I need any information about the ERX02-120 diode from Fuji Electric Corp.
Datasheet or Specifications, how the diode is located inside the case, what is the analogue, etc.
Thank you.
Hi, Adam7. I did some searching around but I also came up with no leads for technical specifications or a datasheet for this part. The only consistent information was the description of “diode” and the fact that it’s a TO-263.
I know this is a bit odd, but I found this PDF from ST that matched the search for the ERX02-120. It could be something ST made to compete with Fuji: STPR1620
This may also be a possibility. It shares a very similar part number: Vishay V20DM120
I hope this is helpful.
Mike
