Hello!
We bought the AMT49406 demoboard and the available datasheet told me there were an application note, a configuration guide and a GUI for tuning and programming the IC. Where can I find them? Allegro does not answer by now.
Thank you!
Hello!
Thank you!
Hi @MF3 , you might have to sign up into this portal:
https://www.allegromicro.com/en/products/motor-drivers/bldc-drivers/amt49406#Packaging
Regards,
Hi!
They answered, that’s the correct way to do it, thank you!
The link above shows no datasheets nor GUI application right now. I think they have deleted those documents for some reason.
Thank you for your inquiry and welcome to the community!
I was able to track down Application Note AN296259. As of at least 2022 Allegro required registration/logging into the Allegro Software Portal to access that data per the references section of the above App Note.
If after logging if the documents/program are not otherwise available, you’ll want to request access from Allegro.
