hi , i bought item BCR8AS14LJ-T13#B01. i would like to know how to decode the DC and part no from the body marking
Hi Grace,
I wasn’t able to find the information on the date code nor the part number, nor how to decode them from the part marking. I didn’t locate any information on that in the data sheet nor any other documentation on the manufacturers website of this part. I’m reaching out to our product specialist on these to see if they have any information that can help do that. I will reply here when I have some feedback from them.
Someone else may know more on this and post here in the mean time.
Thanks for your patience and have a great day.
The DC guide on this change notice https://www.renesas.com/us/en/document/tcu/pcn-marking-power-transistors might help.
Applicable Part Numbers
2SB1032K,2SB1079,2SC3336,2SC3365,2SD1436K,2SD1559,2SD2256
2SJ160,2SJ161,2SJ162,2SJ215,2SJ217,2SJ351,2SJ352,2SJ554,2SJ555, 2SK1056,2SK1057,2SK1058, 2SK1161,
2SK1162,2SK1165,2SK1166,2SK1166,2SK1167,2SK1168, 2SK1169,2SK1170, 2SK1298,2SK1303,2SK1304,2SK1317,
2SK1339,2SK1340,2SK1341,2SK1342,2SK1401A,2SK1403A,2SK1515,2SK1516, 2SK1517,2SK1518,2SK1573,2SK1669,
2SK1671,2SK1773,2SK1835,2SK1933,2SK1934,2SK1968,2SK2007,2SK2220,2SK2221,2SK2554,2SK2568,2SK2586,
2SK2727,2SK2728,2SK2729,2SK2730,2SK2955,2SK3151, 2SK3159,2SK3163, 2SK3235,2SK3419
H5N1503P,H5N1506P,H5N2003P,H5N2008P,H5N2305P,H5N2501P,H5N2503P,H5N2507P,H5N2509P,H5N2514P,
H5N2515P,H5N2519P,H5N2801P,H5N2802P,H5N2803P,H5N3003P,H5N3004P,H5N3008P,H5N3011P,H5N5007P,
H5N5015P,H5N6001P
RJK1529DPK,RJK2009DPK,RJK2508DPK,RJK2511DPK,RJK2916DPK,RJK3008DPK,RJK3016DPK,RJK4018DPK,
RJK4514DPK,RJK4515DPK,RJK4518DPK,RJK5010DPK,RJK5013DPK,RJK5014DPK, RJK5015DPK,RJK5018DPK,
RJK5020DPK,RJK6014DPK,RJK6015DPK,RJK6018DPK,RJK6020DPK
GN6060V5DP,GN6065V5DP
RJH6007DPK,RJP2557DPK,RJP3057DPK,RJP3067DPK,RJP4067DPK,RJP6006DPK,RJP6085DPK
TO-3PFM
TO-3PFM
2SC5480
2SJ216,2SJ218, 2SK1328,2SK1329,2SK1405,2SK1670,2SK1775,2SK1832,2SK1859,2SK2008,2SK2225
H5N2301PF,H5N2305PF,H5N2306PF,H5N2509PF,H5N2803PF,RJK2009DPM,RJH6075DPM
TO-220AB and LDPAK
TO-220AB LDPAK
TO-220AB
2SB566K,2SB566AK,2SB727K,2SB765K,2SB791K,2SB857,2SB858,2SB859,2SB860,2SB861, 2SB955K,2SB1091,
2SB1103,2SC1881K,2SC2612,2SC2613,2SC2816,2SC2979,2SC4913,2SD476K, 2SD476AK,2SD768K,2SD864K,
2SD970K,2SD1113K,2SD1126K,2SD1133,2SD1134,2SD1135, 2SD1137,2SD1138,2SD1163A,2SD1527
2SJ76,2SJ77,2SJ78,2SJ79,2SJ117,2SJ172,2SJ173,2SJ174,2SJ221,2SJ247,2SJ292,2SJ539, 2SJ540,2SJ541,2SJ542,
2SJ543,2SJ544, 2SK213,2SK214,2SK215,2SK216,2SK970,2SK971,2SK972, ,2SK1153,2SK1154,2SK1155, 2SK1156,
2SK1157,2SK1158,2SK1159,2SK1160,2SK1302,2SK1338,2SK1400A,2SK1402A,2SK1627, 2SK1667,2SK1761,2SK1807,
2SK2328,2SK2408,2SK2800,2SK2927,2SK2928,2SK2929,2SK2930, 2SK2931,2SK2959,2SK3069,2SK3136,2SK3141,
2SK3149,2SK3154,2SK3156,2SK3158,2SK3228, 2SK3418,2SK3736
H7N0203AB,H7N0307AB,H7N0308AB,H7N0312AB, H7N0602AB, H7N0603AB,H7N0608AB,H7N1002AB,H7N1004AB,
H8N0801AB,HS76654,HS76655
GN6030V4AB,RJP3054DPN,RJP3064DPN,RJP3065DPN,RJP6065DPN
LDPAK packaged transistor including special specification or custom parts that are not written on follow will be applied.
2SJ214L/S,2SJ220L/S,2SJ280L/S,2SJ296L/S,2SJ297L/S,2SJ409L/S,2SJ479L/S,2SJ505L/S, 2SJ549L/S,2SJ550L/S,
2SJ551L/S,2SJ552L/S,2SJ553L/S, 2SK1313L/S,2SK1314L/S,2SK1315L/S,2SK1316L/S,2SK1528L/S, 2SK1620L/S,
2SK1623L/S, 2SK1636L/S,2SK1647L/S,2SK2553L/S,2SK2684L/S,2SK2912L/S,2SK2938L/S,2SK2939L/S, 2SK2940L/S,
2SK2957L/S,2SK2958L/S,2SK3070L/S,2SK3082L/S,2SK3134L/S,2SK3135L/S,2SK3150L/S,2SK3161L/S,2SK3210L/S,
2SK3211L/S
H5N2001LS, H5N2007LS, H5N2307LS,H5N2901LS,H5N3007LS,H5N3301LS H7N0307LD/LS,H7N0308LD/LS,
H7N0307LD/LS,H7N0308LD/LS,H7N0310LD/LS,H7N0311LD/LS,H7N0312LD/LS,H7N0602LD/LS/LM, H7N0606LD/LS,
H7N1002LD/LS/LM,H7N1004LD/LS,H7N1005LD/LS,H8N0603LD
RJK1525DPJ/DPE/DPF,RJK1526DPE/DPF,RJK1535DPE,RJK2017DPE,RJK4013DPE,RJK4514APE, RJK6012DPE,
RJK6026DPE
GN6020V4LS,GN6030V4LS,RJP6003DPE
TO-220FM and TO-220CFM
2SB1262,2SB1389,2SB1390,2SB1391,2SB1392,2SB1399,2SB1400,2SB1530,2SC5022,2SD1900, 2SD2101,2SD2106,
2SD2337
2SJ175,2SJ176,2SJ177,2SJ222,2SJ248,2SJ293,2SJ294,2SJ295,2SJ350,2SJ504,2SJ526, 2SJ534,2SJ535,2SJ547,
2SJ548, 2SK1093,2SK1094,2SK1095,2SK1305,2SK1306,2SK1307,2SK1318,2SK1404,2SK1566,2SK1567, 2SK1572,
2SK1626, 2SK1637,2SK1668,2SK1762,2SK1808,2SK1957,2SK2202,2SK2937,2SK3148, 2SK3152,2SK3155,2SK3157,
2SK3160,2SK3162,2SK3177,2SK3209,2SK3212,2SK3308
H5N5001FM,H5N5006FM,H7N0608FM,H7N1004FM,H7N1005FM
5.9. Applied Products for TO-220CFM
TO-220CFM packaged transistor including special specification or custom parts that are not
2SJ471,2SJ532,2SJ533,2SJ545,2SJ546, 2SK2114,2SK2424,2SK2425,2SK2529,2SK2725,2SK2726, 2SK2736, 2SK2737,
2SK2738,2SK2932, 2SK2933,2SK2934,2SK2935,2SK2936,2SK2956,2SK3140,2SK3142,2SK3229, ,2SK3233,2SK3234,
H5N2502CF,H5N2512CF,H5N3007CF,H7N0308CF,RJK1525DPS
2SB1072L/S,2SB1407L/S,2SB1661S,2SB1681S,2SC4500L/S,2SD2115L/S, 2SD2123L/S, 2SD2124L/S,2SD2592S,
2SD2632S
2SJ130L/S,2SJ181L/S,2SJ182L/S,2SJ234L/S,2SJ245L/S,2SJ246L/S,2SJ279L/S,2SJ318L/S, 2SJ319L/S,2SJ332L/S,
2SJ387L/S,2SJ389L/S,2SJ506L/S,2SJ527L/S,2SJ528L/S,2SJ529L/S,2SJ530L/S,2SK973LS,2SK974L/S,2SK1151L/S,
2SK1152L/S,2SK1254L/S,2SK1299L/S,2SK1335L/S, 2SK1838L/S,2SK1880L/S, 2SK1949L/S,2SK2059L/S,2SK2084L/S,
2SK2329L/S,2SK2735L/S,2SK2796L/S,2SK2869L/S,2SK2925L/S,2SK2926L/S,2SK3147L/S,2SK3274L/S
H5N2004DL/DS,H5N2005DL/DS,H5N2504DL/DS,H5N2505DL/DS,H5N2508DL/DS,H5N2510DL/DS, H5N5006DL/DS,
H7N0603DL/DS,H7N0607DL/DS,H7N1004DL/DS,H7N1005DL/DS,H7P0601DL/DS,H7N1002DL/DS
5.12. Cahanging of Marking for LFPAK and LFPAK-i
[ Example for LFPAK(Note:The marking for LFPAK-i is same layout.) ]
Part name indication
Work code
(Year,Month,Week)
Grade indication
Tracability code
Work code
(Year,Month)
Grade indication
Work code
Work code
Tracability code
LFPAK packaged transistor including special specification or custom parts that are not written on follow will be applied.
HAT1072H,HAT1125H,HAT1127H,HAT1139H,HAT2096H,HAT2099H,HAT2116H,HAT2129H,HAT2134H, HAT2137H,
HAT2139H,HAT2140H,HAT2141H,HAT2142H,HAT2143H,HAT2160H,HAT2164H,HAT2165H, HAT2166H,HAT2167H,
HAT2168H,HAT2169H,HAT2170H,HAT2171H,HAT2172H,HAT2173H,HAT2174H, HAT2175H,HAT2261H,HAT2265H,
HAT2266H,HAT2267H,HAT2270H,HAT2279H
RJK0301DPB,RJK0302DPB,RJK0303DPB,RJK0304DPB,RJK0305DPB,RJK0328DPB,RJK0329DPB, RJK0330DPB,
RJK0331DPB,RJK0332DPB,RJK0372DPB
5.14. Applied Products for LFPAK-i
LFPAK –i packaged transistor including special specification or custom parts that are not written on follow will be applied.
HAT2160N,HAT2164N,HAT2165N,HAT2166N,HAT2167N,HAT2168N,HAT2169N,HAT2170N,HAT2171N, HAT2172N,
HAT2173N,HAT2174N,HAT2175N,HAT2261N,HAT2265N,HAT2266N,HAT2279N
RJK0301DPC,RJK0302DPC,RJK0303DPC,RJK0304DPC,RJK0305DPC
5.15. Cahanging of Marking for WPAK
[ Example for WPAK ]
Current marking New marking
5.16. Applied Products for WPAK
WPAK packaged transistor including special specification or custom parts that are not written on follow will be applied.
HAT1101WP,HAT1107WP,HAT2087WP,HAT2089WP,HAT2183WP,HAT2184WP,HAT2185WP,HAT2187WP, HAT2188WP,
HAT2189WP,HAT2191WP,HAT2191WP,HAT2192WP,HAT2193WP,HAT2195WP,HAT2197WP, HAT2198WP,HAT2199WP,
HAT2200WP,HAT2201WP,HAT2209WP,HAT2210WP,HAT2211WP.HAT2244WP, HAT2285WP,HAT2287WP,HAT2299WP
RJK0316DPA,RJK0317DPA,RJK0346DPA,RJK0347DPA,RJK0348DPA,RJK0349DPA,RJK0350DPA, RJK0351DPA,
RJK0353DPA,RJK0355DPA,RJK0356DPA,RJK0358DPA,RJK0359DPA,RJK0360DPA, RJK0364DPA,RJK0365DPA,
RJK0366DPA,RJK0369DPA
TSSOP-8
HAT1033T, HAT1041T, HAT1065T, HAT2050T, HAT2051T, HAT2080T, HAT2085T, HAT2105T, HAT3015T
