Need help to find about the IC on picture
It is 6SC2 C0VQ
Welcome to the techforum!
I searched through our system trying to match this part but i was not able to locate a suitable alternate to offer. Hopefully someone else can add some info but I was not able to locate this.
Thank you
Ryan
Hello bpotmhenos,
The 6SC2 microcircuit is made by Micrel company.
I did not find a datasheet for the 6SC2 microcircuit.
But, I found an analogue - this is SI4010-C2 (Silicon Labs).
I have attached the datasheet for SI4010-C2
You can buy this chip on DigiKey:
SI4010-C2.pdf (3,6 МБ)
Hello!
Thank you guys for replying.
@Adam7 , yes that part is very similar according to datasheet. Pin 2 in my pcb i GND and pin 5 is VDD and pin 3 and 4 connected to antenna. (TXN and TXP)
So I can actually use this IC.
Now my question is - can I upload HEX file onto this Si4010-C2 chip? I found that there is some kind of software from Silicon labs that need to be used in this case as well as SL programmer.
You help is extremelly appreciated!!
I’m not familiar with the programming of this chip, but maybe one of the engineers may have some knowledge on this.
