When looking at ATP Industrial Grade Compact Flash, one common question we often see at DigiKey is ‘What is the meaning of this “-OEM” suffix in this ATP part number?’
For example, ATP part number AF8GCFI-OEM has an “-OEM” suffix at DigiKey.
Please note that the ATP part numbers stocked at Digikey with the “OEM” suffix are intended to be “BOM Agnostic” in that they cover several different BOM’s with that suffix. Usually the primary difference is in a specific firmware revision. As firmware / controller revisions are constantly being cycled, the only way we can stock product without dealing with substantial stock rotations is to have a “generic” suffix, i.e. the “OEM” suffix.
If you need to order your exact part, including the specified firmware revision, please feel free to consult DigiKey anytime.
Applicable Part Numbers
AF8GCFP3-OEM AF1GCFI-OEM AF2GCFI-OEM
AF4GCFI-OEM AF8GCFI-OEM AF32GCFI-OEM
AF512CFI-OEM AF256CFI-OEM AF4GCFP-OEM
AF16GCFP7-OEM AF32GCFP7-OEM AF16GCFI-OEM
AF128CFI-OEM
AF128CFI-OEM-ND AF16GCFI-OEM-ND AF16GCFP7-OEM-ND
AF1GCFI-OEM-ND AF256CFI-OEM-ND AF2GCFI-OEM-ND
AF32GCFI-OEM-ND AF32GCFP7-OEM-ND AF4GCFI-OEM-ND
AF4GCFP-OEM-ND AF512CFI-OEM-ND AF8GCFI-OEM-ND
AF8GCFP3-OEM-ND
