When looking at the part number for SMT ceramic capacitors from KYOCERA AVX, you may spot a suffix “A” after the part number you’re searching for.
AVX’s documentation confirms this is a ‘no special’ Special Code. If the datasheet list this out as “Std. Product”, it denotes a standard catalog part number. No special requirements needed.
