Sometimes you may find that some of the EcoFlex® series cables from Alpha Wire have different jacket (Insulation) wall thickness depoending on which spot in the jacket you inspect.
For example, the part number 79021 SL005:
For reference, check this photo:
Alpha Wire confirms that this is not a defect because the jacket wall thickness is nominal, it is not a minimum. It is not a tube-style jacket because it is extruded over the wires, so it will get thinner or thicker as it is molded around the wires.
Applicable part numbers
79050SL005-ND
79052SL005-ND
79003SL005-ND
A79019S-100-ND
79058SL005-ND
79121SL005-ND
79057SL005-ND
79257SL005-ND
79228SL001-ND
79051SL005-ND
79044SL005-ND
79001SL005-ND
79010SL005-ND
79059SL005-ND
79028SL005-ND
79202SL005-ND
79252SL005-ND
79012SL005-ND
79116SL005-ND
79044SL001-ND
79255SL005-ND
79122SL005-ND
79052SL001-ND
79010SL001-ND
79062SL005-ND
79046SL005-ND
79053SL005-ND
79060SL005-ND
79247SL005-ND
79014SL005-ND
79046SL001-ND
79061SL005-ND
79045SL005-ND
79256SL005-ND
79054SL005-ND
79258SL005-ND
79004SL005-ND
79020SL005-ND
79013SL005-ND
79246SL005-ND
79029SL005-ND
79259SL005-ND
79006SL005-ND
79253SL005-ND
79211SL005-ND
79104SL005-ND
79117SL005-ND
79219SL005-ND
79051SL001-ND
79254SL005-ND
79007SL005-ND
79015SL005-ND
79001SL001-ND
79031SL005-ND
79038SL005-ND
79053SL001-ND
79012SL001-ND
79260SL005-ND
79032SL005-ND
79047SL001-ND
79055SL001-ND
79222SL005-ND
79222SL001-ND
79225SL005-ND
79244SL005-ND
79021SL005-ND
79118SL005-ND
79002SL005-ND
79054SL001-ND
79003SL001-ND
79048SL001-ND
79047SL005-ND
79109SL005-ND
79048SL005-ND
79055SL005-ND
79056SL005-ND
79261SL005-ND
79262SL005-ND
79011SL005-ND
79245SL005-ND
79201SL005-ND
79102SL005-ND
79210SL005-ND
79218SL005-ND
79103SL005-ND
79203SL005-ND
79110SL005-ND
79050SL001-ND
79049SL005-ND
79030SL005-ND
79111SL005-ND
79037SL005-ND
79248SL005-ND
79058SL001-ND
79226SL005-ND
79002SL001-ND
79008SL005-ND
79004SL001-ND
79251SL005-ND
79005SL005-ND
79011SL001-ND
79056SL001-ND
79062SL001-ND
79057SL001-ND
79045SL001-ND
79261SL001-ND
79061SL199-ND
79257SL001-ND
79056SL199-ND
79251SL001-ND
79050SL199-ND
79060SL001-ND
79062SL199-ND
79057SL199-ND
79028SL001-ND
79051SL199-ND
79044SL199-ND
79109SL001-ND
79246SL001-ND
79058SL199-ND
79001SL199-ND
79013SL001-ND
79005SL001-ND
79052SL199-ND
79201SL001-ND
79102SL001-ND
79019SL001-ND
79259SL001-ND
79253SL001-ND
79261SL199-ND
79045SL199-ND
79250SL005-ND
79020SL001-ND
79010SL199-ND
79256SL199-ND
79116SL001-ND
79104SL001-ND
79002SL199-ND
79203SL001-ND
79250SL199-ND
79218SL001-ND
79006SL001-ND
79247SL001-ND
79046SL199-ND
79110SL001-ND
79059SL199-ND
79260SL001-ND
79211SL001-ND
79053SL199-ND
79254SL001-ND
79111SL001-ND
79262SL199-ND
79003SL199-ND
79244SL199-ND
79212SL001-ND
79257SL199-ND
79117SL001-ND
79030SL001-ND
79251SL199-ND
79121SL001-ND
79014SL001-ND
79219SL001-ND
79011SL199-ND
79101SL199-ND
79047SL199-ND
79225SL001-ND
79205SL001-ND
79112SL001-ND
79201SL199-ND
79245SL199-ND
79015SL001-ND
79060SL199-ND
79102SL199-ND
79118SL001-ND
79224SL005-ND
79054SL199-ND
79028SL199-ND
79109SL199-ND
79258SL199-ND
79202SL199-ND
79122SL001-ND
79023SL001-ND
79252SL199-ND
79249SL001-ND
79004SL199-ND
79210SL199-ND
79038SL001-ND
79031SL001-ND
79048SL199-ND
79012SL199-ND
79206SL001-ND
79113SL001-ND
79016SL001-ND
79019SL199-ND
79119SL001-ND
79221SL001-ND
79116SL199-ND
79020SL199-ND
79107SL001-ND
79013SL199-ND
79055SL199-ND
79024SL001-ND
79246SL199-ND
79120SL001-ND
79218SL199-ND
79207SL001-ND
79005SL199-ND
79103SL199-ND
79114SL001-ND
79008SL001-ND
79021SL199-ND
79123SL001-ND
79039SL001-ND
79203SL199-ND
79029SL199-ND
79110SL199-ND
79259SL199-ND
79227SL001-ND
79006SL199-ND
79253SL199-ND
79124SL001-ND
79211SL199-ND
79108SL001-ND
79049SL199-ND
79121SL199-ND
79022SL199-ND
79115SL001-ND
79025SL001-ND
79208SL001-ND
79247SL199-ND
79225SL199-ND
79104SL199-ND
79216SL001-ND
79125SL001-ND
79014SL199-ND
79127SL001-ND
79030SL199-ND
79117SL199-ND
79204SL199-ND
79229SL001-ND
79111SL199-ND
79233SL001-ND
79037SL199-ND
79260SL199-ND
79219SL199-ND
79017SL001-ND
79212SL199-ND
79254SL199-ND
79112SL005-ND
79007SL199-ND
79105SL199-ND
79023SL005-ND
79015SL199-ND
79016SL005-ND
79112SL199-ND
79205SL199-ND
79031SL199-ND
79255SL199-ND
79248SL199-ND
79041SL005-ND
79220SL005-ND
79023SL199-ND
79249SL005-ND
79213SL199-ND
79118SL199-ND
79122SL199-ND
79038SL199-ND
79016SL199-ND
79206SL005-ND
79041SL199-ND
79220SL199-ND
79119SL005-ND
79226SL199-ND
79113SL005-ND
79106SL199-ND
79249SL199-ND
79024SL005-ND
79039SL005-ND
79206SL199-ND
79123SL005-ND
79008SL199-ND
79119SL199-ND
79113SL199-ND
79042SL005-ND
79126SL005-ND
79024SL199-ND
79039SL199-ND
79221SL199-ND
79214SL199-ND
79232SL005-ND
79123SL199-ND
79207SL005-ND
79114SL005-ND
79042SL199-ND
79126SL199-ND
79032SL199-ND
79107SL199-ND
79227SL199-ND
79228SL005-ND
79120SL005-ND
79215SL005-ND
79232SL199-ND
79124SL199-ND
79207SL199-ND
79114SL199-ND
79043SL005-ND
79228SL199-ND
79017SL005-ND
79215SL199-ND
79033SL005-ND
79222SL199-ND
79115SL005-ND
79025SL199-ND
79040SL005-ND
79043SL199-ND
79233SL005-ND
79017SL199-ND
79216SL005-ND
79236SL005-ND
79208SL005-ND
79033SL199-ND
79127SL199-ND
79115SL199-ND
79108SL199-ND
79040SL199-ND
79223SL005-ND
79233SL199-ND
79216SL199-ND
79236SL199-ND
79208SL199-ND
79229SL005-ND
79223SL199-ND
79234SL005-ND
79125SL199-ND
79229SL199-ND
79237SL005-ND
79217SL005-ND
79234SL199-ND
79034SL199-ND
79237SL199-ND
79217SL199-ND
79224SL199-ND
79026SL005-ND
79230SL199-ND
79026SL199-ND
79231SL005-ND
79235SL199-ND
79231SL199-ND
79035SL005-ND
79035SL199-ND
79101SL005-ND
79061SL001-ND
79022SL005-ND
79204SL005-ND
79212SL005-ND
79105SL005-ND
79205SL005-ND
79213SL005-ND
79106SL005-ND
79256SL001-ND
79250SL001-ND
79221SL005-ND
79214SL005-ND
79107SL005-ND
79227SL005-ND
79124SL005-ND
79262SL001-ND
79059SL001-ND
79244SL001-ND
79025SL005-ND
79127SL005-ND
79245SL001-ND
79108SL005-ND
79258SL001-ND
79252SL001-ND
79125SL005-ND
79034SL005-ND
79101SL001-ND
79210SL001-ND
79230SL005-ND
79202SL001-ND
79103SL001-ND
79049SL001-ND
79235SL005-ND
79204SL001-ND
79021SL001-ND
79022SL001-ND
79029SL001-ND
79105SL001-ND
79255SL001-ND
79007SL001-ND
79213SL001-ND
79037SL001-ND
79248SL001-ND
79220SL001-ND
79106SL001-ND
79226SL001-ND
79214SL001-ND
79041SL001-ND
79215SL001-ND
79032SL001-ND
79126SL001-ND
79232SL001-ND
79223SL001-ND
216-79042SL001-ND
216-79033SL001-ND
216-79043SL001-ND
216-79217SL001-ND
216-79040SL001-ND
216-79236SL001-ND
216-79224SL001-ND
216-79034SL001-ND
216-79237SL001-ND
216-79234SL001-ND
216-79230SL001-ND
216-79026SL001-ND
216-79231SL001-ND
216-79235SL001-ND
216-79035SL001-ND
79050 SL005
79052 SL005
79003 SL005
79019 SL005
79058 SL005
79121 SL005
79057 SL005
79257 SL005
79228 SL001
79051 SL005
79044 SL005
79001 SL005
79010 SL005
79059 SL005
79028 SL005
79202 SL005
79252 SL005
79012 SL005
79116 SL005
79044 SL001
79255 SL005
79122 SL005
79052 SL001
79010 SL001
79062 SL005
79046 SL005
79053 SL005
79060 SL005
79247 SL005
79014 SL005
79046 SL001
79061 SL005
79045 SL005
79256 SL005
79054 SL005
79258 SL005
79004 SL005
79020 SL005
79013 SL005
79246 SL005
79029 SL005
79259 SL005
79006 SL005
79253 SL005
79211 SL005
79104 SL005
79117 SL005
79219 SL005
79051 SL001
79254 SL005
79007 SL005
79015 SL005
79001 SL001
79031 SL005
79038 SL005
79053 SL001
79012 SL001
79260 SL005
79032 SL005
79047 SL001
79055 SL001
79222 SL005
79222 SL001
79225 SL005
79244 SL005
79021 SL005
79118 SL005
79002 SL005
79054 SL001
79003 SL001
79048 SL001
79047 SL005
79109 SL005
79048 SL005
79055 SL005
79056 SL005
79261 SL005
79262 SL005
79011 SL005
79245 SL005
79201 SL005
79102 SL005
79210 SL005
79218 SL005
79103 SL005
79203 SL005
79110 SL005
79050 SL001
79049 SL005
79030 SL005
79111 SL005
79037 SL005
79248 SL005
79058 SL001
79226 SL005
79002 SL001
79008 SL005
79004 SL001
79251 SL005
79005 SL005
79011 SL001
79056 SL001
79062 SL001
79057 SL001
79045 SL001
79261 SL001
79061 SL199
79257 SL001
79056 SL199
79251 SL001
79050 SL199
79060 SL001
79062 SL199
79057 SL199
79028 SL001
79051 SL199
79044 SL199
79109 SL001
79246 SL001
79058 SL199
79001 SL199
79013 SL001
79005 SL001
79052 SL199
79201 SL001
79102 SL001
79019 SL001
79259 SL001
79253 SL001
79261 SL199
79045 SL199
79250 SL005
79020 SL001
79010 SL199
79256 SL199
79116 SL001
79104 SL001
79002 SL199
79203 SL001
79250 SL199
79218 SL001
79006 SL001
79247 SL001
79046 SL199
79110 SL001
79059 SL199
79260 SL001
79211 SL001
79053 SL199
79254 SL001
79111 SL001
79262 SL199
79003 SL199
79244 SL199
79212 SL001
79257 SL199
79117 SL001
79030 SL001
79251 SL199
79121 SL001
79014 SL001
79219 SL001
79011 SL199
79101 SL199
79047 SL199
79225 SL001
79205 SL001
79112 SL001
79201 SL199
79245 SL199
79015 SL001
79060 SL199
79102 SL199
79118 SL001
79224 SL005
79054 SL199
79028 SL199
79109 SL199
79258 SL199
79202 SL199
79122 SL001
79023 SL001
79252 SL199
79249 SL001
79004 SL199
79210 SL199
79038 SL001
79031 SL001
79048 SL199
79012 SL199
79206 SL001
79113 SL001
79016 SL001
79019 SL199
79119 SL001
79221 SL001
79116 SL199
79020 SL199
79107 SL001
79013 SL199
79055 SL199
79024 SL001
79246 SL199
79120 SL001
79218 SL199
79207 SL001
79005 SL199
79103 SL199
79114 SL001
79008 SL001
79021 SL199
79123 SL001
79039 SL001
79203 SL199
79029 SL199
79110 SL199
79259 SL199
79227 SL001
79006 SL199
79253 SL199
79124 SL001
79211 SL199
79108 SL001
79049 SL199
79121 SL199
79022 SL199
79115 SL001
79025 SL001
79208 SL001
79247 SL199
79225 SL199
79104 SL199
79216 SL001
79125 SL001
79014 SL199
79127 SL001
79030 SL199
79117 SL199
79204 SL199
79229 SL001
79111 SL199
79233 SL001
79037 SL199
79260 SL199
79219 SL199
79017 SL001
79212 SL199
79254 SL199
79112 SL005
79007 SL199
79105 SL199
79023 SL005
79015 SL199
79016 SL005
79112 SL199
79205 SL199
79031 SL199
79255 SL199
79248 SL199
79041 SL005
79220 SL005
79023 SL199
79249 SL005
79213 SL199
79118 SL199
79122 SL199
79038 SL199
79016 SL199
79206 SL005
79041 SL199
79220 SL199
79119 SL005
79226 SL199
79113 SL005
79106 SL199
79249 SL199
79024 SL005
79039 SL005
79206 SL199
79123 SL005
79008 SL199
79119 SL199
79113 SL199
79042 SL005
79126 SL005
79024 SL199
79039 SL199
79221 SL199
79214 SL199
79232 SL005
79123 SL199
79207 SL005
79114 SL005
79042 SL199
79126 SL199
79032 SL199
79107 SL199
79227 SL199
79228 SL005
79120 SL005
79215 SL005
79232 SL199
79124 SL199
79207 SL199
79114 SL199
79043 SL005
79228 SL199
79017 SL005
79215 SL199
79033 SL005
79222 SL199
79115 SL005
79025 SL199
79040 SL005
79043 SL199
79233 SL005
79017 SL199
79216 SL005
79236 SL005
79208 SL005
79033 SL199
79127 SL199
79115 SL199
79108 SL199
79040 SL199
79223 SL005
79233 SL199
79216 SL199
79236 SL199
79208 SL199
79229 SL005
79223 SL199
79234 SL005
79125 SL199
79229 SL199
79237 SL005
79217 SL005
79234 SL199
79034 SL199
79237 SL199
79217 SL199
79224 SL199
79026 SL005
79230 SL199
79026 SL199
79231 SL005
79235 SL199
79231 SL199
79035 SL005
79035 SL199
79101 SL005
79061 SL001
79022 SL005
79204 SL005
79212 SL005
79105 SL005
79205 SL005
79213 SL005
79106 SL005
79256 SL001
79250 SL001
79221 SL005
79214 SL005
79107 SL005
79227 SL005
79124 SL005
79262 SL001
79059 SL001
79244 SL001
79025 SL005
79127 SL005
79245 SL001
79108 SL005
79258 SL001
79252 SL001
79125 SL005
79034 SL005
79101 SL001
79210 SL001
79230 SL005
79202 SL001
79103 SL001
79049 SL001
79235 SL005
79204 SL001
79021 SL001
79022 SL001
79029 SL001
79105 SL001
79255 SL001
79007 SL001
79213 SL001
79037 SL001
79248 SL001
79220 SL001
79106 SL001
79226 SL001
79214 SL001
79041 SL001
79215 SL001
79032 SL001
79126 SL001
79232 SL001
79223 SL001
79042 SL001
79033 SL001
79043 SL001
79217 SL001
79040 SL001
79236 SL001
79224 SL001
79034 SL001
79237 SL001
79234 SL001
79230 SL001
79026 SL001
79231 SL001
79235 SL001
79035 SL001
