B73180A0101M062 - UN 38.3 TEST RAPPORT SUMMARY
------Question for B73180A0101M062 Please Put your question below------
Is it possilble to get UN 38.3 TEST RAPPORT SUMMARY whit thid Item?
Hello @evy.johansen,
Thank you for your post.
I have requested this information from the manufacturer and will respond once I have that.
I just heard back from the manufacturer, and they would need your order information before they can provide that report.
So essentially, they do not give that out unless you have ordered the part.
Okay, thank you for your information.
I just wonder if it was possible to get this report along with this Item.
So, the way I interpret your answer, is that you can provide this report after we purchased the item.
That is correct, you can get that information if you order the part.
Okay, thank you for your quick replay.
FYI: I will send a PO on this Item tomorrow, and add a note that we need this report provided.
Thanks’ again.
