I am trying to identify the proper replacement o-ring for an Amphenol RJF connector.
Hello and welcome to the Digi-Key Tech Forum,
It would be helpful if you could post a picture of what you’re needing. The RJF connector accessories do not list O rings as an option.
I believe you might be looking for something like:
RJF54402JE or JE19
Below is a link of all RJF accessories we carry.
https://www.digikey.com/en/products/filter/modular-connectors-accessories/442?s=N4IgjCBcoCwOxVAYygMwIYBsDOBTANCAPZQDaIAzHAGxwwUiEUCccYcArI5a%2B9dyzZwETXnAAcAscyltxABllhxEUXIBMS8QwC6hAA4AXKCADKhgE4BLAHYBzEAF9HhLtBD6o6g58jqOzkA
Hope that helps.
We have part RJF6MB in stock currently but unfortunately its O ring seal is not sold as a separate entity. There also seems to be no documentation within the data sheet on the size of the o ring specifically.
We have O rings available for purchase in the link below.
https://www.digikey.com/en/products/filter/accessories/569?s=N4IgTCBcDaIPYAIBOBLAdgcxAXQDQgFYpQAHKARnxLMjAIF96g
Unfortunately there are no options from Amphenol but there is an O ring size chart from Boyd in the link below that may help.
o ring chart creative 2.0 (digikey.com)
OK, thank you. I was hoping you would have a resource at Amphenol that may help identify the proper size. I will continue this search through other avenues.
