Timed out waiting for device dev-ttyS0.device
Still working at trying to get Linux operating on a custom AM3352 processor. I am using a prebuilt Kernel 4.19.94-ti-r36 for the BBB. I am using my own DTB file. I am scratching my head with regard to what is happening to the Getty for TTYS0. Thoughts anyone?
loading /boot/initrd.img-4.19.94-ti-r36 ...
6447239 bytes read in 858 ms (7.2 MiB/s)
debug: [console=ttyS0,115200n8 earlyprintk coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:626087 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Ramdisk to 8d93a000, end 8df60087 ... OK
   Loading Device Tree to 8d92f000, end 8d9396fe ... OK
Starting kernel ...
[    0.001633] timer_probe: no matching timers found
[    0.395533] l4_wkup_cm:clk:0010:0: failed to disable
[    2.365045] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    2.552506] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 600000000 (-34)
[    3.002486] omap_voltage_late_init: Voltage driver support not added
[    3.011214] PM: Cannot get wkup_m3_ipc handle
[    3.136779] PM: Cannot get wkup_m3_ipc handle
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[ TIME ] Timed out waiting for device dev-ttyS0.device.
[DEPEND] Dependency failed for Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Started Generic Board Startup.
         Starting BB WL18xx Bluetooth Service...
[  OK  ] Started BB WL18xx Bluetooth Service.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Freezes here.
Hmm, no thoughts.
So now I tried a new kernel build. This appears to stop booting (hang?) I am using the same U-Boot, just a different Kernel version.
I have been trying to get Linux booting on this board for months now.
Here is the output:
loading /boot/vmlinuz-5.4.66EPN11291-ti-r18 …
7270912 bytes read in 982 ms (7.1 MiB/s)
setenv fdtdir /boot/dtbs/5.4.66EPN11291-ti-r18 …
debug: [enable_uboot_overlays=] …
loading /boot/ep11291.dtb …
30463 bytes read in 53 ms (560.5 KiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable… debug: [console=ttyS0,115200n8 earlyprintk coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 systemd.unit=rescue.target] …
debug: [bootz 0x82000000 - 0x88000000] …
Loading Device Tree to 8df55000, end 8df5f6fe … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.66EPN11291-ti-r18 (rich@poseiden) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 PREEMPT Tue Oct 20 18:43:42 EDT 2020
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Flight Circuits EPN11291
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x8a800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64452
[ 0.000000] Kernel command line: console=ttyS0,115200n8 earlyprintk coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 systemd.unit=rescue.target
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 194640K/260096K available (7168K kernel code, 934K rwdata, 2956K rodata, 1024K init, 297K bss, 16304K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x31c with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 35692 entries in 70 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 25000000 Hz
[ 0.000028] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[ 0.000074] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000102] OMAP clocksource: timer1 at 25000000 Hz
[ 0.001523] timer_probe: no matching timers found
[ 0.002043] Console: colour dummy device 80x30
[ 0.002180] Calibrating delay loop… 297.98 BogoMIPS (lpj=595968)
[ 0.037800] pid_max: default: 32768 minimum: 301
[ 0.038630] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.038673] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.038935] *** VALIDATE tmpfs ***
[ 0.040606] *** VALIDATE proc ***
[ 0.041276] *** VALIDATE cgroup1 ***
[ 0.041314] *** VALIDATE cgroup2 ***
[ 0.041452] CPU: Testing write buffer coherency: ok
[ 0.041572] CPU0: Spectre v2: using BPIALL workaround
[ 0.043946] Setting up static identity map for 0x80100000 - 0x80100054
[ 0.044364] rcu: Hierarchical SRCU implementation.
[ 0.049733] EFI services will not be available.
[ 0.050898] devtmpfs: initialized
[ 0.073447] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.074859] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.074912] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.083755] pinctrl core: initialized pinctrl subsystem
[ 0.086673] NET: Registered protocol family 16
[ 0.096547] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.140267] l4_wkup_cm:clk:0010:0: failed to disable
[ 0.143067] audit: initializing netlink subsys (disabled)
[ 0.145359] cpuidle: using governor ladder
[ 0.145453] cpuidle: using governor menu
[ 0.149883] audit: type=2000 audit(0.136:1): state=initialized audit_enabled=0 res=1
[ 0.160108] platform 44e07000.gpio: Cannot lookup hwmod ‘gpio1’
[ 0.160479] omap_gpio 44e07000.gpio: Could not get gpio dbck. Disable debounce
[ 0.160531] omap_gpio 44e07000.gpio: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.161466] OMAP GPIO hardware version 0.1
[ 0.162260] platform 4804c000.gpio: Cannot lookup hwmod ‘gpio2’
[ 0.162623] omap_gpio 4804c000.gpio: Could not get gpio dbck. Disable debounce
[ 0.162669] omap_gpio 4804c000.gpio: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.164149] platform 481ac000.gpio: Cannot lookup hwmod ‘gpio3’
[ 0.164493] omap_gpio 481ac000.gpio: Could not get gpio dbck. Disable debounce
[ 0.164537] omap_gpio 481ac000.gpio: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.166060] platform 481ae000.gpio: Cannot lookup hwmod ‘gpio4’
[ 0.166418] omap_gpio 481ae000.gpio: Could not get gpio dbck. Disable debounce
[ 0.166461] omap_gpio 481ae000.gpio: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 0.167884] platform 44e09000.serial: Cannot lookup hwmod ‘uart1’
[ 0.168571] platform 48022000.serial: Cannot lookup hwmod ‘uart2’
[ 0.169526] platform 48060000.mmc: Cannot lookup hwmod ‘mmc1’
[ 0.170295] platform 481d8000.mmc: Cannot lookup hwmod ‘mmc2’
[ 0.178324] platform 4a100000.ethernet: Cannot lookup hwmod ‘cpgmac0’
[ 0.183078] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.240293] debugfs: Directory ‘49000000.edma’ with parent ‘dmaengine’ already present!
[ 0.240361] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.247228] SCSI subsystem initialized
[ 0.248610] pps_core: LinuxPPS API ver. 1 registered
[ 0.248638] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.249623] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.251335] Advanced Linux Sound Architecture Driver Initialized.
[ 0.254690] clocksource: Switched to clocksource timer1
[ 1.026709] random: fast init done
[ 2.624734] *** VALIDATE bpf ***
[ 2.625586] VFS: Disk quotas dquot_6.6.0
[ 2.625769] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.626016] *** VALIDATE ramfs ***
[ 2.651490] thermal_sys: Registered thermal governor ‘fair_share’
[ 2.651507] thermal_sys: Registered thermal governor ‘bang_bang’
[ 2.651543] thermal_sys: Registered thermal governor ‘step_wise’
[ 2.652496] NET: Registered protocol family 2
[ 2.654502] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 2.654583] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 2.654665] TCP bind hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 2.654944] TCP: Hash tables configured (established 2048 bind 2048)
[ 2.655225] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.655283] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.655824] NET: Registered protocol family 1
[ 2.657487] RPC: Registered named UNIX socket transport module.
[ 2.657519] RPC: Registered udp transport module.
[ 2.657539] RPC: Registered tcp transport module.
[ 2.657558] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.657585] NET: Registered protocol family 44
[ 2.659841] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 2.664478] Initialise system trusted keyrings
[ 2.665029] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 2.683636] zbud: loaded
[ 2.690499] NFS: Registering the id_resolver key type
[ 2.690581] Key type id_resolver registered
[ 2.690604] Key type id_legacy registered
[ 2.690653] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.691368] fuse: init (API version 7.31)
[ 2.691658] *** VALIDATE fuse ***
[ 2.691693] *** VALIDATE fuse ***
[ 2.806308] Key type asymmetric registered
[ 2.806345] Asymmetric key parser ‘x509’ registered
[ 2.806481] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.807023] io scheduler mq-deadline registered
[ 2.812269] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 2.818334] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.821474] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 2.828446] omap8250 44e09000.serial: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 2.829167] printk: console [ttyS0] disabled
[ 2.829386] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 3.599561] printk: console [ttyS0] enabled
[ 3.605556] omap8250 48022000.serial: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 3.615358] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 3.629075] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 3.635906] random: crng init done
[ 3.641315] sdhci: Secure Digital Host Controller Interface driver
[ 3.647627] sdhci: Copyright© Pierre Ossman
[ 3.652973] omap_gpio 4804c000.gpio: Could not set line 27 debounce to 200000 microseconds (-524)
[ 3.661991] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 3.667100] omap_hsmmc: probe of 48060000.mmc failed with error -2
[ 3.674151] omap_hsmmc: probe of 481d8000.mmc failed with error -2
[ 3.680751] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.699992] libphy: Fixed MDIO Bus: probed
[ 3.708729] cpsw 4a100000.ethernet: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
[ 3.722540] omap_rtc 44e3e000.rtc: registered as rtc0
[ 3.728242] i2c /dev entries driver
[ 3.735481] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 3.743327] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 3.755100] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
[ 3.762804] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 600000000 (-34)
[ 3.771690] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 300000 KHz
[ 3.782160] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.789660] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 3.796519] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 3.811760] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 3.833397] remoteproc remoteproc0: wkup_m3 is available
[ 3.856172] drop_monitor: Initializing network drop monitor service
[ 3.863344] wireguard: WireGuard 0.0.20191219 loaded. See www.wireguard.com for information.
[ 3.871997] wireguard: Copyright © 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
[ 3.886173] NET: Registered protocol family 10
[ 3.904094] Segment Routing with IPv6
[ 3.908953] mip6: Mobile IPv6
[ 3.912729] NET: Registered protocol family 17
[ 3.918499] Key type dns_resolver registered
[ 3.923193] mpls_gso: MPLS GSO support
[ 3.928777] ThumbEE CPU extension supported.
[ 3.933356] omap_voltage_late_init: Voltage driver support not added
[ 3.940855] PM: Cannot get wkup_m3_ipc handle
[ 3.947553] registered taskstats version 1
[ 3.951856] Loading compiled-in X.509 certificates
[ 3.957182] zswap: loaded using pool lzo/zbud
[ 3.964219] Key type ._fscrypt registered
[ 3.968435] Key type .fscrypt registered
[ 4.056040] PM: Cannot get wkup_m3_ipc handle
[ 4.060720] remoteproc remoteproc0: powering up wkup_m3
[ 4.067085] PM: Cannot get wkup_m3_ipc handle
[ 4.071710] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 4.082390] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[ 4.091798] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
Collapse
No output after this point.
Thanks for looking this far.
Rich
Not the main issue, but your doubling up some options in /boot/uEnv.txt…
please post your kernel config, what ever changes you made seem to have nuked the gpio pin-muxing…
Regards,
Thanks. I knew about the cmd line args. I modified your script that makes SD card images and I added some code to append to the cmd args stuff to bring up the board in rescue mode if specified on the command line of the script.
part 1
# Automatically generated file; DO NOT EDIT.
# Linux/arm 5.4.66 Kernel Configuration
# Compiler: arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=80300
CONFIG_CLANG_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="EPN11291"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
# CONFIG_KERNEL_GZIP is not set
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
CONFIG_KERNEL_LZO=y
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_PSI=y
# CONFIG_PSI_DEFAULT_DISABLED is not set
# end of CPU/Task time and stats accounting
# RCU Subsystem
CONFIG_PREEMPT_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_TASKS_RCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_IKHEADERS=m
CONFIG_LOG_BUF_SHIFT=17
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# end of Scheduler features
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_MEMCG_SWAP_ENABLED=y
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_RDMA=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CHECKPOINT_RESTORE=y
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
# CONFIG_SYSFS_SYSCALL is not set
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_BPF_SYSCALL=y
# CONFIG_BPF_JIT_ALWAYS_ON is not set
CONFIG_USERFAULTFD=y
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_RSEQ=y
# CONFIG_DEBUG_RSEQ is not set
CONFIG_EMBEDDED=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_MEMCG_SYSFS_ON is not set
# CONFIG_COMPAT_BRK is not set
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
CONFIG_SLAB_FREELIST_RANDOM=y
CONFIG_SLAB_FREELIST_HARDENED=y
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_ARCH_HAS_BANDGAP=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# end of Multiple platform selection
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MILBEAUT is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NPCM is not set
CONFIG_ARCH_OMAP=y
# TI OMAP Common Features
# OMAP Feature Selections
CONFIG_OMAP_RESET_CLOCKS=y
CONFIG_OMAP_32K_TIMER=y
# end of TI OMAP Common Features
CONFIG_MACH_OMAP_GENERIC=y
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
CONFIG_SOC_OMAP5=y
CONFIG_SOC_AM33XX=y
CONFIG_SOC_AM43XX=y
CONFIG_SOC_DRA7XX=y
CONFIG_ARCH_OMAP2PLUS=y
CONFIG_OMAP_INTERCONNECT_BARRIER=y
# TI OMAP2/3/4 Specific Features
CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
CONFIG_SOC_HAS_OMAP2_SDRC=y
CONFIG_SOC_HAS_REALTIME_COUNTER=y
# OMAP Legacy Platform Data Board Type
# end of TI OMAP2/3/4 Specific Features
CONFIG_OMAP5_ERRATA_801819=y
# end of TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_RDA is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
CONFIG_ARM_THUMB=y
CONFIG_ARM_THUMBEE=y
CONFIG_ARM_VIRT_EXT=y
# CONFIG_SWP_EMULATE is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
# CONFIG_CACHE_L2X0_PMU is not set
CONFIG_PL310_ERRATA_588369=y
CONFIG_PL310_ERRATA_727915=y
CONFIG_PL310_ERRATA_753970=y
CONFIG_PL310_ERRATA_769419=y
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_DEBUG_ALIGN_RODATA=y
CONFIG_ARM_ERRATA_430973=y
CONFIG_ARM_ERRATA_720789=y
CONFIG_ARM_ERRATA_754322=y
CONFIG_ARM_ERRATA_775420=y
CONFIG_ARM_ERRATA_773022=y
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_857271 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# CONFIG_ARM_ERRATA_857272 is not set
# end of System Type
# Bus support
CONFIG_ARM_ERRATA_814220=y
# end of Bus support
# Kernel Features
CONFIG_HAVE_SMP=y
# CONFIG_SMP is not set
CONFIG_HAVE_ARM_SCU=y
CONFIG_HAVE_ARM_ARCH_TIMER=y
CONFIG_HAVE_ARM_TWD=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_ARM_PSCI=y
CONFIG_ARCH_NR_GPIO=512
CONFIG_HZ_FIXED=0
# CONFIG_HZ_100 is not set
# CONFIG_HZ_200 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_SCHED_HRTICK=y
CONFIG_THUMB2_KERNEL=y
CONFIG_THUMB2_AVOID_R_ARM_THM_JUMP11=y
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARM_MODULE_PLTS=y
CONFIG_FORCE_MAX_ZONEORDER=12
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
CONFIG_SECCOMP=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
# CONFIG_ATAGS is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
# CONFIG_ARM_APPENDED_DTB is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
CONFIG_EFI_STUB=y
CONFIG_EFI=y
# CONFIG_DMI is not set
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=m
CONFIG_CPU_FREQ_GOV_ONDEMAND=m
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set
CONFIG_ARM_TI_CPUFREQ=y
# CONFIG_QORIQ_CPUFREQ is not set
# end of CPU Frequency scaling
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
# CONFIG_CPU_IDLE_GOV_TEO is not set
CONFIG_DT_IDLE_STATES=y
# ARM CPU Idle Drivers
CONFIG_ARM_CPUIDLE=y
# CONFIG_ARM_PSCI_CPUIDLE is not set
# CONFIG_ARM_HIGHBANK_CPUIDLE is not set
# end of ARM CPU Idle Drivers
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# end of Floating point emulation
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_SUSPEND_SKIP_SYNC is not set
CONFIG_HIBERNATE_CALLBACKS=y
CONFIG_HIBERNATION=y
CONFIG_PM_STD_PARTITION=""
CONFIG_PM_SLEEP=y
CONFIG_PM_AUTOSLEEP=y
CONFIG_PM_WAKELOCKS=y
CONFIG_PM_WAKELOCKS_LIMIT=100
CONFIG_PM_WAKELOCKS_GC=y
CONFIG_PM=y
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_PM_SLEEP_DEBUG=y
CONFIG_APM_EMULATION=y
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
# Firmware Drivers
# CONFIG_ARM_SCMI_PROTOCOL is not set
# CONFIG_ARM_SCPI_PROTOCOL is not set
# CONFIG_FIRMWARE_MEMMAP is not set
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_TRUSTED_FOUNDATIONS is not set
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_ARM_PSCI_FW=y
# CONFIG_GOOGLE_FIRMWARE is not set
# EFI (Extensible Firmware Interface) Support
# CONFIG_EFI_VARS is not set
CONFIG_EFI_ESRT=y
CONFIG_EFI_PARAMS_FROM_FDT=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_ARMSTUB=y
CONFIG_EFI_ARMSTUB_DTB_LOADER=y
# CONFIG_EFI_CAPSULE_LOADER is not set
# CONFIG_EFI_TEST is not set
# CONFIG_RESET_ATTACK_MITIGATION is not set
# end of EFI (Extensible Firmware Interface) Support
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
# CONFIG_CRYPTO_SHA1_ARM_CE is not set
# CONFIG_CRYPTO_SHA2_ARM_CE is not set
CONFIG_CRYPTO_SHA256_ARM=m
CONFIG_CRYPTO_SHA512_ARM=m
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
# CONFIG_CRYPTO_AES_ARM_CE is not set
# CONFIG_CRYPTO_GHASH_ARM_CE is not set
# CONFIG_CRYPTO_CRCT10DIF_ARM_CE is not set
# CONFIG_CRYPTO_CRC32_ARM_CE is not set
CONFIG_CRYPTO_CHACHA20_NEON=m
# CONFIG_CRYPTO_NHPOLY1305_NEON is not set
# CONFIG_VIRTUALIZATION is not set
# General architecture-dependent options
CONFIG_OPROFILE=m
CONFIG_HAVE_OPROFILE=y
CONFIG_KPROBES=y
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_UPROBES=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_HAVE_COPY_THREAD_TLS=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_64BIT_TIME=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
CONFIG_REFCOUNT_FULL=y
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_PLUGIN_HOSTCC="g++"
CONFIG_HAVE_GCC_PLUGINS=y
# CONFIG_GCC_PLUGINS is not set
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
CONFIG_MODULE_COMPRESS=y
# CONFIG_MODULE_COMPRESS_GZIP is not set
CONFIG_MODULE_COMPRESS_XZ=y
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_BSGLIB=y
CONFIG_BLK_DEV_INTEGRITY=y
CONFIG_BLK_DEV_ZONED=y
CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_BLK_DEV_THROTTLING_LOW is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
CONFIG_BLK_WBT=y
# CONFIG_BLK_CGROUP_IOLATENCY is not set
# CONFIG_BLK_CGROUP_IOCOST is not set
CONFIG_BLK_WBT_MQ=y
CONFIG_BLK_DEBUG_FS=y
CONFIG_BLK_DEBUG_FS_ZONED=y
CONFIG_BLK_SED_OPAL=y
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
CONFIG_KARMA_PARTITION=y
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
# end of Partition Types
CONFIG_BLK_MQ_VIRTIO=y
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=m
CONFIG_IOSCHED_BFQ=m
CONFIG_BFQ_GROUP_IOSCHED=y
# CONFIG_BFQ_CGROUP_DEBUG is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_UNINLINE_SPIN_UNLOCK=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
CONFIG_BINFMT_MISC=m
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_BOUNCE=y
CONFIG_KSM=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
# CONFIG_CLEANCACHE is not set
CONFIG_FRONTSWAP=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
CONFIG_ZSWAP=y
CONFIG_ZPOOL=y
CONFIG_ZBUD=y
CONFIG_Z3FOLD=m
CONFIG_ZSMALLOC=m
# CONFIG_PGTABLE_MAPPING is not set
# CONFIG_ZSMALLOC_STAT is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
# end of Memory Management options
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
CONFIG_NET_REDIRECT=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_DIAG=m
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_UNIX_DIAG=m
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_OFFLOAD=y
CONFIG_XFRM_ALGO=m
CONFIG_XFRM_USER=m
CONFIG_XFRM_INTERFACE=m
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
CONFIG_XFRM_STATISTICS=y
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
CONFIG_NET_KEY_MIGRATE=y
CONFIG_XDP_SOCKETS=y
# CONFIG_XDP_SOCKETS_DIAG is not set
CONFIG_INET=y
CONFIG_WIREGUARD=y
# CONFIG_WIREGUARD_DEBUG is not set
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_FIB_TRIE_STATS=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=y
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=y
CONFIG_NET_FOU=m
CONFIG_NET_FOU_IP_TUNNELS=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_ESP_OFFLOAD=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
CONFIG_INET_UDP_DIAG=m
CONFIG_INET_RAW_DIAG=m
CONFIG_INET_DIAG_DESTROY=y
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
CONFIG_TCP_CONG_HSTCP=m
CONFIG_TCP_CONG_HYBLA=m
CONFIG_TCP_CONG_VEGAS=m
CONFIG_TCP_CONG_NV=m
CONFIG_TCP_CONG_SCALABLE=m
CONFIG_TCP_CONG_LP=m
CONFIG_TCP_CONG_VENO=m
CONFIG_TCP_CONG_YEAH=m
CONFIG_TCP_CONG_ILLINOIS=m
CONFIG_TCP_CONG_DCTCP=m
CONFIG_TCP_CONG_CDG=m
CONFIG_TCP_CONG_BBR=m
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
CONFIG_TCP_MD5SIG=y
CONFIG_IPV6=y
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_ESP_OFFLOAD=m
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_MIP6=y
CONFIG_IPV6_ILA=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_IPV6_VTI=m
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
CONFIG_IPV6_GRE=m
CONFIG_IPV6_FOU=m
CONFIG_IPV6_FOU_TUNNEL=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_PIMSM_V2=y
CONFIG_IPV6_SEG6_LWTUNNEL=y
CONFIG_IPV6_SEG6_HMAC=y
CONFIG_IPV6_SEG6_BPF=y
CONFIG_NETWORK_SECMARK=y
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NETFILTER_NETLINK_OSF=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_COMMON=m
CONFIG_NF_LOG_NETDEV=m
CONFIG_NETFILTER_CONNCOUNT=m
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_SECMARK=y
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_PROCFS=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_TIMEOUT=y
CONFIG_NF_CONNTRACK_TIMESTAMP=y
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_GRE=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NF_CT_NETLINK_TIMEOUT=m
CONFIG_NF_CT_NETLINK_HELPER=m
CONFIG_NETFILTER_NETLINK_GLUE_CT=y
CONFIG_NF_NAT=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_NAT_MASQUERADE=y
CONFIG_NETFILTER_SYNPROXY=m
CONFIG_NF_TABLES=m
CONFIG_NF_TABLES_SET=m
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=m
CONFIG_NFT_FLOW_OFFLOAD=m
CONFIG_NFT_COUNTER=m
CONFIG_NFT_CONNLIMIT=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
CONFIG_NFT_TUNNEL=m
CONFIG_NFT_OBJREF=m
CONFIG_NFT_QUEUE=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_REJECT_INET=m
CONFIG_NFT_COMPAT=m
CONFIG_NFT_HASH=m
CONFIG_NFT_FIB=m
CONFIG_NFT_FIB_INET=m
CONFIG_NFT_XFRM=m
CONFIG_NFT_SOCKET=m
CONFIG_NFT_OSF=m
CONFIG_NFT_TPROXY=m
CONFIG_NFT_SYNPROXY=m
CONFIG_NF_DUP_NETDEV=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NFT_FIB_NETDEV=m
CONFIG_NF_FLOW_TABLE_INET=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NETFILTER_XTABLES=m
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
# Xtables targets
CONFIG_NETFILTER_XT_TARGET_AUDIT=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
# CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_SECMARK=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
CONFIG_NETFILTER_XT_MATCH_CGROUP=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPCOMP=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
# end of Core Netfilter Configuration
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
CONFIG_IP_SET_HASH_IPMARK=m
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
CONFIG_IP_SET_HASH_IPMAC=m
CONFIG_IP_SET_HASH_MAC=m
CONFIG_IP_SET_HASH_NETPORTNET=m
CONFIG_IP_SET_HASH_NET=m
CONFIG_IP_SET_HASH_NETNET=m
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
CONFIG_IP_VS_IPV6=y
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_FO=m
CONFIG_IP_VS_OVF=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_MH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS MH scheduler
CONFIG_IP_VS_MH_TAB_INDEX=12
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_TABLES_IPV4=y
CONFIG_NFT_REJECT_IPV4=m
CONFIG_NFT_DUP_IPV4=m
CONFIG_NFT_FIB_IPV4=m
CONFIG_NF_TABLES_ARP=y
CONFIG_NF_FLOW_TABLE_IPV4=m
CONFIG_NF_DUP_IPV4=m
CONFIG_NF_LOG_ARP=m
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_SYNPROXY=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# end of IP: Netfilter Configuration
# IPv6: Netfilter Configuration
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_NF_TABLES_IPV6=y
CONFIG_NFT_REJECT_IPV6=m
CONFIG_NFT_DUP_IPV6=m
CONFIG_NFT_FIB_IPV6=m
CONFIG_NF_FLOW_TABLE_IPV6=m
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_MATCH_SRH=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_TARGET_SYNPROXY=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
# end of IPv6: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV6=m
CONFIG_NF_TABLES_BRIDGE=m
CONFIG_NFT_BRIDGE_META=m
CONFIG_NFT_BRIDGE_REJECT=m
CONFIG_NF_LOG_BRIDGE=m
CONFIG_NF_CONNTRACK_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
# CONFIG_BPFILTER is not set
CONFIG_IP_DCCP=m
CONFIG_INET_DCCP_DIAG=m
# DCCP CCIDs Configuration
# CONFIG_IP_DCCP_CCID2_DEBUG is not set
CONFIG_IP_DCCP_CCID3=y
# CONFIG_IP_DCCP_CCID3_DEBUG is not set
CONFIG_IP_DCCP_TFRC_LIB=y
# end of DCCP CCIDs Configuration
# DCCP Kernel Hacking
# CONFIG_IP_DCCP_DEBUG is not set
# end of DCCP Kernel Hacking
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_SHA1=y
CONFIG_INET_SCTP_DIAG=m
CONFIG_RDS=m
CONFIG_RDS_TCP=m
# CONFIG_RDS_DEBUG is not set
CONFIG_TIPC=m
CONFIG_TIPC_MEDIA_UDP=y
CONFIG_TIPC_DIAG=m
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
# CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
# CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_L2TP=m
CONFIG_L2TP_DEBUGFS=m
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_MRP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
# CONFIG_DECNET is not set
CONFIG_LLC=m
CONFIG_LLC2=m
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=m
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
CONFIG_PHONET=m
CONFIG_6LOWPAN=m
# CONFIG_6LOWPAN_DEBUGFS is not set
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
CONFIG_6LOWPAN_NHC_HOP=m
CONFIG_6LOWPAN_NHC_IPV6=m
CONFIG_6LOWPAN_NHC_MOBILITY=m
CONFIG_6LOWPAN_NHC_ROUTING=m
CONFIG_6LOWPAN_NHC_UDP=m
CONFIG_6LOWPAN_GHC_EXT_HDR_HOP=m
CONFIG_6LOWPAN_GHC_UDP=m
CONFIG_6LOWPAN_GHC_ICMPV6=m
CONFIG_6LOWPAN_GHC_EXT_HDR_DEST=m
CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG=m
CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE=m
CONFIG_IEEE802154=m
# CONFIG_IEEE802154_NL802154_EXPERIMENTAL is not set
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
# CONFIG_NET_SCH_TAPRIO is not set
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_SKBPRIO=m
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
CONFIG_NET_SCH_CAKE=m
CONFIG_NET_SCH_FQ=m
CONFIG_NET_SCH_HHF=m
CONFIG_NET_SCH_PIE=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_SCH_PLUG=m
# CONFIG_NET_SCH_DEFAULT is not set
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_PERF=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
CONFIG_NET_CLS_BPF=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_MATCHALL=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
CONFIG_NET_EMATCH_CANID=m
CONFIG_NET_EMATCH_IPSET=m
CONFIG_NET_EMATCH_IPT=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_SAMPLE=m
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
# CONFIG_NET_ACT_MPLS is not set
CONFIG_NET_ACT_VLAN=m
CONFIG_NET_ACT_BPF=m
CONFIG_NET_ACT_CONNMARK=m
# CONFIG_NET_ACT_CTINFO is not set
CONFIG_NET_ACT_SKBMOD=m
CONFIG_NET_ACT_IFE=m
CONFIG_NET_ACT_TUNNEL_KEY=m
# CONFIG_NET_ACT_CT is not set
CONFIG_NET_IFE_SKBMARK=m
CONFIG_NET_IFE_SKBPRIO=m
CONFIG_NET_IFE_SKBTCINDEX=m
# CONFIG_NET_TC_SKB_EXT is not set
CONFIG_NET_SCH_FIFO=y
CONFIG_DCB=y
CONFIG_DNS_RESOLVER=y
CONFIG_BATMAN_ADV=m
# CONFIG_BATMAN_ADV_BATMAN_V is not set
CONFIG_BATMAN_ADV_BLA=y
CONFIG_BATMAN_ADV_DAT=y
CONFIG_BATMAN_ADV_NC=y
CONFIG_BATMAN_ADV_MCAST=y
CONFIG_BATMAN_ADV_DEBUGFS=y
# CONFIG_BATMAN_ADV_DEBUG is not set
CONFIG_BATMAN_ADV_SYSFS=y
# CONFIG_BATMAN_ADV_TRACING is not set
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
CONFIG_OPENVSWITCH_GENEVE=m
CONFIG_VSOCKETS=m
CONFIG_VSOCKETS_DIAG=m
CONFIG_VIRTIO_VSOCKETS=m
CONFIG_VIRTIO_VSOCKETS_COMMON=m
CONFIG_NETLINK_DIAG=m
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=y
CONFIG_MPLS_ROUTING=m
CONFIG_MPLS_IPTUNNEL=m
CONFIG_NET_NSH=m
# CONFIG_HSR is not set
CONFIG_NET_SWITCHDEV=y
CONFIG_NET_L3_MASTER_DEV=y
# CONFIG_NET_NCSI is not set
CONFIG_CGROUP_NET_PRIO=y
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
CONFIG_BPF_JIT=y
CONFIG_BPF_STREAM_PARSER=y
# Network testing
CONFIG_NET_PKTGEN=m
CONFIG_NET_DROP_MONITOR=y
# end of Network testing
# end of Networking options
CONFIG_HAMRADIO=y
# Packet Radio protocols
CONFIG_AX25=m
CONFIG_AX25_DAMA_SLAVE=y
CONFIG_NETROM=m
CONFIG_ROSE=m
# AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_YAM=m
# end of AX.25 network device drivers
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
# CONFIG_CAN_J1939 is not set
CONFIG_CAN_ISOTP=m
# CAN Device Drivers
CONFIG_CAN_VCAN=m
# CONFIG_CAN_VXCAN is not set
CONFIG_CAN_SLCAN=m
CONFIG_CAN_DEV=m
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_TI_HECC is not set
CONFIG_CAN_C_CAN=m
CONFIG_CAN_C_CAN_PLATFORM=m
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_RCAR is not set
# CONFIG_CAN_RCAR_CANFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
CONFIG_CAN_HI311X=m
CONFIG_CAN_MCP251X=m
# end of CAN SPI interfaces
# CONFIG_CAN_DEBUG_DEVICES is not set
# end of CAN Device Drivers
CONFIG_BT=m
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
CONFIG_BT_LEDS=y
# CONFIG_BT_SELFTEST is not set
CONFIG_BT_DEBUGFS=y
# Bluetooth device drivers
CONFIG_BT_HCIBTSDIO=m
# CONFIG_BT_HCIUART is not set
# CONFIG_BT_HCIVHCI is not set
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_BT_WILINK=m
# CONFIG_BT_MTKSDIO is not set
CONFIG_BT_MTKUART=m
CONFIG_BT_HCIRSI=m
# end of Bluetooth device drivers
CONFIG_AF_RXRPC=m
CONFIG_AF_RXRPC_IPV6=y
# CONFIG_AF_RXRPC_INJECT_LOSS is not set
# CONFIG_AF_RXRPC_DEBUG is not set
CONFIG_RXKAD=y
# CONFIG_AF_KCM is not set
CONFIG_STREAM_PARSER=y
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
# CONFIG_CFG80211_DEFAULT_PS is not set
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_LIB80211=m
CONFIG_LIB80211_CRYPT_WEP=m
CONFIG_LIB80211_CRYPT_CCMP=m
CONFIG_LIB80211_CRYPT_TKIP=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_WIMAX=m
CONFIG_WIMAX_DEBUG_LEVEL=8
CONFIG_RFKILL=y
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
# CONFIG_RFKILL_GPIO is not set
CONFIG_NET_9P=m
CONFIG_NET_9P_VIRTIO=m
# CONFIG_NET_9P_DEBUG is not set
# CONFIG_CAIF is not set
# CONFIG_RPMSG_PROTO is not set
CONFIG_CEPH_LIB=m
# CONFIG_CEPH_LIB_PRETTYDEBUG is not set
# CONFIG_CEPH_LIB_USE_DNS_RESOLVER is not set
CONFIG_NFC=m
CONFIG_NFC_DIGITAL=m
CONFIG_NFC_NCI=m
CONFIG_NFC_NCI_SPI=m
CONFIG_NFC_NCI_UART=m
# CONFIG_NFC_HCI is not set
# Near Field Communication (NFC) devices
CONFIG_NFC_TRF7970A=m
CONFIG_NFC_SIM=m
# CONFIG_NFC_FDP is not set
CONFIG_NFC_PN533=m
CONFIG_NFC_PN533_I2C=m
# CONFIG_NFC_MRVL_UART is not set
CONFIG_NFC_ST_NCI=m
CONFIG_NFC_ST_NCI_I2C=m
CONFIG_NFC_ST_NCI_SPI=m
CONFIG_NFC_NXP_NCI=m
CONFIG_NFC_NXP_NCI_I2C=m
# CONFIG_NFC_S3FWRN5_I2C is not set
CONFIG_NFC_ST95HF=m
# end of Near Field Communication (NFC) devices
CONFIG_PSAMPLE=m
CONFIG_NET_IFE=m
CONFIG_LWTUNNEL=y
CONFIG_LWTUNNEL_BPF=y
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_NET_SOCK_MSG=y
CONFIG_PAGE_POOL=y
CONFIG_FAILOVER=m
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_FW_LOADER_PAGED_BUF=y
CONFIG_EXTRA_FIRMWARE="am335x-pm-firmware.elf am335x-bone-scale-data.bin am335x-evm-scale-data.bin am43x-evm-scale-data.bin"
CONFIG_EXTRA_FIRMWARE_DIR="firmware"
CONFIG_FW_LOADER_USER_HELPER=y
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
# CONFIG_FW_LOADER_COMPRESS is not set
# end of Firmware loader
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
# end of Generic Driver Options
# Bus devices
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_MOXTET is not set
CONFIG_OMAP_INTERCONNECT=y
CONFIG_OMAP_OCP2SCP=y
CONFIG_SIMPLE_PM_BUS=y
CONFIG_TI_SYSC=y
# CONFIG_VEXPRESS_CONFIG is not set
# end of Bus devices
CONFIG_CONNECTOR=y
CONFIG_PROC_EVENTS=y
CONFIG_GNSS=m
CONFIG_GNSS_SERIAL=m
CONFIG_GNSS_MTK_SERIAL=m
CONFIG_GNSS_SIRF_SERIAL=m
CONFIG_GNSS_UBX_SERIAL=m
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# Partition parsers
CONFIG_MTD_AR7_PARTS=m
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=m
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
CONFIG_RFD_FTL=m
CONFIG_SSFDC=m
# CONFIG_SM_FTL is not set
CONFIG_MTD_OOPS=m
CONFIG_MTD_SWAP=m
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_RAM=m
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=m
# CONFIG_MTD_PHYSMAP_COMPAT is not set
# CONFIG_MTD_PHYSMAP_OF is not set
CONFIG_MTD_PLATRAM=m
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
CONFIG_MTD_DATAFLASH=m
# CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
# CONFIG_MTD_DATAFLASH_OTP is not set
# CONFIG_MTD_MCHP23K256 is not set
CONFIG_MTD_SST25L=m
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
CONFIG_MTD_NAND_CORE=y
CONFIG_MTD_ONENAND=y
CONFIG_MTD_ONENAND_VERIFY_WRITE=y
# CONFIG_MTD_ONENAND_GENERIC is not set
# CONFIG_MTD_ONENAND_OTP is not set
CONFIG_MTD_ONENAND_2X_PROGRAM=y
CONFIG_MTD_NAND_ECC_SW_HAMMING=y
# CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
CONFIG_MTD_RAW_NAND=y
CONFIG_MTD_NAND_ECC_SW_BCH=y
# Raw/parallel NAND flash controllers
# CONFIG_MTD_NAND_DENALI_DT is not set
CONFIG_MTD_NAND_OMAP2=m
# CONFIG_MTD_NAND_OMAP_BCH is not set
# CONFIG_MTD_NAND_BRCMNAND is not set
# CONFIG_MTD_NAND_MXIC is not set
# CONFIG_MTD_NAND_GPIO is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# Misc
CONFIG_MTD_NAND_NANDSIM=m
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_SPI_NAND is not set
# LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_LPDDR=m
CONFIG_MTD_QINFO_PROBE=m
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=m
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_MTK_QUADSPI is not set
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
CONFIG_MTD_UBI_BLOCK=y
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_DYNAMIC=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_OF_RESOLVE=y
CONFIG_OF_OVERLAY=y
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
CONFIG_BLK_DEV_NULL_BLK=m
CONFIG_CDROM=m
CONFIG_ZRAM=m
CONFIG_ZRAM_WRITEBACK=y
CONFIG_ZRAM_MEMORY_TRACKING=y
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=m
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=16384
# CONFIG_CDROM_PKTCDVD is not set
CONFIG_ATA_OVER_ETH=m
CONFIG_VIRTIO_BLK=m
# CONFIG_VIRTIO_BLK_SCSI is not set
CONFIG_BLK_DEV_RBD=m
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
CONFIG_SRAM=y
CONFIG_SRAM_EXEC=y
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_DMA_BUF_PHYS is not set
# CONFIG_C2PORT is not set
# EEPROM support
CONFIG_EEPROM_AT24=y
CONFIG_EEPROM_AT25=y
CONFIG_EEPROM_LEGACY=m
CONFIG_EEPROM_MAX6875=m
CONFIG_EEPROM_93CX6=m
CONFIG_EEPROM_93XX46=m
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
CONFIG_TI_ST=m
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# CONFIG_VOP_BUS is not set
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# end of Intel MIC & related support
CONFIG_BEAGLEBONE_PINMUX_HELPER=y
# CONFIG_ECHO is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
CONFIG_RAID_ATTRS=m
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_NETLINK=y
# CONFIG_SCSI_PROC_FS is not set
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_ST=m
CONFIG_BLK_DEV_SR=m
CONFIG_CHR_DEV_SG=m
CONFIG_CHR_DEV_SCH=m
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
CONFIG_SCSI_SCAN_ASYNC=y
# SCSI Transports
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_SCSI_FC_ATTRS=m
CONFIG_SCSI_ISCSI_ATTRS=m
CONFIG_SCSI_SAS_ATTRS=m
CONFIG_SCSI_SAS_LIBSAS=m
CONFIG_SCSI_SAS_HOST_SMP=y
CONFIG_SCSI_SRP_ATTRS=m
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_ISCSI_BOOT_SYSFS=m
CONFIG_SCSI_UFSHCD=m
# CONFIG_SCSI_UFSHCD_PLATFORM is not set
# CONFIG_SCSI_UFS_BSG is not set
CONFIG_LIBFC=m
CONFIG_LIBFCOE=m
# CONFIG_SCSI_DEBUG is not set
CONFIG_SCSI_VIRTIO=m
CONFIG_SCSI_DH=y
CONFIG_SCSI_DH_RDAC=m
CONFIG_SCSI_DH_HP_SW=m
CONFIG_SCSI_DH_EMC=m
CONFIG_SCSI_DH_ALUA=m
# end of SCSI device support
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
CONFIG_EQUALIZER=m
CONFIG_IFB=m
CONFIG_NET_TEAM=m
CONFIG_NET_TEAM_MODE_BROADCAST=m
CONFIG_NET_TEAM_MODE_ROUNDROBIN=m
CONFIG_NET_TEAM_MODE_RANDOM=m
CONFIG_NET_TEAM_MODE_ACTIVEBACKUP=m
CONFIG_NET_TEAM_MODE_LOADBALANCE=m
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN_L3S=y
CONFIG_IPVLAN=m
CONFIG_IPVTAP=m
CONFIG_VXLAN=m
CONFIG_GENEVE=m
CONFIG_GTP=m
CONFIG_MACSEC=m
CONFIG_NETCONSOLE=m
CONFIG_NETCONSOLE_DYNAMIC=y
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_TUN=m
CONFIG_TAP=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
CONFIG_VIRTIO_NET=m
CONFIG_NLMON=m
CONFIG_NET_VRF=m
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_DUMMY=m
# CONFIG_ATM_TCP is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
# CONFIG_NET_VENDOR_ALACRITECH is not set
# CONFIG_ALTERA_TSE is not set
# CONFIG_NET_VENDOR_AMAZON is not set
# CONFIG_NET_VENDOR_AQUANTIA is not set
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_AURORA is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CADENCE is not set
# CONFIG_NET_VENDOR_CAVIUM is not set
# CONFIG_NET_VENDOR_CIRRUS is not set
# CONFIG_NET_VENDOR_CORTINA is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
# CONFIG_NET_VENDOR_EZCHIP is not set
# CONFIG_NET_VENDOR_FARADAY is not set
# CONFIG_NET_VENDOR_GOOGLE is not set
# CONFIG_NET_VENDOR_HISILICON is not set
# CONFIG_NET_VENDOR_HUAWEI is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
# CONFIG_NET_VENDOR_MELLANOX is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
CONFIG_NET_VENDOR_MICROCHIP=y
CONFIG_ENC28J60=y
# CONFIG_ENC28J60_WRITEVERIFY is not set
CONFIG_ENCX24J600=y
CONFIG_NET_VENDOR_MICROSEMI=y
# CONFIG_MSCC_OCELOT_SWITCH is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_NETRONOME is not set
# CONFIG_NET_VENDOR_NI is not set
# CONFIG_ETHOC is not set
# CONFIG_NET_VENDOR_PENSANDO is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_NET_VENDOR_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
# CONFIG_NET_VENDOR_SOLARFLARE is not set
CONFIG_NET_VENDOR_SMSC=y
CONFIG_SMC91X=m
CONFIG_SMC911X=m
CONFIG_SMSC911X=m
# CONFIG_NET_VENDOR_SOCIONEXT is not set
# CONFIG_NET_VENDOR_STMICRO is not set
# CONFIG_NET_VENDOR_SYNOPSYS is not set
CONFIG_NET_VENDOR_TI=y
CONFIG_TI_DAVINCI_MDIO=y
CONFIG_TI_CPSW_PHY_SEL=y
CONFIG_TI_CPSW=y
CONFIG_TI_CPTS=y
CONFIG_TI_CPTS_MOD=y
# CONFIG_TI_PRUETH is not set
CONFIG_TI_ICSS_IEP=m
CONFIG_TI_PRUETH_ECAP=m
# CONFIG_NET_VENDOR_VIA is not set
CONFIG_NET_VENDOR_WIZNET=y
CONFIG_WIZNET_W5100=y
# CONFIG_WIZNET_W5300 is not set
# CONFIG_WIZNET_BUS_DIRECT is not set
# CONFIG_WIZNET_BUS_INDIRECT is not set
CONFIG_WIZNET_BUS_ANY=y
CONFIG_WIZNET_W5100_SPI=y
# CONFIG_NET_VENDOR_XILINX is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_MDIO_BCM_UNIMAC=m
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MSCC_MIIM is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
CONFIG_LED_TRIGGER_PHY=y
# MII PHY device drivers
# CONFIG_ADIN_PHY is not set
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
CONFIG_AT803X_PHY=y
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
CONFIG_MICREL_PHY=y
CONFIG_MICROCHIP_PHY=y
# CONFIG_MICROCHIP_T1_PHY is not set
CONFIG_MICROSEMI_PHY=y
# CONFIG_NATIONAL_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
CONFIG_SMSC_PHY=y
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
CONFIG_VITESSE_PHY=y
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
CONFIG_PPP=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
CONFIG_PPTP=m
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_SLIP=m
CONFIG_SLHC=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
# Host-side USB support is needed for USB Network Adapter support
CONFIG_WLAN=y
# CONFIG_WIRELESS_WDS is not set
CONFIG_WLAN_VENDOR_ADMTEK=y
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
# CONFIG_ATH9K_AHB is not set
# CONFIG_ATH9K_DEBUGFS is not set
# CONFIG_ATH9K_DYNACK is not set
# CONFIG_ATH9K_WOW is not set
CONFIG_ATH9K_RFKILL=y
CONFIG_ATH9K_CHANNEL_CONTEXT=y
CONFIG_ATH9K_PCOEM=y
# CONFIG_ATH9K_HWRNG is not set
CONFIG_ATH6KL=m
CONFIG_ATH6KL_SDIO=m
# CONFIG_ATH6KL_DEBUG is not set
# CONFIG_ATH6KL_TRACING is not set
CONFIG_ATH10K=m
CONFIG_ATH10K_CE=y
# CONFIG_ATH10K_SDIO is not set
# CONFIG_ATH10K_DEBUG is not set
# CONFIG_ATH10K_DEBUGFS is not set
# CONFIG_ATH10K_TRACING is not set
# CONFIG_WCN36XX is not set
CONFIG_WLAN_VENDOR_ATMEL=y
CONFIG_WLAN_VENDOR_BROADCOM=y
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
CONFIG_BRCMUTIL=m
# CONFIG_BRCMSMAC is not set
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
# CONFIG_BRCM_TRACING is not set
# CONFIG_BRCMDBG is not set
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
CONFIG_WLAN_VENDOR_INTERSIL=y
CONFIG_HOSTAP=m
CONFIG_HOSTAP_FIRMWARE=y
# CONFIG_HOSTAP_FIRMWARE_NVRAM is not set
CONFIG_P54_COMMON=m
# CONFIG_P54_SPI is not set
CONFIG_P54_LEDS=y
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_SDIO=m
# CONFIG_LIBERTAS_SPI is not set
# CONFIG_LIBERTAS_DEBUG is not set
CONFIG_LIBERTAS_MESH=y
CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
# CONFIG_MWIFIEX is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_RT2X00=m
CONFIG_WLAN_VENDOR_REALTEK=y
CONFIG_RTW88=m
CONFIG_WLAN_VENDOR_RSI=y
CONFIG_RSI_91X=m
CONFIG_RSI_DEBUGFS=y
# CONFIG_RSI_SDIO is not set
CONFIG_RSI_COEX=y
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
CONFIG_WL1251=m
CONFIG_WL1251_SPI=m
CONFIG_WL1251_SDIO=m
CONFIG_WL12XX=m
CONFIG_WL18XX=m
CONFIG_WLCORE=m
CONFIG_WLCORE_SPI=m
CONFIG_WLCORE_SDIO=m
CONFIG_WILINK_PLATFORM_DATA=y
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_WLAN_VENDOR_QUANTENNA=y
CONFIG_MAC80211_HWSIM=m
# CONFIG_VIRT_WIFI is not set
# WiMAX Wireless Broadband devices
# Enable USB support to see WiMAX USB drivers
# end of WiMAX Wireless Broadband devices
# CONFIG_WAN is not set
CONFIG_IEEE802154_DRIVERS=m
CONFIG_IEEE802154_FAKELB=m
CONFIG_IEEE802154_AT86RF230=m
# CONFIG_IEEE802154_AT86RF230_DEBUGFS is not set
CONFIG_IEEE802154_MRF24J40=m
CONFIG_IEEE802154_CC2520=m
CONFIG_IEEE802154_ADF7242=m
# CONFIG_IEEE802154_CA8210 is not set
# CONFIG_IEEE802154_MCR20A is not set
CONFIG_IEEE802154_HWSIM=m
# CONFIG_NETDEVSIM is not set
CONFIG_NET_FAILOVER=m
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=y
CONFIG_INPUT_POLLDEV=y
CONFIG_INPUT_SPARSEKMAP=m
CONFIG_INPUT_MATRIXKMAP=m
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
# CONFIG_INPUT_EVBUG is not set
# CONFIG_INPUT_APMPOWER is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
CONFIG_KEYBOARD_ADP5588=m
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
CONFIG_KEYBOARD_QT2160=m
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
CONFIG_KEYBOARD_LM8323=m
# CONFIG_KEYBOARD_LM8333 is not set
CONFIG_KEYBOARD_MAX7359=m
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
CONFIG_KEYBOARD_STOWAWAY=m
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_STMPE is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
part 2
CONFIG_INPUT_MOUSE=y
# CONFIG_MOUSE_PS2 is not set
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_CYAPA is not set
CONFIG_MOUSE_ELAN_I2C=m
CONFIG_MOUSE_ELAN_I2C_I2C=y
# CONFIG_MOUSE_ELAN_I2C_SMBUS is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_MOUSE_GPIO is not set
CONFIG_MOUSE_SYNAPTICS_I2C=m
CONFIG_INPUT_JOYSTICK=y
# CONFIG_JOYSTICK_ANALOG is not set
# CONFIG_JOYSTICK_A3D is not set
# CONFIG_JOYSTICK_ADI is not set
# CONFIG_JOYSTICK_COBRA is not set
# CONFIG_JOYSTICK_GF2K is not set
# CONFIG_JOYSTICK_GRIP is not set
# CONFIG_JOYSTICK_GRIP_MP is not set
# CONFIG_JOYSTICK_GUILLEMOT is not set
# CONFIG_JOYSTICK_INTERACT is not set
# CONFIG_JOYSTICK_SIDEWINDER is not set
# CONFIG_JOYSTICK_TMDC is not set
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_232=m
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDJOY=m
CONFIG_JOYSTICK_ZHENHUA=m
CONFIG_JOYSTICK_AS5011=m
# CONFIG_JOYSTICK_JOYDUMP is not set
CONFIG_JOYSTICK_PSXPAD_SPI=y
CONFIG_JOYSTICK_PSXPAD_SPI_FF=y
CONFIG_JOYSTICK_FSIA6B=m
CONFIG_INPUT_TABLET=y
CONFIG_TABLET_SERIAL_WACOM4=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
CONFIG_TOUCHSCREEN_ADS7846=m
CONFIG_TOUCHSCREEN_AD7877=m
CONFIG_TOUCHSCREEN_AD7879=m
CONFIG_TOUCHSCREEN_AD7879_I2C=m
# CONFIG_TOUCHSCREEN_AD7879_SPI is not set
# CONFIG_TOUCHSCREEN_ADC is not set
CONFIG_TOUCHSCREEN_AR1021_I2C=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
CONFIG_TOUCHSCREEN_DYNAPRO=m
CONFIG_TOUCHSCREEN_HAMPSHIRE=m
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
CONFIG_TOUCHSCREEN_FUJITSU=m
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
CONFIG_TOUCHSCREEN_GUNZE=m
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
CONFIG_TOUCHSCREEN_ELO=m
CONFIG_TOUCHSCREEN_WACOM_W8001=m
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
CONFIG_TOUCHSCREEN_MCS5000=m
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
CONFIG_TOUCHSCREEN_MTOUCH=m
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
CONFIG_TOUCHSCREEN_INEXIO=m
CONFIG_TOUCHSCREEN_MK712=m
CONFIG_TOUCHSCREEN_PENMOUNT=m
CONFIG_TOUCHSCREEN_EDT_FT5X06=y
CONFIG_TOUCHSCREEN_TOUCHRIGHT=m
CONFIG_TOUCHSCREEN_TOUCHWIN=m
CONFIG_TOUCHSCREEN_TI_AM335X_TSC=y
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
CONFIG_TOUCHSCREEN_TSC200X_CORE=m
# CONFIG_TOUCHSCREEN_TSC2004 is not set
CONFIG_TOUCHSCREEN_TSC2005=m
CONFIG_TOUCHSCREEN_TSC2007=m
# CONFIG_TOUCHSCREEN_TSC2007_IIO is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
CONFIG_TOUCHSCREEN_SILEAD=y
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
CONFIG_TOUCHSCREEN_STMPE=y
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
CONFIG_TOUCHSCREEN_TPS6507X=m
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MSM_VIBRATOR is not set
CONFIG_INPUT_MMA8450=m
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_TPS65218_PWRBUTTON=y
CONFIG_INPUT_UINPUT=y
CONFIG_INPUT_PALMAS_PWRBUTTON=y
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
CONFIG_RMI4_CORE=m
# CONFIG_RMI4_I2C is not set
# CONFIG_RMI4_SPI is not set
# CONFIG_RMI4_SMB is not set
CONFIG_RMI4_F03=y
CONFIG_RMI4_F03_SERIO=m
CONFIG_RMI4_2D_SENSOR=y
CONFIG_RMI4_F11=y
CONFIG_RMI4_F12=y
CONFIG_RMI4_F30=y
# CONFIG_RMI4_F34 is not set
# CONFIG_RMI4_F55 is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_LIBPS2 is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
# CONFIG_SERIAL_NONSTANDARD is not set
CONFIG_N_GSM=m
# CONFIG_TRACE_SINK is not set
# CONFIG_NULL_TTY is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
# CONFIG_SERIAL_8250_DMA is not set
CONFIG_SERIAL_8250_NR_UARTS=6
CONFIG_SERIAL_8250_RUNTIME_UARTS=6
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_FSL=y
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_8250_OMAP=y
CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
CONFIG_SERIAL_8250_PRUSS=m
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
CONFIG_SERIAL_MAX3100=m
CONFIG_SERIAL_MAX310X=m
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_OMAP is not set
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
CONFIG_SERIAL_PRU_SUART=m
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
CONFIG_SERIAL_DEV_BUS=y
CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
CONFIG_TTY_PRINTK=m
CONFIG_TTY_PRINTK_LEVEL=6
CONFIG_HVC_DRIVER=y
# CONFIG_HVC_DCC is not set
CONFIG_VIRTIO_CONSOLE=m
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
CONFIG_HW_RANDOM_OMAP=y
CONFIG_HW_RANDOM_VIRTIO=m
# CONFIG_RAW_DRIVER is not set
CONFIG_TCG_TPM=y
CONFIG_HW_RANDOM_TPM=y
# CONFIG_TCG_TIS is not set
# CONFIG_TCG_TIS_SPI is not set
CONFIG_TCG_TIS_I2C_ATMEL=y
# CONFIG_TCG_TIS_I2C_INFINEON is not set
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
# CONFIG_XILLYBUS is not set
# end of Character devices
CONFIG_RANDOM_TRUST_BOOTLOADER=y
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
CONFIG_I2C_ARB_GPIO_CHALLENGE=m
CONFIG_I2C_MUX_GPIO=y
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
CONFIG_I2C_MUX_PCA954x=m
CONFIG_I2C_MUX_PINCTRL=y
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_GPIO=y
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
# CONFIG_I2C_OCORES is not set
CONFIG_I2C_OMAP=y
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
CONFIG_I2C_TAOS_EVM=m
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
CONFIG_SPI_OMAP24XX=y
CONFIG_SPI_TI_QSPI=y
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
CONFIG_SPI_SLAVE=y
CONFIG_SPI_SLAVE_TIME=m
CONFIG_SPI_SLAVE_SYSTEM_CONTROL=m
CONFIG_SPI_DYNAMIC=y
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_GENERIC_PINCTRL_GROUPS=y
CONFIG_PINMUX=y
CONFIG_GENERIC_PINMUX_FUNCTIONS=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
CONFIG_PINCTRL_SINGLE=y
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_PALMAS is not set
# CONFIG_PINCTRL_OCELOT is not set
CONFIG_PINCTRL_TI_IODELAY=y
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_OF_HELPER=y
CONFIG_GPIO_GENERIC=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
CONFIG_GPIO_GENERIC_PLATFORM=y
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
CONFIG_GPIO_OMAP=y
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
CONFIG_GPIO_SYSCON=y
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# CONFIG_GPIO_PALMAS is not set
# CONFIG_GPIO_STMPE is not set
# CONFIG_GPIO_TPS65218 is not set
# end of MFD GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_W1 is not set
CONFIG_POWER_AVS=y
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMKONA is not set
# CONFIG_POWER_RESET_BRCMSTB is not set
CONFIG_POWER_RESET_GPIO=y
CONFIG_POWER_RESET_GPIO_RESTART=y
# CONFIG_POWER_RESET_LTC2952 is not set
CONFIG_POWER_RESET_RESTART=y
# CONFIG_POWER_RESET_VERSATILE is not set
CONFIG_POWER_RESET_SYSCON=y
CONFIG_POWER_RESET_SYSCON_POWEROFF=y
# CONFIG_SYSCON_REBOOT_MODE is not set
# CONFIG_NVMEM_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_APM_POWER is not set
CONFIG_GENERIC_ADC_BATTERY=m
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_LEGO_EV3 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
CONFIG_CHARGER_GPIO=m
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_CHARGER_TPS65217 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_HWMON is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_STATISTICS=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_BANG_BANG=y
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
CONFIG_CLOCK_THERMAL=y
CONFIG_DEVFREQ_THERMAL=y
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
# CONFIG_QORIQ_THERMAL is not set
# Texas Instruments thermal drivers
CONFIG_TI_SOC_THERMAL=y
CONFIG_TI_THERMAL=y
CONFIG_OMAP5_THERMAL=y
CONFIG_DRA752_THERMAL=y
# end of Texas Instruments thermal drivers
CONFIG_GENERIC_ADC_THERMAL=m
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
CONFIG_WATCHDOG_SYSFS=y
# Watchdog Pretimeout Governors
CONFIG_WATCHDOG_PRETIMEOUT_GOV=y
CONFIG_WATCHDOG_PRETIMEOUT_GOV_SEL=m
CONFIG_WATCHDOG_PRETIMEOUT_GOV_NOOP=y
CONFIG_WATCHDOG_PRETIMEOUT_GOV_PANIC=m
CONFIG_WATCHDOG_PRETIMEOUT_DEFAULT_GOV_NOOP=y
# CONFIG_WATCHDOG_PRETIMEOUT_DEFAULT_GOV_PANIC is not set
# Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=y
# CONFIG_SOFT_WATCHDOG_PRETIMEOUT is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_FTWDT010_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_OMAP_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP20X_I2C is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
CONFIG_MFD_STMPE=y
# STMicroelectronics STMPE Interface Drivers
CONFIG_STMPE_I2C=y
# CONFIG_STMPE_SPI is not set
# end of STMicroelectronics STMPE Interface Drivers
CONFIG_MFD_SYSCON=y
CONFIG_MFD_TI_AM335X_TSCADC=y
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
CONFIG_MFD_PALMAS=y
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
CONFIG_MFD_TPS65217=y
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
CONFIG_MFD_TPS65218=y
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
CONFIG_MFD_WL1273_CORE=m
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# CONFIG_RAVE_SP_CORE is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
CONFIG_REGULATOR_USERSPACE_CONSUMER=y
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MT6311 is not set
CONFIG_REGULATOR_PALMAS=y
CONFIG_REGULATOR_PBIAS=y
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
CONFIG_REGULATOR_PWM=y
# CONFIG_REGULATOR_SLG51000 is not set
CONFIG_REGULATOR_TI_ABB=y
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
CONFIG_REGULATOR_TPS65217=y
CONFIG_REGULATOR_TPS65218=y
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_CEC_CORE=y
# CONFIG_RC_CORE is not set
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
CONFIG_DRM_MIPI_DBI=m
CONFIG_DRM_MIPI_DSI=y
CONFIG_DRM_DP_AUX_CHARDEV=y
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
CONFIG_DRM_VM=y
CONFIG_DRM_SCHED=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
CONFIG_DRM_I2C_NXP_TDA998X=y
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# ACP (Audio CoProcessor) Configuration
# end of ACP (Audio CoProcessor) Configuration
CONFIG_DRM_VGEM=m
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
CONFIG_DRM_OMAP=y
CONFIG_OMAP2_DSS_INIT=y
CONFIG_OMAP_DSS_BASE=y
CONFIG_OMAP2_DSS=y
# CONFIG_OMAP2_DSS_DEBUG is not set
# CONFIG_OMAP2_DSS_DEBUGFS is not set
CONFIG_OMAP2_DSS_DPI=y
CONFIG_OMAP2_DSS_VENC=y
CONFIG_OMAP2_DSS_HDMI_COMMON=y
CONFIG_OMAP4_DSS_HDMI=y
CONFIG_OMAP4_DSS_HDMI_CEC=y
CONFIG_OMAP5_DSS_HDMI=y
# CONFIG_OMAP2_DSS_SDI is not set
# CONFIG_OMAP2_DSS_DSI is not set
CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
# OMAPDRM External Display Device Drivers
# CONFIG_DRM_OMAP_ENCODER_OPA362 is not set
CONFIG_DRM_OMAP_ENCODER_TPD12S015=y
# CONFIG_DRM_OMAP_DRA7EVM_ENCODER_TPD12S015 is not set
CONFIG_DRM_OMAP_CONNECTOR_HDMI=y
# CONFIG_DRM_OMAP_CONNECTOR_ANALOG_TV is not set
# CONFIG_DRM_OMAP_PANEL_DSI_CM is not set
# end of OMAPDRM External Display Device Drivers
CONFIG_DRM_TILCDC=y
# CONFIG_DRM_VIRTIO_GPU is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
# CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_ROCKTECH_JH057N00900 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
CONFIG_DRM_PANEL_SONY_ACX565AKM=m
CONFIG_DRM_PANEL_TPO_TD028TTEC1=m
CONFIG_DRM_PANEL_TPO_TD043MTEA1=m
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_CDNS_MHDP is not set
# CONFIG_DRM_DUMB_VGA_DAC is not set
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SIL_SII8620 is not set
CONFIG_DRM_SII902X=y
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
CONFIG_DRM_TI_TFP410=y
# CONFIG_DRM_TI_SN65DSI86 is not set
CONFIG_DRM_I2C_ADV7511=y
CONFIG_DRM_I2C_ADV7511_AUDIO=y
CONFIG_DRM_I2C_ADV7533=y
CONFIG_DRM_I2C_ADV7511_CEC=y
# end of Display Interface Bridges
# CONFIG_DRM_STI is not set
CONFIG_DRM_ETNAVIV=y
CONFIG_DRM_ETNAVIV_THERMAL=y
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
CONFIG_TINYDRM_HX8357D=m
CONFIG_TINYDRM_ILI9225=m
CONFIG_TINYDRM_ILI9341=m
CONFIG_TINYDRM_MI0283QT=m
CONFIG_TINYDRM_REPAPER=m
CONFIG_TINYDRM_ST7586=m
CONFIG_TINYDRM_ST7735R=m
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_TVE200 is not set
# CONFIG_DRM_LIMA is not set
# CONFIG_DRM_PANFROST is not set
# CONFIG_DRM_MCDE is not set
# CONFIG_DRM_TIDSS is not set
CONFIG_DRM_LEGACY=y
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
CONFIG_FIRMWARE_EDID=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_BACKLIGHT=y
CONFIG_FB_MODE_HELPERS=y
CONFIG_FB_TILEBLITTING=y
# Frame buffer hardware drivers
# CONFIG_FB_UVESA is not set
# CONFIG_FB_EFI is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_DA8XX is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=y
# end of Frame buffer Devices
# Backlight & LCD device support
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_GENERIC is not set
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_TPS65217 is not set
CONFIG_BACKLIGHT_GPIO=y
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_BACKLIGHT_LED is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
# end of Console display driver support
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
# CONFIG_SOUND_OSS_CORE_PRECLAIM is not set
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_PCM_ELD=y
CONFIG_SND_PCM_IEC958=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_HRTIMER=m
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_MAX_CARDS=32
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
# CONFIG_SND_SEQUENCER_OSS is not set
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_ALOOP=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
# HD-Audio
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=2048
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Audio support for Texas Instruments SoCs
CONFIG_SND_SOC_TI_EDMA_PCM=y
CONFIG_SND_SOC_TI_SDMA_PCM=y
CONFIG_SND_SOC_TI_UDMA_PCM=y
# Texas Instruments DAI support for:
CONFIG_SND_SOC_DAVINCI_MCASP=y
CONFIG_SND_SOC_OMAP_DMIC=y
CONFIG_SND_SOC_OMAP_MCBSP=y
CONFIG_SND_SOC_OMAP_MCPDM=y
# Audio support for boards with Texas Instruments SoCs
CONFIG_SND_SOC_OMAP_HDMI=y
# end of Audio support for Texas Instruments SoCs
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
CONFIG_SND_SOC_ADAU1701=m
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
CONFIG_SND_SOC_ADAU7002=m
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
CONFIG_SND_SOC_AK4554=m
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
CONFIG_SND_SOC_CS4265=m
# CONFIG_SND_SOC_CS4270 is not set
CONFIG_SND_SOC_CS4271=m
CONFIG_SND_SOC_CS4271_I2C=m
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DMIC is not set
CONFIG_SND_SOC_HDMI_CODEC=y
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
CONFIG_SND_SOC_PCM5102A=y
CONFIG_SND_SOC_PCM512x=m
CONFIG_SND_SOC_PCM512x_I2C=m
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_SGTL5000 is not set
CONFIG_SND_SOC_SIGMADSP=m
CONFIG_SND_SOC_SIGMADSP_I2C=m
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
CONFIG_SND_SOC_TLV320AIC23=m
CONFIG_SND_SOC_TLV320AIC23_I2C=m
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
CONFIG_SND_SOC_TLV320AIC31XX=m
# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
CONFIG_SND_SOC_TLV320AIC3X=m
CONFIG_SND_SOC_TS3A227E=m
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
CONFIG_SND_SOC_WM8753=m
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
CONFIG_SND_SOC_WM8804=m
CONFIG_SND_SOC_WM8804_I2C=m
# CONFIG_SND_SOC_WM8804_SPI is not set
CONFIG_SND_SOC_WM8903=m
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
CONFIG_SND_SOC_TPA6130A2=m
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=y
CONFIG_SND_SIMPLE_CARD=y
CONFIG_SND_AUDIO_GRAPH_CARD=y
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
# CONFIG_HID_GENERIC is not set
# Special HID drivers
CONFIG_HID_A4TECH=m
CONFIG_HID_ACRUX=m
CONFIG_HID_ACRUX_FF=y
CONFIG_HID_APPLE=m
CONFIG_HID_ASUS=m
CONFIG_HID_AUREAL=m
CONFIG_HID_BELKIN=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
CONFIG_HID_COUGAR=m
CONFIG_HID_MACALLY=m
CONFIG_HID_PRODIKEYS=m
CONFIG_HID_CMEDIA=m
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=m
CONFIG_DRAGONRISE_FF=y
CONFIG_HID_EMS_FF=m
CONFIG_HID_ELECOM=m
CONFIG_HID_EZKEY=m
CONFIG_HID_GEMBIRD=m
CONFIG_HID_GFRM=m
CONFIG_HID_KEYTOUCH=m
CONFIG_HID_KYE=m
CONFIG_HID_WALTOP=m
CONFIG_HID_VIEWSONIC=m
CONFIG_HID_GYRATION=m
CONFIG_HID_ICADE=m
CONFIG_HID_ITE=m
CONFIG_HID_JABRA=m
CONFIG_HID_TWINHAN=m
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LCPOWER=m
CONFIG_HID_LED=m
CONFIG_HID_LENOVO=m
CONFIG_HID_LOGITECH=y
CONFIG_HID_LOGITECH_HIDPP=y
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_LOGIWHEELS_FF=y
CONFIG_HID_MAGICMOUSE=m
CONFIG_HID_MALTRON=m
CONFIG_HID_MAYFLASH=m
CONFIG_HID_REDRAGON=m
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_MULTITOUCH=m
CONFIG_HID_NTI=m
CONFIG_HID_ORTEK=m
CONFIG_HID_PANTHERLORD=m
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PETALYNX=m
CONFIG_HID_PICOLCD=m
CONFIG_HID_PICOLCD_FB=y
CONFIG_HID_PICOLCD_BACKLIGHT=y
CONFIG_HID_PICOLCD_LEDS=y
CONFIG_HID_PLANTRONICS=m
CONFIG_HID_PRIMAX=m
CONFIG_HID_SAITEK=m
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SPEEDLINK=m
CONFIG_HID_STEAM=m
CONFIG_HID_STEELSERIES=m
CONFIG_HID_SUNPLUS=m
CONFIG_HID_RMI=m
CONFIG_HID_GREENASIA=m
CONFIG_GREENASIA_FF=y
CONFIG_HID_SMARTJOYPLUS=m
CONFIG_SMARTJOYPLUS_FF=y
CONFIG_HID_TIVO=m
CONFIG_HID_TOPSEED=m
CONFIG_HID_THINGM=m
CONFIG_HID_THRUSTMASTER=m
CONFIG_THRUSTMASTER_FF=y
CONFIG_HID_UDRAW_PS3=m
CONFIG_HID_WIIMOTE=m
CONFIG_HID_XINMO=m
CONFIG_HID_ZEROPLUS=m
CONFIG_ZEROPLUS_FF=y
CONFIG_HID_ZYDACRON=m
CONFIG_HID_SENSOR_HUB=m
CONFIG_HID_SENSOR_CUSTOM_SENSOR=m
CONFIG_HID_ALPS=m
# end of Special HID drivers
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
# CONFIG_USB_SUPPORT is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SD8787=m
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=256
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
# CONFIG_MMC_SDHCI_OF_ARASAN is not set
# CONFIG_MMC_SDHCI_OF_ASPEED is not set
# CONFIG_MMC_SDHCI_OF_AT91 is not set
# CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
# CONFIG_MMC_SDHCI_CADENCE is not set
# CONFIG_MMC_SDHCI_F_SDH30 is not set
# CONFIG_MMC_OMAP is not set
CONFIG_MMC_OMAP_HS=y
CONFIG_MMC_SPI=y
# CONFIG_MMC_DW is not set
# CONFIG_MMC_USDHI6ROL0 is not set
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MMC_SDHCI_XENON is not set
# CONFIG_MMC_SDHCI_OMAP is not set
# CONFIG_MMC_SDHCI_AM654 is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
CONFIG_LEDS_BRIGHTNESS_HW_CHANGED=y
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
CONFIG_LEDS_PWM=y
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
CONFIG_LEDS_TRIGGER_MTD=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_ACTIVITY=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
CONFIG_LEDS_TRIGGER_TRANSIENT=m
CONFIG_LEDS_TRIGGER_CAMERA=m
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_LEDS_TRIGGER_NETDEV=y
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
CONFIG_ACCESSIBILITY=y
# CONFIG_A11Y_BRAILLE_CONSOLE is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_PALMAS is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_EFI is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_OMAP=y
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
CONFIG_TI_CPPI41=y
CONFIG_TI_EDMA=y
CONFIG_DMA_OMAP=y
CONFIG_TI_DMA_CROSSBAR=y
# DMA Clients
CONFIG_ASYNC_TX_DMA=y
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_SELFTESTS is not set
# CONFIG_DMABUF_HEAPS is not set
# end of DMABUF options
CONFIG_AUXDISPLAY=y
# CONFIG_HD44780 is not set
# CONFIG_IMG_ASCII_LCD is not set
# CONFIG_HT16K33 is not set
# CONFIG_CHARLCD_BL_OFF is not set
# CONFIG_CHARLCD_BL_ON is not set
CONFIG_CHARLCD_BL_FLASH=y
CONFIG_UIO=y
CONFIG_UIO_PDRV_GENIRQ=m
CONFIG_UIO_DMEM_GENIRQ=m
# CONFIG_UIO_PRUSS is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO=y
# CONFIG_VIRTIO_MENU is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
# CONFIG_STAGING is not set
# CONFIG_GOLDFISH is not set
# CONFIG_MFD_CROS_EC is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
CONFIG_COMMON_CLK_PALMAS=y
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_COMMON_CLK_TI_ADPLL=y
# end of Common Clock Framework
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_OMAP_DM_TIMER=y
CONFIG_CLKSRC_MMIO=y
CONFIG_CLKSRC_TI_32K=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# end of Clock Source drivers
CONFIG_MAILBOX=y
# CONFIG_PLATFORM_MHU is not set
CONFIG_OMAP2PLUS_MBOX=y
CONFIG_OMAP_MBOX_KFIFO_SIZE=256
# CONFIG_ALTERA_MBOX is not set
# CONFIG_MAILBOX_TEST is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
CONFIG_REMOTEPROC=y
CONFIG_WKUP_M3_RPROC=y
CONFIG_PRU_REMOTEPROC=y
# end of Remoteproc drivers
# Rpmsg drivers
CONFIG_RPMSG=y
CONFIG_RPMSG_CHAR=y
# CONFIG_RPMSG_QCOM_GLINK_RPM is not set
CONFIG_RPMSG_VIRTIO=y
CONFIG_RPMSG_PRU=y
# end of Rpmsg drivers
# Rpmsg virtual device drivers
CONFIG_RPMSG_KDRV=m
# CONFIG_RPMSG_KDRV_DEMO is not set
# CONFIG_RPMSG_KDRV_DISPLAY is not set
CONFIG_RPMSG_KDRV_ETH_SWITCH=m
# end of Rpmsg virtual device drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SOC_TI=y
CONFIG_AMX3_PM=y
CONFIG_WKUP_M3_IPC=y
CONFIG_TI_PRUSS=y
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_POWERSAVE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_DEVFREQ_GOV_PASSIVE=y
# DEVFREQ Drivers
CONFIG_PM_DEVFREQ_EVENT=y
# CONFIG_EXTCON is not set
CONFIG_MEMORY=y
CONFIG_DDR=y
CONFIG_TI_EMIF=y
CONFIG_OMAP_GPMC=y
# CONFIG_OMAP_GPMC_DEBUG is not set
CONFIG_TI_EMIF_SRAM=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=m
# CONFIG_IIO_BUFFER_HW_CONSUMER is not set
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGERED_BUFFER=y
CONFIG_IIO_CONFIGFS=m
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
CONFIG_IIO_SW_DEVICE=m
CONFIG_IIO_SW_TRIGGER=m
CONFIG_IIO_TRIGGERED_EVENT=m
# Accelerometers
CONFIG_ADIS16201=m
CONFIG_ADIS16209=m
CONFIG_ADXL345=m
CONFIG_ADXL345_I2C=m
CONFIG_ADXL345_SPI=m
CONFIG_ADXL372=m
CONFIG_ADXL372_SPI=m
CONFIG_ADXL372_I2C=m
CONFIG_BMA180=m
CONFIG_BMA220=m
CONFIG_BMC150_ACCEL=m
CONFIG_BMC150_ACCEL_I2C=m
CONFIG_BMC150_ACCEL_SPI=m
CONFIG_DA280=m
CONFIG_DA311=m
CONFIG_DMARD06=m
CONFIG_DMARD09=m
CONFIG_DMARD10=m
CONFIG_HID_SENSOR_ACCEL_3D=m
CONFIG_IIO_ST_ACCEL_3AXIS=m
CONFIG_IIO_ST_ACCEL_I2C_3AXIS=m
CONFIG_IIO_ST_ACCEL_SPI_3AXIS=m
CONFIG_KXSD9=m
CONFIG_KXSD9_SPI=m
CONFIG_KXSD9_I2C=m
CONFIG_KXCJK1013=m
CONFIG_MC3230=m
CONFIG_MMA7455=m
CONFIG_MMA7455_I2C=m
CONFIG_MMA7455_SPI=m
CONFIG_MMA7660=m
CONFIG_MMA8452=m
CONFIG_MMA9551_CORE=m
CONFIG_MMA9551=m
CONFIG_MMA9553=m
CONFIG_MXC4005=m
CONFIG_MXC6255=m
CONFIG_SCA3000=m
CONFIG_STK8312=m
CONFIG_STK8BA50=m
# end of Accelerometers
# Analog to digital converters
CONFIG_AD_SIGMA_DELTA=m
CONFIG_AD7124=m
CONFIG_AD7266=m
CONFIG_AD7291=m
CONFIG_AD7298=m
CONFIG_AD7476=m
CONFIG_AD7606=m
# CONFIG_AD7606_IFACE_PARALLEL is not set
CONFIG_AD7606_IFACE_SPI=m
CONFIG_AD7766=m
CONFIG_AD7768_1=m
CONFIG_AD7780=m
CONFIG_AD7791=m
CONFIG_AD7793=m
CONFIG_AD7887=m
CONFIG_AD7923=m
CONFIG_AD7949=m
CONFIG_AD799X=m
CONFIG_CC10001_ADC=m
CONFIG_ENVELOPE_DETECTOR=m
CONFIG_HI8435=m
CONFIG_HX711=m
CONFIG_INA2XX_ADC=m
CONFIG_LTC2471=m
CONFIG_LTC2485=m
CONFIG_LTC2497=m
CONFIG_MAX1027=m
CONFIG_MAX11100=m
CONFIG_MAX1118=m
CONFIG_MAX1363=m
CONFIG_MAX9611=m
CONFIG_MCP320X=m
CONFIG_MCP3422=m
CONFIG_MCP3911=m
CONFIG_NAU7802=m
CONFIG_PALMAS_GPADC=m
CONFIG_SD_ADC_MODULATOR=m
CONFIG_STMPE_ADC=m
CONFIG_TI_ADC081C=m
CONFIG_TI_ADC0832=m
CONFIG_TI_ADC084S021=m
CONFIG_TI_ADC12138=m
CONFIG_TI_ADC108S102=m
CONFIG_TI_ADC128S052=m
CONFIG_TI_ADC161S626=m
CONFIG_TI_ADS1015=m
CONFIG_TI_ADS7950=m
CONFIG_TI_ADS8344=m
CONFIG_TI_ADS8688=m
CONFIG_TI_ADS124S08=m
CONFIG_TI_AM335X_ADC=y
CONFIG_TI_TLC4541=m
# CONFIG_VF610_ADC is not set
# CONFIG_XILINX_XADC is not set
# end of Analog to digital converters
# Analog Front Ends
CONFIG_IIO_RESCALE=m
# end of Analog Front Ends
# Amplifiers
CONFIG_AD8366=m
# end of Amplifiers
# Chemical Sensors
CONFIG_ATLAS_PH_SENSOR=m
CONFIG_BME680=m
CONFIG_BME680_I2C=m
CONFIG_BME680_SPI=m
CONFIG_CCS811=m
CONFIG_IAQCORE=m
CONFIG_PMS7003=m
CONFIG_SENSIRION_SGP30=m
CONFIG_SPS30=m
CONFIG_VZ89X=m
# end of Chemical Sensors
# Hid Sensor IIO Common
CONFIG_HID_SENSOR_IIO_COMMON=m
CONFIG_HID_SENSOR_IIO_TRIGGER=m
# end of Hid Sensor IIO Common
CONFIG_IIO_MS_SENSORS_I2C=m
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# end of SSP Sensor Common
CONFIG_IIO_ST_SENSORS_I2C=m
CONFIG_IIO_ST_SENSORS_SPI=m
CONFIG_IIO_ST_SENSORS_CORE=m
# Digital to analog converters
CONFIG_AD5064=m
CONFIG_AD5360=m
CONFIG_AD5380=m
CONFIG_AD5421=m
CONFIG_AD5446=m
CONFIG_AD5449=m
CONFIG_AD5592R_BASE=m
CONFIG_AD5592R=m
CONFIG_AD5593R=m
CONFIG_AD5504=m
CONFIG_AD5624R_SPI=m
CONFIG_LTC1660=m
CONFIG_LTC2632=m
CONFIG_AD5686=m
CONFIG_AD5686_SPI=m
CONFIG_AD5696_I2C=m
CONFIG_AD5755=m
CONFIG_AD5758=m
CONFIG_AD5761=m
CONFIG_AD5764=m
CONFIG_AD5791=m
CONFIG_AD7303=m
CONFIG_AD8801=m
CONFIG_DPOT_DAC=m
CONFIG_DS4424=m
CONFIG_M62332=m
CONFIG_MAX517=m
CONFIG_MAX5821=m
CONFIG_MCP4725=m
CONFIG_MCP4922=m
CONFIG_TI_DAC082S085=m
CONFIG_TI_DAC5571=m
CONFIG_TI_DAC7311=m
CONFIG_TI_DAC7612=m
# CONFIG_VF610_DAC is not set
# end of Digital to analog converters
# IIO dummy driver
# CONFIG_IIO_SIMPLE_DUMMY is not set
# end of IIO dummy driver
# Frequency Synthesizers DDS/PLL
part 3
# Clock Generator/Distribution
CONFIG_AD9523=m
# end of Clock Generator/Distribution
# Phase-Locked Loop (PLL) frequency synthesizers
CONFIG_ADF4350=m
CONFIG_ADF4371=m
# end of Phase-Locked Loop (PLL) frequency synthesizers
# end of Frequency Synthesizers DDS/PLL
# Digital gyroscope sensors
CONFIG_ADIS16080=m
CONFIG_ADIS16130=m
CONFIG_ADIS16136=m
CONFIG_ADIS16260=m
CONFIG_ADXRS450=m
CONFIG_BMG160=m
CONFIG_BMG160_I2C=m
CONFIG_BMG160_SPI=m
CONFIG_FXAS21002C=m
CONFIG_FXAS21002C_I2C=m
CONFIG_FXAS21002C_SPI=m
CONFIG_HID_SENSOR_GYRO_3D=m
CONFIG_MPU3050=m
CONFIG_MPU3050_I2C=m
CONFIG_IIO_ST_GYRO_3AXIS=m
CONFIG_IIO_ST_GYRO_I2C_3AXIS=m
CONFIG_IIO_ST_GYRO_SPI_3AXIS=m
CONFIG_ITG3200=m
# end of Digital gyroscope sensors
# Health Sensors
# Heart Rate Monitors
CONFIG_AFE4403=m
CONFIG_AFE4404=m
CONFIG_MAX30100=m
CONFIG_MAX30102=m
# end of Heart Rate Monitors
# end of Health Sensors
# Humidity sensors
CONFIG_AM2315=m
CONFIG_DHT11=m
CONFIG_HDC100X=m
CONFIG_HID_SENSOR_HUMIDITY=m
CONFIG_HTS221=m
CONFIG_HTS221_I2C=m
CONFIG_HTS221_SPI=m
CONFIG_HTU21=m
CONFIG_SI7005=m
CONFIG_SI7020=m
# end of Humidity sensors
# Inertial measurement units
CONFIG_ADIS16400=m
CONFIG_ADIS16460=m
CONFIG_ADIS16480=m
CONFIG_BMI160=m
CONFIG_BMI160_I2C=m
CONFIG_BMI160_SPI=m
CONFIG_KMX61=m
CONFIG_INV_MPU6050_IIO=m
CONFIG_INV_MPU6050_I2C=m
CONFIG_INV_MPU6050_SPI=m
CONFIG_IIO_ST_LSM6DSX=m
CONFIG_IIO_ST_LSM6DSX_I2C=m
CONFIG_IIO_ST_LSM6DSX_SPI=m
# end of Inertial measurement units
CONFIG_IIO_ADIS_LIB=m
CONFIG_IIO_ADIS_LIB_BUFFER=y
# Light sensors
CONFIG_ADJD_S311=m
CONFIG_AL3320A=m
CONFIG_APDS9300=m
CONFIG_APDS9960=m
CONFIG_BH1750=m
CONFIG_BH1780=m
CONFIG_CM32181=m
CONFIG_CM3232=m
CONFIG_CM3323=m
CONFIG_CM3605=m
CONFIG_CM36651=m
CONFIG_GP2AP020A00F=m
CONFIG_SENSORS_ISL29018=m
CONFIG_SENSORS_ISL29028=m
CONFIG_ISL29125=m
CONFIG_HID_SENSOR_ALS=m
CONFIG_HID_SENSOR_PROX=m
CONFIG_JSA1212=m
CONFIG_RPR0521=m
CONFIG_LTR501=m
CONFIG_LV0104CS=m
CONFIG_MAX44000=m
CONFIG_MAX44009=m
CONFIG_NOA1305=m
CONFIG_OPT3001=m
CONFIG_PA12203001=m
CONFIG_SI1133=m
CONFIG_SI1145=m
CONFIG_STK3310=m
CONFIG_ST_UVIS25=m
CONFIG_ST_UVIS25_I2C=m
CONFIG_ST_UVIS25_SPI=m
CONFIG_TCS3414=m
CONFIG_TCS3472=m
CONFIG_SENSORS_TSL2563=m
CONFIG_TSL2583=m
CONFIG_TSL2772=m
CONFIG_TSL4531=m
CONFIG_US5182D=m
CONFIG_VCNL4000=m
CONFIG_VCNL4035=m
CONFIG_VEML6070=m
CONFIG_VL6180=m
CONFIG_ZOPT2201=m
# end of Light sensors
# Magnetometer sensors
CONFIG_AK8974=m
CONFIG_AK8975=m
CONFIG_AK09911=m
CONFIG_BMC150_MAGN=m
CONFIG_BMC150_MAGN_I2C=m
CONFIG_BMC150_MAGN_SPI=m
CONFIG_MAG3110=m
CONFIG_HID_SENSOR_MAGNETOMETER_3D=m
CONFIG_MMC35240=m
CONFIG_IIO_ST_MAGN_3AXIS=m
CONFIG_IIO_ST_MAGN_I2C_3AXIS=m
CONFIG_IIO_ST_MAGN_SPI_3AXIS=m
CONFIG_SENSORS_HMC5843=m
CONFIG_SENSORS_HMC5843_I2C=m
CONFIG_SENSORS_HMC5843_SPI=m
CONFIG_SENSORS_RM3100=m
CONFIG_SENSORS_RM3100_I2C=m
CONFIG_SENSORS_RM3100_SPI=m
# end of Magnetometer sensors
# Multiplexers
# CONFIG_IIO_MUX is not set
# end of Multiplexers
# Inclinometer sensors
CONFIG_HID_SENSOR_INCLINOMETER_3D=m
CONFIG_HID_SENSOR_DEVICE_ROTATION=m
# end of Inclinometer sensors
# Triggers - standalone
CONFIG_IIO_HRTIMER_TRIGGER=m
CONFIG_IIO_INTERRUPT_TRIGGER=m
CONFIG_IIO_TIGHTLOOP_TRIGGER=m
CONFIG_IIO_SYSFS_TRIGGER=m
# end of Triggers - standalone
# Digital potentiometers
CONFIG_AD5272=m
CONFIG_DS1803=m
CONFIG_MAX5432=m
CONFIG_MAX5481=m
CONFIG_MAX5487=m
CONFIG_MCP4018=m
CONFIG_MCP4131=m
CONFIG_MCP4531=m
CONFIG_MCP41010=m
CONFIG_TPL0102=m
# end of Digital potentiometers
# Digital potentiostats
CONFIG_LMP91000=m
# end of Digital potentiostats
# Pressure sensors
CONFIG_ABP060MG=m
CONFIG_BMP280=m
CONFIG_BMP280_I2C=m
CONFIG_BMP280_SPI=m
CONFIG_DPS310=m
CONFIG_HID_SENSOR_PRESS=m
CONFIG_HP03=m
CONFIG_MPL115=m
CONFIG_MPL115_I2C=m
CONFIG_MPL115_SPI=m
CONFIG_MPL3115=m
CONFIG_MS5611=m
CONFIG_MS5611_I2C=m
CONFIG_MS5611_SPI=m
CONFIG_MS5637=m
CONFIG_IIO_ST_PRESS=m
CONFIG_IIO_ST_PRESS_I2C=m
CONFIG_IIO_ST_PRESS_SPI=m
CONFIG_T5403=m
CONFIG_HP206C=m
CONFIG_ZPA2326=m
CONFIG_ZPA2326_I2C=m
CONFIG_ZPA2326_SPI=m
# end of Pressure sensors
# Lightning sensors
CONFIG_AS3935=m
# end of Lightning sensors
# Proximity and distance sensors
CONFIG_ISL29501=m
CONFIG_LIDAR_LITE_V2=m
CONFIG_MB1232=m
CONFIG_RFD77402=m
CONFIG_SRF04=m
CONFIG_SX9500=m
CONFIG_SRF08=m
CONFIG_VL53L0X_I2C=m
# end of Proximity and distance sensors
# Resolver to digital converters
CONFIG_AD2S90=m
CONFIG_AD2S1200=m
# end of Resolver to digital converters
# Temperature sensors
CONFIG_MAXIM_THERMOCOUPLE=m
CONFIG_HID_SENSOR_TEMP=m
CONFIG_MLX90614=m
CONFIG_MLX90632=m
CONFIG_TMP006=m
CONFIG_TMP007=m
CONFIG_TSYS01=m
CONFIG_TSYS02D=m
CONFIG_MAX31856=m
# end of Temperature sensors
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
CONFIG_PWM_OMAP_DMTIMER=y
# CONFIG_PWM_PCA9685 is not set
# CONFIG_PWM_STMPE is not set
CONFIG_PWM_TIECAP=y
CONFIG_PWM_TIEHRPWM=y
CONFIG_PWM_TIPWMSS=y
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_AL_FIC is not set
CONFIG_OMAP_IRQCHIP=y
CONFIG_IRQ_CROSSBAR=y
CONFIG_TI_PRUSS_INTC=y
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_TI_SYSCON=y
# PHY Subsystem
CONFIG_GENERIC_PHY=y
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_TORRENT is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
CONFIG_OMAP_CONTROL_PHY=y
CONFIG_TI_PIPE3=y
CONFIG_PHY_TI_GMII_SEL=y
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCI_PMU is not set
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
# end of Performance monitor support
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
CONFIG_COUNTER=y
# CONFIG_FTM_QUADDEC is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
CONFIG_VALIDATE_FS_PARSER=y
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_EXPORTFS_BLOCK_OPS=y
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
CONFIG_FS_ENCRYPTION=y
CONFIG_FS_VERITY=y
# CONFIG_FS_VERITY_DEBUG is not set
# CONFIG_FS_VERITY_BUILTIN_SIGNATURES is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
CONFIG_PRINT_QUOTA_WARNING=y
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=m
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
CONFIG_FUSE_FS=y
CONFIG_CUSE=m
CONFIG_VIRTIO_FS=m
CONFIG_OVERLAY_FS=y
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
# CONFIG_OVERLAY_FS_INDEX is not set
# CONFIG_OVERLAY_FS_XINO_AUTO is not set
# CONFIG_OVERLAY_FS_METACOPY is not set
# Caches
CONFIG_FSCACHE=m
CONFIG_FSCACHE_STATS=y
# CONFIG_FSCACHE_HISTOGRAM is not set
# CONFIG_FSCACHE_DEBUG is not set
# CONFIG_FSCACHE_OBJECT_LIST is not set
CONFIG_CACHEFILES=m
# CONFIG_CACHEFILES_DEBUG is not set
# CONFIG_CACHEFILES_HISTOGRAM is not set
# end of Caches
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
# end of CD-ROM/DVD Filesystems
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="ascii"
CONFIG_FAT_DEFAULT_UTF8=y
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
# CONFIG_NTFS_RW is not set
# end of DOS/FAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_PROC_CHILDREN=y
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=y
CONFIG_EFIVAR_FS=m
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_ECRYPT_FS=m
CONFIG_ECRYPT_FS_MESSAGING=y
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_FS_POSIX_ACL=y
CONFIG_JFFS2_FS_SECURITY=y
CONFIG_JFFS2_COMPRESSION_OPTIONS=y
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_LZO=y
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
# CONFIG_JFFS2_CMODE_NONE is not set
CONFIG_JFFS2_CMODE_PRIORITY=y
# CONFIG_JFFS2_CMODE_SIZE is not set
# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
CONFIG_UBIFS_FS=y
CONFIG_UBIFS_FS_ADVANCED_COMPR=y
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_UBIFS_FS_AUTHENTICATION is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=m
CONFIG_SQUASHFS_FILE_CACHE=y
# CONFIG_SQUASHFS_FILE_DIRECT is not set
CONFIG_SQUASHFS_DECOMP_SINGLE=y
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_ZLIB=y
CONFIG_SQUASHFS_LZ4=y
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_SQUASHFS_ZSTD=y
# CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
CONFIG_ROMFS_FS=m
# CONFIG_ROMFS_BACKED_BY_BLOCK is not set
# CONFIG_ROMFS_BACKED_BY_MTD is not set
CONFIG_ROMFS_BACKED_BY_BOTH=y
CONFIG_ROMFS_ON_BLOCK=y
CONFIG_ROMFS_ON_MTD=y
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_EROFS_FS=m
# CONFIG_EROFS_FS_DEBUG is not set
CONFIG_EROFS_FS_XATTR=y
CONFIG_EROFS_FS_POSIX_ACL=y
CONFIG_EROFS_FS_SECURITY=y
CONFIG_EROFS_FS_ZIP=y
CONFIG_EROFS_FS_CLUSTER_PAGE_LIMIT=1
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DEBUG=y
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_PNFS=y
CONFIG_NFSD_BLOCKLAYOUT=y
# CONFIG_NFSD_SCSILAYOUT is not set
# CONFIG_NFSD_FLEXFILELAYOUT is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_SUNRPC_SWAP=y
# CONFIG_RPCSEC_GSS_KRB5 is not set
CONFIG_SUNRPC_DEBUG=y
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# CONFIG_9P_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=m
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
CONFIG_NLS_ISO8859_15=m
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
CONFIG_NLS_UTF8=y
CONFIG_DLM=m
CONFIG_DLM_DEBUG=y
# CONFIG_UNICODE is not set
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_TRUSTED_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
CONFIG_HARDENED_USERCOPY=y
# CONFIG_HARDENED_USERCOPY_FALLBACK is not set
# CONFIG_HARDENED_USERCOPY_PAGESPAN is not set
CONFIG_FORTIFY_SOURCE=y
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,apparmor,selinux,smack,tomoyo"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_CRYPTD=m
CONFIG_CRYPTO_AUTHENC=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_SIMD=m
CONFIG_CRYPTO_ENGINE=y
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
CONFIG_CRYPTO_DH=y
CONFIG_CRYPTO_ECC=m
CONFIG_CRYPTO_ECDH=m
# CONFIG_CRYPTO_ECRDSA is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_AEGIS128=m
CONFIG_CRYPTO_AEGIS128_SIMD=y
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=y
CONFIG_CRYPTO_CTS=y
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_LRW=m
# CONFIG_CRYPTO_OFB is not set
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XTS=y
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
CONFIG_CRYPTO_ESSIV=m
# Hash modes
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_VMAC=m
# Digest
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=y
# CONFIG_CRYPTO_XXHASH is not set
CONFIG_CRYPTO_CRCT10DIF=y
CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_POLY1305=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_RMD128=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_RMD256=m
CONFIG_CRYPTO_RMD320=m
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_LIB_SHA256=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_SHA3=m
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
# Ciphers
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_LIB_ARC4=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_BLOWFISH_COMMON=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_LIB_DES=y
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SALSA20=m
CONFIG_CRYPTO_CHACHA20=m
CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
# CONFIG_CRYPTO_SM4 is not set
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
# Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_LZO=y
# CONFIG_CRYPTO_842 is not set
CONFIG_CRYPTO_LZ4=m
CONFIG_CRYPTO_LZ4HC=m
CONFIG_CRYPTO_ZSTD=y
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
# CONFIG_CRYPTO_STATS is not set
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_OMAP=y
CONFIG_CRYPTO_DEV_OMAP_SHAM=y
CONFIG_CRYPTO_DEV_OMAP_AES=y
CONFIG_CRYPTO_DEV_OMAP_DES=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
CONFIG_CRYPTO_DEV_VIRTIO=m
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
CONFIG_PKCS8_PRIVATE_KEY_PARSER=m
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
CONFIG_BINARY_PRINTF=y
# Library routines
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_CORDIC=m
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC64=m
# CONFIG_CRC4 is not set
CONFIG_CRC7=y
CONFIG_LIBCRC32C=y
CONFIG_CRC8=m
CONFIG_XXHASH=y
CONFIG_AUDIT_GENERIC=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4HC_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=y
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
# CONFIG_XZ_DEC_X86 is not set
# CONFIG_XZ_DEC_POWERPC is not set
# CONFIG_XZ_DEC_IA64 is not set
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
# CONFIG_XZ_DEC_SPARC is not set
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_BCH=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_REMAP=y
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=48
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_LRU_CACHE=m
CONFIG_CLZ_TAB=y
CONFIG_IRQ_POLL=y
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_UCS2_STRING=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_SPLIT=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
CONFIG_BOOT_PRINTK_DELAY=y
CONFIG_DYNAMIC_DEBUG=y
# end of printk and dmesg options
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_STRIP_ASM_SYMS=y
# CONFIG_READABLE_ASM is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_INSTALL is not set
CONFIG_OPTIMIZE_INLINING=y
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x01b6
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_PAGE_REF is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_KASAN_STACK=1
# end of Memory Debugging
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
CONFIG_DETECT_HUNG_TASK=y
CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
# CONFIG_WQ_WATCHDOG is not set
# end of Debug Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
CONFIG_SCHED_STACK_END_CHECK=y
# CONFIG_DEBUG_TIMEKEEPING is not set
CONFIG_DEBUG_PREEMPT=y
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_LIST=y
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
CONFIG_NOTIFIER_ERROR_INJECTION=m
CONFIG_PM_NOTIFIER_ERROR_INJECT=m
# CONFIG_OF_RECONFIG_NOTIFIER_ERROR_INJECT is not set
# CONFIG_NETDEV_NOTIFIER_ERROR_INJECT is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACER_MAX_TRACE=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_TRACING=y
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
CONFIG_FUNCTION_TRACER=y
# CONFIG_PREEMPTIRQ_EVENTS is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_HWLAT_TRACER is not set
CONFIG_FTRACE_SYSCALLS=y
CONFIG_TRACER_SNAPSHOT=y
# CONFIG_TRACER_SNAPSHOT_PER_CPU_SWAP is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
CONFIG_STACK_TRACER=y
CONFIG_BLK_DEV_IO_TRACE=y
CONFIG_KPROBE_EVENTS=y
CONFIG_UPROBE_EVENTS=y
CONFIG_BPF_EVENTS=y
CONFIG_DYNAMIC_EVENTS=y
CONFIG_PROBE_EVENTS=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_DYNAMIC_FTRACE_WITH_REGS=y
# CONFIG_FUNCTION_PROFILER is not set
CONFIG_FTRACE_MCOUNT_RECORD=y
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
# CONFIG_TRACE_EVAL_MAP_FILE is not set
# CONFIG_RUNTIME_TESTING_MENU is not set
# CONFIG_MEMTEST is not set
CONFIG_BUG_ON_DATA_CORRUPTION=y
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_UBSAN is not set
CONFIG_UBSAN_ALIGNMENT=y
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_WX is not set
CONFIG_UNWINDER_ARM=y
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_ARM_KPROBES_TEST is not set
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# end of Kernel hacking
you can post the config as .txt to this thread. :wink:
config-5.4.66EPN11291-ti-r18.txt (132.5 KB)
I think I know what it might be. I see a lot of things in there with ‘=m’. Those are modules I assume. I don’t think I am including the modules in the boot? I am not that experienced with the Kernel, but I would suppose they would have to go somewhere in the boot directory. Is there a quick way for me to cook all the modules in the the Kernel file?
Does you setup_sdcard.sh script handle the installing of the modules?
Thanks
Rich
Nope… If you build the *.deb file, you can just install that, if you build the kernel manually, you need to install the modules yourself:
Regards,
Boot output looks the same
Modules copied
rich@poseiden:~/ti-linux-kernel-dev/deploy$ ls  /media/rich/rootfs/lib/modules
4.19.94-ti-r36  5.4.24-armv7-x20  **5.4.66EPN11291-ti-r18**
from uEnv.txt:
uname_r=5.4.66EPN11291-ti-r18
#uname_r=4.19.94-ti-r36
#uuid=
dtb=ep11291.dtb
I already had a line in the FSTAB from your script, so I am not sure i needed the second one.
rich@poseiden:~/ti-linux-kernel-dev/deploy$ tail /media/rich/rootfs/etc/fstab
# /etc/fstab: static file system information.
# Auto generated by RootStock-NG: setup_sdcard.sh
/dev/mmcblk0p1  /  ext4  noatime,errors=remount-ro  0  1
debugfs  /sys/kernel/debug  debugfs  mode=755,uid=root,gid=gpio,defaults  0  0
/dev/mmcblk0p1  /  auto  errors=remount-ro  0  1
rich@poseiden:~/ti-linux-kernel-dev/deploy$*
The engineer I am working with is concerned that UBoot set up the RTC to be external and we don’t have one external.
Untitled.txt (13.6 KB)
RTC 32KCLK Source: External.  <-- U-Boot
This leads to the next question, is this a clone of the BeagleBone Black or a BeagleBone Black?
Regards,
5.4 default config on bbb:
loading /boot/vmlinuz-5.4.66-ti-r18 ...
10027520 bytes read in 665 ms (14.4 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/5.4.66-ti-r18/am335x-boneblack.dtb ...
94128 bytes read in 62 ms (1.4 MiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_q
uality=100] ...
debug: [bootz 0x82000000 - 0x88000000] ...
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Device Tree to 8ffe6000, end 8fffffaf ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.66-ti-r18 (voodoo@hestia) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm
-rel-8.36))) #1 SMP PREEMPT Wed Oct 21 10:02:03 CDT 2020
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 20 pages/cpu s53068 r8192 d20660 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lp
j=1990656 rng_core.default_quality=100
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 446636K/522240K available (14336K kernel code, 1129K rwdata, 3808K rodata, 1024K init, 363K bss, 26452K reserved, 491
52K cma-reserved, 0K highmem)
[    0.000000] random: get_random_u32 called from __kmem_cache_create+0x44/0x530 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 44622 entries in 88 pages
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000043] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000056] OMAP clocksource: timer1 at 24000000 Hz
[    0.001146] timer_probe: no matching timers found
[    0.001377] Console: colour dummy device 80x30
[    0.001416] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001424] This ensures that you still see kernel messages. Please
[    0.001431] update your kernel commandline.
[    0.001492] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.001512] pid_max: default: 32768 minimum: 301
[    0.001811] LSM: Security Framework initializing
[    0.001908] Yama: becoming mindful.
[    0.002083] AppArmor: AppArmor initialized
[    0.002101] TOMOYO Linux initialized
[    0.002207] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002222] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002326] *** VALIDATE tmpfs ***
[    0.003252] *** VALIDATE proc ***
[    0.003695] *** VALIDATE cgroup1 ***
[    0.003713] *** VALIDATE cgroup2 ***
[    0.003806] CPU: Testing write buffer coherency: ok
[    0.003875] CPU0: Spectre v2: using BPIALL workaround
[    0.004450] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.005545] Setting up static identity map for 0x80100000 - 0x80100060
[    0.005811] rcu: Hierarchical SRCU implementation.
[    0.009465] EFI services will not be available.
[    0.009943] smp: Bringing up secondary CPUs ...
[    0.009963] smp: Brought up 1 node, 1 CPU
[    0.009975] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.009985] CPU: All CPU(s) started in SVC mode.
[    0.011111] devtmpfs: initialized
[    0.029798] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.030901] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030940] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.034740] xor: automatically using best checksumming function   neon
[    0.034981] pinctrl core: initialized pinctrl subsystem
[    0.036476] NET: Registered protocol family 16
[    0.041298] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.088965] l3-aon-clkctrl:0000:0: failed to disable
[    0.090695] audit: initializing netlink subsys (disabled)
[    0.092220] cpuidle: using governor ladder
[    0.092283] cpuidle: using governor menu
[    0.098885] audit: type=2000 audit(0.084:1): state=initialized audit_enabled=0 res=1
[    0.120367] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.145619] raid6: using algorithm neonx8 gen() 0 MB/s
[    0.145642] raid6: .... xor() 0 MB/s, rmw enabled
[    0.145653] raid6: using neon recovery algorithm
[    0.155306] debugfs: Directory '49000000.edma' with parent 'dmaengine' already present!
[    0.155351] edma 49000000.edma: TI EDMA DMA engine driver
[    0.158166] iommu: Default domain type: Translated
[    0.161073] SCSI subsystem initialized
[    0.161914] usbcore: registered new interface driver usbfs
[    0.161993] usbcore: registered new interface driver hub
[    0.162127] usbcore: registered new device driver usb
[    0.163328] mc: Linux media interface: v0.10
[    0.163381] videodev: Linux video capture interface: v2.00
[    0.163538] pps_core: LinuxPPS API ver. 1 registered
[    0.163550] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.163577] PTP clock support registered
[    0.164740] Advanced Linux Sound Architecture Driver Initialized.
[    0.165625] NetLabel: Initializing
[    0.165644] NetLabel:  domain hash size = 128
[    0.165652] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.165767] NetLabel:  unlabeled traffic allowed by default
[    0.167012] clocksource: Switched to clocksource timer1
[    1.027010] random: fast init done
[    1.038100] *** VALIDATE bpf ***
[    1.038619] VFS: Disk quotas dquot_6.6.0
[    1.038729] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.038902] *** VALIDATE ramfs ***
[    1.040067] AppArmor: AppArmor Filesystem Enabled
[    1.053147] thermal_sys: Registered thermal governor 'fair_share'
[    1.053158] thermal_sys: Registered thermal governor 'bang_bang'
[    1.053181] thermal_sys: Registered thermal governor 'step_wise'
[    1.053906] NET: Registered protocol family 2
[    1.055287] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.055332] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.055380] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.055440] TCP: Hash tables configured (established 4096 bind 4096)
[    1.055577] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.055605] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.055859] NET: Registered protocol family 1
[    1.057003] RPC: Registered named UNIX socket transport module.
[    1.057024] RPC: Registered udp transport module.
[    1.057033] RPC: Registered tcp transport module.
[    1.057041] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.057061] NET: Registered protocol family 44
[    1.058710] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.061529] Initialise system trusted keyrings
[    1.062022] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.070393] zbud: loaded
[    1.073916] NFS: Registering the id_resolver key type
[    1.073977] Key type id_resolver registered
[    1.073987] Key type id_legacy registered
[    1.074011] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.074398] fuse: init (API version 7.31)
[    1.074568] *** VALIDATE fuse ***
[    1.074587] *** VALIDATE fuse ***
[    1.111193] Key type asymmetric registered
[    1.111219] Asymmetric key parser 'x509' registered
[    1.111300] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.111651] io scheduler mq-deadline registered
[    1.120195] OMAP GPIO hardware version 0.1
[    1.153693] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    1.157391] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    1.179007] ti-sysc 4a101200.target-module: OCP softreset timed out
[    1.189106] ti-sysc 4a101200.target-module: OCP softreset timed out
[    1.196072] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.197685] gpio-of-helper ocp:cape-universal: ready
[    1.205492] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    1.208808] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.213398] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
[    2.025027] printk: console [ttyS0] enabled
[    2.033370] omap_rng 48310000.rng: Random Number Generator ver. 20
[    2.039996] random: crng init done
[    2.045346] sdhci: Secure Digital Host Controller Interface driver
[    2.051652] sdhci: Copyright(c) Pierre Ossman
[    2.057039] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    2.065858] omap_hsmmc 48060000.mmc: Got CD GPIO
[    2.123934] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    2.135554] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.148027] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.165865] mmc0: new high speed SDHC card at address aaaa
[    2.172670] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[    2.179851]  mmcblk0: p1
[    2.222201] mmc1: new high speed MMC card at address 0001
[    2.228896] mmcblk1: mmc1:0001 S10004 3.56 GiB
[    2.234158] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[    2.240686] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[    2.247214] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB, chardev (243:0)
[    2.291628] libphy: Fixed MDIO Bus: probed
[    2.308444] ti-sysc 4a101200.target-module: OCP softreset timed out
[    2.355091] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.362847] libphy: 4a101000.mdio: probed
[    2.367290] mdio_bus 4a101000.mdio: MDIO device at address 0 is missing.
[    2.374307] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    2.380742] cpsw 4a100000.ethernet: ALE Table size 1024
[    2.386121] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    2.393487] cpsw 4a100000.ethernet: Detected MACID = b0:d5:cc:fc:03:fc
[    2.402584] usbcore: registered new interface driver smsc95xx
[    2.410619] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.417322] ehci-platform: EHCI generic platform driver
[    2.423128] ehci-omap: OMAP-EHCI Host Controller driver
[    2.430029] usbcore: registered new interface driver uas
[    2.435581] usbcore: registered new interface driver usb-storage
[    2.441697] usbcore: registered new interface driver ums-alauda
[    2.447712] usbcore: registered new interface driver ums-cypress
[    2.453806] usbcore: registered new interface driver ums-datafab
[    2.459900] usbcore: registered new interface driver ums_eneub6250
[    2.466170] usbcore: registered new interface driver ums-freecom
[    2.472277] usbcore: registered new interface driver ums-isd200
[    2.478286] usbcore: registered new interface driver ums-jumpshot
[    2.484467] usbcore: registered new interface driver ums-karma
[    2.490583] usbcore: registered new interface driver ums-onetouch
[    2.496799] usbcore: registered new interface driver ums-realtek
[    2.502898] usbcore: registered new interface driver ums-sddr09
[    2.508905] usbcore: registered new interface driver ums-sddr55
[    2.514911] usbcore: registered new interface driver ums-usbat
[    2.524898] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[    2.542239] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[    2.562559] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    2.568127] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    2.575949] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.584301] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.591582] usb usb1: Product: MUSB HDRC host driver
[    2.596591] usb usb1: Manufacturer: Linux 5.4.66-ti-r18 musb-hcd
[    2.602645] usb usb1: SerialNumber: musb-hdrc.1
[    2.608151] hub 1-0:1.0: USB hub found
[    2.612148] hub 1-0:1.0: 1 port detected
[    2.635320] omap_rtc 44e3e000.rtc: already running
[    2.641414] omap_rtc 44e3e000.rtc: registered as rtc0
[    2.648377] i2c /dev entries driver
[    2.653118] Driver for 1-wire Dallas network protocol.
[    2.662334] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.669968] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    2.680619] cpuidle: enable-method property 'ti,am3352' found operations
[    2.689235] ledtrig-cpu: registered to indicate activity on CPUs
[    2.696017] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.702303] omap-aes 53500000.aes: will run requests pump with realtime priority
[    2.713032] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.724500] hidraw: raw HID events driver (C) Jiri Kosina
[    2.730972] usbcore: registered new interface driver usbhid
[    2.737020] usbhid: USB HID core driver
[    2.742286] remoteproc remoteproc0: wkup_m3 is available
[    2.756999] davinci-mcasp 48038000.mcasp: IRQ common not found
[    2.766089] drop_monitor: Initializing network drop monitor service
[    2.772869] wireguard: WireGuard 0.0.20191219 loaded. See www.wireguard.com for information.
[    2.781411] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[    2.792080] NET: Registered protocol family 10
[    2.801340] Segment Routing with IPv6
[    2.805497] mip6: Mobile IPv6
[    2.808671] NET: Registered protocol family 17
[    2.813777] Key type dns_resolver registered
[    2.818249] mpls_gso: MPLS GSO support
[    2.822397] ThumbEE CPU extension supported.
[    2.826795] Registering SWP/SWPB emulation handler
[    2.831647] omap_voltage_late_init: Voltage driver support not added
[    2.838462] PM: Cannot get wkup_m3_ipc handle
[    2.843768] registered taskstats version 1
[    2.847961] Loading compiled-in X.509 certificates
[    2.852966] zswap: loaded using pool lzo/zbud
[    2.857977] Key type ._fscrypt registered
[    2.862083] Key type .fscrypt registered
[    2.870292] Btrfs loaded, crc32c=crc32c-generic
[    2.875121] AppArmor: AppArmor sha1 policy hashing enabled
[    2.941363] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    2.948782] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-m
odule/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    2.967443] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.973843] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    3.101918] tda998x 0-0070: found TDA19988
[    3.109852] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc0f923dc)
[    3.115925] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.122599] [drm] No driver support for vblank timestamp query.
[    3.129596] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    3.137555] [drm] Cannot find any crtc or sizes
[    3.142492] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    3.157315] remoteproc remoteproc1: 4a334000.pru is available
[    3.163384] pru-rproc 4a334000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@34000 probed suc
cessfully
[    3.178244] remoteproc remoteproc2: 4a338000.pru is available
[    3.184247] pru-rproc 4a338000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@38000 probed suc
cessfully
[    3.201600] remoteproc remoteproc0: powering up wkup_m3
[    3.210553] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[    3.221220] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[    3.231689] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[    3.238780] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    3.246656] PM: Cannot get wkup_m3_ipc handle
[    3.251631] PM: Cannot get wkup_m3_ipc handle
[    3.257527] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:13:32 UTC (946685612)
[    3.267863] ALSA device list:
[    3.270870]   #0: TI BeagleBone Black
[    3.296648] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    3.304996] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[    3.313862] devtmpfs: mounted
[    3.323340] Freeing unused kernel memory: 1024K
[    3.328647] Run /sbin/init as init process
[    3.354545] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    4.073901] systemd[1]: System time before build time, advancing clock.
[    4.314490] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +G
CRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    4.337112] systemd[1]: Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
It is a custom board with AM3352, MARVEL phy, eMMC and two serial ports. There is bluetooth haning of the second serial port. Nothing else. The U-boot might have been copied over from another project and that is why my partner said it my be the external RTC issue. I borrowed a lot of the UBOOT startup scripts from the EVM and BBB.
Does that help?
Should I try disabling the RTC in the kernel just to get past this if that is the issue?
There are a bunch of FIXMEs in there as well that are suspicious.
No, it’s not that…
Here’s your config…
Running uname_boot ...
7270912 bytes read in 491 ms (14.1 MiB/s)
94128 bytes read in 60 ms (1.5 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100] ...
Starting kernel ...
[    0.000000] Linux version 5.4.66-ti-r18 (voodoo@hestia) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #2 PREEMPT Wed Oct 21 10:41:34 CDT 2020
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
[    0.000000] Memory: 454116K/522240K available (7168K kernel code, 934K rwdata, 2956K rodata, 1024K init, 297K bss, 18972K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x31c with crng_init=0
[    0.000000] ftrace: allocating 35692 entries in 70 pages
[    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000031] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000041] OMAP clocksource: timer1 at 24000000 Hz
[    0.001017] timer_probe: no matching timers found
[    0.001204] Console: colour dummy device 80x30
[    0.001237] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001243] This ensures that you still see kernel messages. Please
[    0.001248] update your kernel commandline.
[    0.001293] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.001309] pid_max: default: 32768 minimum: 301
[    0.001622] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001637] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001745] *** VALIDATE tmpfs ***
[    0.002397] *** VALIDATE proc ***
[    0.002693] *** VALIDATE cgroup1 ***
[    0.002707] *** VALIDATE cgroup2 ***
[    0.002764] CPU: Testing write buffer coherency: ok
[    0.002818] CPU0: Spectre v2: using BPIALL workaround
[    0.003824] Setting up static identity map for 0x80100000 - 0x80100054
[    0.003973] rcu: Hierarchical SRCU implementation.
[    0.006160] EFI services will not be available.
[    0.006728] devtmpfs: initialized
[    0.021270] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.021793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.021827] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.025612] pinctrl core: initialized pinctrl subsystem
[    0.026802] NET: Registered protocol family 16
[    0.030360] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.059467] l3-aon-clkctrl:0000:0: failed to disable
[    0.061023] audit: initializing netlink subsys (disabled)
[    0.061998] cpuidle: using governor ladder
[    0.062033] cpuidle: using governor menu
[    0.067072] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[    0.079491] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.100198] debugfs: Directory '49000000.edma' with parent 'dmaengine' already present!
[    0.100230] edma 49000000.edma: TI EDMA DMA engine driver
[    0.103951] SCSI subsystem initialized
[    0.104657] pps_core: LinuxPPS API ver. 1 registered
[    0.104667] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.105461] Advanced Linux Sound Architecture Driver Initialized.
[    0.106715] clocksource: Switched to clocksource timer1
[    0.826045] *** VALIDATE bpf ***
[    0.826467] VFS: Disk quotas dquot_6.6.0
[    0.826538] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.826647] *** VALIDATE ramfs ***
[    0.835370] thermal_sys: Registered thermal governor 'fair_share'
[    0.835378] thermal_sys: Registered thermal governor 'bang_bang'
[    0.835394] thermal_sys: Registered thermal governor 'step_wise'
[    0.836002] NET: Registered protocol family 2
[    0.836806] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.836838] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.836878] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.836916] TCP: Hash tables configured (established 4096 bind 4096)
[    0.837016] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.837035] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.837227] NET: Registered protocol family 1
[    0.837972] RPC: Registered named UNIX socket transport module.
[    0.837985] RPC: Registered udp transport module.
[    0.837992] RPC: Registered tcp transport module.
[    0.837998] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.838009] NET: Registered protocol family 44
[    0.838878] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.840808] Initialise system trusted keyrings
[    0.841100] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.847177] zbud: loaded
[    0.849707] NFS: Registering the id_resolver key type
[    0.849752] Key type id_resolver registered
[    0.849760] Key type id_legacy registered
[    0.849778] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.850047] fuse: init (API version 7.31)
[    0.850153] *** VALIDATE fuse ***
[    0.850168] *** VALIDATE fuse ***
[    0.885475] Key type asymmetric registered
[    0.885491] Asymmetric key parser 'x509' registered
[    0.885551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.885745] io scheduler mq-deadline registered
[    0.891343] OMAP GPIO hardware version 0.1
[    0.916964] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.919215] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.936674] ti-sysc 4a101200.target-module: OCP softreset timed out
[    0.946777] ti-sysc 4a101200.target-module: OCP softreset timed out
[    0.950883] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.951957] gpio-of-helper ocp:cape-universal: ready
[    0.956289] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    0.958336] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.961480] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
[    1.114052] random: fast init done
[    1.630587] printk: console [ttyS0] enabled
[    1.637581] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.644076] random: crng init done
[    1.648926] sdhci: Secure Digital Host Controller Interface driver
[    1.655185] sdhci: Copyright(c) Pierre Ossman
[    1.660245] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.669026] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.725415] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.735008] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.747879] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.761732] mmc0: new high speed SDHC card at address aaaa
[    1.768082] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[    1.774478]  mmcblk0: p1
[    1.818780] mmc1: new high speed MMC card at address 0001
[    1.825057] mmcblk1: mmc1:0001 S10004 3.56 GiB
[    1.830030] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[    1.836326] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[    1.842592] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB, chardev (245:0)
[    1.885048] libphy: Fixed MDIO Bus: probed
[    1.901222] ti-sysc 4a101200.target-module: OCP softreset timed out
[    1.946763] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.954487] libphy: 4a101000.mdio: probed
[    1.960046] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    1.969478] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.975917] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.981313] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    1.988672] cpsw 4a100000.ethernet: Detected MACID = b0:d5:cc:fc:03:fc
[    1.998521] omap_rtc 44e3e000.rtc: already running
[    2.004261] omap_rtc 44e3e000.rtc: registered as rtc0
[    2.009608] i2c /dev entries driver
[    2.015917] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    2.023222] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    2.033047] cpuidle: enable-method property 'ti,am3352' found operations
[    2.041216] ledtrig-cpu: registered to indicate activity on CPUs
[    2.047684] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    2.053761] omap-aes 53500000.aes: will run requests pump with realtime priority
[    2.063168] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    2.072294] remoteproc remoteproc0: wkup_m3 is available
[    2.083275] davinci-mcasp 48038000.mcasp: IRQ common not found
[    2.091223] drop_monitor: Initializing network drop monitor service
[    2.097707] wireguard: WireGuard 0.0.20191219 loaded. See www.wireguard.com for information.
[    2.106207] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[    2.116692] NET: Registered protocol family 10
[    2.124137] Segment Routing with IPv6
[    2.128097] mip6: Mobile IPv6
[    2.131172] NET: Registered protocol family 17
[    2.135997] Key type dns_resolver registered
[    2.140369] mpls_gso: MPLS GSO support
[    2.144363] ThumbEE CPU extension supported.
[    2.148695] omap_voltage_late_init: Voltage driver support not added
[    2.155377] PM: Cannot get wkup_m3_ipc handle
[    2.160341] registered taskstats version 1
[    2.164507] Loading compiled-in X.509 certificates
[    2.169449] zswap: loaded using pool lzo/zbud
[    2.174353] Key type ._fscrypt registered
[    2.178420] Key type .fscrypt registered
[    2.233044] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    2.240106] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    2.258519] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.264562] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    2.393136] tda998x 0-0070: found TDA19988
[    2.400191] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc0870098)
[    2.406210] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.412869] [drm] No driver support for vblank timestamp query.
[    2.419531] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    2.427325] [drm] Cannot find any crtc or sizes
[    2.432104] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    2.443318] remoteproc remoteproc1: 4a334000.pru is available
[    2.449256] pru-rproc 4a334000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@34000 probed successfully
[    2.463490] remoteproc remoteproc2: 4a338000.pru is available
[    2.469399] pru-rproc 4a338000.pru: PRU rproc node /ocp/interconnect@4a000000/segment@0/target-module@300000/pruss@0/pru@38000 probed successfully
[    2.484939] remoteproc remoteproc0: powering up wkup_m3
[    2.490647] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[    2.501204] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[    2.508475] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    2.515048] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[    2.522916] PM: Cannot get wkup_m3_ipc handle
[    2.527555] PM: Cannot get wkup_m3_ipc handle
[    2.532894] omap_rtc 44e3e000.rtc: setting system clock to 2020-10-21T15:51:13 UTC (1603295473)
[    2.542848] ALSA device list:
[    2.545842]   #0: TI BeagleBone Black
[    2.560628] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesystem
[    2.568022] EXT4-fs (mmcblk0p1): write access will be enabled during recovery
[    2.666399] EXT4-fs (mmcblk0p1): recovery complete
[    2.674150] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.682408] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
[    2.690148] devtmpfs: mounted
[    2.696612] Freeing unused kernel memory: 1024K
[    2.701609] Run /sbin/init as init process
[    3.348729] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.371021] systemd[1]: Detected architecture arm.
I bet your device tree is borken…
Regards,
Wow… thanks
I probably could use the BBB DTB. I will try that, and if it still hangs, perhaps it is UBOOT setting up something wrong.
I am running build_deb.sh just so it is apples to apples.
For am335x, u-boot really only set’s up the DDR memory and the RTC clock source (the kernel can’t set that…)… Pretty much everything else can be re-defined in your device tree and the kernel can re-init them.
So first double check all your pinmux’s making sure everything that you use is defined…
Regards,
