------Question for AZ2150-1A-24DETF Please Put your question below------
is it available to order? I am in Canada, how much for 1 piece?
You will have to contact our Orders department at orders@digikey.com for this information.
The part, AZ2150-1A-24DETF, is available of the Canadian digikey.ca site. You will have to logged in to request a quote for this part, as it is not a normally stock part. There is a note that the minimum order quantity for this part must meet the manufactures standard package quantity. If you scroll down to the bottom of the page, the quantity is listed as 40 pcs.
At this time an order for 1 pc isn’t an option available.
Hi globalcellphonerepai ,
If you can consider an alternative part, the J115F11A24VDCSH.6 has some very similar specifications, including the high 4000V contact-to-coil isolation, in the same form-factor and is available in quantity 1 or more.
Of course, one should compare the respective datasheets to ensure compatibility.
