AM3352 stuck at "Loading Kernel..."
I don’t see a lot of activity here but I’ll give it go anyway since I’m out of ideas.
I have a custom AM3352 board that has a Microchip KSZ switch on it that I’m trying to get DSA to work with. I have an older 2019 u-boot/spl that I’ve been using on a couple AM3352 projects that I’ve found “just works.” I initially grabbed a 6.1 kernel from the TI BSP since that’s what I’ve always had the best luck with, everything boots up and is happy as can be, except the KSZ drivers don’t seem to work at all. kernel 6.6 and 6.7 have very significant revisions to these drivers.
Rootfs is a 12.1 minimal Debian from Robert’s repo.
I first tried a mainline 6.6. I don’t care about the PRU, power management or the couple other things that won’t work, as long as I can get the KSZ switch going. I copied my defconfig from an existing and pulled in my devicetree, evetything compiled smoothly, install my modules in my rootfs, u-boot hangs at “Loading Kernel…”
I scratched my head for a while and eventually came across Robert’s repo of patches and scripts and used that to download and patch 6.7, did my defconfig, devicetree, no issues compiling, same “Loading Kernel…” hang.
I’m at kind of a loss why 6.1 works perfect but 6.6 and 6.7 hang. Was there some change between those that I need to account for? Is my u-boot 2019 too old for 6.6 or 6.7? I’m stuck. Any suggestions are helpful.
Thanks,
I’ve only been doing basic testing of 6.6.x/6.6.x-rt… What are you bootargs, smells like the wrong serial driver is being passed…
My current testing: http://gfnd.rcn-ee.org:81/farm/uptime/192.168.2.27-bbb-6.6.12-bone7.txt and http://gfnd.rcn-ee.org:81/farm/uptime/192.168.2.28-bbb-6.6.12-bone-rt-r7.txt
Regards,
That was exactly one of my first thoughts but the system eventually times out and resets so I don’t know if the wrong serial port would cause it to completely hang or just not have any output. I’ll run over to the Linux box and get the bootargs.
Here’s the short version of my bootargs:
"kernel_addr=0x82000000\0" \
	"fdt_addr=0x88000000\0" \
	"bootdir=/boot\0" \
	"bootfile=zImage\0" \
	"console=ttyS0,115200n8\0" \
	"mmcrootfstype=ext4 rootwait\0" \
	"loadimage=load ${devtype} ${bootpart} ${kernel_addr} ${bootdir}/${bootfile}\0" \
	"loadfdt=load ${devtype} ${bootpart} ${fdt_addr} ${bootdir}/${fdtfile}\0" \
	"finduuid=part uuid ${devtype} ${bootpart} uuid\0" \
	"import_script=env import -t ${script_addr} ${script_size}\0 " \
	"args_mmc="\
		"run finduuid; " \
		"${optargs} " \
		"setenv bootargs console=${console} " \
		"root=PARTUUID=${uuid} rw " \
		"rootfstype=${mmcrootfstype}\0 " \
And what I call to do the boot:
"mmc1_boot="\
		"echo Running MMC1 Boot;" \
		"mmc dev 1; " \
		"setenv devnum 1; " \
		"setenv bootpart 1:2; " \
		"setenv devtype mmc; " \
		"if run loadimage; then " \
			"run args_mmc; " \
			"run loadfdt; " \
			"bootz ${kernel_addr} - ${fdt_addr};" \
		"else " \
			"echo WARNING: Nothing found on MMC1;" \
		"fi\0 " \
Yeah that looks fine…
Trying to think of any other major changes in 6.6.x since 6.1.x… Can you share your defconfig?
defconfig_6.6.x.txt (202.5 KB)
Regards,
Defconfig for 6.7:
fpcr_defconfig (203.4 KB)
This is where I got this 6.7 kernel and patch set from: GitHub - RobertCNelson/bb-kernel at am33x-v6.7
The 6.6 was straight from mainline with no patches. Defconfig:
fpcr_defconfig (185.9 KB)
I was also using the toolchain from here: Debian: Getting Started with the BeagleBone
Which seems like it may be super old at this point?
./build_kernel.sh will pull specific tool-chains from Latest cross-compilers …
I honestly just used your sh to download the kernel and apply the patches. I then just did the build and everything manually from there.
I guess I should update the toolchain and try again?
Shouldn’t be needed… In the office, testing 6.6.x/6.7.x on a remote unit i have serial console too…
Board prior: http://gfnd.rcn-ee.org:81/farm/uptime/192.168.2.39-bbb-6.1.69-ti-r25.txt
debian@39-am335x-bbb:~/lab$ sudo apt install bbb.io-kernel-6.6-bone
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  libpruio-modules-6.6.15-bone8 linux-image-6.6.15-bone8
The following NEW packages will be installed:
  bbb.io-kernel-6.6-bone libpruio-modules-6.6.15-bone8
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 36.4 MB of archives.
After this operation, 53.6 MB of additional disk space will be used.
Do you want to continue? [Y/n]
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait uboot_detected_capes=BBORG_COMMS, coherent_pool=1M net.ifnames=0 rng_core.default_quality=100] ...
debug: [bootz 0x82000000 0x88080000:82cff9 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xad2200 ]
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Ramdisk to 8f7d3000, end 8ffffff9 ... OK
   Loading Device Tree to 8f7b7000, end 8f7d2322 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.6.15-bone8 (voodoo@rpi4b4g-06) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 PREEMPT Tue Feb 20 06:25:49 UTC 2024
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c000000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fefffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fefffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fefffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
Hm. So it fired right up? The plot thickens.
Full boot log: http://gfnd.rcn-ee.org:81/farm/uptime/192.168.2.39-bbb-6.6.15-bone8.txt
Trying 6.7.x…
debian@39-am335x-bbb:~/lab$ sudo apt-get install bbb.io-kernel-6.7-bone
  libpruio-modules-6.7.5-bone13 linux-image-6.7.5-bone13
  bbb.io-kernel-6.7-bone libpruio-modules-6.7.5-bone13
Need to get 36.7 MB of archives.
After this operation, 53.9 MB of additional disk space will be used.
Running uname_boot ...
loading /boot/vmlinuz-6.7.5-bone13 ...
11379200 bytes read in 728 ms (14.9 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/6.7.5-bone13/am335x-boneblack.dtb ...
99107 bytes read in 11 ms (8.6 MiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
uboot_overlays: [uboot_detected_capes=BBORG_COMMS,] ...
loading /boot/initrd.img-6.7.5-bone13 ...
8549498 bytes read in 548 ms (14.9 MiB/s)
debug: [bootz 0x82000000 0x88080000:82747a 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xada200 ]
   Loading Ramdisk to 8f7d8000, end 8ffff47a ... OK
   Loading Device Tree to 8f7bc000, end 8f7d7322 ... OK
Starting kernel ...
[    0.000000] Linux version 6.7.5-bone13 (voodoo@rpi4b4g-13) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 PREEMPT Tue Feb 20 02:29:39 UTC 2024
boot log: http://gfnd.rcn-ee.org:81/farm/uptime/192.168.2.39-bbb-6.7.5-bone13.txt
Regards,
I really appreciate you verifying. I’ll try again and follow your process closer and report back.
Comparing your config, try dropping… CONFIG_SERIAL_8250_DMA i had an issue with that before when TI originally pushed it to ti’s git branch…
You also have:
CONFIG_OMAP_WATCHDOG=m
Maybe move that in, i have it built-in… but at-least that’s why it reboots, module probably didn’t load…
Swap these two:
# CONFIG_MUSB_PIO_ONLY is not set
CONFIG_USB_TI_CPPI41_DMA=y
USB_TI_CPPI41_DMA is known busted on am335x, no matter how many patches they try to fix edge cases…
Regards,
so omap2plus_defconfig does have CONFIG_SERIAL_8250_DMA=y let’s see what happens on
debian@39-am335x-bbb:~/lab$ sudo apt-get install linux-image-6.8.0-rc5-omap2plus-r0
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 11.7 MB of archives.
Regards,
You are the man, Robert. I really appreciate all the effort.
no luck, it boots…
loading /boot/vmlinuz-6.8.0-rc5-omap2plus-r0 ...
5249432 bytes read in 338 ms (14.8 MiB/s)
loading /boot/dtbs/6.8.0-rc5-omap2plus-r0/am335x-boneblack.dtb ...
70112 bytes read in 12 ms (5.6 MiB/s)
loading /boot/initrd.img-6.8.0-rc5-omap2plus-r0 ...
7108164 bytes read in 457 ms (14.8 MiB/s)
debug: [bootz 0x82000000 0x88080000:6c7644 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x501998 ]
   Loading Ramdisk to 8f938000, end 8ffff644 ... OK
   Loading Device Tree to 8f923000, end 8f9371df ... OK
Starting kernel ...
[    0.000000] Linux version 6.8.0-rc5-omap2plus-r0 (voodoo@rpi4b4g-03) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1bookworm SMP Mon Feb 19 21:06:45 UTC 2024
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] percpu: Embedded 16 pages/cpu s35924 r8192 d21420 u65536
Here’s teh config diff…
diff --git a/patches/defconfig b/home/voodoo/Downloads/fpcr_defconfig(2)
index 32afd79..b1fcc4c 100644
--- a/patches/defconfig
+++ b/home/voodoo/Downloads/fpcr_defconfig(2)
@@ -1,22 +1,19 @@
 # Automatically generated file; DO NOT EDIT.
-# Linux/arm 6.8.0-rc6 Kernel Configuration
+# Linux/arm 6.6.0 Kernel Configuration
-CONFIG_CC_VERSION_TEXT="arm-linux-gnueabi-gcc (GCC) 13.2.0"
+CONFIG_CC_VERSION_TEXT="arm-linux-gnueabihf-gcc (Linaro GCC 6.5-2018.12) 6.5.0"
 CONFIG_CC_IS_GCC=y
-CONFIG_GCC_VERSION=130200
+CONFIG_GCC_VERSION=60500
 CONFIG_CLANG_VERSION=0
 CONFIG_AS_IS_GNU=y
-CONFIG_AS_VERSION=24100
+CONFIG_AS_VERSION=22700
 CONFIG_LD_IS_BFD=y
-CONFIG_LD_VERSION=24100
+CONFIG_LD_VERSION=22700
 CONFIG_LLD_VERSION=0
-CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
-CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
-CONFIG_GCC_ASM_GOTO_OUTPUT_WORKAROUND=y
-CONFIG_CC_HAS_ASM_INLINE=y
-CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
-CONFIG_PAHOLE_VERSION=124
+CONFIG_CC_CAN_LINK=y
+CONFIG_CC_CAN_LINK_STATIC=y
+CONFIG_PAHOLE_VERSION=0
 CONFIG_IRQ_WORK=y
 CONFIG_BUILDTIME_TABLE_SORT=y
 CONFIG_THREAD_INFO_IN_TASK=y
@@ -27,7 +24,7 @@ CONFIG_THREAD_INFO_IN_TASK=y
 CONFIG_INIT_ENV_ARG_LIMIT=32
 # CONFIG_COMPILE_TEST is not set
 # CONFIG_WERROR is not set
-CONFIG_LOCALVERSION=""
+CONFIG_LOCALVERSION="-fc-am335x"
 # CONFIG_LOCALVERSION_AUTO is not set
 CONFIG_BUILD_SALT=""
 CONFIG_HAVE_KERNEL_GZIP=y
@@ -59,7 +56,6 @@ CONFIG_AUDITSYSCALL=y
 CONFIG_GENERIC_IRQ_PROBE=y
 CONFIG_GENERIC_IRQ_SHOW=y
 CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
-CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
 CONFIG_GENERIC_IRQ_MIGRATION=y
 CONFIG_HARDIRQS_SW_RESEND=y
 CONFIG_GENERIC_IRQ_CHIP=y
@@ -146,11 +142,7 @@ CONFIG_GENERIC_SCHED_CLOCK=y
 # end of Scheduler features
-CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5"
 CONFIG_GCC11_NO_ARRAY_BOUNDS=y
-CONFIG_CC_NO_ARRAY_BOUNDS=y
-CONFIG_GCC_NO_STRINGOP_OVERFLOW=y
-CONFIG_CC_NO_STRINGOP_OVERFLOW=y
 CONFIG_CGROUPS=y
 CONFIG_PAGE_COUNTER=y
 # CONFIG_CGROUP_FAVOR_DYNMODS is not set
@@ -183,15 +175,7 @@ CONFIG_NET_NS=y
 # CONFIG_CHECKPOINT_RESTORE is not set
 # CONFIG_SCHED_AUTOGROUP is not set
 # CONFIG_RELAY is not set
-CONFIG_BLK_DEV_INITRD=y
-CONFIG_INITRAMFS_SOURCE=""
-CONFIG_RD_GZIP=y
-CONFIG_RD_BZIP2=y
-CONFIG_RD_LZMA=y
-CONFIG_RD_XZ=y
-CONFIG_RD_LZO=y
-CONFIG_RD_LZ4=y
-CONFIG_RD_ZSTD=y
+# CONFIG_BLK_DEV_INITRD is not set
 # CONFIG_BOOT_CONFIG is not set
 CONFIG_INITRAMFS_PRESERVE_MTIME=y
 CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
@@ -222,18 +206,18 @@ CONFIG_AIO=y
 CONFIG_IO_URING=y
 CONFIG_ADVISE_SYSCALLS=y
 CONFIG_MEMBARRIER=y
-CONFIG_KCMP=y
-CONFIG_RSEQ=y
-# CONFIG_DEBUG_RSEQ is not set
-CONFIG_CACHESTAT_SYSCALL=y
-# CONFIG_PC104 is not set
 CONFIG_KALLSYMS=y
 # CONFIG_KALLSYMS_SELFTEST is not set
 # CONFIG_KALLSYMS_ALL is not set
 CONFIG_KALLSYMS_BASE_RELATIVE=y
 CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
+CONFIG_KCMP=y
+CONFIG_RSEQ=y
+CONFIG_CACHESTAT_SYSCALL=y
+# CONFIG_DEBUG_RSEQ is not set
 CONFIG_HAVE_PERF_EVENTS=y
 CONFIG_PERF_USE_VMALLOC=y
+# CONFIG_PC104 is not set
 # Kernel Performance Events And Counters
@@ -258,8 +242,6 @@ CONFIG_KEXEC=y
 CONFIG_ARM=y
 CONFIG_ARM_HAS_GROUP_RELOCS=y
-CONFIG_ARM_DMA_USE_IOMMU=y
-CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8
 CONFIG_SYS_SUPPORTS_APM_EMULATION=y
 CONFIG_HAVE_PROC_CPU=y
 CONFIG_STACKTRACE_SUPPORT=y
@@ -295,9 +277,6 @@ CONFIG_ARCH_MULTI_V6_V7=y
 # CONFIG_ARCH_VIRT is not set
 # CONFIG_ARCH_AIROHA is not set
-# CONFIG_ARCH_RDA is not set
-# CONFIG_ARCH_SUNPLUS is not set
-# CONFIG_ARCH_UNIPHIER is not set
 # CONFIG_ARCH_ACTIONS is not set
 # CONFIG_ARCH_ALPINE is not set
 # CONFIG_ARCH_ARTPEC is not set
@@ -325,49 +304,30 @@ CONFIG_ARCH_OMAP=y
 # TI OMAP/AM/DM/DRA Family
-CONFIG_OMAP_HWMOD=y
-CONFIG_ARCH_OMAP2=y
-CONFIG_ARCH_OMAP3=y
-CONFIG_ARCH_OMAP4=y
-CONFIG_SOC_OMAP5=y
+# CONFIG_ARCH_OMAP2 is not set
+# CONFIG_ARCH_OMAP3 is not set
+# CONFIG_ARCH_OMAP4 is not set
+# CONFIG_SOC_OMAP5 is not set
 CONFIG_SOC_AM33XX=y
-CONFIG_SOC_AM43XX=y
-CONFIG_SOC_DRA7XX=y
+# CONFIG_SOC_AM43XX is not set
+# CONFIG_SOC_DRA7XX is not set
 CONFIG_ARCH_OMAP2PLUS=y
-CONFIG_OMAP_INTERCONNECT_BARRIER=y
 # TI OMAP2/3/4 Specific Features
 CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
 CONFIG_SOC_HAS_OMAP2_SDRC=y
-CONFIG_SOC_HAS_REALTIME_COUNTER=y
-CONFIG_POWER_AVS_OMAP=y
-CONFIG_POWER_AVS_OMAP_CLASS3=y
-# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
-# OMAP Core Type
-CONFIG_SOC_OMAP2420=y
-CONFIG_SOC_OMAP2430=y
-CONFIG_SOC_OMAP3430=y
-CONFIG_SOC_TI81XX=y
 # OMAP Legacy Platform Data Board Type
 CONFIG_MACH_OMAP_GENERIC=y
-CONFIG_MACH_OMAP2_TUSB6010=y
-CONFIG_MACH_NOKIA_N810=y
-CONFIG_MACH_NOKIA_N810_WIMAX=y
-CONFIG_MACH_NOKIA_N8X0=y
 # end of TI OMAP2/3/4 Specific Features
-# CONFIG_OMAP5_ERRATA_801819 is not set
 # end of TI OMAP/AM/DM/DRA Family
 # CONFIG_ARCH_QCOM is not set
+# CONFIG_ARCH_RDA is not set
 # CONFIG_ARCH_REALTEK is not set
 # CONFIG_ARCH_ROCKCHIP is not set
 # CONFIG_ARCH_S3C64XX is not set
@@ -377,8 +337,10 @@ CONFIG_MACH_NOKIA_N8X0=y
 # CONFIG_PLAT_SPEAR is not set
 # CONFIG_ARCH_STI is not set
 # CONFIG_ARCH_STM32 is not set
+# CONFIG_ARCH_SUNPLUS is not set
 # CONFIG_ARCH_SUNXI is not set
 # CONFIG_ARCH_TEGRA is not set
+# CONFIG_ARCH_UNIPHIER is not set
 # CONFIG_ARCH_U8500 is not set
 # CONFIG_ARCH_INTEGRATOR is not set
 # CONFIG_ARCH_REALVIEW is not set
@@ -390,7 +352,6 @@ CONFIG_MACH_NOKIA_N8X0=y
 # Processor Type
-CONFIG_CPU_V6=y
 CONFIG_CPU_V6K=y
 CONFIG_CPU_V7=y
 CONFIG_CPU_THUMB_CAPABLE=y
@@ -428,6 +389,7 @@ CONFIG_HARDEN_BRANCH_PREDICTOR=y
 CONFIG_HARDEN_BRANCH_HISTORY=y
 CONFIG_KUSER_HELPERS=y
 CONFIG_VDSO=y
+CONFIG_DMA_CACHE_RWFO=y
 CONFIG_OUTER_CACHE=y
 CONFIG_OUTER_CACHE_SYNC=y
 CONFIG_MIGHT_HAVE_CACHE_L2X0=y
@@ -442,14 +404,12 @@ CONFIG_ARM_L1_CACHE_SHIFT=6
 CONFIG_ARM_DMA_MEM_BUFFERABLE=y
 CONFIG_ARM_HEAVY_MB=y
 CONFIG_DEBUG_ALIGN_RODATA=y
-# CONFIG_ARM_ERRATA_326103 is not set
 CONFIG_ARM_ERRATA_411920=y
 CONFIG_ARM_ERRATA_430973=y
 CONFIG_ARM_ERRATA_643719=y
 CONFIG_ARM_ERRATA_720789=y
 CONFIG_ARM_ERRATA_754322=y
 # CONFIG_ARM_ERRATA_754327 is not set
-# CONFIG_ARM_ERRATA_364296 is not set
 # CONFIG_ARM_ERRATA_764369 is not set
 # CONFIG_ARM_ERRATA_764319 is not set
 CONFIG_ARM_ERRATA_775420=y
@@ -476,13 +436,12 @@ CONFIG_ARM_ERRATA_798181=y
 CONFIG_HAVE_SMP=y
 CONFIG_SMP=y
 CONFIG_SMP_ON_UP=y
+CONFIG_CURRENT_POINTER_IN_TPIDRURO=y
 CONFIG_IRQSTACKS=y
 CONFIG_ARM_CPU_TOPOLOGY=y
 # CONFIG_SCHED_MC is not set
 # CONFIG_SCHED_SMT is not set
-CONFIG_HAVE_ARM_SCU=y
 CONFIG_HAVE_ARM_ARCH_TIMER=y
-CONFIG_HAVE_ARM_TWD=y
 # CONFIG_MCPM is not set
 # CONFIG_BIG_LITTLE is not set
 CONFIG_VMSPLIT_3G=y
@@ -518,7 +477,8 @@ CONFIG_ALIGNMENT_TRAP=y
 # CONFIG_UACCESS_WITH_MEMCPY is not set
 # CONFIG_PARAVIRT is not set
 # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
-CONFIG_CC_HAVE_STACKPROTECTOR_TLS=y
+# CONFIG_XEN is not set
+CONFIG_STACKPROTECTOR_PER_TASK=y
 # end of Kernel Features
@@ -593,8 +553,6 @@ CONFIG_DT_IDLE_STATES=y
 CONFIG_ARM_CPUIDLE=y
 # end of ARM CPU Idle Drivers
-CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=y
 # end of CPU Idle
 # end of CPU Power Management
@@ -730,6 +688,7 @@ CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
 CONFIG_HAVE_GCC_PLUGINS=y
 CONFIG_GCC_PLUGINS=y
 # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
+CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y
 CONFIG_FUNCTION_ALIGNMENT=0
 # end of General architecture-dependent options
@@ -758,7 +717,6 @@ CONFIG_BLK_CGROUP_RWSTAT=y
 CONFIG_BLK_ICQ=y
 # CONFIG_BLK_DEV_BSGLIB is not set
 # CONFIG_BLK_DEV_INTEGRITY is not set
-CONFIG_BLK_DEV_WRITE_MOUNTED=y
 # CONFIG_BLK_DEV_ZONED is not set
 # CONFIG_BLK_DEV_THROTTLING is not set
 # CONFIG_BLK_WBT is not set
@@ -846,8 +804,9 @@ CONFIG_ZSMALLOC=m
 CONFIG_ZSMALLOC_CHAIN_SIZE=8
-# Slab allocator options
+# SLAB allocator options
+# CONFIG_SLAB_DEPRECATED is not set
 CONFIG_SLUB=y
 # CONFIG_SLUB_TINY is not set
 CONFIG_SLAB_MERGE_DEFAULT=y
@@ -856,7 +815,7 @@ CONFIG_SLAB_MERGE_DEFAULT=y
 # CONFIG_SLUB_STATS is not set
 CONFIG_SLUB_CPU_PARTIAL=y
 # CONFIG_RANDOM_KMALLOC_CACHES is not set
-# end of Slab allocator options
+# end of SLAB allocator options
 # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
 CONFIG_COMPAT_BRK=y
@@ -872,7 +831,6 @@ CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1
 # CONFIG_PAGE_REPORTING is not set
 CONFIG_MIGRATION=y
 CONFIG_CONTIG_ALLOC=y
-CONFIG_PCP_BATCH_SCALE_MAX=5
 CONFIG_BOUNCE=y
 # CONFIG_KSM is not set
 CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
@@ -895,8 +853,6 @@ CONFIG_MEMFD_CREATE=y
 # CONFIG_ANON_VMA_NAME is not set
 # CONFIG_USERFAULTFD is not set
 # CONFIG_LRU_GEN is not set
-CONFIG_ARCH_SUPPORTS_PER_VMA_LOCK=y
-CONFIG_PER_VMA_LOCK=y
 CONFIG_LOCK_MM_AND_FIND_VMA=y
@@ -1234,6 +1190,7 @@ CONFIG_NFT_BRIDGE_META=m
 CONFIG_NFT_BRIDGE_REJECT=m
 # CONFIG_NF_CONNTRACK_BRIDGE is not set
 # CONFIG_BRIDGE_NF_EBTABLES is not set
+# CONFIG_BPFILTER is not set
 # CONFIG_IP_DCCP is not set
 # CONFIG_IP_SCTP is not set
 # CONFIG_RDS is not set
@@ -1246,7 +1203,28 @@ CONFIG_BRIDGE_IGMP_SNOOPING=y
 CONFIG_BRIDGE_VLAN_FILTERING=y
 # CONFIG_BRIDGE_MRP is not set
 # CONFIG_BRIDGE_CFM is not set
-# CONFIG_NET_DSA is not set
+CONFIG_NET_DSA=m
+CONFIG_NET_DSA_TAG_NONE=m
+# CONFIG_NET_DSA_TAG_AR9331 is not set
+# CONFIG_NET_DSA_TAG_BRCM is not set
+# CONFIG_NET_DSA_TAG_BRCM_LEGACY is not set
+# CONFIG_NET_DSA_TAG_BRCM_PREPEND is not set
+# CONFIG_NET_DSA_TAG_HELLCREEK is not set
+# CONFIG_NET_DSA_TAG_GSWIP is not set
+# CONFIG_NET_DSA_TAG_DSA is not set
+# CONFIG_NET_DSA_TAG_EDSA is not set
+# CONFIG_NET_DSA_TAG_MTK is not set
+CONFIG_NET_DSA_TAG_KSZ=m
+# CONFIG_NET_DSA_TAG_OCELOT is not set
+# CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set
+# CONFIG_NET_DSA_TAG_QCA is not set
+# CONFIG_NET_DSA_TAG_RTL4_A is not set
+# CONFIG_NET_DSA_TAG_RTL8_4 is not set
+# CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set
+# CONFIG_NET_DSA_TAG_LAN9303 is not set
+# CONFIG_NET_DSA_TAG_SJA1105 is not set
+# CONFIG_NET_DSA_TAG_TRAILER is not set
+# CONFIG_NET_DSA_TAG_XRS700X is not set
 CONFIG_VLAN_8021Q=m
 # CONFIG_VLAN_8021Q_GVRP is not set
 # CONFIG_VLAN_8021Q_MVRP is not set
@@ -1454,15 +1432,14 @@ CONFIG_CFG80211_DEFAULT_PS=y
 # CONFIG_CFG80211_DEBUGFS is not set
 CONFIG_CFG80211_CRDA_SUPPORT=y
 CONFIG_CFG80211_WEXT=y
-CONFIG_LIB80211=m
-# CONFIG_LIB80211_DEBUG is not set
 CONFIG_MAC80211=m
 CONFIG_MAC80211_HAS_RC=y
 CONFIG_MAC80211_RC_MINSTREL=y
 CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
 CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
 # CONFIG_MAC80211_MESH is not set
-# CONFIG_MAC80211_LEDS is not set
+CONFIG_MAC80211_LEDS=y
+# CONFIG_MAC80211_DEBUGFS is not set
 # CONFIG_MAC80211_MESSAGE_TRACING is not set
 # CONFIG_MAC80211_DEBUG_MENU is not set
 CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
@@ -1530,22 +1507,18 @@ CONFIG_VGA_ARB_MAX_GPUS=16
 # CONFIG_PCIE_CADENCE_PLAT_HOST is not set
 # CONFIG_PCIE_CADENCE_PLAT_EP is not set
+# CONFIG_PCI_J721E_HOST is not set
+# CONFIG_PCI_J721E_EP is not set
 # end of Cadence-based PCIe controllers
 # DesignWare-based PCIe controllers
-CONFIG_PCIE_DW=y
-CONFIG_PCIE_DW_HOST=y
-CONFIG_PCIE_DW_EP=y
 # CONFIG_PCI_MESON is not set
 # CONFIG_PCI_LAYERSCAPE is not set
 # CONFIG_PCI_LAYERSCAPE_EP is not set
 # CONFIG_PCIE_DW_PLAT_HOST is not set
 # CONFIG_PCIE_DW_PLAT_EP is not set
-CONFIG_PCI_DRA7XX=y
-CONFIG_PCI_DRA7XX_HOST=y
-CONFIG_PCI_DRA7XX_EP=y
 # end of DesignWare-based PCIe controllers
@@ -1621,6 +1594,7 @@ CONFIG_GENERIC_ARCH_TOPOLOGY=y
 # Bus devices
+# CONFIG_BRCMSTB_GISB_ARB is not set
 # CONFIG_MOXTET is not set
 CONFIG_OMAP_INTERCONNECT=y
 CONFIG_OMAP_OCP2SCP=y
@@ -1653,12 +1627,6 @@ CONFIG_CONNECTOR=m
 # CONFIG_FW_CFG_SYSFS is not set
 # CONFIG_TRUSTED_FOUNDATIONS is not set
 # CONFIG_GOOGLE_FIRMWARE is not set
-# Qualcomm firmware drivers
-# end of Qualcomm firmware drivers
 CONFIG_HAVE_ARM_SMCCC=y
@@ -1674,6 +1642,7 @@ CONFIG_MTD=y
 # Partition parsers
+# CONFIG_MTD_AR7_PARTS is not set
 CONFIG_MTD_CMDLINE_PARTS=y
 CONFIG_MTD_OF_PARTS=y
 # CONFIG_MTD_AFS_PARTS is not set
@@ -1760,7 +1729,6 @@ CONFIG_MTD_NAND_CORE=y
 CONFIG_MTD_ONENAND=y
 CONFIG_MTD_ONENAND_VERIFY_WRITE=y
 # CONFIG_MTD_ONENAND_GENERIC is not set
-CONFIG_MTD_ONENAND_OMAP2=y
 # CONFIG_MTD_ONENAND_OTP is not set
 # CONFIG_MTD_ONENAND_2X_PROGRAM is not set
 CONFIG_MTD_RAW_NAND=y
@@ -1841,7 +1809,6 @@ CONFIG_ZRAM_DEF_COMP_LZORLE=y
 # CONFIG_ZRAM_DEF_COMP_LZO is not set
 CONFIG_ZRAM_DEF_COMP="lzo-rle"
 CONFIG_ZRAM_WRITEBACK=y
-# CONFIG_ZRAM_TRACK_ENTRY_ACTIME is not set
 # CONFIG_ZRAM_MEMORY_TRACKING is not set
 # CONFIG_ZRAM_MULTI_COMP is not set
 CONFIG_BLK_DEV_LOOP=y
@@ -1888,19 +1855,20 @@ CONFIG_SENSORS_TSL2550=m
 CONFIG_SRAM=y
 CONFIG_SRAM_EXEC=y
 # CONFIG_DW_XDATA_PCIE is not set
-CONFIG_PCI_ENDPOINT_TEST=m
+# CONFIG_PCI_ENDPOINT_TEST is not set
 # CONFIG_XILINX_SDFEC is not set
+CONFIG_MISC_RTSX=m
 # CONFIG_HISI_HIKEY_USB is not set
 # CONFIG_OPEN_DICE is not set
 # CONFIG_VCPU_STALL_DETECTOR is not set
-# CONFIG_NSM is not set
 # CONFIG_C2PORT is not set
 # EEPROM support
-CONFIG_EEPROM_AT24=m
+CONFIG_EEPROM_AT24=y
 CONFIG_EEPROM_AT25=m
+# CONFIG_EEPROM_LEGACY is not set
 # CONFIG_EEPROM_MAX6875 is not set
 CONFIG_EEPROM_93CX6=y
 # CONFIG_EEPROM_93XX46 is not set
@@ -1923,7 +1891,7 @@ CONFIG_EEPROM_93CX6=y
 # CONFIG_BCM_VK is not set
 # CONFIG_MISC_ALCOR_PCI is not set
 # CONFIG_MISC_RTSX_PCI is not set
-# CONFIG_MISC_RTSX_USB is not set
+CONFIG_MISC_RTSX_USB=m
 # CONFIG_UACCE is not set
 # CONFIG_PVPANIC is not set
 # CONFIG_GP_PCI1XXXX is not set
@@ -2147,6 +2115,36 @@ CONFIG_NET_CORE=y
 # CONFIG_VIRTIO_NET is not set
 # CONFIG_NLMON is not set
 # CONFIG_ARCNET is not set
+# Distributed Switch Architecture drivers
+# CONFIG_B53 is not set
+# CONFIG_NET_DSA_BCM_SF2 is not set
+# CONFIG_NET_DSA_LOOP is not set
+# CONFIG_NET_DSA_LANTIQ_GSWIP is not set
+# CONFIG_NET_DSA_MT7530 is not set
+# CONFIG_NET_DSA_MV88E6060 is not set
+CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON=m
+# CONFIG_NET_DSA_MICROCHIP_KSZ9477_I2C is not set
+CONFIG_NET_DSA_MICROCHIP_KSZ_SPI=m
+CONFIG_NET_DSA_MICROCHIP_KSZ_PTP=y
+# CONFIG_NET_DSA_MICROCHIP_KSZ8863_SMI is not set
+# CONFIG_NET_DSA_MV88E6XXX is not set
+# CONFIG_NET_DSA_MSCC_OCELOT_EXT is not set
+# CONFIG_NET_DSA_MSCC_SEVILLE is not set
+# CONFIG_NET_DSA_AR9331 is not set
+# CONFIG_NET_DSA_QCA8K is not set
+# CONFIG_NET_DSA_SJA1105 is not set
+# CONFIG_NET_DSA_XRS700X_I2C is not set
+# CONFIG_NET_DSA_XRS700X_MDIO is not set
+# CONFIG_NET_DSA_REALTEK is not set
+# CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
+# CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
+# CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
+# CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
+# end of Distributed Switch Architecture drivers
 CONFIG_ETHERNET=y
 CONFIG_NET_VENDOR_3COM=y
 # CONFIG_VORTEX is not set
@@ -2219,7 +2217,11 @@ CONFIG_NET_VENDOR_ADI=y
 # CONFIG_ADIN1110 is not set
 CONFIG_NET_VENDOR_LITEX=y
 # CONFIG_LITEX_LITEETH is not set
-# CONFIG_NET_VENDOR_MARVELL is not set
+CONFIG_NET_VENDOR_MARVELL=y
+# CONFIG_MVMDIO is not set
+# CONFIG_SKGE is not set
+# CONFIG_SKY2 is not set
+# CONFIG_PRESTERA is not set
 CONFIG_NET_VENDOR_MELLANOX=y
 # CONFIG_MLX4_EN is not set
 # CONFIG_MLX5_CORE is not set
@@ -2230,7 +2232,12 @@ CONFIG_NET_VENDOR_MICREL=y
 CONFIG_KS8851=y
 CONFIG_KS8851_MLL=y
 # CONFIG_KSZ884X_PCI is not set
-# CONFIG_NET_VENDOR_MICROCHIP is not set
+CONFIG_NET_VENDOR_MICROCHIP=y
+# CONFIG_ENC28J60 is not set
+# CONFIG_ENCX24J600 is not set
+# CONFIG_LAN743X is not set
+# CONFIG_LAN966X_SWITCH is not set
+# CONFIG_VCAP is not set
 CONFIG_NET_VENDOR_MICROSEMI=y
 # CONFIG_MSCC_OCELOT_SWITCH is not set
 CONFIG_NET_VENDOR_MICROSOFT=y
@@ -2297,7 +2304,6 @@ CONFIG_NET_VENDOR_SYNOPSYS=y
 CONFIG_NET_VENDOR_TEHUTI=y
 # CONFIG_TEHUTI is not set
 CONFIG_NET_VENDOR_TI=y
-CONFIG_TI_DAVINCI_EMAC=y
 CONFIG_TI_DAVINCI_MDIO=y
 # CONFIG_TI_CPSW_PHY_SEL is not set
 CONFIG_TI_CPSW=y
@@ -2313,6 +2319,7 @@ CONFIG_NET_VENDOR_WANGXUN=y
 # CONFIG_NET_VENDOR_WIZNET is not set
 CONFIG_NET_VENDOR_XILINX=y
 # CONFIG_XILINX_EMACLITE is not set
+# CONFIG_XILINX_AXI_EMAC is not set
 # CONFIG_XILINX_LL_TEMAC is not set
 # CONFIG_FDDI is not set
 # CONFIG_HIPPI is not set
@@ -2351,7 +2358,7 @@ CONFIG_AX88796B_PHY=m
 # CONFIG_MEDIATEK_GE_PHY is not set
 CONFIG_MICREL_PHY=y
 # CONFIG_MICROCHIP_T1S_PHY is not set
-# CONFIG_MICROCHIP_PHY is not set
+CONFIG_MICROCHIP_PHY=y
 # CONFIG_MICROCHIP_T1_PHY is not set
 # CONFIG_MICROSEMI_PHY is not set
 # CONFIG_MOTORCOMM_PHY is not set
@@ -2360,7 +2367,7 @@ CONFIG_MICREL_PHY=y
 # CONFIG_NXP_C45_TJA11XX_PHY is not set
 # CONFIG_NXP_TJA11XX_PHY is not set
 # CONFIG_NCN26000_PHY is not set
-CONFIG_AT803X_PHY=y
+# CONFIG_AT803X_PHY is not set
 # CONFIG_QSEMI_PHY is not set
 # CONFIG_REALTEK_PHY is not set
 # CONFIG_RENESAS_PHY is not set
@@ -2370,11 +2377,10 @@ CONFIG_SMSC_PHY=y
 # CONFIG_TERANETICS_PHY is not set
 # CONFIG_DP83822_PHY is not set
 # CONFIG_DP83TC811_PHY is not set
-CONFIG_DP83848_PHY=y
-CONFIG_DP83867_PHY=y
+# CONFIG_DP83848_PHY is not set
+# CONFIG_DP83867_PHY is not set
 # CONFIG_DP83869_PHY is not set
 # CONFIG_DP83TD510_PHY is not set
-# CONFIG_DP83TG720_PHY is not set
 # CONFIG_VITESSE_PHY is not set
 # CONFIG_XILINX_GMII2RGMII is not set
 # CONFIG_MICREL_KS8995MA is not set
@@ -2518,109 +2524,26 @@ CONFIG_USB_CDC_PHONET=m
 # CONFIG_USB_NET_AQC111 is not set
 CONFIG_USB_RTL8153_ECM=m
 CONFIG_WLAN=y
-CONFIG_WLAN_VENDOR_ADMTEK=y
-# CONFIG_ADM8211 is not set
-CONFIG_WLAN_VENDOR_ATH=y
-# CONFIG_ATH_DEBUG is not set
-# CONFIG_ATH5K is not set
-# CONFIG_ATH5K_PCI is not set
-# CONFIG_ATH9K is not set
-# CONFIG_ATH9K_HTC is not set
-# CONFIG_CARL9170 is not set
-# CONFIG_ATH6KL is not set
-# CONFIG_AR5523 is not set
-# CONFIG_WIL6210 is not set
-# CONFIG_ATH10K is not set
-# CONFIG_WCN36XX is not set
-# CONFIG_ATH11K is not set
-# CONFIG_ATH12K is not set
-CONFIG_WLAN_VENDOR_ATMEL=y
-# CONFIG_AT76C50X_USB is not set
-CONFIG_WLAN_VENDOR_BROADCOM=y
-# CONFIG_B43 is not set
-# CONFIG_B43LEGACY is not set
-# CONFIG_BRCMSMAC is not set
-# CONFIG_BRCMFMAC is not set
-CONFIG_WLAN_VENDOR_INTEL=y
-# CONFIG_IPW2100 is not set
-# CONFIG_IPW2200 is not set
-# CONFIG_IWL4965 is not set
-# CONFIG_IWL3945 is not set
-# CONFIG_IWLWIFI is not set
-CONFIG_WLAN_VENDOR_INTERSIL=y
-# CONFIG_P54_COMMON is not set
-CONFIG_WLAN_VENDOR_MARVELL=y
-CONFIG_LIBERTAS=m
-CONFIG_LIBERTAS_USB=m
-CONFIG_LIBERTAS_SDIO=m
-# CONFIG_LIBERTAS_SPI is not set
-CONFIG_LIBERTAS_DEBUG=y
-# CONFIG_LIBERTAS_MESH is not set
-# CONFIG_LIBERTAS_THINFIRM is not set
-CONFIG_MWIFIEX=m
-CONFIG_MWIFIEX_SDIO=m
-# CONFIG_MWIFIEX_PCIE is not set
-CONFIG_MWIFIEX_USB=m
-# CONFIG_MWL8K is not set
-CONFIG_WLAN_VENDOR_MEDIATEK=y
-# CONFIG_MT7601U is not set
-# CONFIG_MT76x0U is not set
-# CONFIG_MT76x0E is not set
-# CONFIG_MT76x2E is not set
-# CONFIG_MT76x2U is not set
-# CONFIG_MT7603E is not set
-# CONFIG_MT7615E is not set
-# CONFIG_MT7663U is not set
-# CONFIG_MT7663S is not set
-# CONFIG_MT7915E is not set
-# CONFIG_MT7921E is not set
-# CONFIG_MT7921S is not set
-# CONFIG_MT7921U is not set
-# CONFIG_MT7996E is not set
-# CONFIG_MT7925E is not set
-# CONFIG_MT7925U is not set
-CONFIG_WLAN_VENDOR_MICROCHIP=y
-# CONFIG_WILC1000_SDIO is not set
-# CONFIG_WILC1000_SPI is not set
-CONFIG_WLAN_VENDOR_PURELIFI=y
-# CONFIG_PLFXLC is not set
-CONFIG_WLAN_VENDOR_RALINK=y
-# CONFIG_RT2X00 is not set
-CONFIG_WLAN_VENDOR_REALTEK=y
-# CONFIG_RTL8180 is not set
-# CONFIG_RTL8187 is not set
-CONFIG_RTL_CARDS=m
-# CONFIG_RTL8192CE is not set
-# CONFIG_RTL8192SE is not set
-# CONFIG_RTL8192DE is not set
-# CONFIG_RTL8723AE is not set
-# CONFIG_RTL8723BE is not set
-# CONFIG_RTL8188EE is not set
-# CONFIG_RTL8192EE is not set
-# CONFIG_RTL8821AE is not set
-# CONFIG_RTL8192CU is not set
-# CONFIG_RTL8XXXU is not set
-# CONFIG_RTW88 is not set
-# CONFIG_RTW89 is not set
-CONFIG_WLAN_VENDOR_RSI=y
-# CONFIG_RSI_91X is not set
-CONFIG_WLAN_VENDOR_SILABS=y
-# CONFIG_WFX is not set
-CONFIG_WLAN_VENDOR_ST=y
-# CONFIG_CW1200 is not set
-CONFIG_WLAN_VENDOR_TI=y
-CONFIG_WL1251=m
-CONFIG_WL1251_SPI=m
-# CONFIG_WL1251_SDIO is not set
-CONFIG_WL12XX=m
-CONFIG_WL18XX=m
-CONFIG_WLCORE=m
-CONFIG_WLCORE_SPI=m
-CONFIG_WLCORE_SDIO=m
-CONFIG_WLAN_VENDOR_ZYDAS=y
-# CONFIG_ZD1211RW is not set
-CONFIG_WLAN_VENDOR_QUANTENNA=y
-# CONFIG_QTNFMAC_PCIE is not set
+# CONFIG_WLAN_VENDOR_ADMTEK is not set
+# CONFIG_WLAN_VENDOR_ATH is not set
+# CONFIG_WLAN_VENDOR_ATMEL is not set
+# CONFIG_WLAN_VENDOR_BROADCOM is not set
+# CONFIG_WLAN_VENDOR_CISCO is not set
+# CONFIG_WLAN_VENDOR_INTEL is not set
+# CONFIG_WLAN_VENDOR_INTERSIL is not set
+# CONFIG_WLAN_VENDOR_MARVELL is not set
+# CONFIG_WLAN_VENDOR_MEDIATEK is not set
+# CONFIG_WLAN_VENDOR_MICROCHIP is not set
+# CONFIG_WLAN_VENDOR_PURELIFI is not set
+# CONFIG_WLAN_VENDOR_RALINK is not set
+# CONFIG_WLAN_VENDOR_REALTEK is not set
+# CONFIG_WLAN_VENDOR_RSI is not set
+# CONFIG_WLAN_VENDOR_SILABS is not set
+# CONFIG_WLAN_VENDOR_ST is not set
+# CONFIG_WLAN_VENDOR_TI is not set
+# CONFIG_WLAN_VENDOR_ZYDAS is not set
+# CONFIG_WLAN_VENDOR_QUANTENNA is not set
+# CONFIG_USB_NET_RNDIS_WLAN is not set
 # CONFIG_MAC80211_HWSIM is not set
 # CONFIG_VIRT_WIFI is not set
 # CONFIG_WAN is not set
@@ -2792,7 +2715,7 @@ CONFIG_INPUT_CPCAP_PWRBUTTON=m
 # CONFIG_INPUT_CM109 is not set
 # CONFIG_INPUT_REGULATOR_HAPTIC is not set
 CONFIG_INPUT_TPS65218_PWRBUTTON=m
-CONFIG_INPUT_TWL4030_PWRBUTTON=m
+# CONFIG_INPUT_TWL4030_PWRBUTTON is not set
 # CONFIG_INPUT_TWL4030_VIBRA is not set
 # CONFIG_INPUT_TWL6040_VIBRA is not set
 CONFIG_INPUT_UINPUT=m
@@ -2915,7 +2838,6 @@ CONFIG_HW_RANDOM=m
 # CONFIG_HW_RANDOM_TIMERIOMEM is not set
 # CONFIG_HW_RANDOM_BA431 is not set
 CONFIG_HW_RANDOM_OMAP=m
-CONFIG_HW_RANDOM_OMAP3_ROM=m
 # CONFIG_HW_RANDOM_VIRTIO is not set
 # CONFIG_HW_RANDOM_CCTRNG is not set
 # CONFIG_HW_RANDOM_XIPHERA is not set
@@ -2934,23 +2856,7 @@ CONFIG_I2C=y
 CONFIG_I2C_BOARDINFO=y
 CONFIG_I2C_COMPAT=y
 CONFIG_I2C_CHARDEV=y
-CONFIG_I2C_MUX=m
-# Multiplexer I2C Chip support
-# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
-# CONFIG_I2C_MUX_GPIO is not set
-# CONFIG_I2C_MUX_GPMUX is not set
-# CONFIG_I2C_MUX_LTC4306 is not set
-# CONFIG_I2C_MUX_PCA9541 is not set
-# CONFIG_I2C_MUX_PCA954x is not set
-# CONFIG_I2C_MUX_PINCTRL is not set
-# CONFIG_I2C_MUX_REG is not set
-# CONFIG_I2C_DEMUX_PINCTRL is not set
-# CONFIG_I2C_MUX_MLXCPLD is not set
-# end of Multiplexer I2C Chip support
+# CONFIG_I2C_MUX is not set
 CONFIG_I2C_HELPER_AUTO=y
@@ -3007,11 +2913,11 @@ CONFIG_I2C_OMAP=y
 # CONFIG_I2C_VIRTIO is not set
 # end of I2C Hardware Bus support
-# CONFIG_I2C_STUB is not set
+CONFIG_I2C_STUB=m
 # CONFIG_I2C_SLAVE is not set
-# CONFIG_I2C_DEBUG_CORE is not set
-# CONFIG_I2C_DEBUG_ALGO is not set
-# CONFIG_I2C_DEBUG_BUS is not set
+CONFIG_I2C_DEBUG_CORE=y
+CONFIG_I2C_DEBUG_ALGO=y
+CONFIG_I2C_DEBUG_BUS=y
 # end of I2C support
 # CONFIG_I3C is not set
@@ -3067,13 +2973,10 @@ CONFIG_HSI_BOARDINFO=y
 # HSI controllers
-CONFIG_OMAP_SSI=m
 # HSI clients
-# CONFIG_CMT_SPEECH is not set
-CONFIG_SSI_PROTOCOL=m
 # CONFIG_HSI_CHAR is not set
 CONFIG_PPS=y
 # CONFIG_PPS_DEBUG is not set
@@ -3112,7 +3015,9 @@ CONFIG_PINCONF=y
 CONFIG_GENERIC_PINCONF=y
 # CONFIG_DEBUG_PINCTRL is not set
 # CONFIG_PINCTRL_CY8C95X0 is not set
-# CONFIG_PINCTRL_MCP23S08 is not set
+CONFIG_PINCTRL_MCP23S08_I2C=y
+CONFIG_PINCTRL_MCP23S08_SPI=y
+CONFIG_PINCTRL_MCP23S08=y
 # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
 # CONFIG_PINCTRL_OCELOT is not set
 # CONFIG_PINCTRL_PALMAS is not set
@@ -3125,7 +3030,6 @@ CONFIG_PINCTRL_SINGLE=y
 # end of Renesas pinctrl drivers
-CONFIG_PINCTRL_TI_IODELAY=y
 CONFIG_GPIOLIB=y
 CONFIG_GPIOLIB_FASTPATH_LIMIT=512
 CONFIG_OF_GPIO=y
@@ -3228,7 +3132,6 @@ CONFIG_W1_CON=y
 # 1-wire Bus Masters
-# CONFIG_W1_MASTER_AMD_AXI is not set
 # CONFIG_W1_MASTER_MATROX is not set
 # CONFIG_W1_MASTER_DS2490 is not set
 # CONFIG_W1_MASTER_DS2482 is not set
@@ -3261,6 +3164,7 @@ CONFIG_W1_SLAVE_DS250X=m
 CONFIG_POWER_RESET=y
 # CONFIG_POWER_RESET_BRCMKONA is not set
+# CONFIG_POWER_RESET_BRCMSTB is not set
 CONFIG_POWER_RESET_GPIO=y
 # CONFIG_POWER_RESET_GPIO_RESTART is not set
 # CONFIG_POWER_RESET_LTC2952 is not set
@@ -3286,7 +3190,6 @@ CONFIG_BATTERY_CPCAP=m
 # CONFIG_BATTERY_SAMSUNG_SDI is not set
 # CONFIG_BATTERY_SBS is not set
 # CONFIG_CHARGER_SBS is not set
-# CONFIG_MANAGER_SBS is not set
 CONFIG_BATTERY_BQ27XXX=m
 CONFIG_BATTERY_BQ27XXX_I2C=m
 CONFIG_BATTERY_BQ27XXX_HDQ=m
@@ -3326,7 +3229,6 @@ CONFIG_CHARGER_BQ24735=m
 # CONFIG_CHARGER_UCS1002 is not set
 # CONFIG_CHARGER_BD99954 is not set
 # CONFIG_BATTERY_UG3105 is not set
-# CONFIG_FUEL_GAUGE_MM8013 is not set
 CONFIG_HWMON=m
 # CONFIG_HWMON_DEBUG_CHIP is not set
@@ -3365,7 +3267,6 @@ CONFIG_HWMON=m
 # CONFIG_SENSORS_F71882FG is not set
 # CONFIG_SENSORS_F75375S is not set
 # CONFIG_SENSORS_FTSTEUTATES is not set
-# CONFIG_SENSORS_GIGABYTE_WATERFORCE is not set
 # CONFIG_SENSORS_GL518SM is not set
 # CONFIG_SENSORS_GL520SM is not set
 # CONFIG_SENSORS_G760A is not set
@@ -3376,14 +3277,12 @@ CONFIG_SENSORS_GPIO_FAN=m
 # CONFIG_SENSORS_IIO_HWMON is not set
 # CONFIG_SENSORS_IT87 is not set
 # CONFIG_SENSORS_JC42 is not set
-# CONFIG_SENSORS_POWERZ is not set
 # CONFIG_SENSORS_POWR1220 is not set
 # CONFIG_SENSORS_LINEAGE is not set
 # CONFIG_SENSORS_LTC2945 is not set
 # CONFIG_SENSORS_LTC2947_I2C is not set
 # CONFIG_SENSORS_LTC2947_SPI is not set
 # CONFIG_SENSORS_LTC2990 is not set
-# CONFIG_SENSORS_LTC2991 is not set
 # CONFIG_SENSORS_LTC2992 is not set
 # CONFIG_SENSORS_LTC4151 is not set
 # CONFIG_SENSORS_LTC4215 is not set
@@ -3455,7 +3354,7 @@ CONFIG_SENSORS_LM75=m
 # CONFIG_SENSORS_DME1737 is not set
 # CONFIG_SENSORS_EMC1403 is not set
 # CONFIG_SENSORS_EMC2103 is not set
-# CONFIG_SENSORS_EMC2305 is not set
+CONFIG_SENSORS_EMC2305=m
 # CONFIG_SENSORS_EMC6W201 is not set
 # CONFIG_SENSORS_SMSC47M1 is not set
 # CONFIG_SENSORS_SMSC47M192 is not set
@@ -3496,7 +3395,6 @@ CONFIG_SENSORS_TMP102=m
 CONFIG_THERMAL=y
 # CONFIG_THERMAL_NETLINK is not set
 # CONFIG_THERMAL_STATISTICS is not set
-# CONFIG_THERMAL_DEBUGFS is not set
 CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
 CONFIG_THERMAL_OF=y
 # CONFIG_THERMAL_WRITABLE_TRIPS is not set
@@ -3517,10 +3415,6 @@ CONFIG_CPU_FREQ_THERMAL=y
 CONFIG_TI_SOC_THERMAL=y
 CONFIG_TI_THERMAL=y
-CONFIG_OMAP3_THERMAL=y
-CONFIG_OMAP4_THERMAL=y
-CONFIG_OMAP5_THERMAL=y
-CONFIG_DRA752_THERMAL=y
 # end of Texas Instruments thermal drivers
 # CONFIG_GENERIC_ADC_THERMAL is not set
@@ -3674,7 +3568,6 @@ CONFIG_TWL4030_CORE=y
 CONFIG_TWL4030_POWER=y
 CONFIG_MFD_TWL4030_AUDIO=y
 CONFIG_TWL6040_CORE=y
-CONFIG_MENELAUS=y
 # CONFIG_MFD_WL1273_CORE is not set
 # CONFIG_MFD_LM3533 is not set
 # CONFIG_MFD_TC3589X is not set
@@ -3706,7 +3599,6 @@ CONFIG_REGULATOR=y
 CONFIG_REGULATOR_FIXED_VOLTAGE=y
 # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
 # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
-# CONFIG_REGULATOR_NETLINK_EVENTS is not set
 # CONFIG_REGULATOR_88PG86X is not set
 # CONFIG_REGULATOR_ACT8865 is not set
 # CONFIG_REGULATOR_AD5398 is not set
@@ -3730,7 +3622,6 @@ CONFIG_REGULATOR_LP87565=y
 # CONFIG_REGULATOR_LTC3589 is not set
 # CONFIG_REGULATOR_LTC3676 is not set
 # CONFIG_REGULATOR_MAX1586 is not set
-# CONFIG_REGULATOR_MAX77503 is not set
 # CONFIG_REGULATOR_MAX77857 is not set
 # CONFIG_REGULATOR_MAX8649 is not set
 # CONFIG_REGULATOR_MAX8660 is not set
@@ -3802,6 +3693,7 @@ CONFIG_IR_GPIO_TX=m
 # CONFIG_IR_MCEUSB is not set
 CONFIG_IR_PWM_TX=m
 # CONFIG_IR_REDRAT3 is not set
+CONFIG_IR_RX51=m
 # CONFIG_IR_SERIAL is not set
 CONFIG_IR_SPI=m
 # CONFIG_IR_STREAMZAP is not set
@@ -3952,10 +3844,6 @@ CONFIG_V4L_PLATFORM_DRIVERS=y
 # Microchip Technology, Inc. media platform drivers
-# Nuvoton media platform drivers
 # NVidia media platform drivers
@@ -3991,10 +3879,6 @@ CONFIG_V4L_PLATFORM_DRIVERS=y
 # Texas Instruments drivers
-# CONFIG_VIDEO_TI_CAL is not set
-# CONFIG_VIDEO_AM437X_VPFE is not set
-CONFIG_VIDEO_OMAP3=m
-# CONFIG_VIDEO_OMAP3_DEBUG is not set
 # Verisilicon media platform drivers
@@ -4015,11 +3899,6 @@ CONFIG_VIDEO_OMAP3=m
 # CONFIG_SMS_SDIO_DRV is not set
 # CONFIG_V4L_TEST_DRIVERS is not set
 # CONFIG_DVB_TEST_DRIVERS is not set
-CONFIG_VIDEOBUF2_CORE=m
-CONFIG_VIDEOBUF2_V4L2=m
-CONFIG_VIDEOBUF2_MEMOPS=m
-CONFIG_VIDEOBUF2_DMA_CONTIG=m
-CONFIG_VIDEOBUF2_VMALLOC=m
 # end of Media drivers
@@ -4029,10 +3908,7 @@ CONFIG_MEDIA_ATTACH=y
 CONFIG_VIDEO_IR_I2C=m
 CONFIG_VIDEO_CAMERA_SENSOR=y
 CONFIG_VIDEO_APTINA_PLL=m
-# CONFIG_VIDEO_ALVIUM_CSI2 is not set
 # CONFIG_VIDEO_AR0521 is not set
-# CONFIG_VIDEO_GC0308 is not set
-# CONFIG_VIDEO_GC2145 is not set
 # CONFIG_VIDEO_HI556 is not set
 # CONFIG_VIDEO_HI846 is not set
 # CONFIG_VIDEO_HI847 is not set
@@ -4051,7 +3927,6 @@ CONFIG_VIDEO_APTINA_PLL=m
 # CONFIG_VIDEO_IMX415 is not set
 # CONFIG_VIDEO_MT9M001 is not set
 # CONFIG_VIDEO_MT9M111 is not set
-# CONFIG_VIDEO_MT9M114 is not set
 CONFIG_VIDEO_MT9P031=m
 # CONFIG_VIDEO_MT9T112 is not set
 # CONFIG_VIDEO_MT9V011 is not set
@@ -4077,7 +3952,6 @@ CONFIG_VIDEO_MT9P031=m
 # CONFIG_VIDEO_OV5675 is not set
 # CONFIG_VIDEO_OV5693 is not set
 # CONFIG_VIDEO_OV5695 is not set
-# CONFIG_VIDEO_OV64A40 is not set
 # CONFIG_VIDEO_OV6650 is not set
 # CONFIG_VIDEO_OV7251 is not set
 # CONFIG_VIDEO_OV7640 is not set
@@ -4100,12 +3974,6 @@ CONFIG_VIDEO_MT9P031=m
 # CONFIG_VIDEO_CCS is not set
 # CONFIG_VIDEO_ET8EK8 is not set
-# Camera ISPs
-# CONFIG_VIDEO_THP7312 is not set
-# end of Camera ISPs
 # Lens drivers
@@ -4133,7 +4001,6 @@ CONFIG_VIDEO_MT9P031=m
 # CONFIG_VIDEO_CS53L32A is not set
 # CONFIG_VIDEO_MSP3400 is not set
 # CONFIG_VIDEO_SONY_BTF_MPX is not set
-# CONFIG_VIDEO_TDA1997X is not set
 # CONFIG_VIDEO_TDA7432 is not set
 # CONFIG_VIDEO_TDA9840 is not set
 # CONFIG_VIDEO_TEA6415C is not set
@@ -4165,7 +4032,6 @@ CONFIG_VIDEO_MT9P031=m
 # CONFIG_VIDEO_BT866 is not set
 # CONFIG_VIDEO_ISL7998X is not set
 # CONFIG_VIDEO_KS0127 is not set
-# CONFIG_VIDEO_MAX9286 is not set
 # CONFIG_VIDEO_ML86V7667 is not set
 # CONFIG_VIDEO_SAA7110 is not set
 # CONFIG_VIDEO_SAA711X is not set
@@ -4175,7 +4041,6 @@ CONFIG_VIDEO_MT9P031=m
 CONFIG_VIDEO_TVP5150=m
 # CONFIG_VIDEO_TVP7002 is not set
 # CONFIG_VIDEO_TW2804 is not set
-# CONFIG_VIDEO_TW9900 is not set
 # CONFIG_VIDEO_TW9903 is not set
 # CONFIG_VIDEO_TW9906 is not set
 # CONFIG_VIDEO_TW9910 is not set
@@ -4296,7 +4161,6 @@ CONFIG_MEDIA_TUNER_XC5000=m
 # Multistandard (satellite) frontends
-CONFIG_DVB_M88DS3103=m
 CONFIG_DVB_MXL5XX=m
 CONFIG_DVB_STB0899=m
 CONFIG_DVB_STB6100=m
@@ -4348,7 +4212,6 @@ CONFIG_DVB_ZL10039=m
 # DVB-T (terrestrial) frontends
-CONFIG_DVB_AF9013=m
 CONFIG_DVB_CX22700=m
 CONFIG_DVB_CX22702=m
 CONFIG_DVB_CXD2820R=m
@@ -4363,11 +4226,7 @@ CONFIG_DVB_EC100=m
 CONFIG_DVB_L64781=m
 CONFIG_DVB_MT352=m
 CONFIG_DVB_NXT6000=m
-CONFIG_DVB_RTL2830=m
-CONFIG_DVB_RTL2832=m
-CONFIG_DVB_RTL2832_SDR=m
 CONFIG_DVB_S5H1432=m
-CONFIG_DVB_SI2168=m
 CONFIG_DVB_SP887X=m
 CONFIG_DVB_STV0367=m
 CONFIG_DVB_TDA10048=m
@@ -4393,7 +4252,6 @@ CONFIG_DVB_AU8522_V4L=m
 CONFIG_DVB_BCM3510=m
 CONFIG_DVB_LG2160=m
 CONFIG_DVB_LGDT3305=m
-CONFIG_DVB_LGDT3306A=m
 CONFIG_DVB_LGDT330X=m
 CONFIG_DVB_MXL692=m
 CONFIG_DVB_NXT200X=m
@@ -4546,14 +4404,11 @@ CONFIG_DRM_PANEL_EDP=m
 # CONFIG_DRM_PANEL_HIMAX_HX8394 is not set
 # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
 # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
-# CONFIG_DRM_PANEL_ILITEK_ILI9805 is not set
 # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
-# CONFIG_DRM_PANEL_ILITEK_ILI9882T is not set
 # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
 # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
 # CONFIG_DRM_PANEL_JADARD_JD9365DA_H3 is not set
 # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
-# CONFIG_DRM_PANEL_JDI_LPM102A188A is not set
 # CONFIG_DRM_PANEL_JDI_R63452 is not set
 # CONFIG_DRM_PANEL_KHADAS_TS050 is not set
 # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
@@ -4581,7 +4436,6 @@ CONFIG_DRM_PANEL_NEC_NL8048HL11=m
 # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
 # CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
 # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
-# CONFIG_DRM_PANEL_RAYDIUM_RM692E5 is not set
 # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
 # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
 # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
@@ -4602,7 +4456,6 @@ CONFIG_DRM_PANEL_SHARP_LS037V7DW01=m
 # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
 # CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set
 # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
-# CONFIG_DRM_PANEL_SYNAPTICS_R63353 is not set
 CONFIG_DRM_PANEL_SONY_ACX565AKM=m
 # CONFIG_DRM_PANEL_SONY_TD4353_JDI is not set
 # CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set
@@ -4664,6 +4517,7 @@ CONFIG_DRM_TI_TPD12S015=m
 # CONFIG_DRM_CDNS_MHDP8546 is not set
 # end of Display Interface Bridges
+# CONFIG_DRM_LOONGSON is not set
 # CONFIG_DRM_ETNAVIV is not set
 # CONFIG_DRM_LOGICVC is not set
 # CONFIG_DRM_ARCPGU is not set
@@ -4684,10 +4538,12 @@ CONFIG_DRM_TI_TPD12S015=m
 # CONFIG_DRM_PL111 is not set
 # CONFIG_DRM_TVE200 is not set
 # CONFIG_DRM_LIMA is not set
+# CONFIG_DRM_PANFROST is not set
 # CONFIG_DRM_MCDE is not set
 # CONFIG_DRM_TIDSS is not set
 # CONFIG_DRM_GUD is not set
 # CONFIG_DRM_SSD130X is not set
+# CONFIG_DRM_LEGACY is not set
 CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
@@ -4739,7 +4595,7 @@ CONFIG_FB_SYS_FILLRECT=y
 CONFIG_FB_SYS_COPYAREA=y
 CONFIG_FB_SYS_IMAGEBLIT=y
 # CONFIG_FB_FOREIGN_ENDIAN is not set
-CONFIG_FB_SYSMEM_FOPS=y
+CONFIG_FB_SYS_FOPS=y
 CONFIG_FB_DEFERRED_IO=y
 CONFIG_FB_DMAMEM_HELPERS=y
 CONFIG_FB_SYSMEM_HELPERS=y
@@ -4774,7 +4630,6 @@ CONFIG_BACKLIGHT_PWM=m
 # CONFIG_BACKLIGHT_LM3630A is not set
 # CONFIG_BACKLIGHT_LM3639 is not set
 # CONFIG_BACKLIGHT_LP855X is not set
-# CONFIG_BACKLIGHT_MP3309C is not set
 CONFIG_BACKLIGHT_PANDORA=m
 # CONFIG_BACKLIGHT_TPS65217 is not set
 CONFIG_BACKLIGHT_GPIO=m
@@ -4791,8 +4646,6 @@ CONFIG_HDMI=y
 # Console display driver support
 CONFIG_DUMMY_CONSOLE=y
-CONFIG_DUMMY_CONSOLE_COLUMNS=80
-CONFIG_DUMMY_CONSOLE_ROWS=30
 CONFIG_FRAMEBUFFER_CONSOLE=y
 # CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set
 CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
@@ -4807,396 +4660,7 @@ CONFIG_LOGO_LINUX_CLUT224=y
 # end of Graphics support
 # CONFIG_DRM_ACCEL is not set
-CONFIG_SOUND=m
-CONFIG_SOUND_OSS_CORE=y
-CONFIG_SOUND_OSS_CORE_PRECLAIM=y
-CONFIG_SND=m
-CONFIG_SND_TIMER=m
-CONFIG_SND_PCM=m
-CONFIG_SND_PCM_ELD=y
-CONFIG_SND_PCM_IEC958=y
-CONFIG_SND_DMAENGINE_PCM=m
-CONFIG_SND_HWDEP=m
-CONFIG_SND_RAWMIDI=m
-CONFIG_SND_JACK=y
-CONFIG_SND_JACK_INPUT_DEV=y
-CONFIG_SND_OSSEMUL=y
-CONFIG_SND_MIXER_OSS=m
-CONFIG_SND_PCM_OSS=m
-CONFIG_SND_PCM_OSS_PLUGINS=y
-CONFIG_SND_PCM_TIMER=y
-# CONFIG_SND_HRTIMER is not set
-# CONFIG_SND_DYNAMIC_MINORS is not set
-CONFIG_SND_SUPPORT_OLD_API=y
-CONFIG_SND_PROC_FS=y
-CONFIG_SND_VERBOSE_PROCFS=y
-CONFIG_SND_VERBOSE_PRINTK=y
-CONFIG_SND_CTL_FAST_LOOKUP=y
-CONFIG_SND_DEBUG=y
-# CONFIG_SND_DEBUG_VERBOSE is not set
-# CONFIG_SND_PCM_XRUN_DEBUG is not set
-# CONFIG_SND_CTL_INPUT_VALIDATION is not set
-# CONFIG_SND_CTL_DEBUG is not set
-# CONFIG_SND_JACK_INJECTION_DEBUG is not set
-# CONFIG_SND_SEQUENCER is not set
-CONFIG_SND_DRIVERS=y
-# CONFIG_SND_DUMMY is not set
-# CONFIG_SND_ALOOP is not set
-# CONFIG_SND_PCMTEST is not set
-# CONFIG_SND_MTPAV is not set
-# CONFIG_SND_SERIAL_U16550 is not set
-# CONFIG_SND_SERIAL_GENERIC is not set
-# CONFIG_SND_MPU401 is not set
-CONFIG_SND_PCI=y
-# CONFIG_SND_AD1889 is not set
-# CONFIG_SND_ATIIXP is not set
-# CONFIG_SND_ATIIXP_MODEM is not set
-# CONFIG_SND_AU8810 is not set
-# CONFIG_SND_AU8820 is not set
-# CONFIG_SND_AU8830 is not set
-# CONFIG_SND_AW2 is not set
-# CONFIG_SND_BT87X is not set
-# CONFIG_SND_CA0106 is not set
-# CONFIG_SND_CMIPCI is not set
-# CONFIG_SND_OXYGEN is not set
-# CONFIG_SND_CS4281 is not set
-# CONFIG_SND_CS46XX is not set
-# CONFIG_SND_CTXFI is not set
-# CONFIG_SND_DARLA20 is not set
-# CONFIG_SND_GINA20 is not set
-# CONFIG_SND_LAYLA20 is not set
-# CONFIG_SND_DARLA24 is not set
-# CONFIG_SND_GINA24 is not set
-# CONFIG_SND_LAYLA24 is not set
-# CONFIG_SND_MONA is not set
-# CONFIG_SND_MIA is not set
-# CONFIG_SND_ECHO3G is not set
-# CONFIG_SND_INDIGO is not set
-# CONFIG_SND_INDIGOIO is not set
-# CONFIG_SND_INDIGODJ is not set
-# CONFIG_SND_INDIGOIOX is not set
-# CONFIG_SND_INDIGODJX is not set
-# CONFIG_SND_ENS1370 is not set
-# CONFIG_SND_ENS1371 is not set
-# CONFIG_SND_FM801 is not set
-# CONFIG_SND_HDSP is not set
-# CONFIG_SND_HDSPM is not set
-# CONFIG_SND_ICE1724 is not set
-# CONFIG_SND_INTEL8X0 is not set
-# CONFIG_SND_INTEL8X0M is not set
-# CONFIG_SND_KORG1212 is not set
-# CONFIG_SND_LOLA is not set
-# CONFIG_SND_LX6464ES is not set
-# CONFIG_SND_MIXART is not set
-# CONFIG_SND_NM256 is not set
-# CONFIG_SND_PCXHR is not set
-# CONFIG_SND_RIPTIDE is not set
-# CONFIG_SND_RME32 is not set
-# CONFIG_SND_RME96 is not set
-# CONFIG_SND_RME9652 is not set
-# CONFIG_SND_SE6X is not set
-# CONFIG_SND_VIA82XX is not set
-# CONFIG_SND_VIA82XX_MODEM is not set
-# CONFIG_SND_VIRTUOSO is not set
-# CONFIG_SND_VX222 is not set
-# CONFIG_SND_YMFPCI is not set
-# HD-Audio
-# CONFIG_SND_HDA_INTEL is not set
-# end of HD-Audio
-CONFIG_SND_HDA_PREALLOC_SIZE=64
-CONFIG_SND_ARM=y
-CONFIG_SND_SPI=y
-CONFIG_SND_USB=y
-CONFIG_SND_USB_AUDIO=m
-# CONFIG_SND_USB_AUDIO_MIDI_V2 is not set
-CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
-# CONFIG_SND_USB_UA101 is not set
-# CONFIG_SND_USB_CAIAQ is not set
-# CONFIG_SND_USB_6FIRE is not set
-# CONFIG_SND_USB_HIFACE is not set
-# CONFIG_SND_BCD2000 is not set
-# CONFIG_SND_USB_POD is not set
-# CONFIG_SND_USB_PODHD is not set
-# CONFIG_SND_USB_TONEPORT is not set
-# CONFIG_SND_USB_VARIAX is not set
-CONFIG_SND_SOC=m
-CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
-# CONFIG_SND_SOC_ADI is not set
-# CONFIG_SND_SOC_AMD_ACP is not set
-# CONFIG_SND_AMD_ACP_CONFIG is not set
-# CONFIG_SND_ATMEL_SOC is not set
-# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
-# CONFIG_SND_DESIGNWARE_I2S is not set
-# SoC Audio for Freescale CPUs
-# Common SoC Audio options for Freescale CPUs:
-# CONFIG_SND_SOC_FSL_ASRC is not set
-# CONFIG_SND_SOC_FSL_SAI is not set
-# CONFIG_SND_SOC_FSL_AUDMIX is not set
-# CONFIG_SND_SOC_FSL_SSI is not set
-# CONFIG_SND_SOC_FSL_SPDIF is not set
-# CONFIG_SND_SOC_FSL_ESAI is not set
-# CONFIG_SND_SOC_FSL_MICFIL is not set
-# CONFIG_SND_SOC_FSL_XCVR is not set
-# CONFIG_SND_SOC_IMX_AUDMUX is not set
-# end of SoC Audio for Freescale CPUs
-# CONFIG_SND_SOC_CHV3_I2S is not set
-# CONFIG_SND_I2S_HI6210_I2S is not set
-# CONFIG_SND_SOC_IMG is not set
-# CONFIG_SND_SOC_MTK_BTCVSD is not set
-# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
-# STMicroelectronics STM32 SOC audio support
-# end of STMicroelectronics STM32 SOC audio support
-# Audio support for Texas Instruments SoCs
-CONFIG_SND_SOC_TI_EDMA_PCM=m
-CONFIG_SND_SOC_TI_SDMA_PCM=m
-CONFIG_SND_SOC_TI_UDMA_PCM=m
-# Texas Instruments DAI support for:
-CONFIG_SND_SOC_DAVINCI_MCASP=m
-CONFIG_SND_SOC_OMAP_DMIC=m
-CONFIG_SND_SOC_OMAP_MCBSP=m
-CONFIG_SND_SOC_OMAP_MCPDM=m
-# Audio support for boards with Texas Instruments SoCs
-# CONFIG_SND_SOC_NOKIA_N810 is not set
-CONFIG_SND_SOC_NOKIA_RX51=m
-CONFIG_SND_SOC_OMAP3_PANDORA=m
-CONFIG_SND_SOC_OMAP3_TWL4030=m
-CONFIG_SND_SOC_OMAP_ABE_TWL6040=m
-CONFIG_SND_SOC_OMAP_HDMI=m
-# end of Audio support for Texas Instruments SoCs
-# CONFIG_SND_SOC_XILINX_I2S is not set
-# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
-# CONFIG_SND_SOC_XILINX_SPDIF is not set
-# CONFIG_SND_SOC_XTFPGA_I2S is not set
-CONFIG_SND_SOC_I2C_AND_SPI=m
-# CODEC drivers
-# CONFIG_SND_SOC_AC97_CODEC is not set
-# CONFIG_SND_SOC_ADAU1372_I2C is not set
-# CONFIG_SND_SOC_ADAU1372_SPI is not set
-# CONFIG_SND_SOC_ADAU1701 is not set
-# CONFIG_SND_SOC_ADAU1761_I2C is not set
-# CONFIG_SND_SOC_ADAU1761_SPI is not set
-# CONFIG_SND_SOC_ADAU7002 is not set
-# CONFIG_SND_SOC_ADAU7118_HW is not set
-# CONFIG_SND_SOC_ADAU7118_I2C is not set
-# CONFIG_SND_SOC_AK4104 is not set
-# CONFIG_SND_SOC_AK4118 is not set
-# CONFIG_SND_SOC_AK4375 is not set
-# CONFIG_SND_SOC_AK4458 is not set
-# CONFIG_SND_SOC_AK4554 is not set
-# CONFIG_SND_SOC_AK4613 is not set
-# CONFIG_SND_SOC_AK4642 is not set
-# CONFIG_SND_SOC_AK5386 is not set
-# CONFIG_SND_SOC_AK5558 is not set
-# CONFIG_SND_SOC_ALC5623 is not set
-# CONFIG_SND_SOC_AUDIO_IIO_AUX is not set
-# CONFIG_SND_SOC_AW8738 is not set
-# CONFIG_SND_SOC_AW88395 is not set
-# CONFIG_SND_SOC_AW88261 is not set
-# CONFIG_SND_SOC_AW87390 is not set
-# CONFIG_SND_SOC_AW88399 is not set
-# CONFIG_SND_SOC_BD28623 is not set
-# CONFIG_SND_SOC_BT_SCO is not set
-# CONFIG_SND_SOC_CHV3_CODEC is not set
-CONFIG_SND_SOC_CPCAP=m
-# CONFIG_SND_SOC_CS35L32 is not set
-# CONFIG_SND_SOC_CS35L33 is not set
-# CONFIG_SND_SOC_CS35L34 is not set
-# CONFIG_SND_SOC_CS35L35 is not set
-# CONFIG_SND_SOC_CS35L36 is not set
-# CONFIG_SND_SOC_CS35L41_SPI is not set
-# CONFIG_SND_SOC_CS35L41_I2C is not set
-# CONFIG_SND_SOC_CS35L45_SPI is not set
-# CONFIG_SND_SOC_CS35L45_I2C is not set
-# CONFIG_SND_SOC_CS35L56_I2C is not set
-# CONFIG_SND_SOC_CS35L56_SPI is not set
-# CONFIG_SND_SOC_CS42L42 is not set
-# CONFIG_SND_SOC_CS42L51_I2C is not set
-# CONFIG_SND_SOC_CS42L52 is not set
-# CONFIG_SND_SOC_CS42L56 is not set
-# CONFIG_SND_SOC_CS42L73 is not set
-# CONFIG_SND_SOC_CS42L83 is not set
-# CONFIG_SND_SOC_CS4234 is not set
-# CONFIG_SND_SOC_CS4265 is not set
-# CONFIG_SND_SOC_CS4270 is not set
-# CONFIG_SND_SOC_CS4271_I2C is not set
-# CONFIG_SND_SOC_CS4271_SPI is not set
-# CONFIG_SND_SOC_CS42XX8_I2C is not set
-# CONFIG_SND_SOC_CS43130 is not set
-# CONFIG_SND_SOC_CS4341 is not set
-# CONFIG_SND_SOC_CS4349 is not set
-# CONFIG_SND_SOC_CS53L30 is not set
-# CONFIG_SND_SOC_CX2072X is not set
-# CONFIG_SND_SOC_DA7213 is not set
-# CONFIG_SND_SOC_DMIC is not set
-CONFIG_SND_SOC_HDMI_CODEC=m
-# CONFIG_SND_SOC_ES7134 is not set
-# CONFIG_SND_SOC_ES7241 is not set
-# CONFIG_SND_SOC_ES8316 is not set
-# CONFIG_SND_SOC_ES8326 is not set
-# CONFIG_SND_SOC_ES8328_I2C is not set
-# CONFIG_SND_SOC_ES8328_SPI is not set
-# CONFIG_SND_SOC_GTM601 is not set
-# CONFIG_SND_SOC_HDA is not set
-# CONFIG_SND_SOC_ICS43432 is not set
-# CONFIG_SND_SOC_IDT821034 is not set
-# CONFIG_SND_SOC_INNO_RK3036 is not set
-# CONFIG_SND_SOC_MAX98088 is not set
-# CONFIG_SND_SOC_MAX98090 is not set
-# CONFIG_SND_SOC_MAX98357A is not set
-# CONFIG_SND_SOC_MAX98504 is not set
-# CONFIG_SND_SOC_MAX9867 is not set
-# CONFIG_SND_SOC_MAX98927 is not set
-# CONFIG_SND_SOC_MAX98520 is not set
-# CONFIG_SND_SOC_MAX98373_I2C is not set
-# CONFIG_SND_SOC_MAX98388 is not set
-# CONFIG_SND_SOC_MAX98390 is not set
-# CONFIG_SND_SOC_MAX98396 is not set
-# CONFIG_SND_SOC_MAX9860 is not set
-# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
-# CONFIG_SND_SOC_PCM1681 is not set
-# CONFIG_SND_SOC_PCM1789_I2C is not set
-# CONFIG_SND_SOC_PCM179X_I2C is not set
-# CONFIG_SND_SOC_PCM179X_SPI is not set
-# CONFIG_SND_SOC_PCM186X_I2C is not set
-# CONFIG_SND_SOC_PCM186X_SPI is not set
-# CONFIG_SND_SOC_PCM3060_I2C is not set
-# CONFIG_SND_SOC_PCM3060_SPI is not set
-# CONFIG_SND_SOC_PCM3168A_I2C is not set
-# CONFIG_SND_SOC_PCM3168A_SPI is not set
-# CONFIG_SND_SOC_PCM5102A is not set
-# CONFIG_SND_SOC_PCM512x_I2C is not set
-# CONFIG_SND_SOC_PCM512x_SPI is not set
-# CONFIG_SND_SOC_PEB2466 is not set
-# CONFIG_SND_SOC_RK3328 is not set
-# CONFIG_SND_SOC_RT5616 is not set
-# CONFIG_SND_SOC_RT5631 is not set
-# CONFIG_SND_SOC_RT5640 is not set
-# CONFIG_SND_SOC_RT5659 is not set
-# CONFIG_SND_SOC_RT9120 is not set
-# CONFIG_SND_SOC_RTQ9128 is not set
-# CONFIG_SND_SOC_SGTL5000 is not set
-# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
-# CONFIG_SND_SOC_SIMPLE_MUX is not set
-# CONFIG_SND_SOC_SMA1303 is not set
-# CONFIG_SND_SOC_SPDIF is not set
-# CONFIG_SND_SOC_SRC4XXX_I2C is not set
-# CONFIG_SND_SOC_SSM2305 is not set
-# CONFIG_SND_SOC_SSM2518 is not set
-# CONFIG_SND_SOC_SSM2602_SPI is not set
-# CONFIG_SND_SOC_SSM2602_I2C is not set
-# CONFIG_SND_SOC_SSM3515 is not set
-# CONFIG_SND_SOC_SSM4567 is not set
-# CONFIG_SND_SOC_STA32X is not set
-# CONFIG_SND_SOC_STA350 is not set
-# CONFIG_SND_SOC_STI_SAS is not set
-# CONFIG_SND_SOC_TAS2552 is not set
-# CONFIG_SND_SOC_TAS2562 is not set
-# CONFIG_SND_SOC_TAS2764 is not set
-# CONFIG_SND_SOC_TAS2770 is not set
-# CONFIG_SND_SOC_TAS2780 is not set
-# CONFIG_SND_SOC_TAS2781_I2C is not set
-# CONFIG_SND_SOC_TAS5086 is not set
-# CONFIG_SND_SOC_TAS571X is not set
-# CONFIG_SND_SOC_TAS5720 is not set
-# CONFIG_SND_SOC_TAS5805M is not set
-# CONFIG_SND_SOC_TAS6424 is not set
-# CONFIG_SND_SOC_TDA7419 is not set
-# CONFIG_SND_SOC_TFA9879 is not set
-# CONFIG_SND_SOC_TFA989X is not set
-# CONFIG_SND_SOC_TLV320ADC3XXX is not set
-CONFIG_SND_SOC_TLV320AIC23=m
-CONFIG_SND_SOC_TLV320AIC23_I2C=m
-# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
-# CONFIG_SND_SOC_TLV320AIC31XX is not set
-# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
-# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
-CONFIG_SND_SOC_TLV320AIC3X=m
-CONFIG_SND_SOC_TLV320AIC3X_I2C=m
-# CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
-# CONFIG_SND_SOC_TLV320ADCX140 is not set
-# CONFIG_SND_SOC_TS3A227E is not set
-# CONFIG_SND_SOC_TSCS42XX is not set
-# CONFIG_SND_SOC_TSCS454 is not set
-CONFIG_SND_SOC_TWL4030=m
-CONFIG_SND_SOC_TWL6040=m
-# CONFIG_SND_SOC_UDA1334 is not set
-# CONFIG_SND_SOC_WM8510 is not set
-# CONFIG_SND_SOC_WM8523 is not set
-# CONFIG_SND_SOC_WM8524 is not set
-# CONFIG_SND_SOC_WM8580 is not set
-# CONFIG_SND_SOC_WM8711 is not set
-# CONFIG_SND_SOC_WM8728 is not set
-# CONFIG_SND_SOC_WM8731_I2C is not set
-# CONFIG_SND_SOC_WM8731_SPI is not set
-# CONFIG_SND_SOC_WM8737 is not set
-# CONFIG_SND_SOC_WM8741 is not set
-# CONFIG_SND_SOC_WM8750 is not set
-# CONFIG_SND_SOC_WM8753 is not set
-# CONFIG_SND_SOC_WM8770 is not set
-# CONFIG_SND_SOC_WM8776 is not set
-# CONFIG_SND_SOC_WM8782 is not set
-# CONFIG_SND_SOC_WM8804_I2C is not set
-# CONFIG_SND_SOC_WM8804_SPI is not set
-# CONFIG_SND_SOC_WM8903 is not set
-# CONFIG_SND_SOC_WM8904 is not set
-# CONFIG_SND_SOC_WM8940 is not set
-# CONFIG_SND_SOC_WM8960 is not set
-# CONFIG_SND_SOC_WM8961 is not set
-# CONFIG_SND_SOC_WM8962 is not set
-# CONFIG_SND_SOC_WM8974 is not set
-# CONFIG_SND_SOC_WM8978 is not set
-# CONFIG_SND_SOC_WM8985 is not set
-# CONFIG_SND_SOC_ZL38060 is not set
-# CONFIG_SND_SOC_MAX9759 is not set
-# CONFIG_SND_SOC_MT6351 is not set
-# CONFIG_SND_SOC_MT6358 is not set
-# CONFIG_SND_SOC_MT6660 is not set
-# CONFIG_SND_SOC_NAU8315 is not set
-# CONFIG_SND_SOC_NAU8540 is not set
-# CONFIG_SND_SOC_NAU8810 is not set
-# CONFIG_SND_SOC_NAU8821 is not set
-# CONFIG_SND_SOC_NAU8822 is not set
-# CONFIG_SND_SOC_NAU8824 is not set
-CONFIG_SND_SOC_TPA6130A2=m
-# CONFIG_SND_SOC_LPASS_WSA_MACRO is not set
-# CONFIG_SND_SOC_LPASS_VA_MACRO is not set
-# CONFIG_SND_SOC_LPASS_RX_MACRO is not set
-# CONFIG_SND_SOC_LPASS_TX_MACRO is not set
-# end of CODEC drivers
-CONFIG_SND_SIMPLE_CARD_UTILS=m
-CONFIG_SND_SIMPLE_CARD=m
-CONFIG_SND_AUDIO_GRAPH_CARD=m
-# CONFIG_SND_AUDIO_GRAPH_CARD2 is not set
-# CONFIG_SND_TEST_COMPONENT is not set
-# CONFIG_SND_VIRTIO is not set
+# CONFIG_SOUND is not set
 CONFIG_HID_SUPPORT=y
 CONFIG_HID=y
 # CONFIG_HID_BATTERY_STRENGTH is not set
@@ -5222,7 +4686,6 @@ CONFIG_HID_GENERIC=m
 # CONFIG_HID_CORSAIR is not set
 # CONFIG_HID_COUGAR is not set
 # CONFIG_HID_MACALLY is not set
-# CONFIG_HID_PRODIKEYS is not set
 # CONFIG_HID_CMEDIA is not set
 # CONFIG_HID_CREATIVE_SB0540 is not set
 # CONFIG_HID_CYPRESS is not set
@@ -5307,7 +4770,6 @@ CONFIG_HID_GENERIC=m
 # CONFIG_HID_ZYDACRON is not set
 # CONFIG_HID_SENSOR_HUB is not set
 # CONFIG_HID_ALPS is not set
-# CONFIG_HID_MCP2200 is not set
 # CONFIG_HID_MCP2221 is not set
 # end of Special HID drivers
@@ -5337,14 +4799,13 @@ CONFIG_I2C_HID=y
 # CONFIG_I2C_HID_OF_GOODIX is not set
 CONFIG_USB_OHCI_LITTLE_ENDIAN=y
 CONFIG_USB_SUPPORT=y
-CONFIG_USB_COMMON=m
-# CONFIG_USB_LED_TRIG is not set
-# CONFIG_USB_ULPI_BUS is not set
+CONFIG_USB_COMMON=y
+CONFIG_USB_LED_TRIG=y
+CONFIG_USB_ULPI_BUS=y
 # CONFIG_USB_CONN_GPIO is not set
 CONFIG_USB_ARCH_HAS_HCD=y
 CONFIG_USB=m
 CONFIG_USB_PCI=y
-# CONFIG_USB_PCI_AMD is not set
 CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
@@ -5380,7 +4841,6 @@ CONFIG_USB_EHCI_HCD_OMAP=m
 # CONFIG_USB_ISP116X_HCD is not set
 # CONFIG_USB_MAX3421_HCD is not set
 CONFIG_USB_OHCI_HCD=m
-CONFIG_USB_OHCI_HCD_OMAP3=m
 CONFIG_USB_OHCI_HCD_PCI=m
 CONFIG_USB_OHCI_HCD_PLATFORM=m
 # CONFIG_USB_UHCI_HCD is not set
@@ -5392,7 +4852,7 @@ CONFIG_USB_OHCI_HCD_PLATFORM=m
 # USB Device Class drivers
 CONFIG_USB_ACM=m
-# CONFIG_USB_PRINTER is not set
+CONFIG_USB_PRINTER=m
 CONFIG_USB_WDM=m
 # CONFIG_USB_TMC is not set
@@ -5405,20 +4865,21 @@ CONFIG_USB_WDM=m
 CONFIG_USB_STORAGE=m
 # CONFIG_USB_STORAGE_DEBUG is not set
-# CONFIG_USB_STORAGE_REALTEK is not set
-# CONFIG_USB_STORAGE_DATAFAB is not set
-# CONFIG_USB_STORAGE_FREECOM is not set
-# CONFIG_USB_STORAGE_ISD200 is not set
-# CONFIG_USB_STORAGE_USBAT is not set
-# CONFIG_USB_STORAGE_SDDR09 is not set
-# CONFIG_USB_STORAGE_SDDR55 is not set
-# CONFIG_USB_STORAGE_JUMPSHOT is not set
-# CONFIG_USB_STORAGE_ALAUDA is not set
-# CONFIG_USB_STORAGE_ONETOUCH is not set
-# CONFIG_USB_STORAGE_KARMA is not set
-# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
-# CONFIG_USB_STORAGE_ENE_UB6250 is not set
-# CONFIG_USB_UAS is not set
+CONFIG_USB_STORAGE_REALTEK=m
+CONFIG_REALTEK_AUTOPM=y
+CONFIG_USB_STORAGE_DATAFAB=m
+CONFIG_USB_STORAGE_FREECOM=m
+CONFIG_USB_STORAGE_ISD200=m
+CONFIG_USB_STORAGE_USBAT=m
+CONFIG_USB_STORAGE_SDDR09=m
+CONFIG_USB_STORAGE_SDDR55=m
+CONFIG_USB_STORAGE_JUMPSHOT=m
+CONFIG_USB_STORAGE_ALAUDA=m
+CONFIG_USB_STORAGE_ONETOUCH=m
+CONFIG_USB_STORAGE_KARMA=m
+CONFIG_USB_STORAGE_CYPRESS_ATACB=m
+CONFIG_USB_STORAGE_ENE_UB6250=m
+CONFIG_USB_UAS=m
 # USB Imaging devices
@@ -5451,6 +4912,7 @@ CONFIG_USB_INVENTRA_DMA=y
 CONFIG_USB_TUSB_OMAP_DMA=y
 CONFIG_USB_DWC3=m
+# CONFIG_USB_DWC3_ULPI is not set
 # CONFIG_USB_DWC3_HOST is not set
 # CONFIG_USB_DWC3_GADGET is not set
 CONFIG_USB_DWC3_DUAL_ROLE=y
@@ -5534,16 +4996,16 @@ CONFIG_USB_SERIAL_OPTION=m
 # CONFIG_USB_EMI62 is not set
 # CONFIG_USB_EMI26 is not set
 # CONFIG_USB_ADUTUX is not set
-# CONFIG_USB_SEVSEG is not set
+CONFIG_USB_SEVSEG=m
 # CONFIG_USB_LEGOTOWER is not set
 # CONFIG_USB_LCD is not set
 # CONFIG_USB_CYPRESS_CY7C63 is not set
 # CONFIG_USB_CYTHERM is not set
-# CONFIG_USB_IDMOUSE is not set
+CONFIG_USB_IDMOUSE=m
 # CONFIG_USB_APPLEDISPLAY is not set
-# CONFIG_APPLE_MFI_FASTCHARGE is not set
+CONFIG_APPLE_MFI_FASTCHARGE=m
 # CONFIG_USB_SISUSBVGA is not set
-# CONFIG_USB_LD is not set
+CONFIG_USB_LD=m
 # CONFIG_USB_TRANCEVIBRATOR is not set
 # CONFIG_USB_IOWARRIOR is not set
 CONFIG_USB_TEST=m
@@ -5607,7 +5069,6 @@ CONFIG_USB_F_ACM=m
 CONFIG_USB_F_SS_LB=m
 CONFIG_USB_U_SERIAL=m
 CONFIG_USB_U_ETHER=m
-CONFIG_USB_U_AUDIO=m
 CONFIG_USB_F_SERIAL=m
 CONFIG_USB_F_OBEX=m
 CONFIG_USB_F_NCM=m
@@ -5618,9 +5079,6 @@ CONFIG_USB_F_SUBSET=m
 CONFIG_USB_F_RNDIS=m
 CONFIG_USB_F_MASS_STORAGE=m
 CONFIG_USB_F_FS=m
-CONFIG_USB_F_UAC1=m
-CONFIG_USB_F_UAC2=m
-CONFIG_USB_F_MIDI=m
 CONFIG_USB_F_HID=m
 CONFIG_USB_CONFIGFS=m
 CONFIG_USB_CONFIGFS_SERIAL=y
@@ -5635,11 +5093,6 @@ CONFIG_USB_CONFIGFS_PHONET=y
 CONFIG_USB_CONFIGFS_MASS_STORAGE=y
 CONFIG_USB_CONFIGFS_F_LB_SS=y
 CONFIG_USB_CONFIGFS_F_FS=y
-CONFIG_USB_CONFIGFS_F_UAC1=y
-# CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
-CONFIG_USB_CONFIGFS_F_UAC2=y
-CONFIG_USB_CONFIGFS_F_MIDI=y
-# CONFIG_USB_CONFIGFS_F_MIDI2 is not set
 CONFIG_USB_CONFIGFS_F_HID=y
 # CONFIG_USB_CONFIGFS_F_UVC is not set
 # CONFIG_USB_CONFIGFS_F_PRINTER is not set
@@ -5648,14 +5101,12 @@ CONFIG_USB_CONFIGFS_F_HID=y
 # USB Gadget precomposed configurations
 CONFIG_USB_ZERO=m
-# CONFIG_USB_AUDIO is not set
 # CONFIG_USB_ETH is not set
 # CONFIG_USB_G_NCM is not set
 # CONFIG_USB_GADGETFS is not set
 # CONFIG_USB_FUNCTIONFS is not set
 # CONFIG_USB_MASS_STORAGE is not set
 # CONFIG_USB_G_SERIAL is not set
-# CONFIG_USB_MIDI_GADGET is not set
 # CONFIG_USB_G_PRINTER is not set
 # CONFIG_USB_CDC_COMPOSITE is not set
 CONFIG_USB_G_NOKIA=m
@@ -5701,12 +5152,14 @@ CONFIG_MMC_OMAP_HS=y
 # CONFIG_MMC_VUB300 is not set
 # CONFIG_MMC_USHC is not set
 # CONFIG_MMC_USDHI6ROL0 is not set
+# CONFIG_MMC_REALTEK_USB is not set
 # CONFIG_MMC_CQHCI is not set
 # CONFIG_MMC_HSQ is not set
 # CONFIG_MMC_TOSHIBA_PCI is not set
 # CONFIG_MMC_MTK is not set
 # CONFIG_MMC_SDHCI_XENON is not set
 CONFIG_MMC_SDHCI_OMAP=y
+# CONFIG_MMC_SDHCI_AM654 is not set
 CONFIG_MMC_SDHCI_EXTERNAL_DMA=y
 # CONFIG_SCSI_UFSHCD is not set
 # CONFIG_MEMSTICK is not set
@@ -5748,7 +5201,7 @@ CONFIG_LEDS_PCA963X=m
 # CONFIG_LEDS_DAC124S085 is not set
 CONFIG_LEDS_PWM=m
 # CONFIG_LEDS_REGULATOR is not set
-CONFIG_LEDS_BD2606MVV=m
+# CONFIG_LEDS_BD2606MVV is not set
 # CONFIG_LEDS_BD2802 is not set
 # CONFIG_LEDS_LT3593 is not set
 # CONFIG_LEDS_TCA6507 is not set
@@ -5787,7 +5240,6 @@ CONFIG_LEDS_TRIGGER_HEARTBEAT=m
 CONFIG_LEDS_TRIGGER_BACKLIGHT=m
 CONFIG_LEDS_TRIGGER_CPU=y
 # CONFIG_LEDS_TRIGGER_ACTIVITY is not set
-CONFIG_LEDS_TRIGGER_GPIO=m
 CONFIG_LEDS_TRIGGER_DEFAULT_ON=m
@@ -5838,7 +5290,6 @@ CONFIG_RTC_DRV_DS1307=m
 # CONFIG_RTC_DRV_DS1672 is not set
 # CONFIG_RTC_DRV_HYM8563 is not set
 # CONFIG_RTC_DRV_MAX6900 is not set
-# CONFIG_RTC_DRV_MAX31335 is not set
 # CONFIG_RTC_DRV_NCT3018Y is not set
 # CONFIG_RTC_DRV_RS5C372 is not set
 # CONFIG_RTC_DRV_ISL1208 is not set
@@ -5853,7 +5304,6 @@ CONFIG_RTC_DRV_DS1307=m
 CONFIG_RTC_DRV_M41T80=m
 # CONFIG_RTC_DRV_M41T80_WDT is not set
 # CONFIG_RTC_DRV_BQ32K is not set
-CONFIG_RTC_DRV_TWL92330=y
 CONFIG_RTC_DRV_TWL4030=m
 CONFIG_RTC_DRV_PALMAS=m
 # CONFIG_RTC_DRV_TPS65910 is not set
@@ -6022,7 +5472,6 @@ CONFIG_COMMON_CLK=y
 # CONFIG_COMMON_CLK_CDCE706 is not set
 # CONFIG_COMMON_CLK_CDCE925 is not set
 # CONFIG_COMMON_CLK_CS2000_CP is not set
-CONFIG_CLK_TWL=m
 CONFIG_CLK_TWL6040=m
 # CONFIG_COMMON_CLK_AXI_CLKGEN is not set
 CONFIG_COMMON_CLK_PALMAS=m
@@ -6064,6 +5513,7 @@ CONFIG_IOMMU_SUPPORT=y
 # Generic IOMMU Pagetable Support
+# CONFIG_IOMMU_IO_PGTABLE_LPAE is not set
 # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
 # end of Generic IOMMU Pagetable Support
@@ -6075,14 +5525,13 @@ CONFIG_OF_IOMMU=y
 # CONFIG_IOMMUFD is not set
 CONFIG_OMAP_IOMMU=y
 # CONFIG_OMAP_IOMMU_DEBUG is not set
+# CONFIG_ARM_SMMU is not set
 # Remoteproc drivers
 CONFIG_REMOTEPROC=y
 # CONFIG_REMOTEPROC_CDEV is not set
-CONFIG_OMAP_REMOTEPROC=m
-# CONFIG_OMAP_REMOTEPROC_WATCHDOG is not set
 CONFIG_WKUP_M3_RPROC=m
 # end of Remoteproc drivers
@@ -6107,6 +5556,7 @@ CONFIG_WKUP_M3_RPROC=m
 # Broadcom SoC drivers
+# CONFIG_SOC_BRCMSTB is not set
 # end of Broadcom SoC drivers
@@ -6150,33 +5600,6 @@ CONFIG_WKUP_M3_IPC=m
 # end of Xilinx SoC drivers
 # end of SOC (System On Chip) specific Drivers
-# PM Domains
-# Amlogic PM Domains
-# end of Amlogic PM Domains
-# Broadcom PM Domains
-# end of Broadcom PM Domains
-# i.MX PM Domains
-# end of i.MX PM Domains
-# Qualcomm PM Domains
-# end of Qualcomm PM Domains
-CONFIG_OMAP2PLUS_PRM=y
-# end of PM Domains
 # CONFIG_PM_DEVFREQ is not set
 CONFIG_EXTCON=y
@@ -6268,7 +5691,6 @@ CONFIG_KXCJK1013=m
 # CONFIG_AD4130 is not set
 # CONFIG_AD7091R5 is not set
-# CONFIG_AD7091R8 is not set
 # CONFIG_AD7124 is not set
 # CONFIG_AD7192 is not set
 # CONFIG_AD7266 is not set
@@ -6295,7 +5717,6 @@ CONFIG_CPCAP_ADC=m
 # CONFIG_HI8435 is not set
 # CONFIG_HX711 is not set
 CONFIG_INA2XX_ADC=m
-# CONFIG_LTC2309 is not set
 # CONFIG_LTC2471 is not set
 # CONFIG_LTC2485 is not set
 # CONFIG_LTC2496 is not set
@@ -6307,11 +5728,9 @@ CONFIG_INA2XX_ADC=m
 # CONFIG_MAX11410 is not set
 # CONFIG_MAX1241 is not set
 # CONFIG_MAX1363 is not set
-# CONFIG_MAX34408 is not set
 # CONFIG_MAX9611 is not set
 # CONFIG_MCP320X is not set
 # CONFIG_MCP3422 is not set
-# CONFIG_MCP3564 is not set
 # CONFIG_MCP3911 is not set
 # CONFIG_NAU7802 is not set
 # CONFIG_PALMAS_GPADC is not set
@@ -6324,7 +5743,7 @@ CONFIG_INA2XX_ADC=m
 # CONFIG_TI_ADC108S102 is not set
 # CONFIG_TI_ADC128S052 is not set
 # CONFIG_TI_ADC161S626 is not set
-# CONFIG_TI_ADS1015 is not set
+CONFIG_TI_ADS1015=m
 # CONFIG_TI_ADS7924 is not set
 # CONFIG_TI_ADS1100 is not set
 # CONFIG_TI_ADS7950 is not set
@@ -6337,7 +5756,7 @@ CONFIG_TI_AM335X_ADC=m
 # CONFIG_TI_TLC4541 is not set
 # CONFIG_TI_TSC2046 is not set
 CONFIG_TWL4030_MADC=m
-CONFIG_TWL6030_GPADC=m
+# CONFIG_TWL6030_GPADC is not set
 # CONFIG_VF610_ADC is not set
 # CONFIG_XILINX_XADC is not set
 # end of Analog to digital converters
@@ -6373,7 +5792,6 @@ CONFIG_TWL6030_GPADC=m
 # Chemical Sensors
-# CONFIG_AOSONG_AGS02MA is not set
 # CONFIG_ATLAS_PH_SENSOR is not set
 # CONFIG_ATLAS_EZO_SENSOR is not set
 # CONFIG_BME680 is not set
@@ -6395,8 +5813,6 @@ CONFIG_TWL6030_GPADC=m
 # end of Hid Sensor IIO Common
-CONFIG_IIO_INV_SENSORS_TIMESTAMP=m
 # IIO SCMI Sensors
@@ -6449,7 +5865,6 @@ CONFIG_IIO_ST_SENSORS_CORE=m
 # CONFIG_MAX5821 is not set
 # CONFIG_MCP4725 is not set
 # CONFIG_MCP4728 is not set
-# CONFIG_MCP4821 is not set
 # CONFIG_MCP4922 is not set
 # CONFIG_TI_DAC082S085 is not set
 # CONFIG_TI_DAC5571 is not set
@@ -6502,8 +5917,7 @@ CONFIG_IIO_ST_SENSORS_CORE=m
 # CONFIG_ADXRS450 is not set
 # CONFIG_BMG160 is not set
 # CONFIG_FXAS21002C is not set
-CONFIG_MPU3050=m
-CONFIG_MPU3050_I2C=m
+# CONFIG_MPU3050_I2C is not set
 # CONFIG_IIO_ST_GYRO_3AXIS is not set
 # CONFIG_ITG3200 is not set
 # end of Digital gyroscope sensors
@@ -6529,7 +5943,6 @@ CONFIG_MPU3050_I2C=m
 # CONFIG_DHT11 is not set
 # CONFIG_HDC100X is not set
 # CONFIG_HDC2010 is not set
-# CONFIG_HDC3020 is not set
 # CONFIG_HTS221 is not set
 # CONFIG_HTU21 is not set
 # CONFIG_SI7005 is not set
@@ -6545,8 +5958,6 @@ CONFIG_MPU3050_I2C=m
 # CONFIG_ADIS16480 is not set
 # CONFIG_BMI160_I2C is not set
 # CONFIG_BMI160_SPI is not set
-# CONFIG_BMI323_I2C is not set
-# CONFIG_BMI323_SPI is not set
 # CONFIG_BOSCH_BNO055_SERIAL is not set
 # CONFIG_BOSCH_BNO055_I2C is not set
 # CONFIG_FXOS8700_I2C is not set
@@ -6554,8 +5965,7 @@ CONFIG_MPU3050_I2C=m
 # CONFIG_KMX61 is not set
 # CONFIG_INV_ICM42600_I2C is not set
 # CONFIG_INV_ICM42600_SPI is not set
-CONFIG_INV_MPU6050_IIO=m
-CONFIG_INV_MPU6050_I2C=m
+# CONFIG_INV_MPU6050_I2C is not set
 # CONFIG_INV_MPU6050_SPI is not set
 # CONFIG_IIO_ST_LSM6DSX is not set
 # CONFIG_IIO_ST_LSM9DS0 is not set
@@ -6583,12 +5993,10 @@ CONFIG_INV_MPU6050_I2C=m
 # CONFIG_SENSORS_ISL29018 is not set
 CONFIG_SENSORS_ISL29028=m
 # CONFIG_ISL29125 is not set
-# CONFIG_ISL76682 is not set
 # CONFIG_JSA1212 is not set
 # CONFIG_ROHM_BU27008 is not set
 # CONFIG_ROHM_BU27034 is not set
 # CONFIG_RPR0521 is not set
-# CONFIG_LTR390 is not set
 # CONFIG_LTR501 is not set
 # CONFIG_LTRF216A is not set
 # CONFIG_LV0104CS is not set
@@ -6614,7 +6022,6 @@ CONFIG_SENSORS_ISL29028=m
 # CONFIG_VCNL4035 is not set
 # CONFIG_VEML6030 is not set
 # CONFIG_VEML6070 is not set
-# CONFIG_VEML6075 is not set
 # CONFIG_VL6180 is not set
 # CONFIG_ZOPT2201 is not set
 # end of Light sensors
@@ -6690,14 +6097,12 @@ CONFIG_AK8975=m
 # Pressure sensors
 # CONFIG_ABP060MG is not set
-# CONFIG_ROHM_BM1390 is not set
 CONFIG_BMP280=m
 CONFIG_BMP280_I2C=m
 CONFIG_BMP280_SPI=m
 # CONFIG_DLHL60D is not set
 # CONFIG_DPS310 is not set
 # CONFIG_HP03 is not set
-# CONFIG_HSC030PA is not set
 # CONFIG_ICP10100 is not set
 # CONFIG_MPL115_I2C is not set
 # CONFIG_MPL115_SPI is not set
@@ -6741,7 +6146,6 @@ CONFIG_BMP280_SPI=m
 # CONFIG_AD2S90 is not set
 # CONFIG_AD2S1200 is not set
-# CONFIG_AD2S1210 is not set
 # end of Resolver to digital converters
@@ -6751,7 +6155,6 @@ CONFIG_BMP280_SPI=m
 # CONFIG_MAXIM_THERMOCOUPLE is not set
 # CONFIG_MLX90614 is not set
 # CONFIG_MLX90632 is not set
-# CONFIG_MLX90635 is not set
 # CONFIG_TMP006 is not set
 # CONFIG_TMP007 is not set
 # CONFIG_TMP117 is not set
@@ -6760,7 +6163,6 @@ CONFIG_BMP280_SPI=m
 # CONFIG_MAX30208 is not set
 # CONFIG_MAX31856 is not set
 # CONFIG_MAX31865 is not set
-# CONFIG_MCP9600 is not set
 # end of Temperature sensors
 # CONFIG_NTB is not set
@@ -6783,12 +6185,9 @@ CONFIG_PWM_TWL_LED=m
 # IRQ chip support
 CONFIG_IRQCHIP=y
-CONFIG_ARM_GIC=y
-CONFIG_ARM_GIC_MAX_NR=1
 # CONFIG_AL_FIC is not set
 CONFIG_OMAP_IRQCHIP=y
 # CONFIG_XILINX_INTC is not set
-CONFIG_IRQ_CROSSBAR=y
 # end of IRQ chip support
 # CONFIG_IPACK_BUS is not set
@@ -6821,10 +6220,13 @@ CONFIG_GENERIC_PHY=y
 CONFIG_PHY_CPCAP_USB=m
 CONFIG_PHY_MAPPHONE_MDM6600=m
 # CONFIG_PHY_OCELOT_SERDES is not set
+# CONFIG_PHY_QCOM_USB_HS is not set
+# CONFIG_PHY_QCOM_USB_HSIC is not set
 CONFIG_PHY_DM816X_USB=m
 CONFIG_OMAP_CONTROL_PHY=y
 CONFIG_OMAP_USB2=m
 CONFIG_TI_PIPE3=y
+# CONFIG_PHY_TUSB1210 is not set
 CONFIG_TWL4030_USB=m
 CONFIG_PHY_TI_GMII_SEL=y
 # end of PHY Subsystem
@@ -6839,7 +6241,6 @@ CONFIG_PHY_TI_GMII_SEL=y
 # CONFIG_ARM_CCN is not set
 CONFIG_ARM_PMU=y
 # CONFIG_ARM_PMUV3 is not set
-# CONFIG_DWC_PCIE_PMU is not set
 # end of Performance monitor support
 # CONFIG_RAS is not set
@@ -6854,7 +6255,6 @@ CONFIG_ARM_PMU=y
 # CONFIG_DAX is not set
 CONFIG_NVMEM=y
 CONFIG_NVMEM_SYSFS=y
-CONFIG_NVMEM_LAYOUTS=y
 # Layout Types
@@ -6917,7 +6317,6 @@ CONFIG_FS_MBCACHE=y
 # CONFIG_BTRFS_FS is not set
 # CONFIG_NILFS2_FS is not set
 # CONFIG_F2FS_FS is not set
-# CONFIG_BCACHEFS_FS is not set
 CONFIG_FS_POSIX_ACL=y
 CONFIG_EXPORTFS=y
 # CONFIG_EXPORTFS_BLOCK_OPS is not set
@@ -6943,6 +6342,7 @@ CONFIG_AUTOFS_FS=m
 # Caches
+# CONFIG_FSCACHE is not set
 # end of Caches
@@ -7156,16 +6556,12 @@ CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,bpf"
 # Memory initialization
-CONFIG_CC_HAS_AUTO_VAR_INIT_PATTERN=y
-CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO_BARE=y
-CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO=y
-# CONFIG_INIT_STACK_NONE is not set
-# CONFIG_INIT_STACK_ALL_PATTERN is not set
-CONFIG_INIT_STACK_ALL_ZERO=y
+CONFIG_INIT_STACK_NONE=y
+# CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set
+# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set
+# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set
 # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
 # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
-CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y
-# CONFIG_ZERO_CALL_USED_REGS is not set
 # end of Memory initialization
@@ -7188,7 +6584,7 @@ CONFIG_CRYPTO=y
 CONFIG_CRYPTO_ALGAPI=y
 CONFIG_CRYPTO_ALGAPI2=y
-CONFIG_CRYPTO_AEAD=y
+CONFIG_CRYPTO_AEAD=m
 CONFIG_CRYPTO_AEAD2=y
 CONFIG_CRYPTO_SIG2=y
 CONFIG_CRYPTO_SKCIPHER=y
@@ -7253,12 +6649,14 @@ CONFIG_CRYPTO_FCRYPT=m
 # CONFIG_CRYPTO_ADIANTUM is not set
 # CONFIG_CRYPTO_CHACHA20 is not set
 CONFIG_CRYPTO_CBC=m
+# CONFIG_CRYPTO_CFB is not set
 CONFIG_CRYPTO_CTR=m
 # CONFIG_CRYPTO_CTS is not set
-CONFIG_CRYPTO_ECB=y
+CONFIG_CRYPTO_ECB=m
 # CONFIG_CRYPTO_HCTR2 is not set
 # CONFIG_CRYPTO_KEYWRAP is not set
 # CONFIG_CRYPTO_LRW is not set
+# CONFIG_CRYPTO_OFB is not set
 CONFIG_CRYPTO_PCBC=m
 # CONFIG_CRYPTO_XTS is not set
 # end of Length-preserving ciphers and modes
@@ -7328,9 +6726,7 @@ CONFIG_CRYPTO_DRBG_HMAC=y
 # CONFIG_CRYPTO_DRBG_CTR is not set
 CONFIG_CRYPTO_DRBG=m
 CONFIG_CRYPTO_JITTERENTROPY=m
-CONFIG_CRYPTO_JITTERENTROPY_MEMORY_BLOCKS=64
-CONFIG_CRYPTO_JITTERENTROPY_MEMORY_BLOCKSIZE=32
-CONFIG_CRYPTO_JITTERENTROPY_OSR=1
+# CONFIG_CRYPTO_JITTERENTROPY_TESTINTERFACE is not set
 # end of Random number generation
@@ -7379,7 +6775,6 @@ CONFIG_CRYPTO_DEV_OMAP_DES=m
 # CONFIG_CRYPTO_DEV_QAT_C3XXX is not set
 # CONFIG_CRYPTO_DEV_QAT_C62X is not set
 # CONFIG_CRYPTO_DEV_QAT_4XXX is not set
-# CONFIG_CRYPTO_DEV_QAT_420XX is not set
 # CONFIG_CRYPTO_DEV_QAT_DH895xCCVF is not set
 # CONFIG_CRYPTO_DEV_QAT_C3XXXVF is not set
 # CONFIG_CRYPTO_DEV_QAT_C62XVF is not set
@@ -7465,40 +6860,31 @@ CONFIG_ZLIB_INFLATE=y
 CONFIG_ZLIB_DEFLATE=y
 CONFIG_LZO_COMPRESS=y
 CONFIG_LZO_DECOMPRESS=y
-CONFIG_LZ4_DECOMPRESS=y
 CONFIG_ZSTD_COMMON=y
 CONFIG_ZSTD_COMPRESS=y
 CONFIG_ZSTD_DECOMPRESS=y
 CONFIG_XZ_DEC=y
 CONFIG_XZ_DEC_X86=y
 CONFIG_XZ_DEC_POWERPC=y
+CONFIG_XZ_DEC_IA64=y
 CONFIG_XZ_DEC_ARM=y
 CONFIG_XZ_DEC_ARMTHUMB=y
 CONFIG_XZ_DEC_SPARC=y
 # CONFIG_XZ_DEC_MICROLZMA is not set
 CONFIG_XZ_DEC_BCJ=y
 # CONFIG_XZ_DEC_TEST is not set
-CONFIG_DECOMPRESS_GZIP=y
-CONFIG_DECOMPRESS_BZIP2=y
-CONFIG_DECOMPRESS_LZMA=y
-CONFIG_DECOMPRESS_XZ=y
-CONFIG_DECOMPRESS_LZO=y
-CONFIG_DECOMPRESS_LZ4=y
-CONFIG_DECOMPRESS_ZSTD=y
 CONFIG_GENERIC_ALLOCATOR=y
 CONFIG_BCH=y
 CONFIG_TEXTSEARCH=y
 CONFIG_TEXTSEARCH_KMP=m
 CONFIG_TEXTSEARCH_BM=m
 CONFIG_TEXTSEARCH_FSM=m
-CONFIG_XARRAY_MULTI=y
 CONFIG_ASSOCIATIVE_ARRAY=y
 CONFIG_HAS_IOMEM=y
 CONFIG_HAS_IOPORT=y
 CONFIG_HAS_IOPORT_MAP=y
 CONFIG_HAS_DMA=y
 CONFIG_DMA_OPS=y
-CONFIG_NEED_SG_DMA_LENGTH=y
 CONFIG_NEED_DMA_MAP_STATE=y
 CONFIG_DMA_DECLARE_COHERENT=y
 CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
@@ -7506,7 +6892,6 @@ CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
 CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
 CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
 CONFIG_DMA_NONCOHERENT_MMAP=y
-CONFIG_ARCH_HAS_DMA_ALLOC=y
 CONFIG_DMA_CMA=y
@@ -7527,7 +6912,6 @@ CONFIG_DQL=y
 CONFIG_GLOB=y
 # CONFIG_GLOB_SELFTEST is not set
 CONFIG_NLATTR=y
-CONFIG_GENERIC_ATOMIC64=y
 CONFIG_CLZ_TAB=y
 # CONFIG_IRQ_POLL is not set
 CONFIG_MPILIB=y
@@ -7555,9 +6939,7 @@ CONFIG_SG_SPLIT=y
 CONFIG_SG_POOL=y
 CONFIG_ARCH_STACKWALK=y
 CONFIG_STACKDEPOT=y
-CONFIG_STACKDEPOT_MAX_FRAMES=64
 CONFIG_SBITMAP=y
-# CONFIG_LWQ_TEST is not set
 # end of Library routines
 CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
@@ -7588,18 +6970,15 @@ CONFIG_DEBUG_MISC=y
 # Compile-time checks and compiler options
-# CONFIG_DEBUG_INFO is not set
-CONFIG_AS_HAS_NON_CONST_ULEB128=y
-CONFIG_DEBUG_INFO_NONE=y
+CONFIG_DEBUG_INFO=y
+CONFIG_AS_HAS_NON_CONST_LEB128=y
+# CONFIG_DEBUG_INFO_NONE is not set
 # CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT is not set
-# CONFIG_DEBUG_INFO_DWARF4 is not set
+CONFIG_DEBUG_INFO_DWARF4=y
 # CONFIG_DEBUG_INFO_DWARF5 is not set
 # CONFIG_DEBUG_INFO_REDUCED is not set
-# CONFIG_DEBUG_INFO_COMPRESSED_NONE is not set
-# CONFIG_DEBUG_INFO_COMPRESSED_ZLIB is not set
-# CONFIG_DEBUG_INFO_SPLIT is not set
-CONFIG_PAHOLE_HAS_SPLIT_BTF=y
-CONFIG_PAHOLE_HAS_LANG_EXCLUDE=y
+CONFIG_DEBUG_INFO_COMPRESSED_NONE=y
+CONFIG_DEBUG_INFO_SPLIT=y
 # CONFIG_GDB_SCRIPTS is not set
 CONFIG_FRAME_WARN=1024
 # CONFIG_STRIP_ASM_SYMS is not set
@@ -7626,7 +7005,6 @@ CONFIG_HAVE_ARCH_KGDB=y
 # CONFIG_KGDB is not set
 CONFIG_ARCH_HAS_UBSAN_SANITIZE_ALL=y
 # CONFIG_UBSAN is not set
-CONFIG_HAVE_KCSAN_COMPILER=y
 # end of Generic Kernel Debugging Instruments
@@ -7651,7 +7029,6 @@ CONFIG_SLUB_DEBUG=y
 # CONFIG_DEBUG_WX is not set
 CONFIG_HAVE_DEBUG_KMEMLEAK=y
 # CONFIG_DEBUG_KMEMLEAK is not set
-# CONFIG_PER_VMA_LOCK_STATS is not set
 # CONFIG_DEBUG_OBJECTS is not set
 # CONFIG_SHRINKER_DEBUG is not set
 # CONFIG_DEBUG_STACK_USAGE is not set
@@ -7666,8 +7043,6 @@ CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
 CONFIG_HAVE_ARCH_KASAN=y
 CONFIG_HAVE_ARCH_KASAN_VMALLOC=y
 CONFIG_CC_HAS_KASAN_GENERIC=y
-CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
-# CONFIG_KASAN is not set
 CONFIG_HAVE_ARCH_KFENCE=y
 # CONFIG_KFENCE is not set
 # end of Memory Debugging
@@ -7733,6 +7108,8 @@ CONFIG_STACKTRACE=y
 # CONFIG_DEBUG_MAPLE_TREE is not set
 # end of Debug kernel data structures
+# CONFIG_DEBUG_CREDENTIALS is not set
 # RCU Debugging
@@ -7866,7 +7243,6 @@ CONFIG_RUNTIME_TESTING_MENU=y
 # CONFIG_TEST_MEMCAT_P is not set
 # CONFIG_TEST_MEMINIT is not set
 # CONFIG_TEST_FREE_PAGES is not set
-# CONFIG_TEST_OBJPOOL is not set
 CONFIG_ARCH_USE_MEMTEST=y
 # CONFIG_MEMTEST is not set
 # end of Kernel Testing and Coverage
and i do have a 6.6.0 to test…
debian@39-am335x-bbb:~$ sudo apt-get install linux-image-6.6.0-omap2plus-r0
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 11.6 MB of archives.
After this operation, 56.7 MB of additional disk space will be used.
Get:1 http://repos.rcn-ee.com/debian bookworm/main armhf linux-image-6.6.0-omap2plus-r0 armhf 1bookworm [11.6 MB]
Fetched 11.6 MB in 2s (5747 kB/s)
Config is here… omap2plus-mainline-linux/patches/defconfig at v6.6.x · RobertCNelson/omap2plus-mainline-linux · GitHub
Running uname_boot ...
loading /boot/vmlinuz-6.6.0-omap2plus-r0 ...
5203320 bytes read in 335 ms (14.8 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/6.6.0-omap2plus-r0/am335x-boneblack.dtb ...
70079 bytes read in 11 ms (6.1 MiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
uboot_overlays: [uboot_detected_capes=BBORG_COMMS,] ...
loading /boot/initrd.img-6.6.0-omap2plus-r0 ...
7114293 bytes read in 457 ms (14.8 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait uboot_detected_capes=BBORG_COMMS, coherent_pool=1M net.ifnames=0 rng_core.default_quality=100] ...
debug: [bootz 0x82000000 0x88080000:6c8e35 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x4f6578 ]
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Ramdisk to 8f937000, end 8ffffe35 ... OK
   Loading Device Tree to 8f922000, end 8f9361be ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.6.0-omap2plus-r0 (voodoo@rpi4b4g-03) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP Mon Oct 30 20:16:06 UTC 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
Here’s that diff…
diff --git a/defconfig b/home/voodoo/Downloads/fpcr_defconfig(2)
index 7dbf1ff..b1fcc4c 100644
--- a/defconfig
+++ b/home/voodoo/Downloads/fpcr_defconfig(2)
@@ -2,20 +2,18 @@
 # Automatically generated file; DO NOT EDIT.
 # Linux/arm 6.6.0 Kernel Configuration
-CONFIG_CC_VERSION_TEXT="arm-linux-gnueabi-gcc (GCC) 13.2.0"
+CONFIG_CC_VERSION_TEXT="arm-linux-gnueabihf-gcc (Linaro GCC 6.5-2018.12) 6.5.0"
 CONFIG_CC_IS_GCC=y
-CONFIG_GCC_VERSION=130200
+CONFIG_GCC_VERSION=60500
 CONFIG_CLANG_VERSION=0
 CONFIG_AS_IS_GNU=y
-CONFIG_AS_VERSION=24100
+CONFIG_AS_VERSION=22700
 CONFIG_LD_IS_BFD=y
-CONFIG_LD_VERSION=24100
+CONFIG_LD_VERSION=22700
 CONFIG_LLD_VERSION=0
-CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
-CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
-CONFIG_CC_HAS_ASM_INLINE=y
-CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
-CONFIG_PAHOLE_VERSION=124
+CONFIG_CC_CAN_LINK=y
+CONFIG_CC_CAN_LINK_STATIC=y
+CONFIG_PAHOLE_VERSION=0
 CONFIG_IRQ_WORK=y
 CONFIG_BUILDTIME_TABLE_SORT=y
 CONFIG_THREAD_INFO_IN_TASK=y
@@ -26,7 +24,7 @@ CONFIG_THREAD_INFO_IN_TASK=y
 CONFIG_INIT_ENV_ARG_LIMIT=32
 # CONFIG_COMPILE_TEST is not set
 # CONFIG_WERROR is not set
-CONFIG_LOCALVERSION=""
+CONFIG_LOCALVERSION="-fc-am335x"
 # CONFIG_LOCALVERSION_AUTO is not set
 CONFIG_BUILD_SALT=""
 CONFIG_HAVE_KERNEL_GZIP=y
@@ -58,7 +56,6 @@ CONFIG_AUDITSYSCALL=y
 CONFIG_GENERIC_IRQ_PROBE=y
 CONFIG_GENERIC_IRQ_SHOW=y
 CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
-CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
 CONFIG_GENERIC_IRQ_MIGRATION=y
 CONFIG_HARDIRQS_SW_RESEND=y
 CONFIG_GENERIC_IRQ_CHIP=y
@@ -145,9 +142,7 @@ CONFIG_GENERIC_SCHED_CLOCK=y
 # end of Scheduler features
-CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5"
 CONFIG_GCC11_NO_ARRAY_BOUNDS=y
-CONFIG_CC_NO_ARRAY_BOUNDS=y
 CONFIG_CGROUPS=y
 CONFIG_PAGE_COUNTER=y
 # CONFIG_CGROUP_FAVOR_DYNMODS is not set
@@ -180,15 +175,7 @@ CONFIG_NET_NS=y
 # CONFIG_CHECKPOINT_RESTORE is not set
 # CONFIG_SCHED_AUTOGROUP is not set
 # CONFIG_RELAY is not set
-CONFIG_BLK_DEV_INITRD=y
-CONFIG_INITRAMFS_SOURCE=""
-CONFIG_RD_GZIP=y
-CONFIG_RD_BZIP2=y
-CONFIG_RD_LZMA=y
-CONFIG_RD_XZ=y
-CONFIG_RD_LZO=y
-CONFIG_RD_LZ4=y
-CONFIG_RD_ZSTD=y
+# CONFIG_BLK_DEV_INITRD is not set
 # CONFIG_BOOT_CONFIG is not set
 CONFIG_INITRAMFS_PRESERVE_MTIME=y
 CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
@@ -255,8 +242,6 @@ CONFIG_KEXEC=y
 CONFIG_ARM=y
 CONFIG_ARM_HAS_GROUP_RELOCS=y
-CONFIG_ARM_DMA_USE_IOMMU=y
-CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8
 CONFIG_SYS_SUPPORTS_APM_EMULATION=y
 CONFIG_HAVE_PROC_CPU=y
 CONFIG_STACKTRACE_SUPPORT=y
@@ -319,46 +304,26 @@ CONFIG_ARCH_OMAP=y
 # TI OMAP/AM/DM/DRA Family
-CONFIG_OMAP_HWMOD=y
-CONFIG_ARCH_OMAP2=y
-CONFIG_ARCH_OMAP3=y
-CONFIG_ARCH_OMAP4=y
-CONFIG_SOC_OMAP5=y
+# CONFIG_ARCH_OMAP2 is not set
+# CONFIG_ARCH_OMAP3 is not set
+# CONFIG_ARCH_OMAP4 is not set
+# CONFIG_SOC_OMAP5 is not set
 CONFIG_SOC_AM33XX=y
-CONFIG_SOC_AM43XX=y
-CONFIG_SOC_DRA7XX=y
+# CONFIG_SOC_AM43XX is not set
+# CONFIG_SOC_DRA7XX is not set
 CONFIG_ARCH_OMAP2PLUS=y
-CONFIG_OMAP_INTERCONNECT_BARRIER=y
 # TI OMAP2/3/4 Specific Features
 CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
 CONFIG_SOC_HAS_OMAP2_SDRC=y
-CONFIG_SOC_HAS_REALTIME_COUNTER=y
-CONFIG_POWER_AVS_OMAP=y
-CONFIG_POWER_AVS_OMAP_CLASS3=y
-# CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
-# OMAP Core Type
-CONFIG_SOC_OMAP2420=y
-CONFIG_SOC_OMAP2430=y
-CONFIG_SOC_OMAP3430=y
-CONFIG_SOC_TI81XX=y
 # OMAP Legacy Platform Data Board Type
 CONFIG_MACH_OMAP_GENERIC=y
-CONFIG_MACH_OMAP2_TUSB6010=y
-CONFIG_MACH_NOKIA_N810=y
-CONFIG_MACH_NOKIA_N810_WIMAX=y
-CONFIG_MACH_NOKIA_N8X0=y
 # end of TI OMAP2/3/4 Specific Features
-# CONFIG_OMAP5_ERRATA_801819 is not set
 # end of TI OMAP/AM/DM/DRA Family
 # CONFIG_ARCH_QCOM is not set
@@ -387,7 +352,6 @@ CONFIG_MACH_NOKIA_N8X0=y
 # Processor Type
-CONFIG_CPU_V6=y
 CONFIG_CPU_V6K=y
 CONFIG_CPU_V7=y
 CONFIG_CPU_THUMB_CAPABLE=y
@@ -440,14 +404,12 @@ CONFIG_ARM_L1_CACHE_SHIFT=6
 CONFIG_ARM_DMA_MEM_BUFFERABLE=y
 CONFIG_ARM_HEAVY_MB=y
 CONFIG_DEBUG_ALIGN_RODATA=y
-# CONFIG_ARM_ERRATA_326103 is not set
 CONFIG_ARM_ERRATA_411920=y
 CONFIG_ARM_ERRATA_430973=y
 CONFIG_ARM_ERRATA_643719=y
 CONFIG_ARM_ERRATA_720789=y
 CONFIG_ARM_ERRATA_754322=y
 # CONFIG_ARM_ERRATA_754327 is not set
-# CONFIG_ARM_ERRATA_364296 is not set
 # CONFIG_ARM_ERRATA_764369 is not set
 # CONFIG_ARM_ERRATA_764319 is not set
 CONFIG_ARM_ERRATA_775420=y
@@ -474,13 +436,12 @@ CONFIG_ARM_ERRATA_798181=y
 CONFIG_HAVE_SMP=y
 CONFIG_SMP=y
 CONFIG_SMP_ON_UP=y
+CONFIG_CURRENT_POINTER_IN_TPIDRURO=y
 CONFIG_IRQSTACKS=y
 CONFIG_ARM_CPU_TOPOLOGY=y
 # CONFIG_SCHED_MC is not set
 # CONFIG_SCHED_SMT is not set
-CONFIG_HAVE_ARM_SCU=y
 CONFIG_HAVE_ARM_ARCH_TIMER=y
-CONFIG_HAVE_ARM_TWD=y
 # CONFIG_MCPM is not set
 # CONFIG_BIG_LITTLE is not set
 CONFIG_VMSPLIT_3G=y
@@ -516,7 +477,8 @@ CONFIG_ALIGNMENT_TRAP=y
 # CONFIG_UACCESS_WITH_MEMCPY is not set
 # CONFIG_PARAVIRT is not set
 # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
-CONFIG_CC_HAVE_STACKPROTECTOR_TLS=y
+# CONFIG_XEN is not set
+CONFIG_STACKPROTECTOR_PER_TASK=y
 # end of Kernel Features
@@ -591,8 +553,6 @@ CONFIG_DT_IDLE_STATES=y
 CONFIG_ARM_CPUIDLE=y
 # end of ARM CPU Idle Drivers
-CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=y
 # end of CPU Idle
 # end of CPU Power Management
@@ -728,6 +688,7 @@ CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
 CONFIG_HAVE_GCC_PLUGINS=y
 CONFIG_GCC_PLUGINS=y
 # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
+CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y
 CONFIG_FUNCTION_ALIGNMENT=0
 # end of General architecture-dependent options
@@ -1242,7 +1203,28 @@ CONFIG_BRIDGE_IGMP_SNOOPING=y
 CONFIG_BRIDGE_VLAN_FILTERING=y
 # CONFIG_BRIDGE_MRP is not set
 # CONFIG_BRIDGE_CFM is not set
-# CONFIG_NET_DSA is not set
+CONFIG_NET_DSA=m
+CONFIG_NET_DSA_TAG_NONE=m
+# CONFIG_NET_DSA_TAG_AR9331 is not set
+# CONFIG_NET_DSA_TAG_BRCM is not set
+# CONFIG_NET_DSA_TAG_BRCM_LEGACY is not set
+# CONFIG_NET_DSA_TAG_BRCM_PREPEND is not set
+# CONFIG_NET_DSA_TAG_HELLCREEK is not set
+# CONFIG_NET_DSA_TAG_GSWIP is not set
+# CONFIG_NET_DSA_TAG_DSA is not set
+# CONFIG_NET_DSA_TAG_EDSA is not set
+# CONFIG_NET_DSA_TAG_MTK is not set
+CONFIG_NET_DSA_TAG_KSZ=m
+# CONFIG_NET_DSA_TAG_OCELOT is not set
+# CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set
+# CONFIG_NET_DSA_TAG_QCA is not set
+# CONFIG_NET_DSA_TAG_RTL4_A is not set
+# CONFIG_NET_DSA_TAG_RTL8_4 is not set
+# CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set
+# CONFIG_NET_DSA_TAG_LAN9303 is not set
+# CONFIG_NET_DSA_TAG_SJA1105 is not set
+# CONFIG_NET_DSA_TAG_TRAILER is not set
+# CONFIG_NET_DSA_TAG_XRS700X is not set
 CONFIG_VLAN_8021Q=m
 # CONFIG_VLAN_8021Q_GVRP is not set
 # CONFIG_VLAN_8021Q_MVRP is not set
@@ -1438,10 +1420,8 @@ CONFIG_RXKAD=y
 # CONFIG_AF_KCM is not set
 # CONFIG_MCTP is not set
 CONFIG_WIRELESS=y
-CONFIG_WIRELESS_EXT=y
 CONFIG_WEXT_CORE=y
 CONFIG_WEXT_PROC=y
-CONFIG_WEXT_SPY=y
 CONFIG_CFG80211=m
 # CONFIG_NL80211_TESTMODE is not set
 # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
@@ -1452,15 +1432,13 @@ CONFIG_CFG80211_DEFAULT_PS=y
 # CONFIG_CFG80211_DEBUGFS is not set
 CONFIG_CFG80211_CRDA_SUPPORT=y
 CONFIG_CFG80211_WEXT=y
-CONFIG_LIB80211=m
-# CONFIG_LIB80211_DEBUG is not set
 CONFIG_MAC80211=m
 CONFIG_MAC80211_HAS_RC=y
 CONFIG_MAC80211_RC_MINSTREL=y
 CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
 CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
 # CONFIG_MAC80211_MESH is not set
-# CONFIG_MAC80211_LEDS is not set
+CONFIG_MAC80211_LEDS=y
 # CONFIG_MAC80211_DEBUGFS is not set
 # CONFIG_MAC80211_MESSAGE_TRACING is not set
 # CONFIG_MAC80211_DEBUG_MENU is not set
@@ -1536,17 +1514,11 @@ CONFIG_VGA_ARB_MAX_GPUS=16
 # DesignWare-based PCIe controllers
-CONFIG_PCIE_DW=y
-CONFIG_PCIE_DW_HOST=y
-CONFIG_PCIE_DW_EP=y
 # CONFIG_PCI_MESON is not set
 # CONFIG_PCI_LAYERSCAPE is not set
 # CONFIG_PCI_LAYERSCAPE_EP is not set
 # CONFIG_PCIE_DW_PLAT_HOST is not set
 # CONFIG_PCIE_DW_PLAT_EP is not set
-CONFIG_PCI_DRA7XX=y
-CONFIG_PCI_DRA7XX_HOST=y
-CONFIG_PCI_DRA7XX_EP=y
 # end of DesignWare-based PCIe controllers
@@ -1757,7 +1729,6 @@ CONFIG_MTD_NAND_CORE=y
 CONFIG_MTD_ONENAND=y
 CONFIG_MTD_ONENAND_VERIFY_WRITE=y
 # CONFIG_MTD_ONENAND_GENERIC is not set
-CONFIG_MTD_ONENAND_OMAP2=y
 # CONFIG_MTD_ONENAND_OTP is not set
 # CONFIG_MTD_ONENAND_2X_PROGRAM is not set
 CONFIG_MTD_RAW_NAND=y
@@ -1884,8 +1855,9 @@ CONFIG_SENSORS_TSL2550=m
 CONFIG_SRAM=y
 CONFIG_SRAM_EXEC=y
 # CONFIG_DW_XDATA_PCIE is not set
-CONFIG_PCI_ENDPOINT_TEST=m
+# CONFIG_PCI_ENDPOINT_TEST is not set
 # CONFIG_XILINX_SDFEC is not set
+CONFIG_MISC_RTSX=m
 # CONFIG_HISI_HIKEY_USB is not set
 # CONFIG_OPEN_DICE is not set
 # CONFIG_VCPU_STALL_DETECTOR is not set
@@ -1894,7 +1866,7 @@ CONFIG_PCI_ENDPOINT_TEST=m
 # EEPROM support
-CONFIG_EEPROM_AT24=m
+CONFIG_EEPROM_AT24=y
 CONFIG_EEPROM_AT25=m
 # CONFIG_EEPROM_LEGACY is not set
 # CONFIG_EEPROM_MAX6875 is not set
@@ -1919,7 +1891,7 @@ CONFIG_EEPROM_93CX6=y
 # CONFIG_BCM_VK is not set
 # CONFIG_MISC_ALCOR_PCI is not set
 # CONFIG_MISC_RTSX_PCI is not set
-# CONFIG_MISC_RTSX_USB is not set
+CONFIG_MISC_RTSX_USB=m
 # CONFIG_UACCE is not set
 # CONFIG_PVPANIC is not set
 # CONFIG_GP_PCI1XXXX is not set
@@ -2143,6 +2115,36 @@ CONFIG_NET_CORE=y
 # CONFIG_VIRTIO_NET is not set
 # CONFIG_NLMON is not set
 # CONFIG_ARCNET is not set
+# Distributed Switch Architecture drivers
+# CONFIG_B53 is not set
+# CONFIG_NET_DSA_BCM_SF2 is not set
+# CONFIG_NET_DSA_LOOP is not set
+# CONFIG_NET_DSA_LANTIQ_GSWIP is not set
+# CONFIG_NET_DSA_MT7530 is not set
+# CONFIG_NET_DSA_MV88E6060 is not set
+CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON=m
+# CONFIG_NET_DSA_MICROCHIP_KSZ9477_I2C is not set
+CONFIG_NET_DSA_MICROCHIP_KSZ_SPI=m
+CONFIG_NET_DSA_MICROCHIP_KSZ_PTP=y
+# CONFIG_NET_DSA_MICROCHIP_KSZ8863_SMI is not set
+# CONFIG_NET_DSA_MV88E6XXX is not set
+# CONFIG_NET_DSA_MSCC_OCELOT_EXT is not set
+# CONFIG_NET_DSA_MSCC_SEVILLE is not set
+# CONFIG_NET_DSA_AR9331 is not set
+# CONFIG_NET_DSA_QCA8K is not set
+# CONFIG_NET_DSA_SJA1105 is not set
+# CONFIG_NET_DSA_XRS700X_I2C is not set
+# CONFIG_NET_DSA_XRS700X_MDIO is not set
+# CONFIG_NET_DSA_REALTEK is not set
+# CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
+# CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
+# CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
+# CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
+# end of Distributed Switch Architecture drivers
 CONFIG_ETHERNET=y
 CONFIG_NET_VENDOR_3COM=y
 # CONFIG_VORTEX is not set
@@ -2215,7 +2217,11 @@ CONFIG_NET_VENDOR_ADI=y
 # CONFIG_ADIN1110 is not set
 CONFIG_NET_VENDOR_LITEX=y
 # CONFIG_LITEX_LITEETH is not set
-# CONFIG_NET_VENDOR_MARVELL is not set
+CONFIG_NET_VENDOR_MARVELL=y
+# CONFIG_MVMDIO is not set
+# CONFIG_SKGE is not set
+# CONFIG_SKY2 is not set
+# CONFIG_PRESTERA is not set
 CONFIG_NET_VENDOR_MELLANOX=y
 # CONFIG_MLX4_EN is not set
 # CONFIG_MLX5_CORE is not set
@@ -2226,7 +2232,12 @@ CONFIG_NET_VENDOR_MICREL=y
 CONFIG_KS8851=y
 CONFIG_KS8851_MLL=y
 # CONFIG_KSZ884X_PCI is not set
-# CONFIG_NET_VENDOR_MICROCHIP is not set
+CONFIG_NET_VENDOR_MICROCHIP=y
+# CONFIG_ENC28J60 is not set
+# CONFIG_ENCX24J600 is not set
+# CONFIG_LAN743X is not set
+# CONFIG_LAN966X_SWITCH is not set
+# CONFIG_VCAP is not set
 CONFIG_NET_VENDOR_MICROSEMI=y
 # CONFIG_MSCC_OCELOT_SWITCH is not set
 CONFIG_NET_VENDOR_MICROSOFT=y
@@ -2293,7 +2304,6 @@ CONFIG_NET_VENDOR_SYNOPSYS=y
 CONFIG_NET_VENDOR_TEHUTI=y
 # CONFIG_TEHUTI is not set
 CONFIG_NET_VENDOR_TI=y
-CONFIG_TI_DAVINCI_EMAC=y
 CONFIG_TI_DAVINCI_MDIO=y
 # CONFIG_TI_CPSW_PHY_SEL is not set
 CONFIG_TI_CPSW=y
@@ -2348,7 +2358,7 @@ CONFIG_AX88796B_PHY=m
 # CONFIG_MEDIATEK_GE_PHY is not set
 CONFIG_MICREL_PHY=y
 # CONFIG_MICROCHIP_T1S_PHY is not set
-# CONFIG_MICROCHIP_PHY is not set
+CONFIG_MICROCHIP_PHY=y
 # CONFIG_MICROCHIP_T1_PHY is not set
 # CONFIG_MICROSEMI_PHY is not set
 # CONFIG_MOTORCOMM_PHY is not set
@@ -2357,7 +2367,7 @@ CONFIG_MICREL_PHY=y
 # CONFIG_NXP_C45_TJA11XX_PHY is not set
 # CONFIG_NXP_TJA11XX_PHY is not set
 # CONFIG_NCN26000_PHY is not set
-CONFIG_AT803X_PHY=y
+# CONFIG_AT803X_PHY is not set
 # CONFIG_QSEMI_PHY is not set
 # CONFIG_REALTEK_PHY is not set
 # CONFIG_RENESAS_PHY is not set
@@ -2367,8 +2377,8 @@ CONFIG_SMSC_PHY=y
 # CONFIG_TERANETICS_PHY is not set
 # CONFIG_DP83822_PHY is not set
 # CONFIG_DP83TC811_PHY is not set
-CONFIG_DP83848_PHY=y
-CONFIG_DP83867_PHY=y
+# CONFIG_DP83848_PHY is not set
+# CONFIG_DP83867_PHY is not set
 # CONFIG_DP83869_PHY is not set
 # CONFIG_DP83TD510_PHY is not set
 # CONFIG_VITESSE_PHY is not set
@@ -2514,113 +2524,25 @@ CONFIG_USB_CDC_PHONET=m
 # CONFIG_USB_NET_AQC111 is not set
 CONFIG_USB_RTL8153_ECM=m
 CONFIG_WLAN=y
-CONFIG_WLAN_VENDOR_ADMTEK=y
-# CONFIG_ADM8211 is not set
-CONFIG_WLAN_VENDOR_ATH=y
-# CONFIG_ATH_DEBUG is not set
-# CONFIG_ATH5K is not set
-# CONFIG_ATH5K_PCI is not set
-# CONFIG_ATH9K is not set
-# CONFIG_ATH9K_HTC is not set
-# CONFIG_CARL9170 is not set
-# CONFIG_ATH6KL is not set
-# CONFIG_AR5523 is not set
-# CONFIG_WIL6210 is not set
-# CONFIG_ATH10K is not set
-# CONFIG_WCN36XX is not set
-# CONFIG_ATH11K is not set
-# CONFIG_ATH12K is not set
-CONFIG_WLAN_VENDOR_ATMEL=y
-# CONFIG_ATMEL is not set
-# CONFIG_AT76C50X_USB is not set
-CONFIG_WLAN_VENDOR_BROADCOM=y
-# CONFIG_B43 is not set
-# CONFIG_B43LEGACY is not set
-# CONFIG_BRCMSMAC is not set
-# CONFIG_BRCMFMAC is not set
-CONFIG_WLAN_VENDOR_CISCO=y
-# CONFIG_AIRO is not set
-CONFIG_WLAN_VENDOR_INTEL=y
-# CONFIG_IPW2100 is not set
-# CONFIG_IPW2200 is not set
-# CONFIG_IWL4965 is not set
-# CONFIG_IWL3945 is not set
-# CONFIG_IWLWIFI is not set
-CONFIG_WLAN_VENDOR_INTERSIL=y
-# CONFIG_HOSTAP is not set
-# CONFIG_HERMES is not set
-# CONFIG_P54_COMMON is not set
-CONFIG_WLAN_VENDOR_MARVELL=y
-CONFIG_LIBERTAS=m
-CONFIG_LIBERTAS_USB=m
-CONFIG_LIBERTAS_SDIO=m
-# CONFIG_LIBERTAS_SPI is not set
-CONFIG_LIBERTAS_DEBUG=y
-# CONFIG_LIBERTAS_MESH is not set
-# CONFIG_LIBERTAS_THINFIRM is not set
-CONFIG_MWIFIEX=m
-CONFIG_MWIFIEX_SDIO=m
-# CONFIG_MWIFIEX_PCIE is not set
-CONFIG_MWIFIEX_USB=m
-# CONFIG_MWL8K is not set
-CONFIG_WLAN_VENDOR_MEDIATEK=y
-# CONFIG_MT7601U is not set
-# CONFIG_MT76x0U is not set
-# CONFIG_MT76x0E is not set
-# CONFIG_MT76x2E is not set
-# CONFIG_MT76x2U is not set
-# CONFIG_MT7603E is not set
-# CONFIG_MT7615E is not set
-# CONFIG_MT7663U is not set
-# CONFIG_MT7663S is not set
-# CONFIG_MT7915E is not set
-# CONFIG_MT7921E is not set
-# CONFIG_MT7921S is not set
-# CONFIG_MT7921U is not set
-# CONFIG_MT7996E is not set
-CONFIG_WLAN_VENDOR_MICROCHIP=y
-# CONFIG_WILC1000_SDIO is not set
-# CONFIG_WILC1000_SPI is not set
-CONFIG_WLAN_VENDOR_PURELIFI=y
-# CONFIG_PLFXLC is not set
-CONFIG_WLAN_VENDOR_RALINK=y
-# CONFIG_RT2X00 is not set
-CONFIG_WLAN_VENDOR_REALTEK=y
-# CONFIG_RTL8180 is not set
-# CONFIG_RTL8187 is not set
-CONFIG_RTL_CARDS=m
-# CONFIG_RTL8192CE is not set
-# CONFIG_RTL8192SE is not set
-# CONFIG_RTL8192DE is not set
-# CONFIG_RTL8723AE is not set
-# CONFIG_RTL8723BE is not set
-# CONFIG_RTL8188EE is not set
-# CONFIG_RTL8192EE is not set
-# CONFIG_RTL8821AE is not set
-# CONFIG_RTL8192CU is not set
-# CONFIG_RTL8XXXU is not set
-# CONFIG_RTW88 is not set
-# CONFIG_RTW89 is not set
-CONFIG_WLAN_VENDOR_RSI=y
-# CONFIG_RSI_91X is not set
-CONFIG_WLAN_VENDOR_SILABS=y
-# CONFIG_WFX is not set
-CONFIG_WLAN_VENDOR_ST=y
-# CONFIG_CW1200 is not set
-CONFIG_WLAN_VENDOR_TI=y
-CONFIG_WL1251=m
-CONFIG_WL1251_SPI=m
-# CONFIG_WL1251_SDIO is not set
-CONFIG_WL12XX=m
-CONFIG_WL18XX=m
-CONFIG_WLCORE=m
-CONFIG_WLCORE_SPI=m
-CONFIG_WLCORE_SDIO=m
-CONFIG_WLAN_VENDOR_ZYDAS=y
-# CONFIG_USB_ZD1201 is not set
-# CONFIG_ZD1211RW is not set
-CONFIG_WLAN_VENDOR_QUANTENNA=y
-# CONFIG_QTNFMAC_PCIE is not set
+# CONFIG_WLAN_VENDOR_ADMTEK is not set
+# CONFIG_WLAN_VENDOR_ATH is not set
+# CONFIG_WLAN_VENDOR_ATMEL is not set
+# CONFIG_WLAN_VENDOR_BROADCOM is not set
+# CONFIG_WLAN_VENDOR_CISCO is not set
+# CONFIG_WLAN_VENDOR_INTEL is not set
+# CONFIG_WLAN_VENDOR_INTERSIL is not set
+# CONFIG_WLAN_VENDOR_MARVELL is not set
+# CONFIG_WLAN_VENDOR_MEDIATEK is not set
+# CONFIG_WLAN_VENDOR_MICROCHIP is not set
+# CONFIG_WLAN_VENDOR_PURELIFI is not set
+# CONFIG_WLAN_VENDOR_RALINK is not set
+# CONFIG_WLAN_VENDOR_REALTEK is not set
+# CONFIG_WLAN_VENDOR_RSI is not set
+# CONFIG_WLAN_VENDOR_SILABS is not set
+# CONFIG_WLAN_VENDOR_ST is not set
+# CONFIG_WLAN_VENDOR_TI is not set
+# CONFIG_WLAN_VENDOR_ZYDAS is not set
+# CONFIG_WLAN_VENDOR_QUANTENNA is not set
 # CONFIG_USB_NET_RNDIS_WLAN is not set
 # CONFIG_MAC80211_HWSIM is not set
 # CONFIG_VIRT_WIFI is not set
@@ -2793,7 +2715,7 @@ CONFIG_INPUT_CPCAP_PWRBUTTON=m
 # CONFIG_INPUT_CM109 is not set
 # CONFIG_INPUT_REGULATOR_HAPTIC is not set
 CONFIG_INPUT_TPS65218_PWRBUTTON=m
-CONFIG_INPUT_TWL4030_PWRBUTTON=m
+# CONFIG_INPUT_TWL4030_PWRBUTTON is not set
 # CONFIG_INPUT_TWL4030_VIBRA is not set
 # CONFIG_INPUT_TWL6040_VIBRA is not set
 CONFIG_INPUT_UINPUT=m
@@ -2916,7 +2838,6 @@ CONFIG_HW_RANDOM=m
 # CONFIG_HW_RANDOM_TIMERIOMEM is not set
 # CONFIG_HW_RANDOM_BA431 is not set
 CONFIG_HW_RANDOM_OMAP=m
-CONFIG_HW_RANDOM_OMAP3_ROM=m
 # CONFIG_HW_RANDOM_VIRTIO is not set
 # CONFIG_HW_RANDOM_CCTRNG is not set
 # CONFIG_HW_RANDOM_XIPHERA is not set
@@ -2992,11 +2913,11 @@ CONFIG_I2C_OMAP=y
 # CONFIG_I2C_VIRTIO is not set
 # end of I2C Hardware Bus support
-# CONFIG_I2C_STUB is not set
+CONFIG_I2C_STUB=m
 # CONFIG_I2C_SLAVE is not set
-# CONFIG_I2C_DEBUG_CORE is not set
-# CONFIG_I2C_DEBUG_ALGO is not set
-# CONFIG_I2C_DEBUG_BUS is not set
+CONFIG_I2C_DEBUG_CORE=y
+CONFIG_I2C_DEBUG_ALGO=y
+CONFIG_I2C_DEBUG_BUS=y
 # end of I2C support
 # CONFIG_I3C is not set
@@ -3052,13 +2973,10 @@ CONFIG_HSI_BOARDINFO=y
 # HSI controllers
-CONFIG_OMAP_SSI=m
 # HSI clients
-# CONFIG_CMT_SPEECH is not set
-CONFIG_SSI_PROTOCOL=m
 # CONFIG_HSI_CHAR is not set
 CONFIG_PPS=y
 # CONFIG_PPS_DEBUG is not set
@@ -3097,7 +3015,9 @@ CONFIG_PINCONF=y
 CONFIG_GENERIC_PINCONF=y
 # CONFIG_DEBUG_PINCTRL is not set
 # CONFIG_PINCTRL_CY8C95X0 is not set
-# CONFIG_PINCTRL_MCP23S08 is not set
+CONFIG_PINCTRL_MCP23S08_I2C=y
+CONFIG_PINCTRL_MCP23S08_SPI=y
+CONFIG_PINCTRL_MCP23S08=y
 # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
 # CONFIG_PINCTRL_OCELOT is not set
 # CONFIG_PINCTRL_PALMAS is not set
@@ -3110,7 +3030,6 @@ CONFIG_PINCTRL_SINGLE=y
 # end of Renesas pinctrl drivers
-CONFIG_PINCTRL_TI_IODELAY=y
 CONFIG_GPIOLIB=y
 CONFIG_GPIOLIB_FASTPATH_LIMIT=512
 CONFIG_OF_GPIO=y
@@ -3435,7 +3354,7 @@ CONFIG_SENSORS_LM75=m
 # CONFIG_SENSORS_DME1737 is not set
 # CONFIG_SENSORS_EMC1403 is not set
 # CONFIG_SENSORS_EMC2103 is not set
-# CONFIG_SENSORS_EMC2305 is not set
+CONFIG_SENSORS_EMC2305=m
 # CONFIG_SENSORS_EMC6W201 is not set
 # CONFIG_SENSORS_SMSC47M1 is not set
 # CONFIG_SENSORS_SMSC47M192 is not set
@@ -3496,10 +3415,6 @@ CONFIG_CPU_FREQ_THERMAL=y
 CONFIG_TI_SOC_THERMAL=y
 CONFIG_TI_THERMAL=y
-CONFIG_OMAP3_THERMAL=y
-CONFIG_OMAP4_THERMAL=y
-CONFIG_OMAP5_THERMAL=y
-CONFIG_DRA752_THERMAL=y
 # end of Texas Instruments thermal drivers
 # CONFIG_GENERIC_ADC_THERMAL is not set
@@ -3653,7 +3568,6 @@ CONFIG_TWL4030_CORE=y
 CONFIG_TWL4030_POWER=y
 CONFIG_MFD_TWL4030_AUDIO=y
 CONFIG_TWL6040_CORE=y
-CONFIG_MENELAUS=y
 # CONFIG_MFD_WL1273_CORE is not set
 # CONFIG_MFD_LM3533 is not set
 # CONFIG_MFD_TC3589X is not set
@@ -3965,10 +3879,6 @@ CONFIG_V4L_PLATFORM_DRIVERS=y
 # Texas Instruments drivers
-# CONFIG_VIDEO_TI_CAL is not set
-# CONFIG_VIDEO_AM437X_VPFE is not set
-CONFIG_VIDEO_OMAP3=m
-# CONFIG_VIDEO_OMAP3_DEBUG is not set
 # Verisilicon media platform drivers
@@ -3989,10 +3899,6 @@ CONFIG_VIDEO_OMAP3=m
 # CONFIG_SMS_SDIO_DRV is not set
 # CONFIG_V4L_TEST_DRIVERS is not set
 # CONFIG_DVB_TEST_DRIVERS is not set
-CONFIG_VIDEOBUF2_CORE=m
-CONFIG_VIDEOBUF2_V4L2=m
-CONFIG_VIDEOBUF2_MEMOPS=m
-CONFIG_VIDEOBUF2_DMA_CONTIG=m
 # end of Media drivers
@@ -4095,7 +4001,6 @@ CONFIG_VIDEO_MT9P031=m
@@ -4633,6 +4538,7 @@ CONFIG_DRM_TI_TPD12S015=m
@@ -4754,393 +4660,7 @@ CONFIG_LOGO_LINUX_CLUT224=y
-CONFIG_SOUND=m
-CONFIG_SND=m
-CONFIG_SND_TIMER=m
-CONFIG_SND_PCM=m
-CONFIG_SND_HWDEP=m
-CONFIG_SND_JACK=y
-CONFIG_SND_DEBUG=y
-CONFIG_SND_PCI=y
-# HD-Audio
-# end of HD-Audio
-CONFIG_SND_ARM=y
-CONFIG_SND_SPI=y
-CONFIG_SND_USB=y
-CONFIG_SND_SOC=m
-# CODEC drivers
 CONFIG_HID=y
@@ -5166,7 +4686,6 @@ CONFIG_HID_GENERIC=m
@@ -5280,9 +4799,9 @@ CONFIG_I2C_HID=y
 CONFIG_USB=m
@@ -5322,7 +4841,6 @@ CONFIG_USB_EHCI_HCD_OMAP=m
@@ -5334,7 +4852,7 @@ CONFIG_USB_OHCI_HCD_PLATFORM=m
 CONFIG_USB_ACM=m
 CONFIG_USB_WDM=m
@@ -5347,20 +4865,21 @@ CONFIG_USB_WDM=m
+CONFIG_USB_UAS=m
@@ -5393,6 +4912,7 @@ CONFIG_USB_INVENTRA_DMA=y
 CONFIG_USB_TI_CPPI41_DMA=y
 CONFIG_USB_DWC3=m
@@ -5476,16 +4996,16 @@ CONFIG_USB_SERIAL_OPTION=m
+CONFIG_USB_LD=m
 CONFIG_USB_TEST=m
@@ -5549,7 +5069,6 @@ CONFIG_USB_F_ACM=m
 CONFIG_USB_F_OBEX=m
 CONFIG_USB_F_NCM=m
@@ -5560,9 +5079,6 @@ CONFIG_USB_F_SUBSET=m
 CONFIG_USB_F_FS=m
 CONFIG_USB_F_HID=m
@@ -5577,11 +5093,6 @@ CONFIG_USB_CONFIGFS_PHONET=y
@@ -5590,14 +5101,12 @@ CONFIG_USB_CONFIGFS_F_HID=y
 CONFIG_USB_ZERO=m
@@ -5643,6 +5152,7 @@ CONFIG_MMC_OMAP_HS=y
@@ -5794,7 +5304,6 @@ CONFIG_RTC_DRV_DS1307=m
@@ -6004,6 +5513,7 @@ CONFIG_IOMMU_SUPPORT=y
@@ -6015,14 +5525,13 @@ CONFIG_OF_IOMMU=y
 CONFIG_OMAP_IOMMU=y
 CONFIG_REMOTEPROC=y
@@ -6234,7 +5743,7 @@ CONFIG_INA2XX_ADC=m
@@ -6676,12 +6185,9 @@ CONFIG_PWM_TWL_LED=m
 # IRQ chip support
 CONFIG_IRQCHIP=y
-CONFIG_ARM_GIC=y
@@ -6714,10 +6220,13 @@ CONFIG_GENERIC_PHY=y
 CONFIG_OMAP_USB2=m
 CONFIG_TI_PIPE3=y
@@ -7047,16 +6556,12 @@ CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,bpf"
@@ -7355,7 +6860,6 @@ CONFIG_ZLIB_INFLATE=y
@@ -7369,27 +6873,18 @@ CONFIG_XZ_DEC_SPARC=y
 CONFIG_XZ_DEC_BCJ=y
 CONFIG_BCH=y
 CONFIG_TEXTSEARCH=y
 CONFIG_HAS_IOMEM=y
 CONFIG_HAS_IOPORT=y
 CONFIG_HAS_DMA=y
 CONFIG_DMA_OPS=y
@@ -7417,7 +6912,6 @@ CONFIG_DQL=y
 CONFIG_GLOB=y
 CONFIG_NLATTR=y
 CONFIG_CLZ_TAB=y
 CONFIG_MPILIB=y
@@ -7476,18 +6970,15 @@ CONFIG_DEBUG_MISC=y
@@ -7514,7 +7005,6 @@ CONFIG_HAVE_ARCH_KGDB=y
@@ -7553,8 +7043,6 @@ CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
Wonder if it could be a toolchain issue… So for 6.6.x i’m recommending: gcc 13…
Which you can grab here: Index of /pub/tools/crosstool/files/bin/x86_64/13.2.0/
Regards,
Do you have the successful 6.7 defconfig? That’s the kernel I have the most faith has your patch set and everything I’ll upgrade my toolchain, apply that defconfig and see what happens. I just have a few device drivers I’ll need to turn on if that works
Yeap… bb-kernel/patches/debian at am33x-v6.7 · RobertCNelson/bb-kernel · GitHub
Side note looking at my CI farm, the oldest gcc versions used to build the kernel are:
Debian (Buster) 10.x: gcc 8.3.x
Ubuntu (Focal) 20.04: gcc 9.4.x
I’d say gcc 7, and 6 get very little testing anymore… and buster is going away…
Regards,
