Art of Electronics - Components for Lab Course
Learning the Art of Electronics: A Hands-On Lab Course is an introduction to circuit design that offers not just explanations, but a full course. Each of the twenty-five sessions begins with a discussion of a particular sort of circuit followed by the chance to try it out and see how it actually behaves. The full course is divided into two sections – Analog and Digital Circuit Design.
Digi-Key offers lab kits for either course individually or a combined kit for both courses. The kits include most of the Bill of Materials (BOM) needed to successfully complete the requirements for the course. Additional information, including complete parts lists and substitutions, can be found at Parts Lists | Learning the Art of Electronics: A Hands-on Approach
The following Analog and Digital Components Lists are for the Second Edition of Learning the Art of Electronics. These are the products you’ll need to complete the courses in the current version of the book.
2nd ED Analog Lab Kit Component Shopping Cart - Click Here
Analog Lab Kit Component List
Note: Obsolete, Unavailable, and Replacement Products
SD101A-TAPGICT-ND substitutes for the increasingly pricy 1N5711
4316-E-701-ND substitutes for 1N5294.
CA3096E: This is a 16-DIP 3 NPN + 2 PNP BJT array. No equivalent is available in DigiKey’s system. The official parts list from Learning the Art of Electronics recommends using discrete 2N3904 and 2N3906 transistors to replace this array if necessary.
IRL3705NPBF-ND substitutes for obsolete and difficult-to-locate device IRL2505PBF
J210 TO-92 3L ROHS substitutes for obsolete and difficult-to-locate device 2N5485
505-MAX74810ARMZ-ND substitutes for LT6020HMS8#PBF, at the original author’s discretion.
DG403DJ is obsolete. It’s recommended to check the Art of Electronics parts lists linked above for other substitutions.
2451-344-ND is offered as a replacement for JKL’s 344 incandescent bulb. 2451-344-ND is a DigiKey Marketplace product with unpredictable availability. A #7344 lamp may be substituted.
Analog panel ammeter 85C1-A is unavailable from DigiKey with no equivalent option, and will have to be sourced elsewhere.
RS125-KIT-ND is added to the list as an easy-to-order kit containing many common values between 1 ohm and 1 Megaohm. While not strictly part of the BOM for the coursework, this resistor kit should be much easier than individually buying dozens and dozens of individual part numbers for individual resistor values.
5221-RC-10-ND is added to the list for the same purpose as RS125-KIT-ND.
Part Number Manufacturer Part Number
237-1917-ND F-14X
811-2058-ND 13R106C
AIUR-06-101K-ND AIUR-06-101K
399-10820-ND B-20F-46
SW263CT-ND B3F-6000
668-1296-ND AOM-6738P-R
1528-2435-ND 1314
1N5817-TPCT-ND 1N5817-TP
SD101A-TAPGICT-ND SD101A-TAP
1N4148FS-ND 1N4148
641-1999-ND 1N4004B-G
1N5223B-ND 1N5223B
1N5232B-ND 1N5232B
150-1N5294-ND 1N5294
1514-2N3904PBFREE-ND 2N3904 PBFREE
1N5817DICT-ND 1N5817-T
641-1946-ND 2N3906-G
MJE3055TGOS-ND MJE3055TG
MJE2955TGOS-ND MJE2955TG
2N3904TAFSCT-ND 2N3904TA
ZVP3306A-ND ZVP3306A
IRLZ34NPBF-ND IRLZ34NPBF
IRF3205ZPBF-ND IRF3205ZPBF
296-3501-5-ND CD4007UBE
4004-J210TO-923LROHS-ND J210 TO-92 3L ROHS
MCR218-4GOS-ND MCR218-4G
296-26079-5-ND LF411CP
LM741CNNS/NOPB-ND LM741CN/NOPB
296-1395-5-ND LM358P
LMC6482AIN/NOPB-ND LMC6482AIN/NOPB
LMC662CN/NOPB-ND LMC662CN/NOPB
LT1215CN8#PBF-ND LT1215CN8#PBF
LTC1150CN8#PBF-ND LTC1150CN8#PBF
LT6020HMS8#PBF-ND LT6020HMS8#PBF
296-1389-5-ND LM311P
296-1845-5-ND TLC372CP
497-12403-ND LM317T-DG
LM385BLPE3-2-5-ND LM385BLPE3-2-5
497-2952-ND L78L05ACZ
LT1073CN8#PBF-ND LT1073CN8#PBF
2156-DG403DJ-ND DG403DJ
296-1857-5-ND TLC555CP
MAX294CPA±ND MAX294CPA+
LM4667MM/NOPBCT-ND LM4667MM/NOPB
PA0027-ND PA0027
LT1167IN8#PBF-ND LT1167IN8#PBF
TC74HC14APF-ND TC74HC14APF
505-AD630JNZ-ND AD630JNZ
CM47-ND 47
2451-344-ND 344
516-1347-ND HLMP-3950
1080-1061-ND HLMP4700
C566C-AFF-CU0W0252CT-ND C566C-AFF-CU0W0252
160-1602-ND LTL1CHTBK4
TSTS7100-ND TSTS7100
475-SFH4554-ND SFH 4554
751-1003-ND BPV11
QSD123-ND QSD123
HS251-ND 575200B00000G
1528-1150-ND 711
1528-4540-ND 4540
1568-13879-ND SEN-13879
RS125-KIT-ND RS125
3.3MQBK-ND CFR-25JB-52-3M3
10MQBK-ND CFR-25JB-52-10M
10W-5-ND SQP500JB-10R
10.0KXBK-ND MFR-25FBF52-10K
100KXBK-ND MFR-25FBF52-100K
3386P-1-103TLF-ND 3386P-1-103TLF
987-1065-ND 64WR2KLF
1568-09806-ND 09806
3386F-1-153LF-ND 3386F-1-153LF
3386P-1-104TLF-ND 3386P-1-104TLF
3386P-1-105TLF-ND 3386P-1-105TLF
4809-RK16812MG099-ND RK16812MG099
91A1A-B16-B10L-ND 91A1A-B16-B10L
1001-2001-ND CK05BX100K
EF2104-ND ECQ-E2104KF
399-R82EC1100SH50JCT-ND R82EC1100SH50J
338-3275-ND 150103K630BB
1572-1637-ND 104MPW160K
224MWR400K-ND 224MWR400K
399-11513-ND R82DC3330Z360J
399-12645-ND R82EC4100Z370K
478-1907-ND TAP475K035SCS
478-6062-ND TAP106M035SCS
478-1859-ND TAP156K025SCS
478-9332-ND TAP107K020HSB
1189-1300-ND 35ZLH100MEFC6.3X11
P16292-ND 16SEPC100MW
2nd ED Digital Lab Kit Component Shopping Cart - Click Here
Digital Lab Kit Component List
1N5711MS substitutes for the obsolete STMicro version of the diode.
The WebFPGA software used by the lab is not available through DigiKey. The book’s authors recommend EDA Playground as a possible alternative.
2156-SN74LS469AFN-ND is a DigiKey Marketplace product with unpredictable availability. No strong replacement is readily available.
DM74LS503N-ND is a DigiKey Marketplace product with unpredictable availability. No strong replacement is readily available.
SW263CT-ND B3F-6000
EG1218-ND EG1218
2223-DS04-254-1L-04BK-ND DS04-254-1L-04BK
Z8676-ND SS-01GL30PT
27899PAR-ND 27899
2223-CEM-1205-IC-ND CEM-1205-IC
1528-2435-ND 1314
1528-1013-ND 1063
1N5711MS-ND 1N5711
4316-E-701-ND E-701
1N5230B-ND 1N5230B
VN2222LL-G-ND VN2222LL-G
1568-1327-ND 13664
609-3712-ND 20021111-00010T4LF
S1011EC-24-ND PRPC024SAAN-RC
899-8.08.91-ND 8.08.91
296-1626-ND SN74LS00N
296-1563-5-ND SN74HC00N
296-1564-5-ND SN74HC02N
TC74HC04APF-ND TC74HC04APF
296-1605-5-ND SN74HCT04N
296-1570-5-ND SN74HC08N
296-8214-5-ND SN74HC10N
296-1602-5-ND SN74HC74N
296-8375-5-ND SN74HC86N
296-8244-5-ND SN74HC161N
296-8246-5-ND SN74HC163N
296-3663-5-ND SN74LS169BN
296-33038-5-ND CD74HC175E
296-1619-5-ND SN74HCT541N
296-1623-5-ND SN74HCT574N
296-8324-5-ND SN74HC4040N
296-9208-5-ND CD74HC4046AE
296-9213-5-ND CD74HC4050E
296-24383-5-ND TLC5916IN
23K256-I/P-ND 23K256-I/P
AD558JNZ-ND AD558JNZ
MCP41010-I/P-ND MCP41010-I/P
296-43960-5-ND LM386N-4/NOPB
MCP4802-E/P-ND MCP4802-E/P
MCP4902-E/P-ND MCP4902-E/P
1080-1063-ND HLMP4740
1568-LCD-16396-ND 16396
1528-161-ND 161
TSOP38438-ND TSOP38438
1528-389-ND 389
RS125-KIT-ND RS125
51KQBK-ND CFR-25JB-52-51K
4.7MQBK-ND CFR-25JB-52-4M7
3386P-1-102TLF-ND 3386P-1-102TLF
1568-1616-ND 09806
1528-1076-ND 169
237-1917-ND F-14X
2nd ED Combined Analog and Digital Shopping Cart - Click Here
Combined Component List
1N5711MS-ND substitutes for the obsolete STMicro version 497-2499-1-ND
1N5294 is unavailable in small quantities at DigiKey. Consider 4316-E-701-ND as a roughly equivalent alternative.
CA3096E: This is a 16-DIP 3 NPN + 2 PNP BJT array. No equivalent is available in DigiKey’s system. The official parts list from Learning the Art of Electronics recommends using discrete 2N3904 and 2N3906 transistors to replace this array if necessary, and as such 2N3904 is added to these lists.
IRF3205ZPBF-ND substitutes for obsolete and difficult-to-locate device IRL2505PBF
2156-DG403DJ-ND is offered as an alternative for DG403DJ-E3, which is obsolete with no extant replacement. 2156-DG403DJ-ND is a DigiKey marketplace product with unpredictable availability, as the base DG403DJ part number is largely obsolete and only available from suppliers specializing in legacy components.
2451-344-ND is offered as a replacement for JKL’s 344 incandescent bulb. 2451-344-ND is a DigiKey Marketplace product with unpredictable availability. Incandescent bulbs in general are becoming difficult to find, as LEDs largely replace them in a growing list of applications.
RL81C101MDN1KX substitutes for the NRND 16SEPC100MW, from Panasonic.
237-1917-ND F-14X
811-2058-ND 13R106C
SW263CT-ND B3F-6000
1528-2435-ND 1314
1N5711MS-ND 1N5711
1N4148FS-ND 1N4148
1N5223B-ND 1N5223B
1N5232B-ND 1N5232B
PA0027-ND PA0027
CM47-ND 47
2451-344-ND 344
751-1003-ND BPV11
QSD123-ND QSD123
1528-1150-ND 711
1528-4540-ND 4540
RS125-KIT-ND RS125
1568-09806-ND 09806
EG1903-ND EG1218
27899PAR-ND 27899
1528-1013-ND 1063
1N5230B-ND 1N5230B
1568-1327-ND 13664
8.08.91 J-LINK EDU MINI 8.08.91
497-1491-5-ND LD1117V33
1568-LCD-16396-ND 16398
TDCG1050M-ND TDCG1050M
1528-161-ND 161
1528-389-ND 389
1528-1076-ND 169
The following Analog and Digital Components Lists are for the First Edition of Learning the Art of Electronics. If you have an older first-edition version of this book, these lists will help you complete these courses, but note that as the industry marches ever onwards, these products may become less available and the First Edition book’s lessons - especially the digital side - may become less applicable.
1st ED Analog Lab Kit Component Shopping Cart - Click Here
Note: Obsolete part and substitute
MJE2955TTUFS-ND substitute MJE2955TGOS-ND
LM78L05ACZFS-ND substitute MC78L05ABPGOS-ND
NDP6020P-ND substitute IRF5305PBF-ND
102-1124-ND substitute 458-1064-ND
CM47-ND 47
811-2058-ND 13R106C
EG1903-ND EG1218
CKN10157-ND ZMA00A150L04PC
679-2424-ND MJTP1212
3352T-102LF-ND 3352T-1-102LF
3352T-103LF-ND 3352T-1-103LF
3352T-104LF-ND 3352T-1-104LF
3352T-105LF-ND 3352T-1-105LF
1N914BCT-ND 1N914BTR
1N4004DICT-ND 1N4004-T
1N5232BVSCT-ND 1N5232B-TR
2N3904D26ZCT-ND 2N3904TFR
2N3906D26ZCT-ND 2N3906TFR
QSD124-ND QSD124
IRLZ34PBF-ND IRLZ34PBF
BS250P-ND BS250P
DG403CJ±ND DG403CJ+
LMC6482IN/NOPB-ND LMC6482IN/NOPB
LM317HVT/NOPB-ND LM317HVT/NOPB
296-31451-1-ND LM385LPR-2-5
BC1030CT-ND K100J15C0GF5TH5
1572-1263-ND 104MWR400K
338-3914-ND 150334J400IE
399-11374-1-ND T322B105K035AT7200
478-7381-1-ND TAP475K016SRW
478-1856-ND TAP156K010SCS
RS125-ND RS125
A102130-ND HSA2510RJ
PPC5W33.0CT-ND AC05000003309JAC00
1572-1004-ND 103MWR630K
67-1001-ND OED-EL-1L2
CKN1595-ND KS12R22CQD
MC78L05ABPGOS-ND MC78L05ABPG
IRF5305PBF-ND IRF5305PBF
458-1064-ND PB-12N23P-05Q
1st ED Digital Lab Kit Component Shopping Cart - Click Here
EG1903-ND EG1218
450-1364-ND 1825057-3
3352T-1-103LF-ND 3352T-1-103LF
3352T-1-104LF-ND 3352T-1-104LF
3352T-1-105LF-ND 3352T-1-105LF
516-2483-1-ND HLMP-4700-C0002
160-1057-ND LTL-30EHJ
BS250P-ND BS250P
DG403CJ±ND DG403CJ+
XC268-ND ECS-2200B-110.5
CTX743-ND MXO45HS-3C-8M000000
X1064-ND ECS-110.5-S-4X
296-1566-5-ND SN74HC04N
296-1572-5-ND SN74HC125N
296-8257-5-ND SN74HC175N
296-33033-5-ND CD74HC163E
296-8394-5-ND SN74HCT14N
296-8386-5-ND SN74HCT125N
296-8390-5-ND SN74HCT139N
296-1621-5-ND SN74HCT573N
A33179-ND 5103310-1
DS89C430-MNG±ND DS89C430-MNG+
MCP41100-I/P-ND MCP41100-I/P
MXD1210CPA±ND MXD1210CPA+
TSOP31240-ND TSOP31240
BC1011CT-ND K680J15C0GF5TL2
450-1366-ND 1825057-7
160-1130-ND LTL-4233
A9AAT-0803F-ND A9AAT-0803F
A9AAT-0808F-ND A9AAT-0808F
296-1577-5-ND SN74HC14N
67-1119-ND SSL-LX5093XGC
DAC0800LCN/NOPB-ND DAC0800LCN/NOPB
VAOL-5LSBY2-ND VAOL-5LSBY2
C566D-AFE-CV0X0251-ND C566D-AFE-CV0X0251
BC2665CT-ND K104K10X7RF5UH5
MJE2955TGOS-ND MJE2955TG Substitute for MJE2955TTUFS-ND
IRF5305PBF-ND IRF5305PBF Substitute for NDP6020P-ND
458-1064-ND PB-12N23P-05Q Substitute for 102-1124-ND
1st ED Combined Analog and Digital Shopping Cart - Click Here
RS125-ND RS125
QSD124-ND QSD124
811-2058-ND 13R106C
CM47-ND 47
A33179-ND 5103310-1
DG403CJ±ND DG403CJ+
EG1903-ND EG1218
BS250P-ND BS250P
MC78L05ABPGOS-ND MC78L05ABPG Substitute for LM78L05ACZFS-ND
Is this page still valid? https://www.digikey.com/en/resources/edu/harvard-lab-kit The bom links there fail with obsolete parts, and some of the links on that page are dead too.
Hello @Nashenas,
Unfortunately, the original BOMs listed on that page have many parts that have gone obsolete and were built on an old system. The links posted above in this post were updated in 2023 with current parts and could be added to a cart.
-Robert
It seems 1N4004DICT-ND and DS89C430-MNG±ND are now obsolete. Are 1N4004GDICT-ND and DS89C430-MNL±ND good alternatives?
Also does it make sense to swap in A105545-ND and LT1110CS8#PBF-ND paired with
DKS-ADPT-01-ND for items the items that are backordered for several months?
1N4004GDICT-ND is the Mfg recommended substitute for 1N4004DICT-ND.
DS89C430-MNL-ND is a Direct replacement for DS89C430-MNG-ND. Only difference I noticed, is it has a higher Max speed of 33MHz, instead of 25MHz.
For swapping is A105545-ND, LT1110CS8#PBF-ND and DKS-ADPT-01-ND for other items, it depends on what items they are replacing.
Any list with updated part for both analog and digital labs? I just got the book and I wanna roder the kit
Hi, I am also curious to whether there is an updated parts list available. Cheers.
Hello lah706,
I do not see any updates for the list of parts.
@Jeff_2258 @David_1768 can the list be updated please?
Most of the parts I checked on the Analog Labs are coming back in stock. If you find any that aren’t available post them here and we can see if there are substitutes.
One example MJE2955TG is out of stock but MJE2955T would work as a replacement.
For an alternate for KS12R22CQD we have KS12R21CQD
For an alternate for TSOP31240 we have TSOP38240
For an alternate for 1N4004-T we have 1N4004G-T
There is a few components obsolete from the combined kit
IRLZ34PBF-ND = IRFZ24PBF-ND
DS89C430-MNG±ND Direct = 2156-DS89C430-MNG-DS-ND Alternative = AT89C55WD-24PU-ND
1N4004-T Direct = 1N4004G-T
TSOP31240-ND Alternative = TSOP38240-ND
CKN1595-ND Alternative = 360-3950-ND
Please review the datasheet before ordering
