What is the part number of the contacts for the connector VC1-01 from Carling Technologies?
60295-2 from TE Connectivity and similar will work. Make sure the one you choose has the retention tang for use in Quick Connect terminal boots and housings.
While the answer above is still valid and applicable, this link will bring you to a set of search results that will show somewhere around 70 part numbers. This way you can choose the material, plating, and wire size.
Product Index > Connectors, Interconnects > Terminals > Quick Connects, Quick Disconnect Connectors
