Bbxm booting with only 256MB
Hi @RobertCNelson,
following your instructions I’ve dowloaded u-boot v2019.04 and kernel 5.0.19 for the Beagle Board-xm board.
It works but doing a dmesg command I noticed that the DRAM is only 256MB, but in the dt of omap3-beagle-xm.dts there is memory alloctaed for 512MB.
I would try to put sdome traces to understand the dt is correctly loaded. Shall I check the u-boot or the kernel?
Thank you
Hi @Lorenzo sorry the xM has been broken for awhile, please use this binary build:
https://rcn-ee.com/repos/bootloader/omap3_beagle/MLO-omap3_beagle-v2018.03-r9
https://rcn-ee.com/repos/bootloader/omap3_beagle/u-boot-omap3_beagle-v2018.03-r9.img
It would be good to git bisect this and figure out what broke on mainline…
Regards,
@RobertCNelson thank you it works!
Can you also address me to have 1Ghz speed?
Thank you!
I believe that was fixed on mainline… I see your on v5.0.x, i’d give 5.10.x a try…
Regards,
