Zach,
Thank you for a great article. I found it very helpful.
Several follow up questions:
- Did you launch the app from within the Arduino App Lab? …or did you use another method? CLI? SSH?
I could not get the image results windows to display.
Thank you for your help.
Steve B
Nathan,
Thank you! I have looked at the github code, it compiles but does not show the image results frame.
Thank you,
Steve
Okay, maybe Zach Hipps would be able to provide more guidance on the project.
Nathan,
Will you forward the e-mail to him?
Steve
I don’t have a direct e-mail to Zach.
However this conversation is showing up on that article page so I am thinking that he may see it.
I however have asked about this inquiry internally.
Nathan,
Thank you for your help!
Steve
Update, I have been told that Zach has been notified. I am not sure on the ETA of response though.
So sorry for the delayed response! I haven’t figured out how to get App Lab’s python scripts to open a USB camera image. So in the meantime I launch from the CLI using python3 main.py. I hope this helps
Thank you! I’ve been doing some background work. I’ll share what I find. Thank you for a great article!
Follow up question…did you use opencv or opencv-headless?
I think just the regular opencv library
Zach,
Thank you again for a great article. I was able to image a resistor today.
Here are a few additional configuration notes that might be helpful.
- Use Arduino UNO Q in single-board computer configuration.
- Used a Celestron USB microscope.
- Used CLI at ArduinoAppLab Linux OS prompt to issue commands to Arduino UNO Q.
- Installed opencv from root. Did not use within virtual environment.
- Executed program from Linux command line using CLI and command “python3 main.py”
Steve
