications.
Photodiodes are used in optical communication systems where optical signals need to be converted into electrical signals at the receiving end.
They can be used in safety and security systems, for example in smoke detection system and intrusion alarm system. In smoke detectors, they sense the scattering of light by smoke particles and in intrusion alarm system, an infrared beam gets interrupted whenever an intruder attempts to cross a restricted point, which can trigger an alarm.
As an application in medical electronics they are employed in various instruments and devices, for example in pulse oximeters. The change in hemoglobin content changes the amount of red light coming through the skin into the photodiode in pulse oximeter. This change in red light can be converted to the change in electric current which can be used to estimate the amount of hemoglobin in the blood.
Due to their fast response, they are also used in Barcode scanners, TV remotes and brightness adjustment in displays.
Photodiodes available with DigiKey
| 475-SFH213FA-ND | SFH 213 FA | |
| VEMD2020X01TR-ND,VEMD2020X01CT-ND,VEMD2020X01DKR-ND | VEMD2020X01 | |
| TEMD7000X01TR-ND,TEMD7000X01CT-ND,TEMD7000X01DKR-ND | TEMD7000X01 | |
| 475-SFH203FA-ND | SFH 203 FA | |
| 751-1500-2-ND,751-1500-1-ND,751-1500-6-ND | VBPW34S | |
| VEMD1060X01TR-ND,VEMD1060X01CT-ND,VEMD1060X01DKR-ND | VEMD1060X01 | |
| VEMD2520X01TR-ND,VEMD2520X01CT-ND,VEMD2520X01DKR-ND | VEMD2520X01 | |
| 751-VEMD2023X01TR-ND,751-VEMD2023X01CT-ND,751-VEMD2023X01DKR-ND | VEMD2023X01 | |
| 475-SFH2400FA-ZTR-ND,475-SFH2400FA-ZCT-ND,475-SFH2400FA-ZDKR-ND | SFH 2400FA-Z | |
| 475-BP104FAS-ZTR-ND,475-BP104FAS-ZCT-ND,475-BP104FAS-ZDKR-ND | BP 104 FAS-Z | |
| 475-BPW34-ND | BPW34 | |
| 751-1007-ND | BPV22NF | |
| 475-BPW34FS-ZTR-ND,475-BPW34FS-ZCT-ND,475-BPW34FS-ZDKR-ND | BPW 34 FS-Z | |
| 475-BPW34S-ZTR-ND,475-BPW34S-ZCT-ND,475-BPW34S-ZDKR-ND | BPW 34 S-Z | |
| 475-SFH2400-ZTR-ND,475-SFH2400-ZCT-ND,475-SFH2400-ZDKR-ND | SFH 2400-Z | |
| QSB34CGRTR-ND,QSB34CGRCT-ND | QSB34CGR | |
| 475-BPW34FAS-ZTR-ND,475-BPW34FAS-ZCT-ND,475-BPW34FAS-ZDKR-ND | BPW 34 FAS-Z | |
| 751-1048-2-ND,751-1048-1-ND,751-1048-6-ND | TEMD5110X01 | |
| TEMD5080X01TR-ND,TEMD5080X01CT-ND,TEMD5080X01DKR-ND | TEMD5080X01 | |
| VEMD5060X01TR-ND,VEMD5060X01CT-ND,VEMD5060X01DKR-ND | VEMD5060X01 | |
| PDB-C152SMTR-ND,PDB-C152SMCT-ND,PDB-C152SMDKR-ND | PDB-C152SM | |
| PDB-C134-ND | PDB-C134 | |
| VTB8440BH-ND | VTB8440BH | |
| VTB8441BH-ND | VTB8441BH | |
| 751-1012-ND | BPW20RF | |
| 751-1014-ND | BPW24R | |
| 2096-GUVB-C21SDTR-ND,2096-GUVB-C21SDCT-ND,2096-GUVB-C21SDDKR-ND | GUVB-C21SD | |
| PDB-C171SMTR-ND,PDB-C171SMCT-ND,PDB-C171SMDKR-ND | PDB-C171SM | |
| VTB1113H-ND | VTB1113H | |
| 2096-GUVA-S12SDTR-ND,2096-GUVA-S12SDCT-ND,2096-GUVA-S12SDDKR-ND | GUVA-S12SD | |
| 209-0090-3111-185TR-ND,209-0090-3111-185CT-ND,209-0090-3111-185DKR-ND | 0090-3111-185 | |
| 2096-GUVC-S10GDTR-ND,2096-GUVC-S10GDCT-ND,2096-GUVC-S10GDDKR-ND | GUVC-S10GD | |
| SLSD-71N300-ND | SLSD-71N300 | |
| 751-1013-ND | BPW21R | |
| 365-1621-ND | OP913SL | |
| 209-0800-3111-185TR-ND,209-0800-3111-185CT-ND,209-0800-3111-185DKR-ND | 0800-3111-185 | |
| 1125-1327-ND | MTPD1346D-150 | |
| 2096-GUVC-T21GH-ND | GUVC-T21GH | |
| 5556-MICROFJ-30035-TSV-TR-ND,5556-MICROFJ-30035-TSV-TRCT-ND,5556-MICROFJ-30035-TSV-TRDKR-ND | MICROFJ-30035-TSV-TR | |
| 1125-1323-ND | MT03-002 | |
| PDB-C107-ND | PDB-C107 | |
| 516-AFBR-S4N44P014M-ND | AFBR-S4N44P014M | |
| 5556-MICROFC-30050-SMT-TR-ND,5556-MICROFC-30050-SMT-TRCT-ND,5556-MICROFC-30050-SMT-TRDKR-ND | MICROFC-30050-SMT-TR | |
| 5556-MICROFC-30035-SMT-TR-ND,5556-MICROFC-30035-SMT-TRCT-ND,5556-MICROFC-30035-SMT-TRDKR-ND | MICROFC-30035-SMT-TR | |
| ODD-3W-2-ND | ODD-3W-2 | |
| ODD-5WBISOL-ND | ODD-5WBISOL | |
| 5556-MICROFC-10035-SMT-TR-ND,5556-MICROFC-10035-SMT-TRCT-ND,5556-MICROFC-10035-SMT-TRDKR-ND | MICROFC-10035-SMT-TR | |
| ODD-42W-ND | ODD-42W | |
| 5556-MICROFC-60035-SMT-TR-ND,5556-MICROFC-60035-SMT-TRCT-ND,5556-MICROFC-60035-SMT-TRDKR-ND | MICROFC-60035-SMT-TR | |
| 209-076-14-21-011-ND | 076-14-21-011 | |
| ODD-42WB-ND | ODD-42WB | |
| 5556-MICROFJ-60035-TSV-TR-ND,5556-MICROFJ-60035-TSV-TRCT-ND,5556-MICROFJ-60035-TSV-TRDKR-ND | MICROFJ-60035-TSV-TR | |
| 209-UDT-455UV-ND | UDT-455UV | |
| 209-113-24-21-021-ND | 113-24-21-021 | |
| 516-AFBR-S4N66P014M-ND | AFBR-S4N66P014M | |
| PDB-C609-2-ND | PDB-C609-2 | |
| 1125-1501-ND | MTPD2600-100 | |
| 209-100-13-23-222-ND | 100-13-23-222 | |
| 1601-C30902EH-ND | C30902EH | |
| PDB-C613-2-ND | PDB-C613-2 | |
| 2096-GUVC-T20GD-U-ND | GUVC-T20GD-U | |
| C30618GH-ND | C30618GH | |
| ODA-6WB-500M-ND | ODA-6WB-500M | |
| 209-112-43-11-221-ND | 112-43-11-221 | |
| 2640-FCI-INGAAS-1500-ND | FCI-INGAAS-1500 | |
| 1601-1020-ND | C30641GH | |
| 209-085-23-21-021-ND | 085-23-21-021 | |
| 516-AFBR-S4N44P164M-ND | AFBR-S4N44P164M | |
| 958-BXT2-17TF-ND | BXT2-17TF | |
| 958-BXT2S-28T-ND | BXT2S-28T | |
| 1601-1417-ND | C30954EH | |
| 1601-C30642GH-ND | C30642GH | |
| 1601-C30642GH-LC-ND | C30642GH-LC | |
| 958-1021-ND | SXUV5 | |
| 958-1027-ND | AXUV20HS1 | |
| 958-1013-ND | AXUV63HS1 | |
| 958-1002-ND | AXUV100G | |
| 1601-C30662EH-ND | C30662EH | |
| 958-1020-ND | SXUV100 | |
| 1601-C30659-1060-3AH-ND | C30659-1060-3AH | |
| 1830-IN-S126BTNPDTR-ND,1830-IN-S126BTNPDCT-ND,1830-IN-S126BTNPDDKR-ND | IN-S126BTNPD | |
| 160-1987-ND | LTR-323DB | |
| 1830-INL-3APD80-ND | INL-3APD80 | |
| 1830-INL-3ANPD80-ND | INL-3ANPD80 | |
| 1830-INL-5ANPD80-ND | INL-5ANPD80 | |
| 1830-INL-5APD80-ND | INL-5APD80 | |
| VEMD10940FTR-ND,VEMD10940FCT-ND,VEMD10940FDKR-ND | VEMD10940F | |
| 1080-1139-ND | PD204-6B | |
| VEMD10940FX01TR-ND,VEMD10940FX01CT-ND,VEMD10940FX01DKR-ND | VEMD10940FX01 | |
| 1830-IN-S32HSNPDTR-ND,1830-IN-S32HSNPDCT-ND,1830-IN-S32HSNPDDKR-ND | IN-S32HSNPD | |
| 732-1540801EEA300TR-ND,732-1540801EEA300CT-ND,732-1540801EEA300DKR-ND | 1540801EEA300 | |
| 732-1541021ECA170TR-ND,732-1541021ECA170CT-ND,732-1541021ECA170DKR-ND | 1541021ECA170 | |
| 1080-1366-2-ND,1080-1366-1-ND,1080-1366-6-ND | PD15-22B/TR8 | |
| 1080-1140-ND | PD204-6C | |
| 732-13405-2-ND,732-13405-1-ND,732-13405-6-ND | 1541201EEA400 | |
| 1080-1365-2-ND,1080-1365-1-ND,1080-1365-6-ND | PD15-21B/TR8 | |
| VEMD2523SLX01TR-ND,VEMD2523SLX01CT-ND,VEMD2523SLX01DKR-ND | VEMD2523SLX01 | |
| 754-2357-ND | WP3DPD1BT/BD | |
| VEMD2000X01TR-ND,VEMD2000X01CT-ND,VEMD2000X01DKR-ND | VEMD2000X01 | |
| VEMD2023SLX01TR-ND,VEMD2023SLX01CT-ND,VEMD2023SLX01DKR-ND | VEMD2023SLX01 | |
| 732-1540031EC4590-ND | 1540031EC4590 | |
| VTP9812FH-ND | VTP9812FH | |
| 1080-1367-2-ND,1080-1367-1-ND,1080-1367-6-ND | PD15-22C/TR8 | |
| 1080-1142-ND | PD333-3B/H0/L2 | |
| BPV23FL-ND | BPV23FL | |
| TEFD4300F-ND | TEFD4300F | |
| TEFD4300-ND | TEFD4300 | |
| 751-VEMD4010X01TR-ND,751-VEMD4010X01CT-ND,751-VEMD4010X01DKR-ND | VEMD4010X01 | |
| BPW83-ND | BPW83 | |
| 475-SFH203-ND | SFH 203 | |
| 751-1001-ND | BPV10 | |
| 475-SFH229FA-ND | SFH 229FA | |
| 475-SFH229-ND | SFH 229 | |
| 751-1000-ND | BP104 | |
| 751-VEMD2704TR-ND,751-VEMD2704CT-ND,751-VEMD2704DKR-ND | VEMD2704 | |
| 365-1085-ND | OP950 | |
| 365-1623-ND | OP954 | |
| VEMD2523X01TR-ND,VEMD2523X01CT-ND,VEMD2523X01DKR-ND | VEMD2523X01 | |
| 365-1086-ND | OP999 | |
| 751-1043-2-ND,751-1043-1-ND,751-1043-6-ND | TEMD1000 | |
| 751-1044-2-ND,751-1044-1-ND,751-1044-6-ND | TEMD1020 | |
| TEMD7100X01TR-ND,TEMD7100X01CT-ND,TEMD7100X01DKR-ND | TEMD7100X01 | |
| 1080-1373-2-ND,1080-1373-1-ND,1080-1373-6-ND | PD70-01C/TR7 | |
| 475-SFH203PFA-ND | SFH 203 PFA | |
| 475-SFH203P-ND | SFH 203 P | |
| 475-SFH213-ND | SFH 213 | |
| 475-SFH2505FA-ZTR-ND,475-SFH2505FA-ZCT-ND | SFH 2505 FA-Z | |
| QSE773-ND | QSE773 | |
| 1080-1143-ND | PD333-3C/H0/L2 | |
| 475-SFH2704TR-ND,475-SFH2704CT-ND,475-SFH2704DKR-ND | SFH 2704 | |
| 751-1496-2-ND,751-1496-1-ND,751-1496-6-ND | VBP104S | |
| 751-1494-2-ND,751-1494-1-ND,751-1494-6-ND | VBP104FAS | |
| VEMD6010X01TR-ND,VEMD6010X01CT-ND,VEMD6010X01DKR-ND | VEMD6010X01 | |
| 751-1017-ND | BPW46 | |
| 751-1002-ND | BPV10NF | |
| 751-1006-ND | BPV22F | |
| 751-1499-2-ND,751-1499-1-ND,751-1499-6-ND | VBPW34FASR | |
| 751-1498-2-ND,751-1498-1-ND,751-1498-6-ND | VBPW34FAS | |
| 751-1501-2-ND,751-1501-1-ND,751-1501-6-ND | VBPW34SR | |
| 754-2340-2-ND,754-2340-1-ND,754-2340-6-ND | AM2520PD1BT03 | |
| 475-SFH235FA-ND | SFH 235 FA | |
| VEMD1160X01TR-ND,VEMD1160X01CT-ND,VEMD1160X01DKR-ND | VEMD1160X01 | |
| VEMD6110X01TR-ND,VEMD6110X01CT-ND,VEMD6110X01DKR-ND | VEMD6110X01 | |
| 751-1015-ND | BPW34 | |
| 751-1503-2-ND,751-1503-1-ND,751-1503-6-ND | TEMD6200FX01 | |
| 475-SFH2270RTR-ND,475-SFH2270RCT-ND,475-SFH2270RDKR-ND | SFH 2270R | |
| 475-SFH205FA-ND | SFH 205 FA | |
| 209-019-141-411-BTR-ND,209-019-141-411-BCT-ND,209-019-141-411-BDKR-ND | 019-141-411-B | |
| 475-SFH2200A01TR-ND,475-SFH2200A01CT-ND,475-SFH2200A01DKR-ND | SFH 2200 A01 | |
| 475-SFH2200TR-ND,475-SFH2200CT-ND,475-SFH2200DKR-ND | SFH 2200 | |
| 751-1051-2-ND,751-1051-1-ND,751-1051-6-ND | TEMD6010FX01 | |
| BPW34S-ND | BPW34S | |
| 516-HSD6-C170TR-ND,516-HSD6-C170CT-ND,516-HSD6-C170DKR-ND | HSD6-C170 | |
| VEMD6060X01TR-ND,VEMD6060X01CT-ND,VEMD6060X01DKR-ND | VEMD6060X01 | |
| VEMD6160X01TR-ND,VEMD6160X01CT-ND,VEMD6160X01DKR-ND | VEMD6160X01 | |
| VEMD5010X01TR-ND,VEMD5010X01CT-ND,VEMD5010X01DKR-ND | VEMD5010X01 | |
| 209-PDB-C156CT-ND,209-PDB-C156TB-ND | PDB-C156 | |
| 751-1046-2-ND,751-1046-1-ND,751-1046-6-ND | TEMD5010X01 | |
| 209-019-111-411TR-ND,209-019-111-411CT-ND,209-019-111-411DKR-ND | 019-111-411 | |
| 475-SFH2713TR-ND,475-SFH2713CT-ND,475-SFH2713DKR-ND | SFH 2713 | |
| 475-SFH2401TR-ND,475-SFH2401CT-ND,475-SFH2401DKR-ND | SFH 2401 | |
| VEMD5080X01TR-ND,VEMD5080X01CT-ND,VEMD5080X01DKR-ND | VEMD5080X01 | |
| PDB-C154SMTR-ND,PDB-C154SMCT-ND,PDB-C154SMDKR-ND | PDB-C154SM | |
| 475-SFH2430-ZTR-ND,475-SFH2430-ZCT-ND,475-SFH2430-ZDKR-ND | SFH 2430-Z | |
| 209-040-101-411TR-ND,209-040-101-411CT-ND,209-040-101-411DKR-ND | 040-101-411 | |
| 475-SFH2201TR-ND,475-SFH2201CT-ND,475-SFH2201DKR-ND | SFH 2201 | |
| 209-019-141-411-RTR-ND,209-019-141-411-RCT-ND,209-019-141-411-RDKR-ND | 019-141-411-R | |
| 209-019-141-411-GTR-ND,209-019-141-411-GCT-ND,209-019-141-411-GDKR-ND | 019-141-411-G | |
| VEMD5160X01TR-ND,VEMD5160X01CT-ND,VEMD5160X01DKR-ND | VEMD5160X01 | |
| 475-SFH2240TR-ND,475-SFH2240CT-ND,475-SFH2240DKR-ND | SFH 2240 | |
| 475-SFH2705TR-ND,475-SFH2705CT-ND,475-SFH2705DKR-ND | SFH 2705 | |
| TEMD5510FX01TR-ND,TEMD5510FX01CT-ND,TEMD5510FX01DKR-ND | TEMD5510FX01 | |
| VEMD8080TR-ND,VEMD8080CT-ND,VEMD8080DKR-ND | VEMD8080 | |
| 751-VEMD8081TR-ND,751-VEMD8081CT-ND,751-VEMD8081DKR-ND | VEMD8081 | |
| PDB-C134F-ND | PDB-C134F | |
| PDB-C158-ND | PDB-C158 | |
| 2096-GUVA-C22SDTR-ND,2096-GUVA-C22SDCT-ND,2096-GUVA-C22SDDKR-ND | GUVA-C22SD | |
| 2096-GVBL-S12SDTR-ND,2096-GVBL-S12SDCT-ND,2096-GVBL-S12SDDKR-ND | GVBL-S12SD | |
| 2096-GVGR-S11SDTR-ND,2096-GVGR-S11SDCT-ND,2096-GVGR-S11SDDKR-ND | GVGR-S11SD | |
| 2096-GUVB-S11SDTR-ND,2096-GUVB-S11SDCT-ND,2096-GUVB-S11SDDKR-ND | GUVB-S11SD | |
| PDB-C139-ND | PDB-C139 | |
| 1125-1419-ND | MTD3910PM | |
| 1125-1420-ND | MTD3910N | |
| 1125-MTD3910W-ND | MTD3910W | |
| 1125-MTPD3001D3-030-ND | MTPD3001D3-030 | |
| PDB-C160SMTR-ND,PDB-C160SMCT-ND,PDB-C160SMDKR-ND | PDB-C160SM | |
| SLD-70BG2A-ND | SLD-70BG2A | |
| 2096-GUVV-S10SDTR-ND,2096-GUVV-S10SDCT-ND,2096-GUVV-S10SDDKR-ND | GUVV-S10SD | |
| 1601-VTH2110-ND | VTH2110 | |
| 505-ADPD2140BCPZN-R7TR-ND,505-ADPD2140BCPZN-R7CT-ND,505-ADPD2140BCPZN-R7DKR-ND | ADPD2140BCPZN-R7 | |
| 2096-GUVCL-S10GDTR-ND,2096-GUVCL-S10GDCT-ND,2096-GUVCL-S10GDDKR-ND | GUVCL-S10GD | |
| VTB1113BH-ND | VTB1113BH | |
| 2096-GUVA-T11GD-ND | GUVA-T11GD | |
| 1601-VTH2120-ND | VTH2120 | |
| 365-1870-ND | OPR2100 | |
| 1125-1326-ND | MTPD1346D-100 | |
| ODD-5W-ND | ODD-5W | |
| 2096-GVGR-T11GD-ND | GVGR-T11GD | |
| ODD-1WB-ND | ODD-1WB | |
| 1125-1423-ND | MT03-023 | |
| 1125-MTPD1346SL-100-ND | MTPD1346SL-100 | |
| 1601-C30737MH-500-90C-ND | C30737MH-500-90C | |
| 2096-GUVB-S31GDTR-ND,2096-GUVB-S31GDCT-ND,2096-GUVB-S31GDDKR-ND | GUVB-S31GD | |
| 2096-GUVV-T10GD-ND | GUVV-T10GD | |
| 1125-MTPD2601T-100-ND | MTPD2601T-100 | |
| 2096-GUVC-T10GD-L-ND | GUVC-T10GD-L | |
| 2640-S-100CL-ND | S-100CL | |
| 2096-GUVA-T11GD-L-ND | GUVA-T11GD-L | |
| 2096-GUVC-T10GD-ND | GUVC-T10GD | |
| 5556-MICROFJ-30020-TSV-TR-ND,5556-MICROFJ-30020-TSV-TRCT-ND,5556-MICROFJ-30020-TSV-TRDKR-ND | MICROFJ-30020-TSV-TR | |
| ODD-5WISOL-ND | ODD-5WISOL | |
| 1125-1322-ND | MT03-001 | |
| 1601-C30737LH-500-92CTR-ND,1601-C30737LH-500-92CCT-ND,1601-C30737LH-500-92CDKR-ND | C30737LH-500-92C | |
| 008-2151-112-ND | 008-2151-112 | |
| 1601-C30617L-100-ND | C30617L-100 | |
| 1125-MTSM2601SMF2-150-ND | MTSM2601SMF2-150 | |
| C30737LH-500-80A-ND | C30737LH-500-80A | |
| 1125-MTPD2601T8-300-ND | MTPD2601T8-300 | |
| 5556-MICROFC-30035-SMT-TR1-ND | MICROFC-30035-SMT-TR1 | |
| 516-AFBR-S4N66P024M-ND | AFBR-S4N66P024M | |
| PDB-C110-ND | PDB-C110 | |
| 5556-MICROFJ-30035-TSV-TR1-ND | MICROFJ-30035-TSV-TR1 | |
| 209-200-12-22-041-ND | 200-12-22-041 | |
| 209-APX-NG0031QPD-LTR-ND,209-APX-NG0031QPD-LCT-ND,209-APX-NG0031QPD-LDKR-ND | APX-NG0031QPD-L | |
| 5556-MICROFJ-60035-TSV-TR1-ND | MICROFJ-60035-TSV-TR1 | |
| 2640-PIN-10DP/SB-ND | PIN-10DP/SB | |
| 1601-C30645EH-ND | C30645EH | |
| 2640-QD7-0-SD-ND | QD7-0-SD | |
| 2640-FCI-INGAAS-Q3000-ND | FCI-INGAAS-Q3000 | |
| 732-13406-2-ND,732-13406-1-ND,732-13406-6-ND | 1541141ECA570 | |
| BPD-BQDA38V-FZ04TR-ND,BPD-BQDA38V-FZ04CT-ND,BPD-BQDA38V-FZ04DKR-ND | BPD-BQDA38V-FZ04 | |
| 1080-1141-ND | PD204-6C/L3 | |
| 365-1084-ND | OP906 | |
| 1080-1375-2-ND,1080-1375-1-ND,1080-1375-6-ND | PD95-21B/TR10 | |
| BPV22NFL-ND | BPV22NFL | |
| BP104S-ND | BP104S | |
| 160-1032-ND | LTR-516AD | |
| 1080-PD1503-3B/L2-ND | PD1503-3B/L2 | |
| VEMD2003X01TR-ND,VEMD2003X01CT-ND,VEMD2003X01DKR-ND | VEMD2003X01 | |
| 751-VEMD2503X01TR-ND,751-VEMD2503X01CT-ND,751-VEMD2503X01DKR-ND | VEMD2503X01 | |
| 751-1008-ND | BPV23F | |
| 751-1009-ND | BPV23NF | |
| 754-2341-2-ND,754-2341-1-ND,754-2341-6-ND | AM2520PD1BT09 | |
| 751-VBP104SRTR-ND,751-VBP104SRCT-ND,751-VBP104SRDKR-ND | VBP104SR | |
| 751-1495-2-ND,751-1495-1-ND,751-1495-6-ND | VBP104FASR | |
| 516-HLPD-B0D0-00000TR-ND,516-HLPD-B0D0-00000CT-ND | HLPD-B0D0-00000 | |
| 475-BP104FS-Z-ND | BP 104 FS-Z | |
| 1080-1368-2-ND,1080-1368-1-ND,1080-1368-6-ND | PD42-21B/TR8 | |
| 1080-1148-ND | PD438C/S46 | |
| 1080-1144-ND | PD438B | |
| BPV23NFL-ND | BPV23NFL | |
| 1080-1371-2-ND,1080-1371-1-ND,1080-1371-6-ND | PD70-01B/TR7 | |
| 475-BPW34FASR-ZTR-ND,475-BPW34FASR-ZCT-ND,475-BPW34FASR-ZDKR-ND | BPW 34 FASR-Z | |
| 1080-1372-2-ND,1080-1372-1-ND,1080-1372-6-ND | PD70-01C/TR10 | |
| 751-1047-2-ND,751-1047-1-ND,751-1047-6-ND | TEMD5020X01 | |
| TEMD5120X01TR-ND,TEMD5120X01CT-ND,TEMD5120X01DKR-ND | TEMD5120X01 | |
| 209-019-101-411TR-ND,209-019-101-411CT-ND,209-019-101-411DKR-ND | 019-101-411 | |
| VEMD5110X01TR-ND,VEMD5110X01CT-ND,VEMD5110X01DKR-ND | VEMD5110X01 | |
| 209-040-111-411TR-ND,209-040-111-411CT-ND,209-040-111-411DKR-ND | 040-111-411 | |
| 751-VEMD5510FX01TR-ND,751-VEMD5510FX01CT-ND,751-VEMD5510FX01DKR-ND | VEMD5510FX01 | |
| 1125-1418-ND | MTD3910D3 | |
| PDB-C158F-ND | PDB-C158F | |
| 2129-NJL6195R-TE1TR-ND,2129-NJL6195R-TE1CT-ND,2129-NJL6195R-TE1DKR-ND | NJL6195R-TE1 | |
| 365-1873-ND | OPR5925 | |
| 235-1440-ND | SUF268J001 | |
| ODD-1W-ND | ODD-1W | |
| 0200-3111-111-ND | 0200-3111-111 | |
| 365-2077-2-ND,365-2077-1-ND,365-2077-6-ND | OPR2100HST | |
| ODD-15W-ND | ODD-15W | |
| 0200-3111-011-ND | 0200-3111-011 | |
| 0050-3111-111-ND | 0050-3111-111 | |
| 365-1622-ND | OP913WSL | |
| 365-2081-ND | OPR5011 | |
| ODD-12WB-ND | ODD-12WB | |
| 1125-1464-ND | MT03-036 | |
| 51-KPDE030-H8-B-ND | KPDE030-H8-B | |
| 209-057-11-21-011-ND | 057-11-21-011 | |
| PDB-C612-2-ND | PDB-C612-2 | |
| 5556-MICROFJ-30020-TSV-TR1-ND | MICROFJ-30020-TSV-TR1 | |
| 516-AFBR-S4K11C0125B-ND | AFBR-S4K11C0125B | |
| 51-KPDE086S-H8-B-ND | KPDE086S-H8-B | |
| 51-KPMC29-B-ND | KPMC29-B | |
| 209-0800-3111-011-ND | 0800-3111-011 | |
| 2640-A2V-16-ND | A2V-16 | |
| 1125-1458-ND | MTPD1346D-300 | |
| 209-118-23-21-021-ND | 118-23-21-021 | |
| 209-112-45-11-221-ND | 112-45-11-221 | |
| 516-HLPD-B0H0-00000TR-ND,516-HLPD-B0H0-00000CT-ND | HLPD-B0H0-00000 | |
| 516-HLPD-B0F0-00000TR-ND,516-HLPD-B0F0-00000CT-ND | HLPD-B0F0-00000 | |
| QSB34ZRTR-ND,QSB34ZRCT-ND,QSB34ZRDKR-ND | QSB34ZR | |
| QSE773E3R0TR-ND,QSE773E3R0CT-ND | QSE773E3R0 | |
| VTD206KH-ND | VTD206KH | |
| 505-ADPD2140WBCPZN-R7TR-ND,505-ADPD2140WBCPZN-R7CT-ND,505-ADPD2140WBCPZN-R7DKR-ND | ADPD2140WBCPZN-R7 | |
| 1601-C30737LH-230-90C-ND | C30737LH-230-90C | |
| 516-AFBR-S4K33C0115L-ND | AFBR-S4K33C0115L | |
| 209-290-11-31-241-ND | 290-11-31-241 | |
| 475-SFH2716A01TR-ND,475-SFH2716A01CT-ND,475-SFH2716A01DKR-ND | SFH 2716 A01 | |
| 516-AEPD-C0D0-00000TR-ND,516-AEPD-C0D0-00000CT-ND,516-AEPD-C0D0-00000DKR-ND | AEPD-C0D0-00000 | |
| 475-SFH2704ATR-ND,475-SFH2704ACT-ND,475-SFH2704ADKR-ND | SFH 2704A | |
| 475-BP104FASR-ZTR-ND,475-BP104FASR-ZCT-ND,475-BP104FASR-ZDKR-ND | BP 104 FASR-Z | |
| 365-1624-ND | OP955 | |
| 475-BPW34SR-Z-ND | BPW 34 SR-Z | |
| 475-SFH3410RTR-ND,475-SFH3410RCT-ND,475-SFH3410RDKR-ND | SFH 3410R | |
| 516-HSD9-B170TR-ND,516-HSD9-B170CT-ND,516-HSD9-B170DKR-ND | HSD9-B170 | |
| 751-K857PHTR-ND,751-K857PHCT-ND,751-K857PHDKR-ND | K857PH | |
| OPR5910-ND | OPR5910 | |
| 846-SML-H10PD2BT86TR-ND,846-SML-H10PD2BT86CT-ND,846-SML-H10PD2BT86DKR-ND | SML-H10PD2BT86 | |
| 1601-VTB1112H-ND | VTB1112H | |
| ODD-1-ND | ODD-1 | |
| 209-APX-NG011SMDTR-ND,209-APX-NG011SMDCT-ND,209-APX-NG011SMDDKR-ND | APX-NG011SMD | |
| 5556-MICROFC-30020-SMT-TR-ND,5556-MICROFC-30020-SMT-TRCT-ND,5556-MICROFC-30020-SMT-TRDKR-ND | MICROFC-30020-SMT-TR | |
| 5556-MICROFJ-40035-TSV-TR-ND,5556-MICROFJ-40035-TSV-TRCT-ND,5556-MICROFJ-40035-TSV-TRDKR-ND | MICROFJ-40035-TSV-TR | |
| 2640-UV-005EQC-ND | UV-005EQC | |
| 209-APX-SC0010-ND | APX-SC0010 | |
| 516-AFBR-S4N44P044MTR-ND,516-AFBR-S4N44P044MCT-ND,516-AFBR-S4N44P044MDKR-ND | AFBR-S4N44P044M | |
| 2640-UV-005EQ-ND | UV-005EQ | |
| 2640-UV-013EQ-ND | UV-013EQ | |
| 2640-UV-013DQ-ND | UV-013DQ | |
| 2640-UV-035EQ-ND | UV-035EQ | |
| 2640-UV-035EQC-ND | UV-035EQC | |
| 2640-UV-035DQC-ND | UV-035DQC | |
| 209-APX-NG0031QPD-ND | APX-NG0031QPD | |
| 2640-UV-100DQC-ND | UV-100DQC | |
| 2640-UV-100EQC-ND | UV-100EQC | |
| 2640-XUV-005-ND | XUV-005 | |
| 3147-B17M1PD–H9B000114U1930TR-ND,3147-B17M1PD–H9B000114U1930CT-ND,3147-B17M1PD–H9B000114U1930DKR-ND | B17M1PD–H9B000114U1930 | |
| 3147-B15P1PD–H9C000213U1930TR-ND,3147-B15P1PD–H9C000213U1930CT-ND,3147-B15P1PD–H9C000213U1930DKR-ND | B15P1PD–H9C000213U1930 | |
| 3147-B15P1PD–H9B000113U1930TR-ND,3147-B15P1PD–H9B000113U1930CT-ND,3147-B15P1PD–H9B000113U1930DKR-ND | B15P1PD–H9B000113U1930 | |
| 3147-B15W1PD–H9B000112U1930TR-ND,3147-B15W1PD–H9B000112U1930CT-ND,3147-B15W1PD–H9B000112U1930DKR-ND | B15W1PD–H9B000112U1930 | |
| 3147-T4331PD–H9B6401L2U1930TR-ND,3147-T4331PD–H9B6401L2U1930CT-ND,3147-T4331PD–H9B6401L2U1930DKR-ND | T4331PD–H9B6401L2U1930 | |
| 3147-B1501PD–H9B000113U1930TR-ND,3147-B1501PD–H9B000113U1930CT-ND,3147-B1501PD–H9B000113U1930DKR-ND | B1501PD–H9B000113U1930 | |
| 3147-B2151PD–H9B000233U1930TR-ND,3147-B2151PD–H9B000233U1930CT-ND,3147-B2151PD–H9B000233U1930DKR-ND | B2151PD–H9B000233U1930 | |
| BPD-BQDA34-RR-ND | BPD-BQDA34-RR | |
| 5242-EOPD-525-1-0.9-1TR-ND,5242-EOPD-525-1-0.9-1CT-ND,5242-EOPD-525-1-0.9-1DKR-ND | EOPD-525-1-0.9-1 | |
| 235-1438-ND | SUF005A001 | |
| 2156-02A6A-125-XMD-ON-ND | 02A6A-125-XMD | |
| 2156-02A4A-100-XMD-ON-ND | 02A4A-100-XMD | |
| 2156-02A6A-163-XMD-ON-ND | 02A6A-163-XMD | |
| 2156-02A4A-142-XMD-ND | 02A4A-142-XMD | |
| 5556-MICROFC-60035-SMT-TR1-ND | MICROFC-60035-SMT-TR1 | |
| 5242-EOPD-525-0-2.25-1-ND | EOPD-525-0-2.25-1 | |
| 1601-FND-100GH-ND | FND-100GH | |
| 2640-RD07-ND | RD07 | |
| 2640-RD100A-ND | RD100A | |
| 2640-PIN-005D-254F-ND | PIN-005D-254F | |
| 2640-RD15-ND | RD15 | |
| 2640-PIN-4X4D-ND | PIN-4X4D | |
| 2640-A5C-38-ND | A5C-38 | |
| 2640-A5C-35-ND | A5C-35 | |
| 2640-PIN-10AP-1-ND | PIN-10AP-1 | |
| 2640-A2V-76-ND | A2V-76 | |
| 2640-SC-25D-ND | SC-25D | |
| 2156-QSE773-ND | QSE773 | |
| 2156-QSE773E3R0-ND | QSE773E3R0 | |
| 2266-040-1014-000-ND | 040-1014-000 | |
| 3892-T1110P6-SD-F-ND | T1110P6-SD-F | |
| 475-BPX61-ND | BPX 61 | |
| 1601-C30618L-350-ND | C30618L-350 | |
| 1601-C30617BH-ND | C30617BH | |
| 209-445-14-21-305-ND | 445-14-21-305 | |
| 958-1022-ND | AXUV100TF400 | |
| 958-1026-ND | AXUV576C | |
| 1601-C30902SH-DTC-ND | C30902SH-DTC | |
| 1601-C30659-1060E-R8BH-ND | C30659-1060E-R8BH | |
| 958-AXUV16ELG-ND | AXUV16ELG | |
| 1601-LLAM-1060-R8BH-ND | LLAM-1060-R8BH | |
| 732-13445-ND | 1540051EA3590 | |
| 732-13444-ND | 1540051EC3590 | |
| QSD2030-ND | QSD2030 | |
| 365-1625-ND | OP993 | |
| VEMD2500X01TR-ND,VEMD2500X01CT-ND,VEMD2500X01DKR-ND | VEMD2500X01 | |
| 751-K857PETR-ND,751-K857PECT-ND,751-K857PEDKR-ND | K857PE | |
| 1125-1008-ND | MTD5052N | |
| 1125-1363-ND | MTPD1346D-010 | |
| 475-BPW21-ND | BPW 21 | |
| 1125-MTPD2601N-030-ND | MTPD2601N-030 | |
| 0050-3111-011-ND | 0050-3111-011 | |
| 1601-C30737MH-230-80A-ND | C30737MH-230-80A | |
| 2096-GUVA-T31GD-ND | GUVA-T31GD | |
| 365-1841-ND | OPF472 | |
| 1125-MTPD2601T8-150-ND | MTPD2601T8-150 | |
| C30724PH-ND | C30724PH | |
| 2640-S-100VL-ND | S-100VL | |
| 2096-GUVB-T11GD-L-ND | GUVB-T11GD-L | |
| 1125-1325-ND | MT03-004 | |
| 1125-1324-ND | MT03-003 | |
| 1601-C30737MH-500-80ATR-ND,1601-C30737MH-500-80ACT-ND,1601-C30737MH-500-80ADKR-ND | C30737MH-500-80A | |
| 008-2171-112-ND | 008-2171-112 | |
| 2096-GUVCL-T21GH-ND | GUVCL-T21GH | |
| 1125-1286-ND | MTAPD-06-001 | |
| 209-PDV-C406-ND | PDV-C406 | |
| 209-100-14-21-021-ND | 100-14-21-021 | |
| 209-100-12-22-021-ND | 100-12-22-021 | |
| 1125-1466-ND | MT03-047 | |
| 1125-MTPD2601K8-300-ND | MTPD2601K8-300 | |
| 1601-C30645L-080-ND | C30645L-080 | |
| 51-KPDA100P-H8-B-ND | KPDA100P-H8-B | |
| 1601-C30662L-200-ND | C30662L-200 | |
| 2640-FCI-INGAAS-Q1000-ND | FCI-INGAAS-Q1000 | |
| 1601-LLAM-900-R5BH-ND | LLAM-900-R5BH | |
| 5556-ARRAYC-30035-144P-PCB-ND | ARRAYC-30035-144P-PCB | |
| 754-2221-ND | WP7113PD1BT/BD-P22 | |
| 751-VEMD4110X01TR-ND,751-VEMD4110X01CT-ND,751-VEMD4110X01DKR-ND | VEMD4110X01 | |
| BPW82-ND | BPW82 | |
| 365-2015-ND | OP905 | |
| TEMD1040-ND | TEMD1040 | |
| 751-1045-2-ND,751-1045-1-ND,751-1045-6-ND | TEMD1030 | |
| QSB34CZRTR-ND,QSB34CZRCT-ND,QSB34CZRDKR-ND | QSB34CZR | |
| 0003-3111-111-ND | 0003-3111-111 | |
| 2096-GVBL-T14GD-ND | GVBL-T14GD | |
| ODD-1B-ND | ODD-1B | |
| 1125-1463-ND | MT03-029 | |
| 1125-1459-ND | MT03-021 | |
| 365-1839-ND | OPF430 | |
| 1125-1503-ND | MTD6013D3-PD | |
| 2096-GUVB-T11GD-ND | GUVB-T11GD | |
| 1125-1314-ND | MTAPD-07-009 | |
| 2096-GUVA-T21GH-ND | GUVA-T21GH | |
| 2096-GUVV-T13GD-L-ND | GUVV-T13GD-L | |
| 1125-1312-ND | MTAPD-07-005 | |
| 1125-1421-ND | MT03-018 | |
| 1125-1445-ND | MTAPD-07-014-905F | |
| 1125-1446-ND | MTAPD-07-015-905F | |
| 2096-GUVB-T21GH-ND | GUVB-T21GH | |
| 1125-1460-ND | MT03-026 | |
| 1125-1422-ND | MT03-022 | |
| 2640-S-120VL-ND | S-120VL | |
| C30737LH-230-80A-ND | C30737LH-230-80A | |
| 1125-1288-ND | MTAPD-06-003 | |
| 1125-1457-ND | MTPD1346D-200 | |
| C30737LH-230-83A-ND | C30737LH-230-83A | |
| 1125-1292-ND | MTAPD-06-007 | |
| 1125-1443-ND | MTAPD-06-016-905F | |
| ODA-6WB-100M-ND | ODA-6WB-100M | |
| 1125-1465-ND | MT03-041 | |
| 5556-MICROFC-10035-SMT-TR1-ND | MICROFC-10035-SMT-TR1 | |
| 5556-MICROFC-10020-SMT-TR1-ND | MICROFC-10020-SMT-TR1 | |
| 5556-MICROFJ-40035-TSV-TR1-ND | MICROFJ-40035-TSV-TR1 | |
| 2096-GUVB-T21GD-U-ND | GUVB-T21GD-U | |
| 51-KPDA050P-H8-B-ND | KPDA050P-H8-B | |
| 2096-GUVB-S11SM-LA-ND | GUVB-S11SM-LA | |
| 2096-GUVB-T11GM-LA-ND | GUVB-T11GM-LA | |
| 2096-GUVC-T10GM-LA-ND | GUVC-T10GM-LA | |
| 51-KPDE150-H45-B-ND | KPDE150-H45-B | |
| PDB-V615-2-ND | PDB-V615-2 | |
| 209-100-41-21-231-ND | 100-41-21-231 | |
| 1601-C30645EH-1-ND | C30645EH-1 | |
| 5556-ARRAYJ-60035-4P-PCB-ND | ARRAYJ-60035-4P-PCB | |
| 1601-C30902SH-TC-ND | C30902SH-TC | |
| 5556-ARRAYJ-60035-4P-BGA-ND | ARRAYJ-60035-4P-BGA | |
| 1601-1023-ND | VTS2086H | |
| 235-1439-ND | SUF083J001 | |
| 1601-C30737MH-230-90C-ND | C30737MH-230-90C | |
| 2096-GUVCL-T10GD-ND | GUVCL-T10GD | |
| 2096-GUVC-T10GD-L185-ND | GUVC-T10GD-L185 | |
| ODA-6W-500M-ND | ODA-6W-500M | |
| 2096-GUVA-S12SM-LA-ND | GUVA-S12SM-LA | |
| 51-KPDA020P-H8-B-ND | KPDA020P-H8-B | |
| 1601-C30659-1550-R08BH-ND | C30659-1550-R08BH | |
| 1601-C30659-1550E-R08BH-ND | C30659-1550E-R08BH | |
| 1601-C30659-900-R8AH-ND | C30659-900-R8AH | |
| 1601-C30659-1550-R2AH-ND | C30659-1550-R2AH | |
| 1601-LLAM-1550-R2AH-ND | LLAM-1550-R2AH | |
| 1125-MTPD3001D1-030-ND | MTPD3001D1-030 | |
| 1125-MTPD3001D5-030-ND | MTPD3001D5-030 | |
| 1125-MTD5052D3-ND | MTD5052D3 | |
| 1125-MTPD1346SL-030-ND | MTPD1346SL-030 | |
| 1125-MTPD2601N-100-ND | MTPD2601N-100 | |
| 1125-MTPD2601SL-030-ND | MTPD2601SL-030 | |
| 1125-MTPD2601SL-100-ND | MTPD2601SL-100 | |
| 1125-MTPD2601T-030-ND | MTPD2601T-030 | |
| OPF794-ND | OPF794 | |
| 1125-MTPD2601FT-030-ND | MTPD2601FT-030 | |
| 1125-1318-ND | MTAPD-07-013 | |
| 1125-1313-ND | MTAPD-07-007 | |
| 1125-1319-ND | MTAPD-07-014 | |
| 1125-1320-ND | MTAPD-07-015 | |
| 1125-MTPD2601SIW-100-ND | MTPD2601SIW-100 | |
| 1125-MTSM1346SMF1-030-ND | MTSM1346SMF1-030 | |
| 209-APX-SC00025-ND | APX-SC00025 | |
| 1125-MTSM2601SMF1-030-ND | MTSM2601SMF1-030 | |
| 1125-1011-ND | MTD6100PT | |
| 1125-MTSM1346SMF1-100-ND | MTSM1346SMF1-100 | |
| 1125-MTSM2601SMF1-100-ND | MTSM2601SMF1-100 | |
| 1125-MTSM1346SMR1-030-ND | MTSM1346SMR1-030 | |
| 958-BXP-25M-ND | BXP-25M | |
| 1125-MTSM1346SMR1-100-ND | MTSM1346SMR1-100 | |
| 1125-MTPD2601K8-150-ND | MTPD2601K8-150 | |
| 1125-MTSM1346SMF2-150-ND | MTSM1346SMF2-150 | |
| 1125-1299-ND | MTAPD-06-014 | |
| 2640-FCIH250G-INGAAS-75-ND | FCI H250G-INGAAS-75 | |
| 1125-MTSM1346SMF1-030S-ND | MTSM1346SMF1-030S | |
| 1125-MTSM2601SMF1-030S-ND | MTSM2601SMF1-030S | |
| 1125-MTSM1346SMR2-150-ND | MTSM1346SMR2-150 | |
| 1125-MTSM1346SMF1-100S-ND | MTSM1346SMF1-100S | |
| 1125-MTSM2601SMF1-100S-ND | MTSM2601SMF1-100S | |
| 2640-UV-005DQC-ND | UV-005DQC | |
| 1125-MTSM1346SMR1-030S-ND | MTSM1346SMR1-030S | |
| 1125-MTSM1346SMR1-100S-ND | MTSM1346SMR1-100S | |
| 1125-MTSM1346SMF2-150S-ND | MTSM1346SMF2-150S | |
| 1125-MTSM2601SMF2-150S-ND | MTSM2601SMF2-150S | |
| 1125-MTSM1346SMR2-150S-ND | MTSM1346SMR2-150S | |
| 5556-MICROFC-30020-SMT-TR1-ND | MICROFC-30020-SMT-TR1 | |
| 1125-MTSM1057SMF2-046-ND | MTSM1057SMF2-046 | |
| 2640-UV-100DQ-ND | UV-100DQ | |
| 2640-UV-100EQ-ND | UV-100EQ | |
| 2640-PIN-25DP-ND | PIN-25DP | |
| 1125-MTSM2601SMF3-300-ND | MTSM2601SMF3-300 | |
| 1125-MTSM1346SMF3-300-ND | MTSM1346SMF3-300 | |
| 3970-QLPD01DXLB-ND | QLPD01DXLB | |
| 3010-BF3H01G-NPD-ND | BF3H01G-NPD | |
| 3010-BF3A03G-NPD-ND | BF3A03G-NPD | |
| 3970-QLPD01DXMB-ND | QLPD01DXMB | |
| 3970-QLPD04DXNB-ND | QLPD04DXNB | |
| 3892-T1180P6-SD-F-ND | T1180P6-SD-F | |
| 3892-T1172P6-SD-F-ND | T1172P6-SD-F | |
| 3892-T1116P-SD-F-ND | T1116P-SD-F | |
| 2640-OSD5-E-ND | OSD5-E | |
| 2640-SPOT-4DUV-ND | SPOT-4DUV | |
| 958-AXUV300C-ND | AXUV300C | |
| 3010-BF5H02G-NPD-ND | BF5H02G-NPD | |
| 3010-BF5H02G-NPT-ND | BF5H02G-NPT | |
| 3892-T1187P-SD-F-ND | T1187P-SD-F | |
| 3892-T1610P-SD-F-ND | T1610P-SD-F | |
| 3892-T1678P-SD-F-ND | T1678P-SD-F | |
| 3892-T337P6-SD-F-ND | T337P6-SD-F | |
| 3892-T330P-SD-F-ND | T330P-SD-F | |
| 3892-T1670P-SD-F-ND | T1670P-SD-F | |
| 3892-T1170P-SD-F-ND | T1170P-SD-F | |
| 3892-T1112P-SD-F-ND | T1112P-SD-F | |
| 5299-P10T-TO-A-FA-ND | P10T-TO-A-FA | |
| 3892-T1120P-ND | T1120P | |
| 5299-P10-TO-B-FA-ND | P10-TO-B-FA | |
| 5299-A10T-TO-A-FA-ND | A10T-TO-A-FA | |
| 4712-PPD-PIN-IGA-3.00-T46-5523-L-10-NETB-ND | PPD-PIN-IGA-3.00-T46-5523-L-10-NE | |
| 4712-MMPPD-PIN-IGA-3.00-T46-5523-M5L-10-NETB-ND | MMPPD-PIN-IGA-3.00-T46-5523-M5L-10-NE | |
| 4712-FBG-S-1550-002-A-R95-A-B-10-10-FA-FA-ND | FBG-S-1550-002-A-R95-A-B-10-10-FA-FA | |
| QSB34GRTR-ND,QSB34GRCT-ND,QSB34GRDKR-ND | QSB34GR | |
| 475-SFH206K-ND | SFH 206K | |
| 475-SFH2706TR-ND,475-SFH2706CT-ND,475-SFH2706DKR-ND | SFH 2706 | |
| VTP1112H-ND | VTP1112H | |
| 365-1838-ND | OPF422 | |
| 209-100-11-21-221-ND | 100-11-21-221 | |
| 209-172-11-21-221-ND | 172-11-21-221 | |
| 209-197-23-21-041-ND | 197-23-21-041 | |
| 2640-QD50-0-SD-ND | QD50-0-SD | |
| 5556-ARRAYJ-30020-16P-PCB-ND | ARRAYJ-30020-16P-PCB | |
| 1601-C30659-1550E-R2AH-ND | C30659-1550E-R2AH | |
| 5556-ARRAYJ-60035-64P-PCB-ND | ARRAYJ-60035-64P-PCB | |
| QSD2030F-ND | QSD2030F | |
| BPW41N-ND | BPW41N | |
| 475-SFH2201A01TR-ND,475-SFH2201A01CT-ND,475-SFH2201A01DKR-ND | SFH 2201 A01 | |
| 475-SFH2703TR-ND,475-SFH2703CT-ND,475-SFH2703DKR-ND | SFH 2703 | |
| 475-SFH2202TR-ND,475-SFH2202CT-ND,475-SFH2202DKR-ND | SFH 2202 | |
| PDB-C142-ND | PDB-C142 | |
| 475-BPX65-ND | BPX 65 | |
| 1125-1009-ND | MTD5052W | |
| 365-1872-ND | OPR5911 | |
| 0800-3111-111-ND | 0800-3111-111 | |
| 008-2161-112-ND | 008-2161-112 | |
| 1125-1298-ND | MTAPD-06-013 | |
| 2096-GUVA-T21GD-U-ND | GUVA-T21GD-U | |
| 1125-MT03-072-ND | MT03-072 | |
| 732-1540031EA4590-ND | 1540031EA4590 | |
| 475-SFH2500FA-ZTR-ND,475-SFH2500FA-ZCT-ND,475-SFH2500FA-ZDKR-ND | SFH 2500 FA-Z | |
| 1125-1087-ND | MTD1114M3B | |
| PDB-V601-1-25-ND | PDB-V601-1-25 | |
| 1125-1364-ND | MTPD1346D-030 | |
| 1125-1316-ND | MTAPD-07-011 | |
| 1125-1444-ND | MTAPD-07-012-905F | |
| 1125-1289-ND | MTAPD-06-004 | |
| 1125-1294-ND | MTAPD-06-009 | |
| PDB-V107-ND | PDB-V107 | |
| 1125-1301-ND | MTAPD-06-016 | |
| 209-076-11-31-211-ND | 076-11-31-211 | |
| 5556-MICROFC-30050-SMT-TR1-ND | MICROFC-30050-SMT-TR1 | |
| 2096-GUVV-S10SM-LA-ND | GUVV-S10SM-LA | |
| 5556-ARRAYC-60035-4P-BGA-ND | ARRAYC-60035-4P-BGA | |
| 5556-ARRAYC-30035-16P-PCB-ND | ARRAYC-30035-16P-PCB | |
| 958-1017-ND | UVG100 | |
| 5556-ARRAYJ-30035-16P-PCB-ND | ARRAYJ-30035-16P-PCB | |
| 5556-ARRAYJ-30035-64P-PCB-ND | ARRAYJ-30035-64P-PCB | |
| 1080-1506-ND | EAPDSZ4439A4 | |
| 1830-IN-S32GTNPDTR-ND,1830-IN-S32GTNPDCT-ND,1830-IN-S32GTNPDDKR-ND | IN-S32GTNPD | |
| 1080-EAPDST6048A0TR-ND,1080-EAPDST6048A0CT-ND,1080-EAPDST6048A0DKR-ND | EAPDST6048A0 | |
| 365-1903-ND | OPR2101 | |
| 0003-3111-011-ND | 0003-3111-011 | |
| 1125-1311-ND | MTAPD-07-003 | |
| 1125-1317-ND | MTAPD-07-012 | |
| 0008-3111-111-ND | 0008-3111-111 | |
| 2096-GUVA-T13GD-ND | GUVA-T13GD | |
| 365-2078-2-ND,365-2078-1-ND,365-2078-6-ND | OPR2100T | |
| 1125-1321-ND | MTAPD-07-016 | |
| 1125-1447-ND | MTAPD-07-016-905F | |
| 1601-C30737LH-500-90C-ND | C30737LH-500-90C | |
| 1125-1462-ND | MT03-028 | |
| 1125-1461-ND | MT03-027 | |
| 1125-1291-ND | MTAPD-06-006 | |
| 1125-1442-ND | MTAPD-05-003 | |
| 2096-GUVA-T11GM-LA-ND | GUVA-T11GM-LA |
Phototransistor
Phototransistors are widely used as part of light sensing applications rather than as standalone ambient light sensors. As the transistor is a device capable of amplifying signals, it is also used here for amplifying the small changes in optical signals, thereby enhancing sensitivity in detection.
Phototransistors typically have relatively faster response time, so they are used in stringent real-time applications. Depending on the internal amplification factor different phototransistors have different sensing capabilities. Temperature changes are important to be considered while analyzing their performance.
Phototransistors also work similar to normal transistors, with the only difference being the type of input signal which is optical rather than electrical. The light stimulates the base current which then gets reflected in the collector current with a gain. The output of a phototransistor depends on the incident light’s wavelength, the collector-base junction’s area, and the transistor’s DC current gain.
Applications
When greater sensitivity is required, phototransistors are often used. They are more sensitive than photodiodes.
They are used in optoelectronic switching. When light is required to control some electrical mechanism, for example, in automatic lighting systems, phototransistors are employed.
Phototransistors can detect the position of rotating parts by sensing interruptions in light beams in rotary and linear encoders.
Phototransistors are used in optocouplers where they can be used to couple two electrically isolated circuits. First the electrical signal from the transmitting device gets converted into optical signal, this optical signal connects with the receiving device and finally gets converted to electrical signal.
Phototransistors available with DigiKey
| 1080-1384-2-ND,1080-1384-1-ND,1080-1384-6-ND | PT19-21C/L41/TR8 | |
| 1080-1378-2-ND,1080-1378-1-ND,1080-1378-6-ND | PT12-21C/TR8 | |
| 1080-1377-2-ND,1080-1377-1-ND,1080-1377-6-ND | PT12-21B/TR8 | |
| 1080-1244-2-ND,1080-1244-1-ND,1080-1244-6-ND | ALS-PT19-315C/L177/TR8 | |
| 754-1841-2-ND,754-1841-1-ND,754-1841-6-ND | APA3010P3BT-GX | |
| VEMT2020X01TR-ND,VEMT2020X01CT-ND,VEMT2020X01DKR-ND | VEMT2020X01 | |
| 1080-1019-ND | ALS-PT204-6C/L177 | |
| 1080-1389-2-ND,1080-1389-1-ND,1080-1389-6-ND | PT42-21B/TR8 | |
| 475-SFH300FA-3/4-ND | SFH 300 FA-3/4 | |
| 754-2214-2-ND,754-2214-1-ND,754-2214-6-ND | APS3227SP1C-P22 | |
| 365-1070-ND | OP550A | |
| 365-1066-ND | OP505A | |
| 365-1075-ND | OP598A | |
| VEMT2000X01TR-ND,VEMT2000X01CT-ND,VEMT2000X01DKR-ND | VEMT2000X01 | |
| QSD123-ND | QSD123 | |
| 475-SFH3710-ZTR-ND,475-SFH3710-ZCT-ND,475-SFH3710-ZDKR-ND | SFH 3710-Z | |
| VEMT2023SLX01TR-ND,VEMT2023SLX01CT-ND,VEMT2023SLX01DKR-ND | VEMT2023SLX01 | |
| VEMT2523X01TR-ND,VEMT2523X01CT-ND,VEMT2523X01DKR-ND | VEMT2523X01 | |
| VEMT2503X01TR-ND,VEMT2503X01CT-ND,VEMT2503X01DKR-ND | VEMT2503X01 | |
| 751-1053-2-ND,751-1053-1-ND,751-1053-6-ND | TEMT1020 | |
| 475-SFH3710-3/4-ZTR-ND,475-SFH3710-3/4-ZCT-ND,475-SFH3710-3/4-ZDKR-ND | SFH 3710-3/4-Z | |
| 365-1068-ND | OP506A | |
| 751-1052-2-ND,751-1052-1-ND,751-1052-6-ND | TEMT1000 | |
| 846-RPM-075PTT86TR-ND,846-RPM-075PTT86CT-ND,846-RPM-075PTT86DKR-ND | RPM-075PTT86 | |
| QSD124-ND | QSD124 | |
| 751-1004-ND | BPV11F | |
| 751-1055-2-ND,751-1055-1-ND,751-1055-6-ND | TEMT6000X01 | |
| 365-1081-ND | OP804SL | |
| 365-1080-ND | OP802WSL | |
| 365-1615-ND | OP800A | |
| 751-1020-ND | BPW77NA | |
| 1830-INL-3APT30-ND | INL-3APT30 | |
| 1830-IN-S63DTPTTR-ND,1830-IN-S63DTPTCT-ND,1830-IN-S63DTPTDKR-ND | IN-S63DTPT | |
| 732-13441-2-ND,732-13441-1-ND,732-13441-6-ND | 1541141NAA570 | |
| 732-1540601NEA200TR-ND,732-1540601NEA200CT-ND,732-1540601NEA200DKR-ND | 1540601NEA200 | |
| 1830-INL-3ANPT30-ND | INL-3ANPT30 | |
| 1830-INL-5ANPT30-ND | INL-5ANPT30 | |
| 1080-1382-2-ND,1080-1382-1-ND,1080-1382-6-ND | PT17-21C/L41/TR8 | |
| 160-1030-ND | LTR-4206E | |
| 1080-1379-2-ND,1080-1379-1-ND,1080-1379-6-ND | PT15-21B/TR8 | |
| 1080-1159-ND | PT334-6C | |
| 1080-1376-2-ND,1080-1376-1-ND,1080-1376-6-ND | PT11-21C/L41/TR8 | |
| 160-1988-ND | LTR-4206 | |
| 754-2218-ND | WP3DP3BT/BD-P22 | |
| 1080-1383-2-ND,1080-1383-1-ND,1080-1383-6-ND | PT19-21B/L41/TR8 | |
| 1080-1380-2-ND,1080-1380-1-ND,1080-1380-6-ND | PT15-21C/TR8 | |
| 754-1436-2-ND,754-1436-1-ND,754-1436-6-ND | APT2012P3BT | |
| 754-2209-2-ND,754-2209-1-ND,754-2209-6-ND | AP1608P1C-P22 | |
| 1080-1158-ND | PT334-6B | |
| 1080-1157-ND | PT333-3C | |
| 754-2210-2-ND,754-2210-1-ND,754-2210-6-ND | AP2012P3C-P22 | |
| 1080-1168-ND | PT928-6C-F | |
| 754-2217-2-ND,754-2217-1-ND,754-2217-6-ND | APTD3216P3C-P22 | |
| 732-13440-2-ND,732-13440-1-ND,732-13440-6-ND | 1541201NC3060 | |
| 475-SFH300-ND | SFH 300 | |
| 1497-XZRNI55WTR-ND,1497-XZRNI55WCT-ND,1497-XZRNI55WDKR-ND | XZRNI55W | |
| 1080-1167-ND | PT928-6B-F | |
| 160-1031-ND | LTR-3208E | |
| 1080-1386-2-ND,1080-1386-1-ND,1080-1386-6-ND | PT26-21C/TR8 | |
| 1080-1152-ND | PT204-6C | |
| 1080-1381-2-ND,1080-1381-1-ND,1080-1381-6-ND | PT17-21B/L41/TR8 | |
| 1080-1164-ND | PT908-7C-F | |
| 475-SFH309FA-ND | SFH 309 FA | |
| 1080-1161-ND | PT5529B/L2/H2-F | |
| 160-1065-ND | LTR-301 | |
| 1080-1387-2-ND,1080-1387-1-ND,1080-1387-6-ND | PT26-51B/TR8 | |
| 475-SFH320-ZTR-ND,475-SFH320-ZCT-ND,475-SFH320-ZDKR-ND | SFH 320-Z | |
| 1080-1163-ND | PT908-7B-F | |
| VTT9812FH-ND | VTT9812FH | |
| 475-SFH309FA-5/6-ND | SFH 309 FA-5/6 | |
| 475-SFH309FA-4/5-ND | SFH 309 FA-4/5 | |
| VEMT2500X01TR-ND,VEMT2500X01CT-ND,VEMT2500X01DKR-ND | VEMT2500X01 | |
| 732-1541021NCA170TR-ND,732-1541021NCA170CT-ND,732-1541021NCA170DKR-ND | 1541021NCA170 | |
| 475-SFH325FA-ZTR-ND,475-SFH325FA-ZCT-ND,475-SFH325FA-ZDKR-ND | SFH 325 FA-Z | |
| 475-SFH309FA-4-ND | SFH 309 FA-4 | |
| 751-1057-ND | TEPT4400 | |
| 475-SFH300-3/4-ND | SFH 300-3/4 | |
| BPW85A-ND | BPW85A | |
| 475-SFH313FA-ND | SFH 313FA | |
| BPW85C-ND | BPW85C | |
| BPW85B-ND | BPW85B | |
| 751-1041-ND | TEFT4300 | |
| QSB363GRTR-ND,QSB363GRCT-ND,QSB363GRDKR-ND | QSB363GR | |
| 751-BPW85-ND | BPW85 | |
| 751-1058-ND | TEPT5600 | |
| 751-1059-ND | TEPT5700 | |
| 1080-1020-ND | ALS-PT243-3C/L177 | |
| 475-SFH325FA-3/4-ZTR-ND,475-SFH325FA-3/4-ZCT-ND,475-SFH325FA-3/4-ZDKR-ND | SFH 325 FA-3/4-Z | |
| 365-2013-ND | OP593B | |
| 475-SFH309-4/5-ND | SFH 309-4/5 | |
| KDT00030FSTR-ND,KDT00030FSCT-ND,KDT00030FSDKR-ND | KDT00030TR | |
| KDT00030ATRTR-ND,KDT00030ATRCT-ND,KDT00030ATRDKR-ND | KDT00030ATR | |
| 475-SFH3219-ZTR-ND,475-SFH3219-ZCT-ND,475-SFH3219-ZDKR-ND | SFH 3219-Z | |
| 365-1072-ND | OP550C | |
| 475-SFH313FA-3/4-ND | SFH 313 FA-3/4 | |
| 1855-PT100MF0MPTR-ND,1855-PT100MF0MPCT-ND,1855-PT100MF0MPDKR-ND | PT100MF0MP | |
| BPW16N-ND | BPW16N | |
| VEMT2520X01TR-ND,VEMT2520X01CT-ND,VEMT2520X01DKR-ND | VEMT2520X01 | |
| QSD123A4R0TR-ND,QSD123A4R0CT-ND | QSD123A4R0 | |
| VEMT2523SLX01TR-ND,VEMT2523SLX01CT-ND,VEMT2523SLX01DKR-ND | VEMT2523SLX01 | |
| QSE114-ND | QSE114 | |
| TEMT7100X01TR-ND,TEMT7100X01CT-ND,TEMT7100X01DKR-ND | TEMT7100X01 | |
| TEMT7000X01TR-ND,TEMT7000X01CT-ND,TEMT7000X01DKR-ND | TEMT7000X01 | |
| 846-RPT-34PB3F-ND | RPT-34PB3F | |
| BPW96B-ND | BPW96B | |
| 365-1604-ND | OP535B | |
| 365-1613-ND | OP750A | |
| 846-RPT-37PB3FN-ND | RPT-37PB3FN | |
| 751-1061-ND | TEST2600 | |
| TEKT5400S-ND | TEKT5400S | |
| QSE113-ND | QSE113 | |
| 846-RPT-38PB3F-ND | RPT-38PB3F | |
| 751-1003-ND | BPV11 | |
| 475-SFH3310-ND | SFH 3310 | |
| 751-1056-2-ND,751-1056-1-ND,751-1056-6-ND | TEMT6200FX01 | |
| QSE122-ND | QSE122 | |
| 365-1078-ND | OP644SL | |
| 365-1082-ND | OP805SL | |
| 475-BPY62-3/4-ND | BPY 62-3/4 | |
| 751-1021-ND | BPW77NB | |
| 365-1619-ND | OP830SL | |
| 1125-1014-ND | MTD8600N4-T | |
| 1830-INL-5APT30-ND | INL-5APT30 | |
| BPT-BP1A34-ND | BPT-BP1A34 | |
| 1830-IN-S126BTNPTTR-ND,1830-IN-S126BTNPTCT-ND,1830-IN-S126BTNPTDKR-ND | IN-S126BTNPT | |
| 732-1540801NBA300TR-ND,732-1540801NBA300CT-ND,732-1540801NBA300DKR-ND | 1540801NBA300 | |
| 1497-XZRNI56WTR-ND,1497-XZRNI56WCT-ND,1497-XZRNI56WDKR-ND | XZRNI56W | |
| 1497-XZRNI56BFTR-ND,1497-XZRNI56BFCT-ND,1497-XZRNI56BFDKR-ND | XZRNI56BF | |
| 1497-1203-2-ND,1497-1203-1-ND,1497-1203-6-ND | XZRNI56W-1 | |
| 404-1327-2-ND,404-1327-1-ND,404-1327-6-ND | VTPS1192HB-TR | |
| 732-13443-2-ND,732-13443-1-ND,732-13443-6-ND | 1541411NBA210 | |
| 1830-IN-S126FSNPTTR-ND,1830-IN-S126FSNPTCT-ND,1830-IN-S126FSNPTDKR-ND | IN-S126FSNPT | |
| 732-13438-2-ND,732-13438-1-ND,732-13438-6-ND | 1541201NEA400 | |
| 1497-1036-ND | XRNI30W-1 | |
| 754-2229-ND | WP7113P3BT | |
| 160-1986-ND | LTR-3208 | |
| 1080-1393-2-ND,1080-1393-1-ND,1080-1393-6-ND | PT91-21B/TR7 | |
| 1080-1166-ND | PT91-21C | |
| 475-SFH320FA-ZTR-ND,475-SFH320FA-ZCT-ND,475-SFH320FA-ZDKR-ND | SFH 320 FA-Z | |
| 1080-1165-ND | PT91-21B | |
| 404-1287-2-ND,404-1287-1-ND,404-1287-6-ND | TPS1191RB-2-TR | |
| 1080-1395-2-ND,1080-1395-1-ND,1080-1395-6-ND | PT91-21C/TR10 | |
| 475-SFH325-ZTR-ND,475-SFH325-ZCT-ND,475-SFH325-ZDKR-ND | SFH 325-Z | |
| 475-SFH320FA-3/4-ZTR-ND,475-SFH320FA-3/4-ZCT-ND,475-SFH320FA-3/4-ZDKR-ND | SFH 320 FA-3/4-Z | |
| SCM-014TBT86TR-ND,SCM-014TBT86CT-ND,SCM-014TBT86DKR-ND | SCM-014TBT86 | |
| 475-SFH325-3/4-ZTR-ND,475-SFH325-3/4-ZCT-ND,475-SFH325-3/4-ZDKR-ND | SFH 325-3/4-Z | |
| SML-810TBT86TR-ND,SML-810TBT86CT-ND,SML-810TBT86DKR-ND | SML-810TBT86 | |
| 475-SFH325FA-3-ZTR-ND,475-SFH325FA-3-ZCT-ND,475-SFH325FA-3-ZDKR-ND | SFH 325 FA-3-Z | |
| QSB363-ND | QSB363 | |
| 475-SFH320-3-ZTR-ND,475-SFH320-3-ZCT-ND,475-SFH320-3-ZDKR-ND | SFH 320-3-Z | |
| 1855-PT100MF0MP1TR-ND,1855-PT100MF0MP1CT-ND,1855-PT100MF0MP1DKR-ND | PT100MF0MP1 | |
| 475-SFH314FA-ND | SFH 314 FA | |
| QSD124A4R0TR-ND,QSD124A4R0CT-ND | QSD124A4R0 | |
| 365-1067-ND | OP505B | |
| 365-1598-ND | OP505C | |
| 365-1074-ND | OP593A | |
| 365-1600-ND | OP505W | |
| 365-1076-ND | OP598B | |
| 365-1608-ND | OP598C | |
| 365-1077-ND | OP599A | |
| QSE113E3R0TR-ND,QSE113E3R0CT-ND | QSE113E3R0 | |
| VEMT2023X01TR-ND,VEMT2023X01CT-ND,VEMT2023X01DKR-ND | VEMT2023X01 | |
| 751-VEMT2003X01TR-ND,751-VEMT2003X01CT-ND,751-VEMT2003X01DKR-ND | VEMT2003X01 | |
| 475-SFH314FA-2/3-ND | SFH 314 FA-2/3 | |
| 365-1069-ND | OP506B | |
| VEMT3700-GS08TR-ND,VEMT3700-GS08CT-ND,VEMT3700-GS08DKR-ND | VEMT3700-GS08 | |
| 365-1603-ND | OP535A | |
| VEMT3700F-GS08TR-ND,VEMT3700F-GS08CT-ND,VEMT3700F-GS08DKR-ND | VEMT3700F-GS08 | |
| 365-2010-ND | OP508FA | |
| QSE133-ND | QSE133 | |
| QTLP610CPDFSTR-ND,QTLP610CPDFSCT-ND,QTLP610CPDFSDKR-ND | QTLP610CPDTR | |
| 475-SFH3410-ZTR-ND,475-SFH3410-ZCT-ND,475-SFH3410-ZDKR-ND | SFH 3410-Z | |
| 365-1073-ND | OP560C | |
| 475-SFH3410-2/3-ZTR-ND,475-SFH3410-2/3-ZCT-ND,475-SFH3410-2/3-ZDKR-ND | SFH 3410-2/3-Z | |
| 365-1607-ND | OP560A | |
| 475-BPY62-ND | BPY 62 | |
| 365-2014-ND | OP643SL | |
| 365-1079-ND | OP801WSL | |
| 365-1083-ND | OP830WSL | |
| 751-1019-ND | BPW76B | |
| 365-1611-ND | OP600B | |
| 751-1018-ND | BPW76A | |
| 1125-1147-ND | MTD8000M3B-T | |
| 365-2012-ND | OP516A | |
| 1125-1010-ND | MTD6000PT-T | |
| 732-1541201NBA300TR-ND,732-1541201NBA300CT-ND,732-1541201NBA300DKR-ND | 1541201NBA300 | |
| 365-1606-ND | OP555B | |
| 475-SFH309FA-3/4-ND | SFH 309 FA-3/4 | |
| 754-AA3528P3STR-ND,754-AA3528P3SCT-ND,754-AA3528P3SDKR-ND | AA3528P3S | |
| LTR-309-ND | LTR-309 | |
| 1830-IN-P4634ATHIRPTTR-ND,1830-IN-P4634ATHIRPTCT-ND,1830-IN-P4634ATHIRPTDKR-ND | IN-P4634ATHIRPT | |
| 754-2338-2-ND,754-2338-1-ND,754-2338-6-ND | AM2520P3BT03 | |
| 1830-IN-S1914ATHIRPTTR-ND,1830-IN-S1914ATHIRPTCT-ND,1830-IN-S1914ATHIRPTDKR-ND | IN-S1914ATHIRPT | |
| 751-TEMT7100ITX01TR-ND,751-TEMT7100ITX01CT-ND,751-TEMT7100ITX01DKR-ND | TEMT7100ITX01 | |
| OP506W-ND | OP506W | |
| 516-HLPT-B5G0-00000-ND | HLPT-B5G0-00000 | |
| 516-HLPT-B5D0-00000-ND | HLPT-B5D0-00000 | |
| 516-HLPT-B5K0-00000-ND | HLPT-B5K0-00000 | |
| 751-VEMT4700-GS08TR-ND,751-VEMT4700-GS08CT-ND,751-VEMT4700-GS08DKR-ND | VEMT4700-GS08 | |
| 365-1605-ND | OP555A | |
| 516-HST9-B170TR-ND,516-HST9-B170CT-ND,516-HST9-B170DKR-ND | HST9-B170 | |
| 516-HST9-B680TR-ND,516-HST9-B680CT-ND,516-HST9-B680DKR-ND | HST9-B680 | |
| 516-HST9-B380TR-ND,516-HST9-B380CT-ND,516-HST9-B380DKR-ND | HST9-B380 | |
| 516-HST6-C190TR-ND,516-HST6-C190CT-ND,516-HST6-C190DKR-ND | HST6-C190 | |
| 516-HSD9-B680TR-ND,516-HSD9-B680CT-ND,516-HSD9-B680DKR-ND | HSD9-B680 | |
| 516-HSD9-C118TR-ND,516-HSD9-C118CT-ND,516-HSD9-C118DKR-ND | HSD9-C118 | |
| 516-HST9-C350TR-ND,516-HST9-C350CT-ND,516-HST9-C350DKR-ND | HST9-C350 | |
| 516-HST9-B350TR-ND,516-HST9-B350CT-ND,516-HST9-B350DKR-ND | HST9-B350 | |
| 475-BP103-ND | BP 103 | |
| 475-BP103-3/4-ND | BP 103-3/4 | |
| 475-BPY62-4-ND | BPY 62-4 | |
| OP600C-ND | OP600C | |
| 365-1610-ND | OP600A | |
| 3147-B1701PT–H9C000114U1930TR-ND,3147-B1701PT–H9C000114U1930CT-ND,3147-B1701PT–H9C000114U1930DKR-ND | B1701PT–H9C000114U1930 | |
| 3147-B19H1PT–H9C000214U1930TR-ND,3147-B19H1PT–H9C000214U1930CT-ND,3147-B19H1PT–H9C000214U1930DKR-ND | B19H1PT–H9C000214U1930 | |
| 2156-QSE213-ND | QSE213 | |
| 3147-B17L1PT–H9B0001X3U1930TR-ND,3147-B17L1PT–H9B0001X3U1930CT-ND,3147-B17L1PT–H9B0001X3U1930DKR-ND | B17L1PT–H9B0001X3U1930 | |
| 3147-B19H1LS–H9C000114U1930TR-ND,3147-B19H1LS–H9C000114U1930CT-ND,3147-B19H1LS–H9C000114U1930DKR-ND | B19H1LS–H9C000114U1930 | |
| 3147-B15W1PT–H9B000112U1930TR-ND,3147-B15W1PT–H9B000112U1930CT-ND,3147-B15W1PT–H9B000112U1930DKR-ND | B15W1PT–H9B000112U1930 | |
| 3147-B2151PT–H9B000533U1930TR-ND,3147-B2151PT–H9B000533U1930CT-ND,3147-B2151PT–H9B000533U1930DKR-ND | B2151PT–H9B000533U1930 | |
| 2156-SFH320-3-Z-ND | SFH 320-3-Z | |
| 3147-B15P1LS–H9C0001I3U1930TR-ND,3147-B15P1LS–H9C0001I3U1930CT-ND,3147-B15P1LS–H9C0001I3U1930DKR-ND | B15P1LS–H9C0001I3U1930 | |
| 3147-B1921LS–H9C0001I4U1930TR-ND,3147-B1921LS–H9C0001I4U1930CT-ND,3147-B1921LS–H9C0001I4U1930DKR-ND | B1921LS–H9C0001I4U1930 | |
| 3147-T1691PT–H9B000212U1930TR-ND,3147-T1691PT–H9B000212U1930CT-ND,3147-T1691PT–H9B000212U1930DKR-ND | T1691PT–H9B000212U1930 | |
| 3147-B2601PT–H9B000223U1930TR-ND,3147-B2601PT–H9B000223U1930CT-ND,3147-B2601PT–H9B000223U1930DKR-ND | B2601PT–H9B000223U1930 | |
| 3147-B1501PT–H9C000213U1930TR-ND,3147-B1501PT–H9C000213U1930CT-ND,3147-B1501PT–H9C000213U1930DKR-ND | B1501PT–H9C000213U1930 | |
| 3147-B1501PT–H9B000113U1930TR-ND,3147-B1501PT–H9B000113U1930CT-ND,3147-B1501PT–H9B000113U1930DKR-ND | B1501PT–H9B000113U1930 | |
| BPT-BP2931-ND | BPT-BP2931 | |
| BPT-NPG3C1-ND | BPT-NPG3C1 | |
| 2266-OP750B-ND,OP750B-ND | OP750B | |
| QSB363YRTR-ND,2832-QSB363YR-488-ND,QSB363YRCT-ND,QSB363YRDKR-ND | QSB363YR | |
| 2266-OP509A-ND,OP509A-ND | OP509A | |
| 2266-OPR5500-ND,OPR5500-ND | OPR5500 | |
| 2266-SD5491-004-DFC1-ND | SD5491-004-DFC1 | |
| QSB363ZRTR-ND,QSB363ZRCT-ND,QSB363ZRDKR-ND | QSB363ZR | |
| 475-SFH3711TR-ND,475-SFH3711CT-ND,475-SFH3711DKR-ND | SFH 3711 | |
| 1497-1035-ND | XRNI12W | |
| 732-1540032NA3090-ND | 1540032NA3090 | |
| 732-1540052NA3090-ND | 1540052NA3090 | |
| 732-1540031NC6090-ND | 1540031NC6090 | |
| 475-SFH309FA-5-ND | SFH 309 FA-5 | |
| 1601-VTT9814FH-ND | VTT9814FH | |
| 754-APDA3020P3C-P22TR-ND,754-APDA3020P3C-P22CT-ND,754-APDA3020P3C-P22DKR-ND | APDA3020P3C-P22 | |
| 751-1011-ND | BPW17N | |
| TEMT1040-ND | TEMT1040 | |
| BPW96C-ND | BPW96C | |
| 1497-XZRNI54WTR-ND,1497-XZRNI54WCT-ND,1497-XZRNI54WDKR-ND | XZRNI54W | |
| 754-2137-ND | WP7113P3C | |
| 754-1468-ND | WP3DP3BT | |
| 732-13442-2-ND,732-13442-1-ND,732-13442-6-ND | 1541411NEA210 | |
| BPT-XP2A61-TR9TR-ND,BPT-XP2A61-TR9CT-ND,BPT-XP2A61-TR9DKR-ND | BPT-XP2A61-TR9 | |
| 754-2208-2-ND,754-2208-1-ND,754-2208-6-ND | AM2520P3C03-P22 | |
| 475-SFH313FA-2/3-ND | SFH 313 FA-2/3 | |
| 160-1985-ND | LTR-209 | |
| 475-SFH320-3/4-ZTR-ND,475-SFH320-3/4-ZCT-ND,475-SFH320-3/4-ZDKR-ND | SFH 320-3/4-Z | |
| 754-2205-2-ND,754-2205-1-ND,754-2205-6-ND | AA4040P3C-P22 | |
| 846-SML-H10TBT86TR-ND,846-SML-H10TBT86CT-ND,846-SML-H10TBT86DKR-ND | SML-H10TBT86 | |
| 1125-1016-ND | MTD8600T4-T | |
| 751-1054-2-ND,751-1054-1-ND,751-1054-6-ND | TEMT1030 | |
| 1125-1012-ND | MTD8000N4-T | |
| 3011-AM2520P3C09-ND | AM2520P3C09 | |
| 3970-QLPT02DXJB-ND | QLPT02DXJB | |
| 3970-QLPT03DXG-ND | QLPT03DXG | |
| 3010-BF3H01G-NPT-ND | BF3H01G-NPT | |
| 3892-T5096P-SD-F-ND | T5096P-SD-F | |
| 3892-T1070P-SD-F-ND | T1070P-SD-F | |
| 365-2011-ND | OP515B | |
| 1830-IN-S85BTPTTR-ND,1830-IN-S85BTPTCT-ND,1830-IN-S85BTPTDKR-ND | IN-S85BTPT | |
| 732-1540051NC2590-ND | 1540051NC2590 | |
| 732-13439-2-ND,732-13439-1-ND,732-13439-6-ND | 1540601NBA500 | |
| 1080-1151-ND | PT204-6B | |
| 365-1071-ND | OP550B | |
| 1125-1013-ND | MTD8600N-T | |
| 1080-1160-ND | PT534-6B | |
| 754-APTR3216P3BTTR-ND,754-APTR3216P3BTCT-ND,754-APTR3216P3BTDKR-ND | APTR3216P3BT | |
| 754-2339-2-ND,754-2339-1-ND,754-2339-6-ND | AM2520P3BT09 | |
| 1080-1535-2-ND,1080-1535-1-ND,1080-1535-6-ND | EAPSV3026A0 | |
| 1080-1392-2-ND,1080-1392-1-ND,1080-1392-6-ND | PT91-21B/TR10 | |
| 1125-1015-ND | MTD8600T-T | |
| 1125-1448-ND | MTD8000D1 | |
| 1125-1449-ND | MTD8000D3 | |
| 754-AM4457P3C-F-R-ND | AM4457P3C-F-R | |
| 846-RPT-37PB3F-ND | RPT-37PB3F | |
| 488-FODM291BR2TR-ND,488-FODM291BR2CT-ND,488-FODM291BR2DKR-ND | FODM291BR2 | |
| 488-FODM291DR2TR-ND,488-FODM291DR2CT-ND,488-FODM291DR2DKR-ND | FODM291DR2 | |
| 488-4N35SR2TR-ND,488-4N35SR2CT-ND,488-4N35SR2DKR-ND | 4N35SR2 | |
| 488-FODM291AR2TR-ND,488-FODM291AR2CT-ND,488-FODM291AR2DKR-ND | FODM291AR2 | |
| 488-FODM291CR2TR-ND,488-FODM291CR2CT-ND,488-FODM291CR2DKR-ND | FODM291CR2 | |
| EAPSR3216A1-ND | EAPSR3216A1 | |
| LTR-5576D-ND | LTR-5576D | |
| 1080-EAPLP03RDAA0TR-ND | EAPLP03RDAA0 | |
| 1080-PT19-315B/TR8TR-ND | PT19-315B/TR8 | |
| 1080-EAPST17086A0TR-ND | EAPST17086A0 | |
| EAPLP03RDAA1-ND | EAPLP03RDAA1 | |
| 1080-EAPLP03RDAA2TR-ND | EAPLP03RDAA2 | |
| 1080-PT26-21B/CTTR-ND | PT26-21B/CT | |
| XZRNI55W-3-ND | XZRNI55W-3 | |
| 1080-PT968-8CTR-ND | PT968-8C | |
| LTR-306-ND | LTR-306 | |
| 1080-EAPLP05RDEA0-ND | EAPLP05RDEA0 | |
| 1080-EAPLP05RDEA1-ND | EAPLP05RDEA1 | |
| 1080-1156-ND | PT333-3B | |
| EAPLP05RDDA1-ND | EAPLP05RDDA1 | |
| 1080-PT26-21C/CTTR-ND | PT26-21C/CT | |
| 1080-PT333-3C(FTR)TR-ND | PT333-3C(FTR) | |
| 1080-EAPLP05RDDA2-ND | EAPLP05RDDA2 | |
| 1080-PT1302B/C2-ND | PT1302B/C2 | |
| 1080-EAPLP05RDEA2-ND | EAPLP05RDEA2 | |
| 1080-PT15-21CTR-ND | PT15-21C | |
| 1080-1150-ND | PT1504-6B | |
| EAPLP05RDQA0-ND | EAPLP05RDQA0 | |
| 1080-PT928-6C(6-2)TR-ND | PT928-6C(6-2) | |
| 1080-EAPLP05RDDA0-ND | EAPLP05RDDA0 | |
| EAPLP05RDPA0-ND | EAPLP05RDPA0 | |
| XZRNI45S-ND | XZRNI45S | |
| 754-1067-2-ND | APA3010P3BT | |
| 3147-HV-1302004C-U1930-ND | HV-1302004C-U1930 | |
| 2007-BPT-HP2A3J-TRBTR-ND | BPT-HP2A3J-TRB | |
| 160-LTR-C9303BTR-ND | LTR-C9303B | |
| 1516-1151-ND | QSD8T120B | |
| 1080-1154-ND | PT2559B/L2-F | |
| 1080-EAPLP04RRLA0-ND | EAPLP04RRLA0 | |
| 475-SFH309-ND | SFH 309 | |
| 1080-EAPST3216A0TR-ND | EAPST3216A0 | |
| 1080-PT26-61B/TR8TR-ND | PT26-61B/TR8 | |
| EAPLP04RRAA1-ND | EAPLP04RRAA1 | |
| 1080-PT928-6B(7-1)TR-ND | PT928-6B(7-1) | |
| 1080-PT928-6CTR-ND | PT928-6C | |
| 1080-PT26-71B/TR8TR-ND | PT26-71B/TR8 | |
| 1080-1162-ND | PT5529B/L2-F | |
| 1080-1153-ND | PT2559B/L2/H2-F | |
| 160-LTR-301-002TR-ND | LTR-301-002 | |
| 475-SFH309-3/4-ND | SFH 309-3/4 | |
| 475-SFH309-5/6-ND | SFH 309-5/6 | |
| LTR-5888DH-ND | LTR-5888DH | |
| 1080-PT67-21B/L41/TR8TR-ND | PT67-21B/L41/TR8 | |
| 1080-EAPPL3527A1TR-ND | EAPPL3527A1 | |
| 475-SFH300FA-ND | SFH 300 FA | |
| 1080-EAPPL3527A0TR-ND | EAPPL3527A0 | |
| 1080-EAPSV3224A0TR-ND | EAPSV3224A0 | |
| 475-SFH309-4-ND | SFH 309-4 | |
| 475-SFH309-5-ND | SFH 309-5 | |
| 1080-PT42-21C/TR8TR-ND | PT42-21C/TR8 | |
| 475-SFH3211FA-ZTR-ND | SFH 3211 FA-Z | |
| 350-5215500F-ND | 5215500F | |
| 475-SFH320-4-ZTR-ND | SFH 320-4-Z | |
| 475-SFH320FA-3-ZTR-ND | SFH 320 FA-3-Z | |
| 475-SFH320FA-4-ZTR-ND | SFH 320 FA-4-Z | |
| 475-SFH3211FA-3/4-ZTR-ND | SFH 3211 FA-3/4-Z | |
| 475-SFH325-3-ZTR-ND | SFH 325-3-Z | |
| 475-SFH325-4-ZTR-ND | SFH 325-4-Z | |
| 475-SFH325FA-4-ZTR-ND | SFH 325 FA-4-Z | |
| 475-SFH3716TR-ND | SFH 3716 | |
| 751-VEMT3700-GS18TR-ND | VEMT3700-GS18 | |
| 751-VEMT3700X01-GS18TR-ND | VEMT3700X01-GS18 | |
| 751-VEMT3700X01-GS08TR-ND | VEMT3700X01-GS08 | |
| 475-SFH3710-2/3-ZTR-ND | SFH 3710-2/3-Z | |
| 160-LTR-350AB-ND | LTR-350AB | |
| VEMT3704F-GS08-ND | VEMT3704F-GS08 | |
| VEMT4700F-GS08-ND | VEMT4700F-GS08 | |
| 475-SFH3605-3/4-ZTR-ND | SFH 3605-3/4-Z | |
| 1080-1388-2-ND,1080-1388-1-ND,1080-1388-6-ND | PT28-21B/TR8 | |
| 1080-1394-2-ND,1080-1394-1-ND,1080-1394-6-ND | PT91-21B/TR9 | |
| 1080-1385-2-ND,1080-1385-1-ND,1080-1385-6-ND | PT26-21B/TR8 | |
| 475-SFH3410-3/4-ZTR-ND | SFH 3410-3/4-Z | |
| 475-SFH3410-1/2-ZTR-ND | SFH 3410-1/2-Z | |
| 1080-1396-2-ND,1080-1396-1-ND,1080-1396-6-ND | PT91-21C/TR7 | |
| 1080-1391-2-ND,1080-1391-1-ND,1080-1391-6-ND | PT67-21C/L41/TR8 | |
| 1080-1390-2-ND,1080-1390-1-ND,1080-1390-6-ND | PT67-21B/C14/TR8 | |
| OP599C-ND | OP599C | |
| 1080-1243-2-ND,1080-1243-1-ND,1080-1243-6-ND | ALS-PT17-51C/L177/TR8 | |
| 751-VEMT3700F-GS18-ND | VEMT3700F-GS18 | |
| 751-VEMT3700FX01-GS18-ND | VEMT3700FX01-GS18 | |
| 751-VEMT3700FX01-GS08-ND | VEMT3700FX01-GS08 | |
| 365-1602-ND | OP509B | |
| 1528-2545-ND | 2831 | |
| 475-SFH3600-ZTR-ND,475-SFH3600-ZCT-ND,475-SFH3600-ZDKR-ND | SFH 3600-Z | |
| 475-SFH3605-ZTR-ND,475-SFH3605-ZCT-ND,475-SFH3605-ZDKR-ND | SFH 3605-Z | |
| 1568-SEN-12566-ND | SEN-12566 | |
| 475-SFH3600-3/4-ZTR-ND,475-SFH3600-3/4-ZCT-ND,475-SFH3600-3/4-ZDKR-ND | SFH 3600-3/4-Z | |
| TEKT5400S-ASZCT-ND,TEKT5400S-ASZTB-ND | TEKT5400S-ASZ | |
| 1568-COM-08348-ND | COM-08348 | |
| OP800C-ND | OP800C | |
| 365-1917-ND | OP800B | |
| 365-1616-ND | OP800WSL | |
| OP516C-ND | OP516C | |
| OP604TXV-ND | OP604TXV | |
| OP804TX-ND | OP804TX | |
| OP805TX-ND | OP805TX | |
| OP804TXV-ND | OP804TXV | |
| OP805TXV-ND | OP805TXV | |
| OP604S-ND | OP604S | |
| OED-ST-23-TR-ND | OED-ST-23-TR | |
| OED-ST-23G-ND | OED-ST-23G | |
| OED-ST-44F-ND | OED-ST-44F | |
| EAPLP04RRAA3-ND | EAPLP04RRAA3 | |
| EAPLP04RRKA0-ND | EAPLP04RRKA0 | |
| EAPLP04RRKA1-ND | EAPLP04RRKA1 | |
| EAPSG2520A0-ND | EAPSG2520A0 | |
| EAPSR3216A0-ND | EAPSR3216A0 | |
| EAPST2520A1-ND | EAPST2520A1 | |
| EAPSY2520A2-ND | EAPSY2520A2 | |
| EAPSZ2520A0-ND | EAPSZ2520A0 | |
| 475-BP103-4-ND | BP 103-4 | |
| 475-SFH313FA-3-ND | SFH 313 FA-3 | |
| 475-SFH305-2-ND | SFH 305-2 | |
| 350-00029-ND | 350-00029 | |
| EAPST3224A0-ND | EAPST3224A0 | |
| VTPS1192HB-ND | VTPS1192HB | |
| 2661-CSM28PTBZ-ND | CSM28PTBZ | |
| 475-SFH3600-3-Z-XXTR-ND | SFH 3600-3-Z-XX | |
| 1080-EAPLP02RRHA0-ND | EAPLP02RRHA0 | |
| 1080-EAPLP04RRAA0-ND | EAPLP04RRAA0 | |
| 1080-EAPPL3527A2TR-ND | EAPPL3527A2 | |
| 1080-EAPST1608A0-ND | EAPST1608A0 | |
| 3892-T1090P6-SD-F-ND | T1090P6-SD-F |
Integrated Circuit Ambient Light Sensors are specialized integrated circuits which incorporate light sensing functionality into themselves. Essentially, these sensors make use of photodiodes or phototransistors to detect light and convert it into a corresponding electrical signal. The IC then converts this electrical signal into digital data which can further be used with microcontrollers and other digital devices. These sensors can help in reducing device power consumption by automatically adjusting screen brightness in portable devices like smartphones, laptops and some handheld devices, thereby increasing their battery life.
These sensors are very compact which makes them suitable to be used in embedded systems and easy to integrate into new designs. These sensors are relatively stable as they are not much affected by changes in temperature.
Applications
Display Brightness Control: These sensors can automatically adjust the display brightness based on ambient light.
Automatic Lighting Systems: They are used to control the brightness of the indoor and outdoor lighting based on the natural or ambient light available.
IC Ambient Light Sensors can be used in industrial environments when there is no human presence at nights for switching off or dimming the unused lights. This can save enormous amount of electrical energy.
Theses sensors can be used in automotives to adjust the brightness of dashboard displays, speedometer when it is dark.
Integrated Circuit Ambient Light Sensors available with DigiKey
| 160-2160-2-ND,160-2160-1-ND,160-2160-6-ND | LTR-329ALS-01 | |
| 160-2161-2-ND,160-2161-1-ND,160-2161-6-ND | LTR-303ALS-01 | |
| 751-VCNL36825TTR-ND,751-VCNL36825TCT-ND,751-VCNL36825TDKR-ND | VCNL36825T | |
| 516-3578-2-ND,516-3578-1-ND,516-3578-6-ND | APDS-9306-065 | |
| 296-53431-2-ND,296-53431-1-ND,296-53431-6-ND | OPT3001DNPRQ1 | |
| VEML7700TR-ND,VEML7700CT-ND,VEML7700DKR-ND | VEML7700-TR | |
| 751-VEML7700-TTTR-ND,751-VEML7700-TTCT-ND,751-VEML7700-TTDKR-ND | VEML7700-TT | |
| 4991-TCS34103MOLGA6LFT&RDPTR-ND,4991-TCS34103MOLGA6LFT&RDPCT-ND,4991-TCS34103MOLGA6LFT&RDPDKR-ND | TCS34103M OLGA6 LF T&RDP | |
| 296-47274-2-ND,296-47274-1-ND,296-47274-6-ND | OPT3002DNPR | |
| 516-3293-2-ND,516-3293-1-ND,516-3293-6-ND | APDS-9250 | |
| 516-APDS-9253-001TR-ND,516-APDS-9253-001CT-ND,516-APDS-9253-001DKR-ND | APDS-9253-001 | |
| VCNL4040M3OETR-ND,VCNL4040M3OECT-ND,VCNL4040M3OEDKR-ND | VCNL4040M3OE | |
| TSL25721FNTR-ND,TSL25721FNCT-ND,TSL25721FNDKR-ND | TSL25721FN | |
| 4991-TCS37073OQFN12LFT&RDPTR-ND,4991-TCS37073OQFN12LFT&RDPCT-ND,4991-TCS37073OQFN12LFT&RDPDKR-ND | TCS37073 OQFN12 LF T&RDP | |
| VCNL4035X01-GS08TR-ND,VCNL4035X01-GS08CT-ND,VCNL4035X01-GS08DKR-ND | VCNL4035X01-GS08 | |
| BH1726NUC-E2TR-ND,BH1726NUC-E2CT-ND,BH1726NUC-E2DKR-ND | BH1726NUC-E2 | |
| 296-53402-2-ND,296-53402-1-ND,296-53402-6-ND | OPT3004DNPR | |
| TSL25911FNTR-ND,TSL25911FNCT-ND,TSL25911FNDKR-ND | TSL25911FN | |
| VCNL4020-GS08TR-ND,VCNL4020-GS08CT-ND,VCNL4020-GS08DKR-ND | VCNL4020-GS08 | |
| 296-40474-2-ND,296-40474-1-ND,296-40474-6-ND | OPT3001DNPR | |
| TSL2584TSVTR-ND,TSL2584TSVCT-ND,TSL2584TSVDKR-ND | TSL2584TSV | |
| VCNL4200TR-ND,VCNL4200CT-ND,VCNL4200DKR-ND | VCNL4200 | |
| 4991-TCS34303OLGA8LFT&RDPTR-ND,4991-TCS34303OLGA8LFT&RDPCT-ND,4991-TCS34303OLGA8LFT&RDPDKR-ND | TCS34303 OLGA8 LF T&RDP | |
| 4991-TCS34001FNODFN6LFT&RDPTR-ND,4991-TCS34001FNODFN6LFT&RDPCT-ND,4991-TCS34001FNODFN6LFT&RDPDKR-ND | TCS34001FN ODFN6 LF T&RDP | |
| 4991-TCS34001FNMODFN6LFT&RDPTR-ND,4991-TCS34001FNMODFN6LFT&RDPCT-ND,4991-TCS34001FNMODFN6LFT&RDPDKR-ND | TCS34001FNM ODFN6 LF T&RDP | |
| 336-2199-2-ND,336-2199-1-ND,336-2199-6-ND | SI1141-A11-GMR | |
| AS7341-DLGTTR-ND,AS7341-DLGTCT-ND,AS7341-DLGTDKR-ND | AS7341-DLGT | |
| 4991-AS7343L-DLGMTR-ND,4991-AS7343L-DLGMCT-ND,4991-AS7343L-DLGMDKR-ND | AS7343L-DLGM OLGA8 LF T&RDP | |
| 4991-AS7343-DLGMTR-ND,4991-AS7343-DLGMCT-ND,4991-AS7343-DLGMDKR-ND | AS7343-DLGM OLGA8 LF T&RDP | |
| 751-VEML3235TR-ND,751-VEML3235CT-ND,751-VEML3235DKR-ND | VEML3235 | |
| VEML6035TR-ND,VEML6035CT-ND,VEML6035DKR-ND | VEML6035 | |
| TSL25403TR-ND,TSL25403CT-ND,TSL25403DKR-ND | TSL25403 | |
| 4991-TMD26353MOLGA6LFT&RDPTR-ND,4991-TMD26353MOLGA6LFT&RDPCT-ND,4991-TMD26353MOLGA6LFT&RDPDKR-ND | TMD26353M OLGA6 LF T&RDP | |
| RPR-0521RSTR-ND,RPR-0521RSCT-ND,RPR-0521RSDKR-ND | RPR-0521RS | |
| 846-RPR-0720TR-ND,846-RPR-0720CT-ND,846-RPR-0720DKR-ND | RPR-0720 | |
| VEML6030-GS15TR-ND,VEML6030-GS15CT-ND,VEML6030-GS15DKR-ND | VEML6030-GS15 | |
| VEML6030TR-ND,VEML6030CT-ND,VEML6030DKR-ND | VEML6030 | |
| 296-50382-2-ND,296-50382-1-ND,296-50382-6-ND | OPT3007YMFR | |
| 296-47670-2-ND,296-47670-1-ND,296-47670-6-ND | OPT3001IDNPRQ1 | |
| 4991-TMD26363MOLGA6LFT&RDPTR-ND,4991-TMD26363MOLGA6LFT&RDPCT-ND,4991-TMD26363MOLGA6LFT&RDPDKR-ND | TMD26363M OLGA6 LF T&RDP | |
| VCNL36687STR-ND,VCNL36687SCT-ND,VCNL36687SDKR-ND | VCNL36687S | |
| 751-VEML6031X00TR-ND,751-VEML6031X00CT-ND,751-VEML6031X00DKR-ND | VEML6031X00 | |
| 4991-TSL25853PMTR-ND,4991-TSL25853PMCT-ND,4991-TSL25853PMDKR-ND | TSL25853PM | |
| 497-VD6283TX45/1TR-ND,497-VD6283TX45/1CT-ND,497-VD6283TX45/1DKR-ND | VD6283TX45/1 | |
| 516-4303-2-ND,516-4303-1-ND,516-4303-6-ND | APDS-9160-003 | |
| BH1721FVCTR-ND,BH1721FVCCT-ND,BH1721FVCDKR-ND | BH1721FVC-TR | |
| 296-OPT3005DTSRTR-ND,296-OPT3005DTSRCT-ND,296-OPT3005DTSRDKR-ND | OPT3005DTSR | |
| VCNL4030X01-GS08TR-ND,VCNL4030X01-GS08CT-ND,VCNL4030X01-GS08DKR-ND | VCNL4030X01-GS08 | |
| 751-VCNL36826STR-ND,751-VCNL36826SCT-ND,751-VCNL36826SDKR-ND | VCNL36826S | |
| 296-OPT4001DTSRTR-ND,296-OPT4001DTSRCT-ND,296-OPT4001DTSRDKR-ND | OPT4001DTSR | |
| 296-OPT4001YMNRTR-ND,296-OPT4001YMNRCT-ND,296-OPT4001YMNRDKR-ND | OPT4001YMNR | |
| 516-APDS-9999TR-ND,516-APDS-9999CT-ND,516-APDS-9999DKR-ND | APDS-9999 | |
| VCNL4020X01-GS08TR-ND,VCNL4020X01-GS08CT-ND,VCNL4020X01-GS08DKR-ND | VCNL4020X01-GS08 | |
| 296-OPT4001DNPRQ1TR-ND,296-OPT4001DNPRQ1CT-ND,296-OPT4001DNPRQ1DKR-ND | OPT4001DNPRQ1 | |
| BH1715FVCTR-ND,BH1715FVCCT-ND,BH1715FVCDKR-ND | BH1715FVC-TR | |
| TMD27721TR-ND,TMD27721CT-ND,TMD27721DKR-ND | TMD27721 | |
| 296-OPT4003DNPRQ1TR-ND,296-OPT4003DNPRQ1CT-ND,296-OPT4003DNPRQ1DKR-ND | OPT4003DNPRQ1 | |
| TCS34003FNMTR-ND,TCS34003FNMCT-ND,TCS34003FNMDKR-ND | TCS34003FNM | |
| BH1750FVITR-ND,BH1750FVICT-ND,BH1750FVIDKR-ND | BH1750FVI-TR | |
| BH1730FVCTR-ND,BH1730FVCCT-ND,BH1730FVCDKR-ND | BH1730FVC-TR | |
| 336-5918-ND | SI1153-AB00-GM | |
| AS7263-BLGTTR-ND,AS7263-BLGTCT-ND,AS7263-BLGTDKR-ND | AS7263-BLGT | |
| 4991-TCS35303-2OLGA8LFT&RDPTR-ND,4991-TCS35303-2OLGA8LFT&RDPCT-ND,4991-TCS35303-2OLGA8LFT&RDPDKR-ND | TCS35303-2 OLGA8 LF T&RDP | |
| 505-ADPD188BI-ACEZR7TR-ND,505-ADPD188BI-ACEZR7CT-ND,505-ADPD188BI-ACEZR7DKR-ND | ADPD188BI-ACEZR7 | |
| 4991-TMD26353OLGA6TR-ND,4991-TMD26353OLGA6CT-ND,4991-TMD26353OLGA6DKR-ND | TMD26353 OLGA6 | |
| 1080-EAAPMST3923A2TR-ND,1080-EAAPMST3923A2CT-ND,1080-EAAPMST3923A2DKR-ND | EAAPMST3923A2 | |
| TSL25403MTR-ND,TSL25403MCT-ND,TSL25403MDKR-ND | TSL25403M | |
| 4991-TSL25203MTR-ND,4991-TSL25203MCT-ND,4991-TSL25203MDKR-ND | TSL25203M | |
| 1080-APM-16D24-310-DF8/TR8TR-ND,1080-APM-16D24-310-DF8/TR8CT-ND,1080-APM-16D24-310-DF8/TR8DKR-ND | APM-16D24-310-DF8/TR8 | |
| 4991-TMD27123MOLGA6LFT&RDPTR-ND,4991-TMD27123MOLGA6LFT&RDPCT-ND,4991-TMD27123MOLGA6LFT&RDPDKR-ND | TMD27123M OLGA6 LF T&RDP | |
| 4991-TSL25213MTR-ND,4991-TSL25213MCT-ND,4991-TSL25213MDKR-ND | TSL25213M | |
| VCNL4040M3OE-H5TR-ND,VCNL4040M3OE-H5CT-ND,VCNL4040M3OE-H5DKR-ND | VCNL4040M3OE-H5 | |
| 751-VCNL4040M3OE-H3TR-ND,751-VCNL4040M3OE-H3CT-ND,751-VCNL4040M3OE-H3DKR-ND | VCNL4040M3OE-H3 | |
| 296-45132-2-ND,296-45132-1-ND,296-45132-6-ND | OPT3006YMFR | |
| TMD26721TR-ND,TMD26721CT-ND,TMD26721DKR-ND | TMD26721 MOD8 LF T&RDP | |
| TCS37013MTR-ND,TCS37013MCT-ND,TCS37013MDKR-ND | TCS37013M | |
| 1080-ALS-DPDIC17-78C-L749/TR8TR-ND,1080-ALS-DPDIC17-78C-L749/TR8CT-ND,1080-ALS-DPDIC17-78C-L749/TR8DKR-ND | ALS-DPDIC17-78C-L749/TR8 | |
| VCNL40301X01-GS08TR-ND,VCNL40301X01-GS08CT-ND,VCNL40301X01-GS08DKR-ND | VCNL40301X01-GS08 | |
| 336-5875-ND | SI1151-AB00-GM | |
| 336-2201-2-ND,336-2201-1-ND,336-2201-6-ND | SI1143-A11-GMR | |
| 516-3579-2-ND,516-3579-1-ND,516-3579-6-ND | APDS-9500 | |
| AS7261-BLGTTR-ND,AS7261-BLGTCT-ND,AS7261-BLGTDKR-ND | AS7261-BLGT | |
| 505-ADPD188GG-ACEZRLTR-ND,505-ADPD188GG-ACEZRLCT-ND,505-ADPD188GG-ACEZRLDKR-ND | ADPD188GG-ACEZRL | |
| TSL27403TR-ND,TSL27403CT-ND,TSL27403DKR-ND | TSL27403 | |
| TSL27403MTR-ND,TSL27403MCT-ND,TSL27403MDKR-ND | TSL27403M | |
| 4991-TCS37073MOQFN12LFT&RDPTR-ND,4991-TCS37073MOQFN12LFT&RDPCT-ND,4991-TCS37073MOQFN12LFT&RDPDKR-ND | TCS37073M OQFN12 LF T&RDP | |
| 505-ADPD188GG-ACEZR7TR-ND,505-ADPD188GG-ACEZR7CT-ND,505-ADPD188GG-ACEZR7DKR-ND | ADPD188GG-ACEZR7 | |
| 475-SFH5721TR-ND,475-SFH5721CT-ND,475-SFH5721DKR-ND | SFH 5721 | |
| 4991-TMD27553MOLGA6LFT&RDPTR-ND,4991-TMD27553MOLGA6LFT&RDPCT-ND,4991-TMD27553MOLGA6LFT&RDPDKR-ND | TMD27553M OLGA6 LF T&RDP | |
| 751-VEML60311X00TR-ND,751-VEML60311X00CT-ND,751-VEML60311X00DKR-ND | VEML60311X00 | |
| 4991-TCS34087MOQFN12LFT&RDPTR-ND,4991-TCS34087MOQFN12LFT&RDPCT-ND,4991-TCS34087MOQFN12LFT&RDPDKR-ND | TCS34087M OQFN12 LF T&RDP | |
| 4991-TCS34083MOQFN12LFT&RDPTR-ND,4991-TCS34083MOQFN12LFT&RDPCT-ND,4991-TCS34083MOQFN12LFT&RDPDKR-ND | TCS34083M OQFN12 LF T&RDP | |
| 4991-TSL25723FNODFN6LFT&RDPTR-ND,4991-TSL25723FNODFN6LFT&RDPCT-ND,4991-TSL25723FNODFN6LFT&RDPDKR-ND | TSL25723FN ODFN6 LF T&RDP | |
| 751-VCNL40352X01-GS08TR-ND,751-VCNL40352X01-GS08CT-ND,751-VCNL40352X01-GS08DKR-ND | VCNL40352X01-GS08 | |
| 751-VCNL40351X01-GS08TR-ND,751-VCNL40351X01-GS08CT-ND,751-VCNL40351X01-GS08DKR-ND | VCNL40351X01-GS08 | |
| 751-VCNL40353X01-GS08TR-ND,751-VCNL40353X01-GS08CT-ND,751-VCNL40353X01-GS08DKR-ND | VCNL40353X01-GS08 | |
| 751-VCNL40302X01-GS08TR-ND,751-VCNL40302X01-GS08CT-ND,751-VCNL40302X01-GS08DKR-ND | VCNL40302X01-GS08 | |
| 751-VCNL40303X01-GS08TR-ND,751-VCNL40303X01-GS08CT-ND,751-VCNL40303X01-GS08DKR-ND | VCNL40303X01-GS08 | |
| 4991-TMD26723MOD8LFT&RDPTR-ND,4991-TMD26723MOD8LFT&RDPCT-ND,4991-TMD26723MOD8LFT&RDPDKR-ND | TMD26723 MOD8 LF T&RDP | |
| 4991-TMD27723MOD8LFT&RDPTR-ND,4991-TMD27723MOD8LFT&RDPCT-ND,4991-TMD27723MOD8LFT&RDPDKR-ND | TMD27723 MOD8 LF T&RDP | |
| 20-ISL76682AROZ-T7ATR-ND,20-ISL76682AROZ-T7ACT-ND,20-ISL76682AROZ-T7ADKR-ND | ISL76682AROZ-T7A | |
| 4991-TCS34303MOLGA8LFT&RDPTR-ND,4991-TCS34303MOLGA8LFT&RDPCT-ND,4991-TCS34303MOLGA8LFT&RDPDKR-ND | TCS34303M OLGA8 LF T&RDP | |
| BH1772GLC-E2TR-ND,BH1772GLC-E2CT-ND,BH1772GLC-E2DKR-ND | BH1772GLC-E2 | |
| 4991-TMF8701-1BMOLGA12LFT&RDPTR-ND,4991-TMF8701-1BMOLGA12LFT&RDPCT-ND,4991-TMF8701-1BMOLGA12LFT&RDPDKR-ND | TMF8701-1BM OLGA12 LF T&RDP | |
| 846-BU27030NUC-E2TR-ND,846-BU27030NUC-E2CT-ND,846-BU27030NUC-E2DKR-ND | BU27030NUC-E2 | |
| 296-38667-2-ND,296-38667-1-ND,296-38667-6-ND | OPT3001DNPT | |
| 296-OPT4001YMNTTR-ND,296-OPT4001YMNTCT-ND,296-OPT4001YMNTDKR-ND | OPT4001YMNT | |
| TCS37013TR-ND,TCS37013CT-ND,TCS37013DKR-ND | TCS37013 | |
| 2156-ISL29012IROZ-T7-ILTR-ND | ISL29012IROZ-T7 | |
| 2156-ISL29004IROZ-T7-ILTR-ND | ISL29004IROZ-T7 | |
| TSL27723FNTR-ND,TSL27723FNCT-ND,TSL27723FNDKR-ND | TSL27723FN | |
| 2832-SI1153-AB00-GMR-ND,SI1153-AB00-GMR-ND | SI1153-AB00-GMR | |
| ISL29030AIROZ-T7TR-ND | ISL29030AIROZ-T7 | |
| 296-47456-2-ND,296-47456-1-ND,296-47456-6-ND | OPT3007YMFT | |
| 296-OPT3006YMFTTR-ND,296-OPT3006YMFTCT-ND,296-OPT3006YMFTDKR-ND | OPT3006YMFT | |
| ISL76683AROZ-T7ACT-ND | ISL76683AROZ-T7A | |
| TSL2569-CSTR-ND,TSL2569-CSCT-ND | TSL2569CS | |
| 296-46622-2-ND,296-46622-1-ND,296-46622-6-ND | OPT3001IDNPTQ1 | |
| 336-3264-2-ND,336-3264-1-ND | SI1146-M01-GMR | |
| TMD49033TR-ND,TMD49033CT-ND | TMD49033 | |
| 336-5878-ND | SI1152-AB09-GM | |
| 2156-ISL29028IROZ-T7-ND | ISL29028IROZ-T7 | |
| 336-3265-2-ND,336-3265-1-ND | SI1147-M01-GMR | |
| 336-5138-ND | SI1147-M01-GM | |
| 336-3477-2-ND,336-3477-1-ND | SI1133-AA00-GMR | |
| SI1133-AA00-GM-ND | SI1133-AA00-GM | |
| 336-5876-ND | SI1151-AB09-GM | |
| SI1142-A11-GM-ND | SI1142-A11-GM | |
| 336-2200-2-ND,336-2200-1-ND,336-2200-6-ND | SI1142-A11-GMR | |
| ADUX1020BCPZRL7TR-ND,ADUX1020BCPZRL7CT-ND,ADUX1020BCPZRL7DKR-ND | ADUX1020BCPZRL7 | |
| 336-2624-2-ND,336-2624-1-ND | SI1147-A10-GMR | |
| 336-4754-2-ND,336-4754-1-ND | SI1144-AAGX-GMR | |
| 336-5133-ND | SI1144-AAGX-GM | |
| 336-5920-ND | SI1153-AB9X-GM | |
| 751-VEML3235SLTR-ND,751-VEML3235SLCT-ND,751-VEML3235SLDKR-ND | VEML3235SL | |
| 1738-SEN0390-ND | SEN0390 | |
| 4991-TMD37253MOLGA8LFT&RDPTR-ND,4991-TMD37253MOLGA8LFT&RDPCT-ND,4991-TMD37253MOLGA8LFT&RDPDKR-ND | TMD37253M OLGA8 LF T&RDP | |
| 336-5919-ND | SI1153-AB09-GM | |
| 2084-WISE-S100-A-ND | WISE-S100-A | |
| SI1141-A11-GM-ND | SI1141-A11-GM | |
| 1882-6068612-ND | 6068612 | |
| 1882-1220797-ND | 1220797 | |
| 1882-1081731-ND | 1081731 | |
| 1882-1220994-ND | 1220994 | |
| TSL2581-CSTR-ND,TSL2581-CSCT-ND | TSL2581CS | |
| TSL27713-FNTR-ND,TSL27713-FNCT-ND,TSL27713-FNDKR-ND | TSL27713FN | |
| 336-5877-ND | SI1152-AB00-GM | |
| 475-SFH7776TR-ND,475-SFH7776CT-ND,475-SFH7776DKR-ND | SFH 7776 | |
| 516-4304-2-ND,516-4304-1-ND,516-4304-6-ND | APDS-9922-001 | |
| 4991-TSL25413MOQFN10LFT&RDPTR-ND,4991-TSL25413MOQFN10LFT&RDPCT-ND,4991-TSL25413MOQFN10LFT&RDPDKR-ND | TSL25413M OQFN10 LF T&RDP | |
| 20-ISL76682AROZ-T7TR-ND,20-ISL76682AROZ-T7CT-ND,20-ISL76682AROZ-T7DKR-ND | ISL76682AROZ-T7 | |
| 4991-TSL27721FNODFN6LFT&RDPTR-ND,4991-TSL27721FNODFN6LFT&RDPCT-ND,4991-TSL27721FNODFN6LFT&RDPDKR-ND | TSL27721FN ODFN6 LF T&RDP | |
| LTR-308ALS-01-ND | LTR-308ALS-01 | |
| LTR-507ALS-01-ND | LTR-507ALS-01 | |
| 4991-TSL25213TR-ND | TSL25213 | |
| 4991-TSL25413TR-ND | TSL25413 | |
| 4991-TCS34103OLGA6LFT&RDPTR-ND | TCS34103 OLGA6 LF T&RDP | |
| 4991-TMD27553OLGA6LFT&RDPTR-ND | TMD27553 OLGA6 LF T&RDP | |
| 516-APDS-9306-A65TR-ND | APDS-9306-A65 | |
| 4991-TSL25203TR-ND | TSL25203 | |
| GP2AP052A00F-ND | GP2AP052A00F | |
| 1080-ALS-DPDIC17-78C/L653/TR8TR-ND | ALS-DPDIC17-78C/L653/TR8 | |
| 4991-TCS37013HTR-ND | TCS37013H | |
| 20-ISL29034IROZ-T7TR-ND | ISL29034IROZ-T7 | |
| TSL2581-FNTR-ND | TSL2581FN | |
| 475-SFH5712-2/3TR-ND | SFH 5712-2/3 | |
| ISL29035IROZ-T7TR-ND | ISL29035IROZ-T7 | |
| 1080-APM-12D23-20-DF8/TR8TR-ND | APM-12D23-20-DF8/TR8 | |
| NOA1302DCRG-ND | NOA1302DCRG | |
| 1080-EAALSDIC2020A1TR-ND | EAALSDIC2020A1 | |
| 4991-TMD26363OLGA6LFT&RDPTR-ND | TMD26363 OLGA6 LF T&RDP | |
| 751-VEML6031X01-GS15TR-ND | VEML6031X01-GS15 | |
| 751-VEML60311X01-GS15TR-ND | VEML60311X01-GS15 | |
| 296-OPT3004DTSRTR-ND,296-OPT3004DTSRCT-ND,296-OPT3004DTSRDKR-ND | OPT3004DTSR | |
| 751-VEML60311X00-GS15TR-ND | VEML60311X00-GS15 | |
| 751-VEML6031X00-GS15TR-ND | VEML6031X00-GS15 | |
| 4991-TCS34083OQFN12LFT&RDPTR-ND | TCS34083 OQFN12 LF T&RDP | |
| 4991-TCS34087OQFN12LFT&RDPTR-ND | TCS34087 OQFN12 LF T&RDP | |
| 751-VEML60311X01TR-ND | VEML60311X01 | |
| 751-VEML6031X01TR-ND | VEML6031X01 | |
| APDS-9251-001-ND | APDS-9251-001 | |
| 516-1269-2-ND | HSDL-9000 | |
| 4991-TSL25853PTR-ND | TSL25853P | |
| VCNL4035X01-GS18-ND | VCNL4035X01-GS18 | |
| 1080-EAALSDIC2020A2TR-ND | EAALSDIC2020A2 | |
| FLD00060TR-ND | FLD00060 | |
| 751-VCNL40353X01-GS18TR-ND | VCNL40353X01-GS18 | |
| 751-VCNL40351X01-GS18TR-ND | VCNL40351X01-GS18 | |
| 751-VCNL40352X01-GS18TR-ND | VCNL40352X01-GS18 | |
| VCNL4030X01-GS18-ND | VCNL4030X01-GS18 | |
| VCNL4020-GS18-ND | VCNL4020-GS18 | |
| VCNL40301X01-GS18-ND | VCNL40301X01-GS18 | |
| VCNL40302X01-GS18-ND | VCNL40302X01-GS18 | |
| VCNL40303X01-GS18-ND | VCNL40303X01-GS18 | |
| ISL29044AIROMZ-T7-ND | ISL29044AIROMZ-T7 | |
| ISL29023IROZ-T7TR-ND | ISL29023IROZ-T7 | |
| 4991-TCS37209TR-ND | TCS37209 | |
| VCNL4020X01-GS18-ND | VCNL4020X01-GS18 | |
| TCS34007FN-ND | TCS34007FN | |
| VCNL4010-GS18-ND | VCNL4010-GS18 | |
| 4991-TCS37203MOLGA12LFT&RDPTR-ND | TCS37203M OLGA12 LF T&RDP | |
| ISL29033IROZ-T7TR-ND | ISL29033IROZ-T7 | |
| MAX9635EDT+T-ND | MAX9635EDT+T | |
| MAX9635ESA+T-ND | MAX9635ESA+T | |
| 1080-EAAPMST3923A3TR-ND,1080-EAAPMST3923A3CT-ND,1080-EAAPMST3923A3DKR-ND | EAAPMST3923A3 | |
| TSL45315-CLTR-ND,TSL45315-CLCT-ND,TSL45315-CLDKR-ND | TSL45315CL | |
| TCS34007FNMTR-ND | TCS34007FNM | |
| 516-3185-2-ND,516-3185-1-ND,516-3185-6-ND | APDS-9309 | |
| 516-3577-2-ND,516-3577-1-ND,516-3577-6-ND | APDS-9306 | |
| TSL25711-FNTR-ND,TSL25711-FNCT-ND,TSL25711-FNDKR-ND | TSL25711FN | |
| TSL25713-FNTR-ND,TSL25713-FNCT-ND,TSL25713-FNDKR-ND | TSL25713FN | |
| 4991-TCS34003FNODFN6LFT&RDPTR-ND | TCS34003FN ODFN6 LF T&RDP | |
| 336-1968-2-ND | SI1141-A10-GMR | |
| 516-3479-2-ND,516-3479-1-ND,516-3479-6-ND | APDS-9930 | |
| TSL25715-FNTR-ND,TSL25715-FNCT-ND,TSL25715-FNDKR-ND | TSL25715FN | |
| 516-2134-2-ND,516-2134-1-ND,516-2134-6-ND | APDS-9300-020 | |
| ISL29038IROZ-T7TR-ND | ISL29038IROZ-T7 | |
| TMG39923-ND | TMG39923 | |
| SI1132-A10-GM-ND | SI1132-A10-GM | |
| 296-44600-2-ND,296-44600-1-ND,296-44600-6-ND | OPT3002DNPT | |
| ISL29027IROZ-T7TR-ND | ISL29027IROZ-T7 | |
| MAX44000EDT+T-ND | MAX44000EDT+T | |
| MAX44002EDT+T-ND | MAX44002EDT+T | |
| MAX44004EDT+T-ND | MAX44004EDT+T | |
| 516-2664-2-ND,516-2664-1-ND,516-2664-6-ND | APDS-9301-020 | |
| SI1151-AB00-GMR-ND | SI1151-AB00-GMR | |
| 336-1969-2-ND | SI1142-A10-GMR | |
| TMG39923-M-ND | TMG39923-M | |
| TSL27711-FNTR-ND,TSL27711-FNCT-ND,TSL27711-FNDKR-ND | TSL27711FN | |
| FLD00042TR-ND,FLD00042CT-ND | FLD00042 | |
| TMD26711-TTR-ND,TMD26711-TCT-ND,TMD26711-TDKR-ND | TMD26711 | |
| TMD26713-TTR-ND,TMD26713-TCT-ND,TMD26713-TDKR-ND | TMD26713 | |
| ISL29011IROZ-T7TR-ND | ISL29011IROZ-T7 | |
| ISL29028AIROZ-T7TR-ND | ISL29028AIROZ-T7 | |
| SI1152-AB00-GMR-ND | SI1152-AB00-GMR | |
| TMD27711-TTR-ND,TMD27711-TCT-ND,TMD27711-TDKR-ND | TMD27711 | |
| 516-3480-2-ND,516-3480-1-ND,516-3480-6-ND | APDS-9960 | |
| TMD27723WATR-ND,TMD27723WACT-ND,TMD27723WADKR-ND | TMD27723WA | |
| 4991-TMF8701-1BOLGA12LFT&RDPTR-ND | TMF8701-1B OLGA12 LF T&RDP | |
| ISL29029IROZ-T7TR-ND | ISL29029IROZ-T7 | |
| VCNL4010-GS08TR-ND,VCNL4010-GS08CT-ND,VCNL4010-GS08DKR-ND | VCNL4010-GS08 | |
| 336-1970-2-ND | SI1143-A10-GMR | |
| SI1151-AB09-GMR-ND | SI1151-AB09-GMR | |
| 296-OPT3005DTSTTR-ND,296-OPT3005DTSTCT-ND,296-OPT3005DTSTDKR-ND | OPT3005DTST | |
| SI1152-AB09-GMR-ND | SI1152-AB09-GMR | |
| AS7220-BLGM-ND | AS7220-BLGM | |
| AS7225-BLGM-ND | AS7225-BLGM LGA20 LF T&RDP | |
| 296-OPT3004DTSTTR-ND,296-OPT3004DTSTCT-ND,296-OPT3004DTSTDKR-ND | OPT3004DTST | |
| ISL29020IROZ-T7TR-ND,ISL29020IROZ-T7CT-ND | ISL29020IROZ-T7 | |
| SI1153-AB09-GMR-ND | SI1153-AB09-GMR | |
| MAX9635ESA±ND | MAX9635ESA+ | |
| BH1751FVITR-ND,BH1751FVICT-ND,BH1751FVIDKR-ND | BH1751FVI-TR | |
| 336-2621-2-ND,336-2621-1-ND,336-2621-6-ND | SI1132-A10-GMR | |
| 296-OPT4001DTSTTR-ND,296-OPT4001DTSTCT-ND,296-OPT4001DTSTDKR-ND | OPT4001DTST | |
| BH1780GLI-E2TR-ND,BH1780GLI-E2CT-ND,BH1780GLI-E2DKR-ND | BH1780GLI-E2 | |
| AS7211-BLGM-ND | AS7211-BLGM LGA20 LF T&RDP | |
| BH1710FVCTR-ND,BH1710FVCCT-ND,BH1710FVCDKR-ND | BH1710FVC-TR | |
| 4991-AS7341L-DLGTOLGA8LFT&RDPTR-ND | AS7341L-DLGT OLGA8 LF T&RDP | |
| MAX44000GDT+TTR-ND,MAX44000GDT+TCT-ND,MAX44000GDT+TDKR-ND | MAX44000GDT+T | |
| 516-2942-2-ND,516-2942-6-ND | APDS-9901 | |
| VCNL4100TR-ND,VCNL4100CT-ND,VCNL4100DKR-ND | VCNL4100 | |
| 4991-AS7343L-DLGTTR-ND | AS7343L-DLGT OLGA8 LF T&RDP | |
| AS7221-BLGM-ND | AS7221-BLGM | |
| 336-2623-2-ND,336-2623-1-ND,336-2623-6-ND | SI1146-A10-GMR | |
| AS7220-BLGT-ND | AS7220-BLGT | |
| AS7261N-BLGT-ND | AS7261N-BLGT LGA20 LF T&RDP | |
| 4991-AS7341L-DLGMOLGA8LFT&RDPTR-ND | AS7341L-DLGM OLGA8 LF T&RDP | |
| SI1153-AB9X-GMR-ND | SI1153-AB9X-GMR | |
| PH5553A2NA1-Y-A-ND | PH5553A2NA1-Y-A | |
| AS7264N-BLGM-ND | AS7264N-BLGM | |
| BH1771GLC-E2TR-ND,BH1771GLC-E2CT-ND,BH1771GLC-E2DKR-ND | BH1771GLC-E2 | |
| 336-3594-2-ND,336-3594-1-ND,336-3594-6-ND | SI1141-A11-YM0R | |
| ADPD188BI-ACEZRL-ND | ADPD188BI-ACEZRL | |
| AS7000-AA-ND | AS7000-AA | |
| AS7263-BLGM-ND | AS7263-BLGM | |
| AS7261-BLGM-ND | AS7261-BLGM | |
| AS7000-AAMTR-ND | AS7000-AAM | |
| AS7225-BLGTTR-ND,AS7225-BLGTCT-ND,AS7225-BLGTDKR-ND | AS7225-BLGT LGA20 LF T&RDP | |
| AS7264N-BLGT-ND | AS7264N-BLGT LGA20 LF T&RDP | |
| 4991-AS7343-DLGTTR-ND,4991-AS7343-DLGTCT-ND,4991-AS7343-DLGTDKR-ND | AS7343-DLGT OLGA8 LF T&RDP | |
| 4991-AS7261N-BLGMTR-ND,4991-AS7261N-BLGMCT-ND,4991-AS7261N-BLGMDKR-ND | AS7261N-BLGM LGA20 LF T&RDP | |
| AS7211-BLGTTR-ND,AS7211-BLGTCT-ND,AS7211-BLGTDKR-ND | AS7211-BLGT LGA20 LF T&RDP | |
| AS7221-BLGTTR-ND,AS7221-BLGTCT-ND,AS7221-BLGTDKR-ND | AS7221-BLGT | |
| SI1147-M01-PS-ND | SI1147-M01-PS | |
| 1737-1006-ND | S10 | |
| 1882-6068614-ND | 6068614 | |
| 2046-OJ500-M1K-E23-ND | OJ500-M1K-E23 | |
| 1882-1219607-ND | 1219607 | |
| 2046-AL2109-P-1820/40B/49/143-ND | AL2109-P-1820/40B/49/143 | |
| 425-1177-5-ND | IS456 | |
| ISL29002IROZ-ND | ISL29002IROZ | |
| ISL29002IROZ-T7TR-ND | ISL29002IROZ-T7 | |
| ISL29004IROZ-ND | ISL29004IROZ | |
| ISL29004IROZ-T7TR-ND | ISL29004IROZ-T7 | |
| ISL29001IROZ-T7TR-ND | ISL29001IROZ-T7 | |
| ISL29003IROZ-ND | ISL29003IROZ | |
| ISL29010IROZ-T7TR-ND | ISL29010IROZ-T7 | |
| ISL29013IROZ-T7TR-ND | ISL29013IROZ-T7 | |
| ISL29003IROZ-T7TR-ND | ISL29003IROZ-T7 | |
| ISL29001IROZ-ND | ISL29001IROZ | |
| ISL29012IROZ-T7-ND | ISL29012IROZ-T7 | |
| APDS-9801-ND | APDS-9801 | |
| 751-1505-2-ND | VCNL4000-GS08 | |
| ISL29018IROZ-T7-ND | ISL29018IROZ-T7 | |
| ISL29020IROZ-T7A-ND | ISL29020IROZ-T7A | |
| MAX44005EDT+T-ND | MAX44005EDT+T | |
| MAX44009EDT+TTR-ND | MAX44009EDT+T | |
| MAX44007EDT+TTR-ND | MAX44007EDT+T | |
| 475-SFH7770TR-ND | SFH 7770 | |
| MAX44004GDT+T-ND | MAX44004GDT+T | |
| SI1141-A10-GM-ND | SI1141-A10-GM | |
| SI1142-A10-GM-ND | SI1142-A10-GM | |
| SI1143-A10-GM-ND | SI1143-A10-GM | |
| TMD27713-TTR-ND | TMD27713 | |
| TSL2561CLTR-ND | TSL2561CL | |
| TSL2561-FNTR-ND | TSL2561FN | |
| TSL2561-TTR-ND | TSL2561T | |
| TSL2563CLTR-ND | TSL2563CL | |
| TSL2563-CSTR-ND | TSL2563CS | |
| TSL2563-FNTR-ND | TSL2563FN | |
| TSL2563TTR-ND | TSL2563T | |
| TSL2569-TTR-ND | TSL2569T | |
| TSL2583-FNTR-ND | TSL2583FN | |
| TSL45313-CLTR-ND | TSL45313CL | |
| TSL45317-CLTR-ND | TSL45317CL | |
| 475-SFH7773TR-ND | SFH 7773 | |
| ISL29043IROMZ-T7-ND | ISL29043IROMZ-T7 | |
| 425-2788-2-ND | GP2AP012A00F | |
| 516-2665-2-ND,516-2665-1-ND | APDS-9900 | |
| ISL29011IROZ-T7R5484-ND | ISL29011IROZ-T7R5484 | |
| ISL29044IROMZ-T7-ND | ISL29044IROMZ-T7 | |
| VCNL4000-GS18-ND | VCNL4000-GS18 | |
| 475-SFH7770E6TR-ND | SFH 7770 E6 | |
| ISL29147IROMZ-T7-ND | ISL29147IROMZ-T7 | |
| 336-2622-2-ND,336-2622-1-ND | SI1145-A10-GMR | |
| APDS-9930-140-ND | APDS-9930-140 | |
| 516-3478-2-ND | APDS-9930-200 | |
| ISL29035IROZ-T7ATR-ND | ISL29035IROZ-T7A | |
| TSL25913FN-ND | TSL25913FN | |
| 516-3117-2-ND | APDS-9950 | |
| EAALSDIC2020A0-ND | EAALSDIC2020A0 | |
| 475-SFH7779TR-ND | SFH 7779 | |
| LV0104CS-TLM-HOSTR-ND | LV0104CS-TLM-H | |
| NOA1305CUTAGOSTR-ND | NOA1305CUTAG | |
| NOA3302CUTAG-ND | NOA3302CUTAG | |
| 336-3263-2-ND | SI1145-M01-GMR | |
| TMG39931-ND | TMG39931 | |
| TMG39931-M-ND | TMG39931-M | |
| TMG39933-ND | TMG39933 | |
| TMG39933-M-ND | TMG39933-M | |
| TSL2583CS-ND | TSL2583CS | |
| 336-3478-2-ND | SI1153-AA00-GMR | |
| 336-3479-2-ND | SI1153-AA09-GMR | |
| 336-3480-2-ND | SI1153-AA9X-GMR | |
| TMG49033TR-ND | TMG49033 | |
| MAX44004GDT±ND | MAX44004GDT+ | |
| 475-SFH7771TR-ND | SFH 7771 | |
| 490-14389-2-ND | LT-1PA01 | |
| SI1141-A11-YM0-ND | SI1141-A11-YM0 | |
| 336-5130-ND | SI1143-AAGX-GM | |
| 336-5132-ND | SI1144-A10-GM | |
| SI1153-AA09-GM-ND | SI1153-AA09-GM | |
| SI1153-AA9X-GM-ND | SI1153-AA9X-GM | |
| 336-4753-2-ND | SI1143-AAGX-GMR | |
| SI1144-A10-GMR-ND | SI1144-A10-GMR | |
| ISL29030IROZ-T7R5430-ND | ISL29030IROZ-T7R5430 | |
| ISL29030IROZ-T7S2426-ND | ISL29030IROZ-T7S2426 | |
| ISL29038IROZ-T7S2722-ND | ISL29038IROZ-T7S2722 | |
| LTR-553ALS-01-ND | LTR-553ALS-01 | |
| LTR-556ALS-01-ND | LTR-556ALS-01 | |
| LTR-559ALS-01-ND | LTR-559ALS-01 | |
| LTR-659PS-01-ND | LTR-659PS-01 | |
| LTR-91400-ND | LTR-91400 | |
| SI1153-AA00-GM-ND | SI1153-AA00-GM | |
| MAX44005EDT±ND | MAX44005EDT+ | |
| GA1AUV100WP-ND | GA1AUV100WP | |
| GP2AP01VT10F-ND | GP2AP01VT10F | |
| 336-5134-ND | SI1145-A10-GM | |
| 336-5135-ND | SI1145-M01-GM | |
| 336-5136-ND | SI1146-A10-GM | |
| SI1146-M01-GM-ND | SI1146-M01-GM | |
| 336-5137-ND | SI1147-A10-GM | |
| APDS-9200-ND | APDS-9200 | |
| TMG39935-ND | TMG39935 | |
| TMG39935-M-ND | TMG39935-M | |
| TMG39937-ND | TMG39937 | |
| MAX44009EDT±ND | MAX44009EDT+ | |
| 516-APDS-9930-130-ND | APDS-9930-130 | |
| 4991-TMG49037TR-ND | TMG49037 | |
| 751-VEML6030IT-ND | VEML6030IT | |
| 751-VEML6030IT-GS15-ND | VEML6030IT-GS15 | |
| 20-ISL29033IROZ-T7S2722TR-ND | ISL29033IROZ-T7S2722 | |
| 20-ISL29028AIROZT7S2724TR-ND | ISL29028AIROZT7S2724 | |
| 4991-AS7000-AASTR-ND | AS7000-AAS | |
| 4991-AS7000-AA1V4EC7TR-ND | AS7000-AA1V4EC7 | |
| 160-LTR-578ALS-02-ND | LTR-578ALS-02 | |
| 296-POPT4001DNPTQ1-ND | POPT4001DNPTQ1 | |
| 160-LTR-F216ATR-ND | LTR-F216A |
Key Considerations and Selection Tips for Ambient Light Sensors
There are different types of ambient light sensors available in the market and each of them works on different mechanisms and possess different properties. Care should be taken while choosing such a sensor for a particular application. The spectral response of an ambient light sensor is also an important factor to be considered.
If the temperature fluctuates within a wide range, then temperature stability should also be taken into account for reliable performance of the sensor. Some sensors are more sensitive to temperature variations, so performance with each sensor may vary in fluctuating temperature environments.
If the application requires long term usage of the sensor, then durability and stability must be taken into consideration. If the sensor is being used in a portable application, then its power consumption is a key factor in making a choice for a particular sensor. If high-precision light sensing is required, consider the sensor’s calibration needs. Some sensors may require regular calibration to ensure accuracy.
