BBB: About setting up display of BBB
Hi I am using 7 inch LCD monitor using HDMI with Beaglebone black
I want to change display resolution
so I entered the following, but an error occurred.
debian@arm:~$ xrandr
Can't open display
debian@arm:~$ export DISPLAY=:0
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1024 x 600, current 1024 x 600, maximum 1024 x 600
default connected 1024x600+0+0 0mm x 0mm
   1024x600       0.00*
debian@arm:~$ xrandr -q | grep " connected"
debian@arm:~$ xrandr --output HDMI-0 --mode 1024x600 --rate 60
warning: output HDMI-0 not found; ignoring
debian@arm:~$
How can I fix this error message. xrandr: Failed to get size of gamma for output default
and how can I fix next error. warning: output HDMI-0 not found; ignoring
Can you resolve them for me?
and Can you help me to change display resolution?
It looks like your LCD only supports one mode, 1024x600 and doesn’t report Frequency nor anything else over the EDID bus… You could try a 5.10.x based kernel to see if there was a fix for this, or the hardware only reports resolution…
Regards,
Thank you for your help.
I will try it.
