American Zettler AZ2100 Relay Current Rating
Understanding the current rating capability for these relays by matching with what your application use is with the different ratings found on the datasheet.
Determining the current rating for example part number 3385-AZ2100-1AE-110DEF-ND
This Form A relay has max rating listed on the DigiKey websitefor the resistive load condition at 250VAC 40A. Marked on the part however is the Inductive load rating for 277VAC 30A.
Datasheet - AZ2100 Data Sheet
Note the different applications under the load type such as Resistive, Inductive, ballast ect. Each contact form having voltage ratings, expected number of cycles and the current rating.
Applicable Part Numbers
| 3385-AZ2100-1AE-5DEF-ND | AZ2100-1AE-5DEF |
| 3385-AZ2100-1A-24DE-ND | AZ2100-1A-24DE |
| 3385-AZ2100-1AE-15DE-ND | AZ2100-1AE-15DE |
| 3385-AZ2100-1A-12DEF-ND | AZ2100-1A-12DEF |
| 3385-AZ2100-1A-24DEF-ND | AZ2100-1A-24DEF |
| 3385-AZ2100-1CE-5DEF-ND | AZ2100-1CE-5DEF |
| 3385-AZ2100-1AE-24DEF-ND | AZ2100-1AE-24DEF |
| 3385-AZ2100-1CE-12DEF-ND | AZ2100-1CE-12DEF |
| 3385-AZ2100-1CE-24DEF-ND | AZ2100-1CE-24DEF |
| 3385-AZ2100-1C-12DEF-ND | AZ2100-1C-12DEF |
| 3385-AZ2100-1AE-110DEF-ND | AZ2100-1AE-110DEF |
| 3385-AZ2100-1AE-12DE-ND | AZ2100-1AE-12DE |
| 3385-AZ2100-1A-5DE-ND | AZ2100-1A-5DE |
| 3385-AZ2100-1AE-6DE-ND | AZ2100-1AE-6DE |
| 3385-AZ2100-1AE-5DE-ND | AZ2100-1AE-5DE |
| 3385-AZ2100-1AE-24DE-ND | AZ2100-1AE-24DE |
| 3385-AZ2100-1A-6DE-ND | AZ2100-1A-6DE |
| 3385-AZ2100-1AE-18DE-ND | AZ2100-1AE-18DE |
| 3385-AZ2100-1A-18DEF-ND | AZ2100-1A-18DEF |
| 3385-AZ2100-1CE-12DE-ND | AZ2100-1CE-12DE |
| 3385-AZ2100-1C-18DEF-ND | AZ2100-1C-18DEF |
| 3385-AZ2100-1AE-12DEF-ND | AZ2100-1AE-12DEF |
| 3385-AZ2100-1A-12DE-ND | AZ2100-1A-12DE |
| 3385-AZ2100-1C-24DEF-ND | AZ2100-1C-24DEF |
| 3385-AZ2100-1CE-110DEF-ND | AZ2100-1CE-110DEF |
| 3385-AZ2100-1AE-12D-ND | AZ2100-1AE-12D |
| 3385-AZ2100-1A-12D-ND | AZ2100-1A-12D |
| 3385-AZ2100-1AE-6D-ND | AZ2100-1AE-6D |
| 3385-AZ2100-1A-6D-ND | AZ2100-1A-6D |
| 3385-AZ2100-1A-5D-ND | AZ2100-1A-5D |
| 3385-AZ2100-1AE-9DE-ND | AZ2100-1AE-9DE |
| 3385-AZ2100-1A-9DE-ND | AZ2100-1A-9DE |
| 3385-AZ2100-1AE-5D-ND | AZ2100-1AE-5D |
| 3385-AZ2100-1AE-24D-ND | AZ2100-1AE-24D |
| 3385-AZ2100-1AE-15D-ND | AZ2100-1AE-15D |
| 3385-AZ2100-1AE-18D-ND | AZ2100-1AE-18D |
| 3385-AZ2100-1A-15D-ND | AZ2100-1A-15D |
| 3385-AZ2100-1A-18D-ND | AZ2100-1A-18D |
| 3385-AZ2100-1A-24D-ND | AZ2100-1A-24D |
| 3385-AZ2100-1A-15DE-ND | AZ2100-1A-15DE |
| 3385-AZ2100-1A-18DE-ND | AZ2100-1A-18DE |
| 3385-AZ2100-1AE-18DEF-ND | AZ2100-1AE-18DEF |
| 3385-AZ2100-1AE-15DF-ND | AZ2100-1AE-15DF |
| 3385-AZ2100-1A-24DF-ND | AZ2100-1A-24DF |
| 3385-AZ2100-1A-15DF-ND | AZ2100-1A-15DF |
| 3385-AZ2100-1AE-24DF-ND | AZ2100-1AE-24DF |
| 3385-AZ2100-1AE-36DE-ND | AZ2100-1AE-36DE |
| 3385-AZ2100-1A-48DE-ND | AZ2100-1A-48DE |
| 3385-AZ2100-1AE-48DE-ND | AZ2100-1AE-48DE |
| 3385-AZ2100-1AE-48D-ND | AZ2100-1AE-48D |
| 3385-AZ2100-1B-12DE-ND | AZ2100-1B-12DE |
| 3385-AZ2100-1AE-110DE-ND | AZ2100-1AE-110DE |
| 3385-AZ2100-1A-70D-ND | AZ2100-1A-70D |
| 3385-AZ2100-1A-110D-ND | AZ2100-1A-110D |
| 3385-AZ2100-1A-110DE-ND | AZ2100-1A-110DE |
| 3385-AZ2100-1A-110DEF-ND | AZ2100-1A-110DEF |
| 3385-AZ2100-1A-36DE-ND | AZ2100-1A-36DE |
| 3385-AZ2100-1A-48D-ND | AZ2100-1A-48D |
| 3385-AZ2100-1AE-110D-ND | AZ2100-1AE-110D |
| 3385-AZ2100-1CE-24DE-ND | AZ2100-1CE-24DE |
| 3385-AZ2100-1CE-24D-ND | AZ2100-1CE-24D |
| 3385-AZ2100-1C-18D-ND | AZ2100-1C-18D |
| 3385-AZ2100-1C-24D-ND | AZ2100-1C-24D |
| 3385-AZ2100-1C-18DE-ND | AZ2100-1C-18DE |
| 3385-AZ2100-1CE-15D-ND | AZ2100-1CE-15D |
| 3385-AZ2100-1C-15DF-ND | AZ2100-1C-15DF |
| 3385-AZ2100-1C-6DE-ND | AZ2100-1C-6DE |
| 3385-AZ2100-1C-24DE-ND | AZ2100-1C-24DE |
| 3385-AZ2100-1C-5D-ND | AZ2100-1C-5D |
| 3385-AZ2100-1C-6D-ND | AZ2100-1C-6D |
| 3385-AZ2100-1C-5DE-ND | AZ2100-1C-5DE |
| 3385-AZ2100-1CE-6DE-ND | AZ2100-1CE-6DE |
| 3385-AZ2100-1CE-18D-ND | AZ2100-1CE-18D |
| 3385-AZ2100-1C-15DE-ND | AZ2100-1C-15DE |
| 3385-AZ2100-1CE-15DF-ND | AZ2100-1CE-15DF |
| 3385-AZ2100-1CE-15DE-ND | AZ2100-1CE-15DE |
| 3385-AZ2100-1CE-18DE-ND | AZ2100-1CE-18DE |
| 3385-AZ2100-1CE-5D-ND | AZ2100-1CE-5D |
| 3385-AZ2100-1C-15D-ND | AZ2100-1C-15D |
| 3385-AZ2100-1CE-6D-ND | AZ2100-1CE-6D |
| 3385-AZ2100-1CE-5DE-ND | AZ2100-1CE-5DE |
| 3385-AZ2100-1C-12DE-ND | AZ2100-1C-12DE |
| 3385-AZ2100-1CE-12D-ND | AZ2100-1CE-12D |
| 3385-AZ2100-1CE-9DE-ND | AZ2100-1CE-9DE |
| 3385-AZ2100-1C-9DE-ND | AZ2100-1C-9DE |
| 3385-AZ2100-1C-12D-ND | AZ2100-1C-12D |
| 3385-AZ2100-1CE-24DF-ND | AZ2100-1CE-24DF |
| 3385-AZ2100-1CE-22DF-ND | AZ2100-1CE-22DF |
| 3385-AZ2100-1CE-18DEF-ND | AZ2100-1CE-18DEF |
| 3385-AZ2100-1C-22DF-ND | AZ2100-1C-22DF |
| 3385-AZ2100-1C-24DF-ND | AZ2100-1C-24DF |
| 3385-AZ2100-1CE-48D-ND | AZ2100-1CE-48D |
| 3385-AZ2100-1AE-70D-ND | AZ2100-1AE-70D |
| 3385-AZ2100-1C-70D-ND | AZ2100-1C-70D |
| 3385-AZ2100-1C-48DE-ND | AZ2100-1C-48DE |
| 3385-AZ2100-1C-48D-ND | AZ2100-1C-48D |
| 3385-AZ2100-1C-36DE-ND | AZ2100-1C-36DE |
| 3385-AZ2100-1CE-110DE-ND | AZ2100-1CE-110DE |
| 3385-AZ2100-1CE-48DE-ND | AZ2100-1CE-48DE |
| 3385-AZ2100-1CE-110D-ND | AZ2100-1CE-110D |
| 3385-AZ2100-1C-110DE-ND | AZ2100-1C-110DE |
| 3385-AZ2100-1C-110D-ND | AZ2100-1C-110D |
| 3385-AZ2100-1C-110DEF-ND | AZ2100-1C-110DEF |
| 3385-AZ2100-1CE-36DE-ND | AZ2100-1CE-36DE |
