BBB: Building and Rebuilding for arm-arch!
I know it is too late to reply. I am not expecting miracles since this is complicated and comes w/ years of experience from sources around the net, u-boot, and how u-boot signifies itself of am335x_evm_defconfig.
“I am on to something,” as usual but w/out working order, I am bit slow to duplicate for now.
Okay so!
I get a version of a cross-compiler (GCC), u-boot (u-boot), and a kernel set up (Linux).
I am testing now w/out any help. This is why I am reaching out:
‘generic-armv7-a’
The m-tune= ‘switch’ seems to want something outside of what is available, i.e. generic-armv7-a.
Anyway, I am sure someone is familiar w/ this issue as of the current, bleeding edge u-boot being shipped these days, along w/ an updated kernel, and no prior experience in building.
Seth
P.S. I am following along in your, whomever, eewiki Pages for the BBB. They seem very workable and well thought out but when I exchange out what you have produced w/ a new Kernel or u-boot version, I run into errors. Is this normal?
If you’d like assistance, it is best to post your actual build error. That way we can tell you exactly what went wrong…
Regards
@RobertCNelson ,
Yes sir…I will get to it again soon and then we can proceed.
Seth
P.S. Thank you!
@RobertCNelson ,
Sir…please forgive me. The uboot parameter that turns into the error no longer is present. I just built u-boot on master and it worked this time. I am not sure exactly what could have transpired between then and now but it works!
Seth
P.S. Thank you for taking time out to try to help when things already work.
