A few years ago, I was doing a number of projects with the MICRF102, so it made sense to design my own little breakout board. It worked well, but then the MICRF102 was discontinued.
I’ve searched but can’t find the answer to a simple question: Is there an equivalent to this chip? For instance, if it turns out that the MICRF102 can be swapped out for the MICRF112, then I can keep using my circuit design.
I really don’t want to have to re-invent the wheel if I don’t have to!
Thank you.
MICRF112YMM is listed as a possible alternate but you will need to review the linked data to verify it will work in your application.
https://www.digikey.com/en/products/detail/microchip-technology/MICRF112YMM/1640429
