Dual Part Numbers / Markings & Lattice Suffixes
All logic suppliers produce their base part exactly the same and then test, mark, and bin parts after production. Some parts are only tested at lower grades and stamped as such.
Some families are dual marked and may have slight variance between the manufacturer part number on the manufacturer label and actual part marking, which these are tested at higher speeds and temp grades. They meet the specification for both a higher speed lower temp vs lower speed and high temp grade.
LC4256V-3TN100C and LC4256V-5TN100I from Lattice Semiconductor are examples of dual marked parts. Below is an excerpt from the suppliers full data sheet explaining a bit how dual marking works:
Basic Part# Description:
Marking Information
  • C is commercial temp grade and I is industrial temp grade.
Regarding manufacturer part # LC4256V-5TN100I; actual marking on the part is LC4256V-3TN100-5I Why part is marked 3TN not 5TN?
  • The 3 in front of TN is for 3 n seconds and 5 is for 5 n seconds.
The part marking explanation below is:
  • Line1 = LC4246V ; which is the base part number call out for 4000 series products or aka Mach 4000v family.
  • Line2 = 3TN100-5I ; which is the speed, package, pin count, and temp grade; NOTE this happens to be dual marked, meaning the 3 calls out speed at C or commercial temp range of operation, whereas the 5I calls out actual speed of 5 at Industrial temp range.
  • Line3 = B138RR02 ; which is the date/lot trace ability code.
-Thus as in this case a 3C is equal to a 5I
Similarly, the part marking for LC4032V-10TN44I can also be marked LC4032V-75TN44-10I or other iteration.
  • Line2 = 75TN44- 10I ; which is the speed, package, pin count, and temp grade; NOTE this happens to be dual marked, meaning the 75 calls out 7.5 speed at C or commercial temp range of operation, whereas the 10I calls out speed of 10 at Industrial temp range.
Additional Note
AMD for example uses the opposite speed binning, meaning the lower the number the slower the part, so their grade is counter to Lattice.
Click here for CPLDs (Complex Programmable Logic Devices)
Applicable Part Numbers
2156-PALCE16V8H-10JC/4-ND
2156-PALCE20V8H-15JC/4-ND
2156-PALCE20V8H-15PC/4-ND
2156-PALCE20V8Q-25JI/4-ND
2156-PALCE20V8H-25JC/4-ND
2156-PALCE16V8H-7PC/5-ND
2156-PALCE16V8H-15JC/4-ND
2156-PALCE16V8H-5JC/5-ND
2156-PALCE20V8H-10JC/4-ND
2156-PALCE22V10H-15JC/4-ND
2156-PALCE22V10Q-25PC/4-ND
2156-PALCE22V10Q-25JC/4-ND
2156-PALCE16V8Q-10JC/5-ND
2156-PALCE20RA10H-20PC-ND
2156-PALCE22V10H-10JC/5-ND
2156-PALCE20V8Q-20JI/4-ND
2156-PALCE20V8H-7JC/5-ND
2156-PALCE22V10Q-15JC/5-ND
2156-ISPGDS14-7P-ND
2156-PALCE24V10H-25JC-ND
2156-PALLV16V8-10JC-ND
2156-GAL16V8C-7LP-ND
2156-PALCE26V12H-15JC/4-ND
2156-GAL16LV8C-7LJ-ND
2156-PALCE16V8Z-25SC-ND
2156-GAL16LV8ZD-25QJ-ND
2156-GAL16LV8ZD-15QJ-ND
2156-PALCE20V8H-5JC/5-ND
2156-ISPGAL22V10AV-75LSN-ND
2156-ISPGAL22V10AV-75LN-ND
2156-PALCE20RA10H-15PC-ND
2156-PALLV16V8Z-20PI-ND
2156-PALLV22V10-10JC-ND
2156-GAL26V12C-20LPI-ND
2156-ISPGAL22V10AV-75LJ-ND
2156-PALLV16V8-10PC-ND
2156-GAL20XV10B-15LJ-ND
2156-GAL16V8ZD-15QJ-ND
2156-PALCE22V10H-7PC/5-ND
2156-PALLV22V10-7JC-ND
2156-ISPGAL22V10AV-75LS-ND
2156-ISPGAL22LV10-15LJ-ND
2156-GAL22LV10Z-15QJ-ND
2156-ISPGAL22V10AC-75LN-ND
2156-PALCE24V10H-15JC-ND
2156-ISPGAL22V10AV-75LJN-ND
2156-ISPLSI-2032VL-110LB49-ND
2156-ISPGAL22V10AB-75LN-ND
2156-ISPLSI-2064VL-100LT44-ND
2156-ISPLSI-2032VL-110LT44-ND
2156-ISPLSI2032VE-110LB49I-ND
2156-PALCE26V12H-10JC/4-ND
2156-GAL20V8Z-15QP-ND
2156-GAL16V8Z-12QS-ND
2156-GAL22LV10C-15LJN-ND
2156-GAL16V8ZD-15QP-ND
2156-GAL16VP8B-15LP-ND
2156-ISPGDS18-7P-ND
2156-GAL22LV10C-15LJ-ND
2156-MACH111SP-10JC-ND
2156-GAL20LV8D-5LJ-ND
2156-GAL20VP8B-25LJ-ND
2156-ISPGAL22LV10-15LKI-ND
2156-ISPGAL22V10AV-5LJN-ND
2156-ISPGAL22V10AC-5LN-ND
2156-ISPLSI2032-135LJ-ND
2156-ISPLSI-2032VL-135LJ44-ND
2156-GAL6002B-20LJ-ND
2156-GAL20V8Z-15QJ-ND
2156-GAL16V8Z-12QP-ND
2156-GAL16LV8D-5LJ-ND
2156-ISPLSI-2032-135LT44-ND
2156-GAL20VP8B-15LP-ND
2156-ISPGDS22-7J-ND
2156-GAL20V8ZD-15QP-ND
2156-ISPGAL22V10AB-5LN-ND
2156-PALLV22V10Z-25JI-ND
2156-PALCE24V10H-15PC-ND
2156-MACH111-10JC-ND
2156-ISPLSI2032-80LT48I-ND
2156-GAL20V8ZD-15QJ-ND
2156-ISPGAL22LV10-10LJ-ND
2156-GAL20VP8B-15LJ-ND
2156-GAL20XV10B-10LJ-ND
2156-PALCE26V12H-7JC/4-ND
2156-GAL20V8ZD-12QJ-ND
2156-GAL20V8ZD-12QP-ND
2156-GAL20V8Z-12QP-ND
2156-ISPGAL22V10AC-23LN-ND
2156-ISPGAL22LV10-10LJI-ND
2156-GAL20V8Z-12QJ-ND
2156-ISPGAL22V10AV-28LJ-ND
2156-ISPLSI2128VL-135LT100-ND
2156-ISPLSI2032VE-180LB49-ND
2156-GAL22LV10ZD-15QJ-ND
2156-ISPLSI2032VE-110LBN49-ND
2156-ISPGAL22V10AB-23LN-ND
2156-ISPLSI2032-135LT48-ND
2156-MACH211SP-10JC-ND
2156-ISPGAL22LV10-5LJ-ND
2156-GAL16V8C-5LP-ND
2156-PALCE22V10Q-10PC/5-ND
2156-ISPLSI2064VL-100LT100-ND
2156-MACH131SP-10VC-ND
2156-GAL22LV10ZD-25QJ-ND
2156-MACH211-7JC-ND
2156-GAL26CV12C-15LP-ND
2156-ISPLSI2032-180LJ-ND
2156-MACH111-7JC-ND
2156-ISPLSI2064VL-135LB100-ND
2156-MACH111SP-5JC-ND
2156-MACH131SP-15VC-ND
2156-MACH111-5VC-ND
2156-LC4384V-75F256C-ND
2156-MACH210A-10VC-ND
2156-ISPLSI2128VL-100LT100-ND
2156-ISPLSI-2032-150LJ-ND
2156-ISPLSI2096-100LQ-ND
2156-ISPLSI2096VL-100LT128-ND
2156-ISPLSI2128VL-100LT176-ND
2156-ISPLSI2032-180LT44-ND
2156-ISPLSI2096-80LT-ND
2156-ISPLSI2096-80LQI-ND
2156-ISPLSI-2096-80LQ-ND
2156-M5-128/104-12YC/1-ND
2156-MACH130-15JC-ND
2156-MACH210A-7VC-ND
2156-GAL26CV12C-15LPI-ND
2156-ISPLSI2064VL-135LT100-ND
2156-ISPLSI2032-150LT48-ND
2156-ISPLSI2064-100LTI-ND
2156-M5-128/104-10YC/1-ND
2156-ISPLSI2096VL-135LT128-ND
2156-ISPLSI2032-180LT48-ND
2156-ISPLSI-2064-125LT-ND
2156-ISPLSI2128VL-100LB208-ND
2156-ISPLSI2192VL-100LT128-ND
2156-ISPLSI2128-100LT-ND
2156-ISPGAL22LV10-4LJ-ND
2156-ISPLSI2128VL-100LQ160-ND
2156-ISPLSI2128VL-135LT176-ND
2156-M5-128/104-15YC/1-ND
2156-M5-128/104-7YC/1-ND
2156-ISPLSI2096-125LQ-ND
2156-ISPLSI-2096-125LQ-ND
2156-ISPLSI2192VL-100LB144-ND
2156-ISPLSI2096-125LT-ND
2156-ISPLSI2096-100LT-ND
2156-MACH131SP-7VC-ND
2156-MACH221-7JC-ND
2156-ISPLSI2064VL-165LT100-ND
2156-ISPLSI-3160-70LB272-ND
2156-LC5256MC-75F256C-ND
2156-LC4256C-75F256AC-ND
2156-ISPGDX160VA-9B272I-ND
2156-LC5512MC-45QN208C-ND,2832-LC5512MC-45QN208C-ND
2156-LC5256B-4Q208C-ND
2156-M4LV-128N/64-10JC-ND
2156-LC4256C-75FN256BC-ND
2156-LC4256C-75F256BC-ND
2156-LC4256V-10F256BI-ND
2156-ISPLSI-3160-100LQ-ND
2156-MACH230-15JC-ND
2156-ISPLSI3192-70LB272-ND
2156-MACH435Q-20JC-ND
2156-MACH231-7JC-ND
2156-LC5512MC-75F256C-ND
2156-LC5128B-3T128C-ND
2156-ISPLSI-3160-100LB272-ND
2156-ISPLSI1048E-50LT-ND
2156-MACH231-6JC-ND
2156-LC4256V-5FN256AC-ND
2156-LC4256C-5F256AC-ND
2156-LC4256V-5F256AC-ND
2156-LC4256C-5FN256AC-ND
2156-MACH445-12YC-ND
2156-LC4256C-5F256BC-ND
2156-LC4256C-5FN256BC-ND
2156-LC4256B-5FN256BC-ND
2156-LC4256B-5F256BC-ND
2156-LC4256V-5F256BC-ND
2156-ISPLSI2096VL-165LT128-ND
2156-ISPLSI2128VL-150LB100-ND
2156-LC5512B-75F256C-ND
2156-LC4384V-5FN256C-ND
2156-LC5512MC-75F484C-ND
2156-ISPLSI2192VL-135LT128-ND
2156-MACH435-12JC-ND
2156-ISPLSI2128VL-150LT100-ND
2156-ISPLSI-3160-125LB272-ND
2156-ISPLSI2128VL-150LT176-ND
2156-LC4384C-75FN256C-ND
2156-LC4256V-3FN256AC-ND
2156-LC4256V-3F256AC-ND
2156-LC4256C-3FN256AC-ND
2156-LC4256C-3F256AC-ND
2156-LC4256V-3F256BC-ND
2156-LC4256V-3FN256BC-ND
2156-LC4256C-3F256BC-ND
2156-ISPLSI1048E-90LT-ND
2156-ISPLSI-3160-100LQI-ND
2156-ISPLSI3256E-100LB320-ND
2156-LC5768MB-75F256C-ND
2156-M5-192/160-7YC-ND
2156-LC5512B-75Q208C-ND
2156-LC4384V-5F256C-ND
2156-LC4512C-75FN256C-ND
2156-LC4512B-75FN256C-ND
2156-LC4512V-75F256C-ND
2156-LC4512C-75F256C-ND
2156-LC4512B-10F256I-ND
2156-ISPLSI-8600V-60LB272I-ND
2156-ISPLSI8600V-60LB492-ND
2156-ISPLSI3256E-70LQA-ND
2156-ISPLSI3256E-70LB320-ND
2156-LC51024MC-75F484C-ND
2156-LC4384V-35FN256C-ND
2156-LC4384V-35F256C-ND
2156-LC4384B-5FN256I-ND
2156-ISPLSI8840V-60LB492-ND
2156-LC4512V-5F256C-ND
2156-LC4512B-5FN256C-ND
2156-LC4512C-5F256C-ND
2156-LC4512C-5FN256C-ND
2156-LC5512B-45F484C-ND
2156-ISPLSI8600V-90LB492-ND
2156-ISPLSI-3160-125LQ-ND
2156-ISPLSI-3192-100LB272-ND
2156-ISPLSI-8840V-60LB272-ND
2156-LC5512B-75F484C-ND
2156-LC51024MB-52FN484C-ND
2156-LC51024MB-52F484C-ND
2156-LC5512B-45F256C-ND
2156-ISPLSI81080V-60LB272-ND
2156-ISPLSI 3256E-100LQA-ND
2156-ISPLSI-3448-90LB432-ND
2156-ISPLSI8600V-125LB492-ND
2156-LC4512C-35F256C-ND
2156-LC4512B-35FN256C-ND
2156-LC4512B-35F256C-ND
2156-LC4512C-35FN256C-ND
2156-ISPLSI8840V-125LB492-ND
2156-ISPLSI81080V-90LB272-ND
2156-ISPLSI81080V-60LB492-ND
2156-LC5512B-45Q208C-ND
2156-ISPLSI81080V-60LB272I-ND
2156-ISPLSI81080V-125LB492-ND
2156-ISPLSI81080V-125LB272-ND
2156-ISPLSI81080V-90LB492-ND
220-1695-ND
2156-ISPLSI-2032VL-180LB49-ND
2156-ISPGAL22V10AB-28LJ-ND
2156-GAL6002B-15LJ-ND
2156-MACH211SP-7VC-ND
2156-ISPLSI-2032VL-180LT44-ND
2156-MACH231SP-12YC-ND
2156-LC5128B-5T128C-ND
2156-MACH221SP-12YC-ND
2156-GAL22V10D-4LJN-ND
2156-MACH131-7JC/1-ND
2156-LC4256B-75F256AC-ND
2156-LC4256C-75FN256AC-ND
2156-LC4256V-75F256AC-ND
2156-ISPLSI2064VL-165LJ44-ND
2156-ISPLSI1048E-50LQ-ND
2156-ISPLSI2128-100LQ-ND
2156-LC5512MC-45F256C-ND
2156-LC5512MC-45F484C-ND
2156-LC4384B-75FN256C-ND
2156-LC4384V-75FN256C-ND
2156-LC4256B-3F256AC-ND
2156-LC5512B-10Q208C-ND
2156-LC5768MC-75FN256C-ND
2156-LC5768MC-75F256C-ND
2156-LC5512B-10F256C-ND
2156-ISPLSI-3256E-70LQ-ND
2156-LC5512B-10F484C-ND
2156-LC4512V-75FN256C-ND
2156-LC4512V-5FN256C-ND
2156-ISPLSI-3448-70LB432-ND
2156-ISPLSI-3192-100LQ-ND
2156-ISPLSI-8600V-125LB272-ND
2156-ISPLSI-8840V-125LB272-ND
220-1033-ND
220-1637-ND
220-1665-ND
220-1044-ND
220-1046-ND
220-1045-ND
220-1032-ND
220-1705-ND
220-1703-ND
220-1716-ND
220-1717-ND
220-1362-ND
220-1035-ND
220-1366-ND
220-1042-ND
220-1643-ND
220-1041-ND
220-1037-ND
220-1040-ND
220-1690-ND
220-1043-ND
220-1030-ND
220-1684-ND
220-1693-ND
220-1701-ND
220-1014-ND
220-1034-ND
220-1036-ND
220-1648-ND
220-1676-ND
220-1367-ND
220-1674-ND
220-1649-ND
220-2035-ND
220-1039-ND
220-1365-ND
220-1642-ND
220-1645-ND
220-1038-ND
220-1667-ND
220-1669-ND
220-1370-ND
220-1668-ND
220-1023-ND
220-1026-ND
220-1297-ND
220-1024-ND
220-1661-ND
220-1290-ND
220-1640-ND
220-1376-ND
220-1029-ND
220-1712-ND
220-1027-ND
220-1682-ND
220-1713-ND
220-1708-ND
220-2037-ND
220-1709-ND
220-1694-ND
220-1679-ND
220-1700-ND
220-1301-ND
220-2650-ND
220-2038-ND
220-1720-ND
220-1361-ND
220-1654-ND
220-1364-ND
220-1664-ND
220-1691-ND
220-1660-ND
220-1685-ND
220-1680-ND
220-1710-ND
220-1711-ND
220-1706-ND
220-1721-ND
2156-PALCE16V8H-10PC/4-ND
2156-PALCE16V8H-25SC/4-ND
2156-PALCE22V10H-15JI/5-ND
2156-PALCE16V8H-10JI/4-ND
2156-GAL16LV8C-7LJN-ND
2156-PALCE22V10H-25SC/4-ND
2156-GAL16LV8C-15LJ-ND
2156-PALCE22V10H-25PI/4-ND
2156-ISPGAL22V10AC-75LJ-ND
2156-GAL20LV8D-7LJ-ND
2156-ISPGAL22V10AB-75LJ-ND
2156-ISPLSI2032-80LT48-ND
2156-GAL20VP8B-25LP-ND
2156-MACH111-12JC-ND
2156-ISPGAL22V10AB-5LJ-ND
2156-MACH111SP-15VC-ND
2156-MACHLV210-15JC-ND
2156-ISPGAL22V10AC-28LJ-ND
2156-MACH211SP-12VC-ND
2156-GAL26CLV12D-5LJ-ND
2156-PALCE29M16H25JC/4-ND
2156-PALLV22V10-15JI-ND
2156-MACHLV210-12JC-ND
2156-ISPGAL22V10C-15LJ-ND
2156-GAL16V8D-3LJN-ND
2156-M5-128/104-5YC/1-ND
2156-MACH111SP-7VC-ND
2156-MACH111SP-5VC-ND
2156-LC5128B-75T128C-ND
2156-MACH211-7VC-ND
2156-ISPLSI2064-100LJ-ND
2156-MACH131SP-12VC-ND
2156-ISPLSI2032-150LT44-ND
2156-MACH231SP-12VC-ND
2156-M5LV-128/104-10YC-ND
2156-GAL20RA10B-7LJ-ND
2156-LC5256MC-4FN256C-ND
220-1375-ND
2156-M5-256/68-12VC-ND
2156-LC5512MC-45Q208C-ND
2156-M5-128/120-7YC-ND
2156-LC4384C-75F256C-ND
2156-ISPLSI3320-100LQ-ND
PALCE16V8H-10JC/4
PALCE20V8H-15JC/4
PALCE20V8H-15PC/4
PALCE20V8Q-25JI/4
PALCE20V8H-25JC/4
PALCE16V8H-7PC/5
PALCE16V8H-15JC/4
PALCE16V8H-5JC/5
PALCE20V8H-10JC/4
PALCE22V10H-15JC/4
PALCE22V10Q-25PC/4
PALCE22V10Q-25JC/4
PALCE16V8Q-10JC/5
PALCE20RA10H-20PC
PALCE22V10H-10JC/5
PALCE20V8Q-20JI/4
PALCE20V8H-7JC/5
PALCE22V10Q-15JC/5
ISPGDS14-7P
PALCE24V10H-25JC
PALLV16V8-10JC
GAL16V8C-7LP
PALCE26V12H-15JC/4
GAL16LV8C-7LJ
PALCE16V8Z-25SC
GAL16LV8ZD-25QJ
GAL16LV8ZD-15QJ
PALCE20V8H-5JC/5
ISPGAL22V10AV-75LSN
ISPGAL22V10AV-75LN
PALCE20RA10H-15PC
PALLV16V8Z-20PI
PALLV22V10-10JC
GAL26V12C-20LPI
ISPGAL22V10AV-75LJ
PALLV16V8-10PC
GAL20XV10B-15LJ
GAL16V8ZD-15QJ
PALCE22V10H-7PC/5
PALLV22V10-7JC
ISPGAL22V10AV-75LS
ISPGAL22LV10-15LJ
GAL22LV10Z-15QJ
ISPGAL22V10AC-75LN
PALCE24V10H-15JC
ISPGAL22V10AV-75LJN
ISPGAL22V10AB-75LN
PALCE26V12H-10JC/4
GAL20V8Z-15QP
GAL16V8Z-12QS
GAL22LV10C-15LJN
GAL16V8ZD-15QP
GAL16VP8B-15LP
ISPGDS18-7P
GAL22LV10C-15LJ
MACH111SP-10JC
GAL20LV8D-5LJ
GAL20VP8B-25LJ
ISPGAL22LV10-15LKI
ISPGAL22V10AV-5LJN
ISPGAL22V10AC-5LN
ISPLSI2032-135LJ
GAL6002B-20LJ
GAL20V8Z-15QJ
GAL16V8Z-12QP
GAL16LV8D-5LJ
ISPLSI-2032-135LT44
GAL20VP8B-15LP
ISPGDS22-7J
GAL20V8ZD-15QP
ISPGAL22V10AB-5LN
PALLV22V10Z-25JI
PALCE24V10H-15PC
MACH111-10JC
ISPLSI2032-80LT48I
GAL20V8ZD-15QJ
ISPGAL22LV10-10LJ
GAL20VP8B-15LJ
GAL20XV10B-10LJ
PALCE26V12H-7JC/4
GAL20V8ZD-12QJ
GAL20V8ZD-12QP
GAL20V8Z-12QP
ISPGAL22V10AC-23LN
ISPGAL22LV10-10LJI
GAL20V8Z-12QJ
ISPGAL22V10AV-28LJ
GAL22LV10ZD-15QJ
ISPGAL22V10AB-23LN
ISPLSI2032-135LT48
MACH211SP-10JC
ISPGAL22LV10-5LJ
GAL16V8C-5LP
PALCE22V10Q-10PC/5
MACH131SP-10VC
GAL22LV10ZD-25QJ
MACH211-7JC
GAL26CV12C-15LP
ISPLSI2032-180LJ
MACH111-7JC
MACH111SP-5JC
MACH131SP-15VC
MACH111-5VC
LC4384V-75F256C
MACH210A-10VC
ISPLSI-2032-150LJ
ISPLSI2096-100LQ
ISPLSI2032-180LT44
ISPLSI2096-80LT
ISPLSI2096-80LQI
ISPLSI-2096-80LQ
M5-128/104-12YC/1
MACH130-15JC
MACH210A-7VC
GAL26CV12C-15LPI
ISPLSI2032-150LT48
ISPLSI2064-100LTI
M5-128/104-10YC/1
ISPLSI2032-180LT48
ISPLSI-2064-125LT
ISPLSI2128-100LT
ISPGAL22LV10-4LJ
M5-128/104-15YC/1
M5-128/104-7YC/1
ISPLSI2096-125LQ
ISPLSI-2096-125LQ
ISPLSI2096-125LT
ISPLSI2096-100LT
MACH131SP-7VC
MACH221-7JC
ISPLSI-3160-70LB272
LC5256MC-75F256C
LC4256C-75F256AC
ISPGDX160VA-9B272I
LC5512MC-45QN208C
LC5256B-4Q208C
M4LV-128N/64-10JC
LC4256C-75FN256BC
LC4256C-75F256BC
LC4256V-10F256BI
ISPLSI-3160-100LQ
MACH230-15JC
ISPLSI3192-70LB272
MACH435Q-20JC
MACH231-7JC
LC5512MC-75F256C
LC5128B-3T128C
ISPLSI1048E-50LT
MACH231-6JC
LC4256V-5FN256AC
LC4256C-5F256AC
LC4256V-5F256AC
LC4256C-5FN256AC
MACH445-12YC
LC4256C-5F256BC
LC4256C-5FN256BC
LC4256B-5FN256BC
LC4256B-5F256BC
LC4256V-5F256BC
LC5512B-75F256C
LC4384V-5FN256C
LC5512MC-75F484C
MACH435-12JC
LC4384C-75FN256C
LC4256V-3FN256AC
LC4256V-3F256AC
LC4256C-3FN256AC
LC4256C-3F256AC
LC4256V-3F256BC
LC4256V-3FN256BC
LC4256C-3F256BC
ISPLSI1048E-90LT
ISPLSI-3160-100LQI
LC5768MB-75F256C
M5-192/160-7YC
LC5512B-75Q208C
LC4384V-5F256C
LC4512C-75FN256C
LC4512B-75FN256C
LC4512V-75F256C
LC4512C-75F256C
LC4512B-10F256I
ISPLSI8600V-60LB492
ISPLSI3256E-70LQA
ISPLSI3256E-70LB320
LC51024MC-75F484C
LC4384V-35FN256C
LC4384V-35F256C
LC4384B-5FN256I
ISPLSI8840V-60LB492
LC4512V-5F256C
LC4512B-5FN256C
LC4512C-5F256C
LC4512C-5FN256C
LC5512B-45F484C
ISPLSI8600V-90LB492
ISPLSI-3160-125LQ
LC5512B-75F484C
LC51024MB-52FN484C
LC51024MB-52F484C
LC5512B-45F256C
ISPLSI 3256E-100LQA
ISPLSI-3448-90LB432
LC4512C-35F256C
LC4512B-35FN256C
LC4512B-35F256C
LC4512C-35FN256C
LC5512B-45Q208C
LC4256V-3FTN256BC
ISPGAL22V10AB-28LJ
GAL6002B-15LJ
MACH211SP-7VC
MACH231SP-12YC
LC5128B-5T128C
MACH221SP-12YC
GAL22V10D-4LJN
MACH131-7JC/1
LC4256B-75F256AC
LC4256C-75FN256AC
LC4256V-75F256AC
ISPLSI1048E-50LQ
ISPLSI2128-100LQ
LC5512MC-45F256C
LC5512MC-45F484C
LC4384B-75FN256C
LC4384V-75FN256C
LC4256B-3F256AC
LC5512B-10Q208C
LC5768MC-75FN256C
LC5768MC-75F256C
LC5512B-10F256C
ISPLSI-3256E-70LQ
LC5512B-10F484C
LC4512V-75FN256C
LC4512V-5FN256C
ISPLSI-3448-70LB432
ISPLSI-3192-100LQ
LC4032V-75TN48C
LAMXO256C-3TN100E
LC4064V-5TN48I
LC4128V-75TN100C
LC4128V-10TN100I
LC4128V-10TN144I
LC4256ZE-7TN100I
LC4256V-75TN100C
LC4256V-75FTN256BC
LC4384V-75TN176C
LC4512V-10TN176I
LC4032ZE-7TN48C
LC4032V-10TN48I
LC4064ZE-7TN48C
LC4064V-10TN44I
LC4032V-25TN48C
LC4064V-10TN48I
LC4064V-75TN100C
LC4064V-10TN100I
LC4128ZC-75TN100C
LC4128V-75TN144C
LC4256ZE-7TN144I
LC4128V-75TN100I
LC4256V-10TN100I
LC4256V-5TN144C
LC4032ZE-7TN48I
LC4032V-75TN44C
LC4032V-10TN44I
LC4032V-75TN44I
LC4064ZE-5TN48C
LC4064ZE-7TN48I
LC4064ZC-75TN48C
LC4032V-75TN48I
LC4064ZE-5TN48I
LC4064V-75TN44C
LC4064ZE-7TN100C
LC4032V-25TN44C
LC4032V-5TN44I
LC4064V-75TN48C
LC4064V-75TN44I
LC4064V-75TN48I
LC4128ZE-7MN144C
LC4064V-75TN48E
LC4128ZE-5TN100C
LC4128ZE-7TN100I
LC4064V-75TN100E
LC4128ZE-7TN144I
LC4064V-25TN48C
LC4064V-25TN100C
LAMXO640C-3TN144E
LC4256ZE-7TN144C
LC4256ZE-5TN100C
LC4256ZC-75TN100C
LC4256ZE-5TN144C
LC4128V-5TN128C
LC4256ZC-75TN100I
LC4256V-75TN144C
LC4256V-10TN144I
LC4256V-75TN176C
LC4256V-10TN176I
LC4128V-27TN100C
LC4256V-5TN100C
LC4256V-5TN176C
LC4256V-75TN176I
LC4384V-10TN176I
LC4512V-75FTN256C
LC4032ZE-7MN64C
LC4032ZC-75TN48C
LC4064ZE-7MN64C
LC4064V-5TN48C
LC4128ZE-7TN100C
LC4064V-25TN44C
LC4128V-75TN128C
LC4128V-5TN100C
LC4256ZC-45TN100C
LC4256ZC-75MN132I
LC4256V-75TN100E
LC4512V-75TN176C
PALCE16V8H-10PC/4
PALCE16V8H-25SC/4
PALCE22V10H-15JI/5
PALCE16V8H-10JI/4
GAL16LV8C-7LJN
PALCE22V10H-25SC/4
GAL16LV8C-15LJ
PALCE22V10H-25PI/4
ISPGAL22V10AC-75LJ
GAL20LV8D-7LJ
ISPGAL22V10AB-75LJ
ISPLSI2032-80LT48
GAL20VP8B-25LP
MACH111-12JC
ISPGAL22V10AB-5LJ
MACH111SP-15VC
MACHLV210-15JC
ISPGAL22V10AC-28LJ
MACH211SP-12VC
GAL26CLV12D-5LJ
PALCE29M16H25JC/4
PALLV22V10-15JI
MACHLV210-12JC
ISPGAL22V10C-15LJ
GAL16V8D-3LJN
M5-128/104-5YC/1
MACH111SP-7VC
MACH111SP-5VC
LC5128B-75T128C
MACH211-7VC
ISPLSI2064-100LJ
MACH131SP-12VC
ISPLSI2032-150LT44
MACH231SP-12VC
M5LV-128/104-10YC
GAL20RA10B-7LJ
LC5256MC-4FN256C
LC4256ZE-7TN100C
M5-256/68-12VC
LC5512MC-45Q208C
M5-128/120-7YC
LC4384C-75F256C
ISPLSI3320-100LQ
2832-LC4512C-5FTN256C-ND
LC4032B-25TN48C-ND
LC4032B-25TN44C-ND
LC4032B-5TN48C-ND
LC4032B-5TN44C-ND
LC4032B-75TN48C-ND
LC4032B-75TN44C-ND
LC4032B-5TN48I-ND
LC4032B-5TN44I-ND
LC4032B-75TN48I-ND
LC4032B-75TN44I-ND
LC4032B-10TN48I-ND
LC4032B-10TN44I-ND
LC4032C-25TN48C-ND
LC4032C-25TN44C-ND
LC4032C-5TN48C-ND
LC4032C-5TN44C-ND
LC4032C-75TN48C-ND
LC4032C-75TN44C-ND
LC4032C-5TN48I-ND
LC4032C-5TN44I-ND
LC4032C-75TN48I-ND
LC4032C-75TN44I-ND
LC4032C-10TN48I-ND
2832-LC4032C-10TN44I-ND,LC4032C-10TN44I-ND
LC4064B-25TN100C-ND
LC4064B-25TN48C-ND
LC4064B-25TN44C-ND
LC4064B-5TN100C-ND
LC4064B-5TN48C-ND
LC4064B-5TN44C-ND
LC4064B-75TN100C-ND
LC4064B-75TN48C-ND
LC4064B-75TN44C-ND
LC4064B-5TN100I-ND
LC4064B-5TN48I-ND
LC4064B-5TN44I-ND
LC4064B-75TN100I-ND
LC4064B-75TN48I-ND
LC4064B-75TN44I-ND
LC4064B-10TN100I-ND
LC4064B-10TN48I-ND
LC4064B-10TN44I-ND
LC4064C-25TN100C-ND
LC4064C-25TN48C-ND
LC4064C-25TN44C-ND
LC4064C-5TN100C-ND
LC4064C-5TN48C-ND
220-1657-ND
220-1658-ND
220-1659-ND
LC4064C-75TN44C-ND
LC4064C-5TN100I-ND
LC4064C-5TN48I-ND
LC4064C-5TN44I-ND
LC4064C-75TN100I-ND
2832-LC4064C-75TN48I-ND,LC4064C-75TN48I-ND
LC4064C-75TN44I-ND
LC4064C-10TN100I-ND
LC4064C-10TN48I-ND
LC4064C-10TN44I-ND
LC4128B-27TN128C-ND
LC4128B-27TN100C-ND
LC4128B-5TN128C-ND
LC4128B-5TN100C-ND
LC4128B-75TN128C-ND
LC4128B-75TN100C-ND
LC4128B-5TN128I-ND
LC4128B-5TN100I-ND
LC4128B-75TN128I-ND
LC4128B-75TN100I-ND
LC4128B-10TN128I-ND
LC4128B-10TN100I-ND
LC4128C-27TN128C-ND
LC4128C-27TN100C-ND
LC4128C-5TN128C-ND
LC4128C-5TN100C-ND
220-1678-ND
220-1677-ND
LC4128C-5TN128I-ND
LC4128C-5TN100I-ND
LC4128C-75TN128I-ND
LC4128C-75TN100I-ND
LC4128C-10TN128I-ND
LC4128C-10TN100I-ND
LC4256B-3FTN256AC-ND
LC4256B-3FTN256BC-ND
LC4256B-3TN176C-ND
LC4256B-3TN100C-ND
LC4256B-5FTN256AC-ND
LC4256B-5FTN256BC-ND
LC4256B-5TN176C-ND
LC4256B-5TN100C-ND
LC4256B-75FTN256AC-ND
LC4256B-75FTN256BC-ND
LC4256B-75TN176C-ND
LC4256B-75TN100C-ND
LC4256B-5FTN256AI-ND
LC4256B-5FTN256BI-ND
LC4256B-5TN176I-ND
LC4256B-5TN100I-ND
LC4256B-75FTN256AI-ND
LC4256B-75FTN256BI-ND
LC4256B-75TN176I-ND
LC4256B-75TN100I-ND
LC4256B-10FTN256AI-ND
LC4256B-10FTN256BI-ND
LC4256B-10TN176I-ND
220-1692-ND
LC4256C-3FTN256AC-ND
LC4256C-3FTN256BC-ND
LC4256C-3TN176C-ND
LC4256C-3TN100C-ND
LC4256C-5FTN256AC-ND
LC4256C-5FTN256BC-ND
LC4256C-5TN176C-ND
LC4256C-5TN100C-ND
LC4256C-75FTN256AC-ND
LC4256C-75FTN256BC-ND
LC4256C-75TN176C-ND
LC4256C-75TN100C-ND
LC4256C-5FTN256BI-ND
LC4256C-5TN176I-ND
LC4256C-5TN100I-ND
LC4256C-75FTN256AI-ND
LC4256C-75FTN256BI-ND
LC4256C-75TN176I-ND
LC4256C-75TN100I-ND
LC4256C-10FTN256AI-ND
LC4256C-10FTN256BI-ND
LC4256C-10TN176I-ND
LC4256C-10TN100I-ND
LC4384B-35FTN256C-ND
LC4384B-35TN176C-ND
LC4384B-5FTN256C-ND
LC4384B-5TN176C-ND
LC4384B-75FTN256C-ND
LC4384B-75TN176C-ND
LC4384B-5FTN256I-ND
LC4384B-5TN176I-ND
LC4384B-75FTN256I-ND
LC4384B-75TN176I-ND
LC4384B-10FTN256I-ND
LC4384B-10TN176I-ND
LC4384C-35FTN256C-ND
LC4384C-35TN176C-ND
LC4384C-5FTN256C-ND
2832-LC4384C-5TN176C-ND,LC4384C-5TN176C-ND
LC4384C-75FTN256C-ND
LC4384C-75TN176C-ND
LC4384C-5FTN256I-ND
2832-LC4384C-5TN176I-ND,LC4384C-5TN176I-ND
LC4384C-75FTN256I-ND
LC4384C-75TN176I-ND
LC4384C-10FTN256I-ND
LC4384C-10TN176I-ND
LC4512B-35FTN256C-ND
LC4512B-35TN176C-ND
LC4512B-5FTN256C-ND
LC4512B-5TN176C-ND
LC4512B-75FTN256C-ND
LC4512B-75TN176C-ND
LC4512B-5FTN256I-ND
LC4512B-5TN176I-ND
LC4512B-75FTN256I-ND
LC4512B-75TN176I-ND
LC4512B-10FTN256I-ND
LC4512B-10TN176I-ND
LC4512C-35FTN256C-ND
LC4512C-35TN176C-ND
LC4512C-5TN176C-ND
LC4512C-75FTN256C-ND
LC4512C-75TN176C-ND
LC4512C-5FTN256I-ND
LC4512C-5TN176I-ND
LC4512C-75FTN256I-ND
LC4512C-75TN176I-ND
LC4512C-10FTN256I-ND
LC4512C-10TN176I-ND
LC4032B-10T44I-ND
LC4032B-10T48I-ND
LC4032B-25T44C-ND
LC4032B-25T48C-ND
LC4032B-5T44C-ND
LC4032B-5T44I-ND
LC4032B-5T48C-ND
LC4032B-5T48I-ND
LC4032B-75T44C-ND
LC4032B-75T44I-ND
LC4032B-75T48C-ND
LC4032B-75T48I-ND
LC4032C-10T44I-ND
LC4032C-10T48I-ND
LC4032C-25T44C-ND
LC4032C-25T48C-ND
LC4032C-5T44C-ND
LC4032C-5T44I-ND
LC4032C-5T48C-ND
LC4032C-5T48I-ND
LC4032C-75T44C-ND
LC4032C-75T44I-ND
LC4032C-75T48C-ND
LC4032C-75T48I-ND
LC4064B-10T100I-ND
LC4064B-10T44I-ND
LC4064B-10T48I-ND
LC4064B-25T100C-ND
LC4064B-25T44C-ND
LC4064B-25T48C-ND
LC4064B-5T100C-ND
LC4064B-5T100I-ND
LC4064B-5T44C-ND
LC4064B-5T44I-ND
LC4064B-5T48C-ND
LC4064B-5T48I-ND
LC4064B-75T100C-ND
LC4064B-75T100I-ND
LC4064B-75T44C-ND
LC4064B-75T44I-ND
LC4064B-75T48C-ND
LC4064B-75T48I-ND
LC4064C-10T100I-ND
LC4064C-10T44I-ND
LC4064C-10T48I-ND
LC4064C-25T100C-ND
LC4064C-25T44C-ND
LC4064C-25T48C-ND
LC4064C-5T100C-ND
LC4064C-5T100I-ND
LC4064C-5T44C-ND
LC4064C-5T44I-ND
LC4064C-5T48C-ND
LC4064C-5T48I-ND
LC4064C-75T100C-ND
LC4064C-75T100I-ND
LC4064C-75T44C-ND
LC4064C-75T44I-ND
LC4064C-75T48C-ND
LC4064C-75T48I-ND
LC4128B-10T100I-ND
LC4128B-10T128I-ND
LC4128B-27T100C-ND
LC4128B-27T128C-ND
LC4128B-5T100C-ND
LC4128B-5T100I-ND
LC4128B-5T128C-ND
LC4128B-5T128I-ND
LC4128B-75T100C-ND
LC4128B-75T100I-ND
LC4128B-75T128C-ND
LC4128B-75T128I-ND
LC4128C-10T100I-ND
LC4128C-10T128I-ND
LC4128C-27T100C-ND
LC4128C-27T128C-ND
2832-LC4128C-5T100C-ND,LC4128C-5T100C-ND
LC4128C-5T100I-ND
LC4128C-5T128C-ND
LC4128C-5T128I-ND
2832-LC4128C-75T100C-ND,LC4128C-75T100C-ND
LC4128C-75T100I-ND
LC4128C-75T128C-ND
LC4128C-75T128I-ND
LC4256B-10F256BI-ND
LC4256B-10FN256AI-ND
LC4256B-10FN256BI-ND
LC4256B-10FT256AI-ND
LC4256B-10FT256BI-ND
LC4256B-10T100I-ND
LC4256B-10T176I-ND
LC4256B-3F256BC-ND
LC4256B-3FN256AC-ND
LC4256B-3FN256BC-ND
LC4256B-3FT256AC-ND
LC4256B-3FT256BC-ND
LC4256B-3T100C-ND
LC4256B-3T176C-ND
LC4256B-5F256AC-ND
LC4256B-5F256BI-ND
LC4256B-5FN256AC-ND
LC4256B-5FN256AI-ND
LC4256B-5FN256BI-ND
LC4256B-5FT256AC-ND
LC4256B-5FT256AI-ND
LC4256B-5FT256BC-ND
LC4256B-5FT256BI-ND
LC4256B-5T100C-ND
LC4256B-5T100I-ND
LC4256B-5T176C-ND
2832-LC4256B-5T176I-ND,LC4256B-5T176I-ND
LC4256B-75F256AI-ND
LC4256B-75F256BC-ND
LC4256B-75FN256AC-ND
LC4256B-75FN256AI-ND
LC4256B-75FN256BC-ND
LC4256B-75FT256AC-ND
LC4256B-75FT256AI-ND
LC4256B-75FT256BC-ND
LC4256B-75FT256BI-ND
LC4256B-75T100C-ND
LC4256B-75T100I-ND
LC4256B-75T176C-ND
LC4256B-75T176I-ND
LC4256C-10FT256AI-ND
LC4256C-10FT256BI-ND
LC4256C-10T100I-ND
LC4256C-10T176I-ND
LC4256C-3FN256BC-ND
LC4256C-3FT256AC-ND
LC4256C-3FT256BC-ND
LC4256C-3T100C-ND
LC4256C-3T176C-ND
LC4256C-5FN256BI-ND
LC4256C-5FT256AC-ND
LC4256C-5FT256AI-ND
LC4256C-5FT256BC-ND
LC4256C-5FT256BI-ND
LC4256C-5FTN256AI-ND
LC4256C-5T100C-ND
LC4256C-5T100I-ND
LC4256C-5T176C-ND
LC4256C-5T176I-ND
LC4256C-75FT256AC-ND
LC4256C-75FT256AI-ND
LC4256C-75FT256BC-ND
LC4256C-75FT256BI-ND
LC4256C-75T100C-ND
LC4256C-75T100I-ND
LC4256C-75T176C-ND
LC4256C-75T176I-ND
LC4384B-10F256I-ND
LC4384B-10FT256I-ND
LC4384B-10T176I-ND
LC4384B-35F256C-ND
LC4384B-35FT256C-ND
LC4384B-35T176C-ND
LC4384B-5F256I-ND
LC4384B-5FN256C-ND
LC4384B-5FT256C-ND
LC4384B-5FT256I-ND
LC4384B-5T176C-ND
LC4384B-5T176I-ND
LC4384B-75F256C-ND
LC4384B-75FN256I-ND
LC4384B-75FT256C-ND
LC4384B-75FT256I-ND
LC4384B-75T176C-ND
LC4384B-75T176I-ND
LC4384C-10FT256I-ND
LC4384C-10T176I-ND
LC4384C-35FN256C-ND
LC4384C-35FT256C-ND
LC4384C-35T176C-ND
LC4384C-5FN256C-ND
LC4384C-5FN256I-ND
LC4384C-5FT256C-ND
LC4384C-5FT256I-ND
LC4384C-5T176C-ND
LC4384C-5T176I-ND
LC4384C-75FN256I-ND
LC4384C-75FT256C-ND
LC4384C-75FT256I-ND
LC4384C-75T176C-ND
2832-LC4384C-75T176I-ND,LC4384C-75T176I-ND
LC4512B-10FT256I-ND
LC4512B-10T176I-ND
LC4512B-35FT256C-ND
LC4512B-35T176C-ND
LC4512B-5F256C-ND
LC4512B-5FT256C-ND
LC4512B-5FT256I-ND
LC4512B-5T176C-ND
LC4512B-5T176I-ND
LC4512B-75F256I-ND
LC4512B-75FT256C-ND
LC4512B-75FT256I-ND
LC4512B-75T176C-ND
LC4512B-75T176I-ND
LC4512C-10FT256I-ND
LC4512C-10T176I-ND
LC4512C-35FT256C-ND
LC4512C-35T176C-ND
LC4512C-5FT256C-ND
LC4512C-5FT256I-ND
LC4512C-5T176C-ND
LC4512C-5T176I-ND
LC4512C-75FT256C-ND
LC4512C-75FT256I-ND
LC4512C-75T176C-ND
LC4512C-75T176I-ND
LC4384B-5F256C-ND
LC4384B-75F256I-ND
LC4384C-35F256C-ND
LC4384C-5F256C-ND
LC4384C-5F256I-ND
LC4384C-75F256I-ND
LC4512C-5FTN256C
LC4032B-25TN48C
LC4032B-25TN44C
LC4032B-5TN48C
LC4032B-5TN44C
LC4032B-75TN48C
LC4032B-75TN44C
LC4032B-5TN48I
LC4032B-5TN44I
LC4032B-75TN48I
LC4032B-75TN44I
LC4032B-10TN48I
LC4032B-10TN44I
LC4032C-25TN48C
LC4032C-25TN44C
LC4032C-5TN48C
LC4032C-5TN44C
LC4032C-75TN48C
LC4032C-75TN44C
LC4032C-5TN48I
LC4032C-5TN44I
LC4032C-75TN48I
LC4032C-75TN44I
LC4032C-10TN48I
LC4032C-10TN44I
LC4064B-25TN100C
LC4064B-25TN48C
LC4064B-25TN44C
LC4064B-5TN100C
LC4064B-5TN48C
LC4064B-5TN44C
LC4064B-75TN100C
LC4064B-75TN48C
LC4064B-75TN44C
LC4064B-5TN100I
LC4064B-5TN48I
LC4064B-5TN44I
LC4064B-75TN100I
LC4064B-75TN48I
LC4064B-75TN44I
LC4064B-10TN100I
LC4064B-10TN48I
LC4064B-10TN44I
LC4064C-25TN100C
LC4064C-25TN48C
LC4064C-25TN44C
LC4064C-5TN100C
LC4064C-5TN48C
LC4064C-5TN44C
LC4064C-75TN100C
LC4064C-75TN48C
LC4064C-75TN44C
LC4064C-5TN100I
LC4064C-5TN48I
LC4064C-5TN44I
LC4064C-75TN100I
LC4064C-75TN48I
LC4064C-75TN44I
LC4064C-10TN100I
LC4064C-10TN48I
LC4064C-10TN44I
LC4128B-27TN128C
LC4128B-27TN100C
LC4128B-5TN128C
LC4128B-5TN100C
LC4128B-75TN128C
LC4128B-75TN100C
LC4128B-5TN128I
LC4128B-5TN100I
LC4128B-75TN128I
LC4128B-75TN100I
LC4128B-10TN128I
LC4128B-10TN100I
LC4128C-27TN128C
LC4128C-27TN100C
LC4128C-5TN128C
LC4128C-5TN100C
LC4128C-75TN128C
LC4128C-75TN100C
LC4128C-5TN128I
LC4128C-5TN100I
LC4128C-75TN128I
LC4128C-75TN100I
LC4128C-10TN128I
LC4128C-10TN100I
LC4256B-3FTN256AC
LC4256B-3FTN256BC
LC4256B-3TN176C
LC4256B-3TN100C
LC4256B-5FTN256AC
LC4256B-5FTN256BC
LC4256B-5TN176C
LC4256B-5TN100C
LC4256B-75FTN256AC
LC4256B-75FTN256BC
LC4256B-75TN176C
LC4256B-75TN100C
LC4256B-5FTN256AI
LC4256B-5FTN256BI
LC4256B-5TN176I
LC4256B-5TN100I
LC4256B-75FTN256AI
LC4256B-75FTN256BI
LC4256B-75TN176I
LC4256B-75TN100I
LC4256B-10FTN256AI
LC4256B-10FTN256BI
LC4256B-10TN176I
LC4256B-10TN100I
LC4256C-3FTN256AC
LC4256C-3FTN256BC
LC4256C-3TN176C
LC4256C-3TN100C
LC4256C-5FTN256AC
LC4256C-5FTN256BC
LC4256C-5TN176C
LC4256C-5TN100C
LC4256C-75FTN256AC
LC4256C-75FTN256BC
LC4256C-75TN176C
LC4256C-75TN100C
LC4256C-5FTN256BI
LC4256C-5TN176I
LC4256C-5TN100I
LC4256C-75FTN256AI
LC4256C-75FTN256BI
LC4256C-75TN176I
LC4256C-75TN100I
LC4256C-10FTN256AI
LC4256C-10FTN256BI
LC4256C-10TN176I
LC4256C-10TN100I
LC4384B-35FTN256C
LC4384B-35TN176C
LC4384B-5FTN256C
LC4384B-5TN176C
LC4384B-75FTN256C
LC4384B-75TN176C
LC4384B-5FTN256I
LC4384B-5TN176I
LC4384B-75FTN256I
LC4384B-75TN176I
LC4384B-10FTN256I
LC4384B-10TN176I
LC4384C-35FTN256C
LC4384C-35TN176C
LC4384C-5FTN256C
LC4384C-5TN176C
LC4384C-75FTN256C
LC4384C-75TN176C
LC4384C-5FTN256I
LC4384C-5TN176I
LC4384C-75FTN256I
LC4384C-75TN176I
LC4384C-10FTN256I
LC4384C-10TN176I
LC4512B-35FTN256C
LC4512B-35TN176C
LC4512B-5FTN256C
LC4512B-5TN176C
LC4512B-75FTN256C
LC4512B-75TN176C
LC4512B-5FTN256I
LC4512B-5TN176I
LC4512B-75FTN256I
LC4512B-75TN176I
LC4512B-10FTN256I
LC4512B-10TN176I
LC4512C-35FTN256C
LC4512C-35TN176C
LC4512C-5TN176C
LC4512C-75FTN256C
LC4512C-75TN176C
LC4512C-5FTN256I
LC4512C-5TN176I
LC4512C-75FTN256I
LC4512C-75TN176I
LC4512C-10FTN256I
LC4512C-10TN176I
LC4032B-10T44I
LC4032B-10T48I
LC4032B-25T44C
LC4032B-25T48C
LC4032B-5T44C
LC4032B-5T44I
LC4032B-5T48C
LC4032B-5T48I
LC4032B-75T44C
LC4032B-75T44I
LC4032B-75T48C
LC4032B-75T48I
LC4032C-10T44I
LC4032C-10T48I
LC4032C-25T44C
LC4032C-25T48C
LC4032C-5T44C
LC4032C-5T44I
LC4032C-5T48C
LC4032C-5T48I
LC4032C-75T44C
LC4032C-75T44I
LC4032C-75T48C
LC4032C-75T48I
LC4064B-10T100I
LC4064B-10T44I
LC4064B-10T48I
LC4064B-25T100C
LC4064B-25T44C
LC4064B-25T48C
LC4064B-5T100C
LC4064B-5T100I
LC4064B-5T44C
LC4064B-5T44I
LC4064B-5T48C
LC4064B-5T48I
LC4064B-75T100C
LC4064B-75T100I
LC4064B-75T44C
LC4064B-75T44I
LC4064B-75T48C
LC4064B-75T48I
LC4064C-10T100I
LC4064C-10T44I
LC4064C-10T48I
LC4064C-25T100C
LC4064C-25T44C
LC4064C-25T48C
LC4064C-5T100C
LC4064C-5T100I
LC4064C-5T44C
LC4064C-5T44I
LC4064C-5T48C
LC4064C-5T48I
LC4064C-75T100C
LC4064C-75T100I
LC4064C-75T44C
LC4064C-75T44I
LC4064C-75T48C
LC4064C-75T48I
LC4128B-10T100I
LC4128B-10T128I
LC4128B-27T100C
LC4128B-27T128C
LC4128B-5T100C
LC4128B-5T100I
LC4128B-5T128C
LC4128B-5T128I
LC4128B-75T100C
LC4128B-75T100I
LC4128B-75T128C
LC4128B-75T128I
LC4128C-10T100I
LC4128C-10T128I
LC4128C-27T100C
LC4128C-27T128C
LC4128C-5T100C
LC4128C-5T100I
LC4128C-5T128C
LC4128C-5T128I
LC4128C-75T100C
LC4128C-75T100I
LC4128C-75T128C
LC4128C-75T128I
LC4256B-10F256BI
LC4256B-10FN256AI
LC4256B-10FN256BI
LC4256B-10FT256AI
LC4256B-10FT256BI
LC4256B-10T100I
LC4256B-10T176I
LC4256B-3F256BC
LC4256B-3FN256AC
LC4256B-3FN256BC
LC4256B-3FT256AC
LC4256B-3FT256BC
LC4256B-3T100C
LC4256B-3T176C
LC4256B-5F256AC
LC4256B-5F256BI
LC4256B-5FN256AC
LC4256B-5FN256AI
LC4256B-5FN256BI
LC4256B-5FT256AC
LC4256B-5FT256AI
LC4256B-5FT256BC
LC4256B-5FT256BI
LC4256B-5T100C
LC4256B-5T100I
LC4256B-5T176C
LC4256B-5T176I
LC4256B-75F256AI
LC4256B-75F256BC
LC4256B-75FN256AC
LC4256B-75FN256AI
LC4256B-75FN256BC
LC4256B-75FT256AC
LC4256B-75FT256AI
LC4256B-75FT256BC
LC4256B-75FT256BI
LC4256B-75T100C
LC4256B-75T100I
LC4256B-75T176C
LC4256B-75T176I
LC4256C-10FT256AI
LC4256C-10FT256BI
LC4256C-10T100I
LC4256C-10T176I
LC4256C-3FN256BC
LC4256C-3FT256AC
LC4256C-3FT256BC
LC4256C-3T100C
LC4256C-3T176C
LC4256C-5FN256BI
LC4256C-5FT256AC
LC4256C-5FT256AI
LC4256C-5FT256BC
LC4256C-5FT256BI
LC4256C-5FTN256AI
LC4256C-5T100C
LC4256C-5T100I
LC4256C-5T176C
LC4256C-5T176I
LC4256C-75FT256AC
LC4256C-75FT256AI
LC4256C-75FT256BC
LC4256C-75FT256BI
LC4256C-75T100C
LC4256C-75T100I
LC4256C-75T176C
LC4256C-75T176I
LC4384B-10F256I
LC4384B-10FT256I
LC4384B-10T176I
LC4384B-35F256C
LC4384B-35FT256C
LC4384B-35T176C
LC4384B-5F256I
LC4384B-5FN256C
LC4384B-5FT256C
LC4384B-5FT256I
LC4384B-5T176C
LC4384B-5T176I
LC4384B-75F256C
LC4384B-75FN256I
LC4384B-75FT256C
LC4384B-75FT256I
LC4384B-75T176C
LC4384B-75T176I
LC4384C-10FT256I
LC4384C-10T176I
LC4384C-35FN256C
LC4384C-35FT256C
LC4384C-35T176C
LC4384C-5FN256C
LC4384C-5FN256I
LC4384C-5FT256C
LC4384C-5FT256I
LC4384C-5T176C
LC4384C-5T176I
LC4384C-75FN256I
LC4384C-75FT256C
LC4384C-75FT256I
LC4384C-75T176C
LC4384C-75T176I
LC4512B-10FT256I
LC4512B-10T176I
LC4512B-35FT256C
LC4512B-35T176C
LC4512B-5F256C
LC4512B-5FT256C
LC4512B-5FT256I
LC4512B-5T176C
LC4512B-5T176I
LC4512B-75F256I
LC4512B-75FT256C
LC4512B-75FT256I
LC4512B-75T176C
LC4512B-75T176I
LC4512C-10FT256I
LC4512C-10T176I
LC4512C-35FT256C
LC4512C-35T176C
LC4512C-5FT256C
LC4512C-5FT256I
LC4512C-5T176C
LC4512C-5T176I
LC4512C-75FT256C
LC4512C-75FT256I
LC4512C-75T176C
LC4512C-75T176I
LC4384B-5F256C
LC4384B-75F256I
LC4384C-35F256C
LC4384C-5F256C
LC4384C-5F256I
LC4384C-75F256I
220-1695-ND
220-1033-ND
220-1665-ND
220-1044-ND
220-1046-ND
220-1045-ND
220-1032-ND
220-1705-ND
220-1703-ND
220-1716-ND
220-1717-ND
220-1362-ND
220-1035-ND
220-1366-ND
220-1042-ND
220-1643-ND
220-1041-ND
220-1037-ND
220-1040-ND
220-1690-ND
220-1043-ND
220-1030-ND
220-1684-ND
220-1693-ND
220-1701-ND
220-1014-ND
220-1034-ND
220-1036-ND
220-1648-ND
220-1676-ND
220-1367-ND
220-1674-ND
220-1649-ND
220-2035-ND
220-1039-ND
220-1365-ND
220-1642-ND
220-1645-ND
220-1038-ND
220-1667-ND
220-1669-ND
220-1370-ND
220-1668-ND
220-1023-ND
220-1026-ND
220-1297-ND
220-1024-ND
220-1661-ND
220-1290-ND
220-1376-ND
220-1029-ND
220-1712-ND
220-1027-ND
220-1682-ND
220-1713-ND
220-1708-ND
220-2037-ND
220-1709-ND
220-1694-ND
220-1679-ND
220-1700-ND
220-1301-ND
220-2650-ND
220-2038-ND
220-1720-ND
220-1361-ND
220-1654-ND
220-1364-ND
220-1664-ND
220-1691-ND
220-1660-ND
220-1685-ND
220-1680-ND
220-1710-ND
220-1711-ND
220-1706-ND
220-1721-ND
220-1375-ND
220-1012-ND
LC4032ZE-4TN48C-ND
220-2652-ND
220-1011-ND
220-1013-ND
220-1651-ND
220-1656-ND
220-1652-ND
220-1655-ND
LC4032ZE-4MN64C-ND
LC4032ZE-5MN64I-ND
LC4032ZC-5MN56C-ND
220-1653-ND
LC4032ZC-35TN48C-ND
LC4032ZC-5TN48I-ND
220-1644-ND
220-1650-ND
LC4032ZC-5MN56I-ND
220-1368-ND
2832-LC4032V-75TN44E-ND,220-1647-ND
220-1646-ND
LC4064ZE-4TN48C-ND
LC4064ZE-5UMN64C-ND
220-1369-ND
220-1017-ND
220-1020-ND
LC4032V-75TN48E-ND
LC4064ZE-4UMN64C-ND
LC4064ZE-5UMN64I-ND
220-1673-ND
LC4064ZE-4MN64C-ND
LC4064ZE-5MN64I-ND
220-1363-ND
220-1289-ND
220-1016-ND
220-1019-ND
220-1015-ND
LC4032V-5TN48I-ND
220-1018-ND
220-1671-ND
220-1675-ND
LC4064ZE-4TN100C-ND
LC4064ZE-5TN100I-ND
LC4064ZE-4MN144C-ND
LC4064ZE-5MN144I-ND
220-1672-ND
2832-LC4064ZC-5MN56C-ND,LC4064ZC-5MN56C-ND
LC4064ZC-75MN56I-ND
LC4064ZC-75TN48E-ND
220-1670-ND
LC4064ZC-75TN100I-ND
LC4064ZC-75TN100E-ND
LC4064ZC-37TN48C-ND
LC4064ZC-5TN48I-ND
220-1663-ND
LC4064ZC-5MN132C-ND
LC4064ZC-75MN132I-ND
LC4064ZC-37MN56C-ND
LC4064ZC-5MN56I-ND
220-1372-ND
LC4064V-75TN44E-ND
220-1022-ND
220-1025-ND
LC4128ZE-5UMN132C-ND
220-1373-ND
220-1662-ND
220-1666-ND
220-1371-ND
LC4064ZC-37TN100C-ND
LC4064ZC-5TN100I-ND
220-1021-ND
LC4064ZC-37MN132C-ND
LC4064ZC-5MN132I-ND
LC4064V-5TN44I-ND
220-1688-ND
LC4064V-5TN100I-ND
220-2036-ND
220-1374-ND
220-1028-ND
220-1031-ND
LC4256ZC-75TN176C-ND
220-1687-ND
LC4128ZC-75TN100I-ND
220-1686-ND
220-1689-ND
2832-LC4128ZC-75TN100E-ND,220-2654-ND
LC4256ZC-75MN132C-ND
220-1683-ND
LC4128V-75TN144I-ND
LC4128V-75TN128I-ND
LC4128V-75TN100E-ND
LC4128V-75TN128E-ND
LC4256ZC-75TN100E-ND
LC4256ZC-45TN176C-ND
LC4256ZC-75TN176I-ND
LC4128V-75TN144E-ND
220-1702-ND
LC4256V-10FTN256AI-ND
LC4256ZC-75TN176E-ND
220-1681-ND
LC4128V-27TN128C-ND
LC4128V-5TN128I-ND
LC4256V-10FTN256BI-ND
LC4256ZC-45MN132C-ND
LC4128V-27TN144C-ND
LC4128V-5TN144I-ND
220-1707-ND
LC4256V-75TN144I-ND
220-1698-ND
LC4256V-75FTN256AI-ND
LC4256V-75TN144E-ND
LC4256V-75TN176E-ND
220-1699-ND
220-1704-ND
220-1696-ND
LC4256V-5TN100I-ND
2832-LC4256V-3TN144C-ND,220-1697-ND
LC4256V-5TN144I-ND
220-1715-ND
LC4384V-10FTN256I-ND
LC4256V-3TN176C-ND
LC4256V-5TN176I-ND
LC4256V-3FTN256AC-ND
LC4256V-5FTN256AI-ND
LC4256V-5FTN256BI-ND
LC4384V-5TN176C-ND
LC4384V-75TN176I-ND
220-1714-ND
LC4384V-75FTN256I-ND
220-2039-ND
LC4384V-35TN176C-ND
LC4384V-5TN176I-ND
LC4384V-35FTN256C-ND
LC4384V-5FTN256I-ND
LC4512V-5TN176C-ND
LC4512V-75TN176I-ND
220-1719-ND
LC4512V-75FTN256I-ND
LC4512V-35TN176C-ND
LC4512V-5TN176I-ND
220-1718-ND
LC4512V-5FTN256I-ND
2832-LC4512V-5FT256C-ND
LC4128V-5T144I-ND
LC4064ZE-4TCN100C-ND
LC4064ZE-5TCN100C-ND
LC4064ZE-7TCN100C-ND
LC4064ZE-5TCN100I-ND
LC4064ZE-7TCN100I-ND
LC4128ZE-5TCN100C-ND
LC4128ZE-7TCN100C-ND
LC4128ZE-7TCN100I-ND
LC4032V-10T44I-ND
LC4032V-10T48I-ND
LC4032V-25T44C-ND
LC4032V-25T48C-ND
LC4032V-5T44C-ND
LC4032V-5T44I-ND
LC4032V-5T48C-ND
LC4032V-5T48I-ND
LC4032V-75T44C-ND
LC4032V-75T44I-ND
220-2634-ND
LC4032V-75T48E-ND
LC4032V-75T48I-ND
LC4032ZC-35M56C-ND
LC4032ZC-35T48C-ND
LC4032ZC-5M56C-ND
LC4032ZC-5M56I-ND
LC4032ZC-5T48C-ND
LC4032ZC-5T48I-ND
LC4032ZC-75M56C-ND
LC4032ZC-75M56I-ND
LC4032ZC-75T48C-ND
LC4032ZC-75T48E-ND
LC4032ZC-75T48I-ND
LC4064V-10T100I-ND
220-2653-ND
LC4064V-10T48I-ND
LC4064V-25T100C-ND
LC4064V-25T44C-ND
LC4064V-25T48C-ND
LC4064V-5T100C-ND
LC4064V-5T100I-ND
LC4064V-5T44C-ND
LC4064V-5T44I-ND
LC4064V-5T48C-ND
LC4064V-5T48I-ND
220-1866-ND
LC4064V-75T100E-ND
LC4064V-75T100I-ND
LC4064V-75T44C-ND
LC4064V-75T44E-ND
LC4064V-75T44I-ND
LC4064V-75T48C-ND
LC4064V-75T48E-ND
LC4064V-75T48I-ND
LC4064ZC-37M132C-ND
LC4064ZC-37M56C-ND
LC4064ZC-37T100C-ND
LC4064ZC-37T48C-ND
LC4064ZC-5M132C-ND
LC4064ZC-5M132I-ND
LC4064ZC-5M56C-ND
2832-LC4064ZC-5M56I-220-ND,LC4064ZC-5M56I-ND
LC4064ZC-5T100C-ND
LC4064ZC-5T100I-ND
LC4064ZC-5T48C-ND
LC4064ZC-5T48I-ND
LC4064ZC-75M132C-ND
LC4064ZC-75M132I-ND
LC4064ZC-75M56C-ND
LC4064ZC-75M56I-ND
LC4064ZC-75T100C-ND
LC4064ZC-75T100E-ND
LC4064ZC-75T100I-ND
LC4064ZC-75T48C-ND
LC4064ZC-75T48E-ND
LC4064ZC-75T48I-ND
LC4128V-10T100I-ND
LC4128V-10T128I-ND
LC4128V-10T144I-ND
LC4128V-27T100C-ND
LC4128V-27T128C-ND
LC4128V-27T144C-ND
LC4128V-5T100C-ND
LC4128V-5T100I-ND
LC4128V-5T128C-ND
LC4128V-5T128I-ND
LC4128V-5T144C-ND
LC4128V-75T100C-ND
220-1890-ND
LC4128V-75T100I-ND
LC4128V-75T128C-ND
LC4128V-75T128E-ND
LC4128V-75T128I-ND
LC4128V-75T144C-ND
LC4128V-75T144E-ND
LC4128V-75T144I-ND
LC4128ZC-42M132C-ND
LC4128ZC-42T100C-ND
LC4128ZC-75M132C-ND
LC4128ZC-75M132I-ND
LC4128ZC-75T100C-ND
LC4128ZC-75T100E-ND
LC4128ZC-75T100I-ND
LC4256V-10FT256AI-ND
LC4256V-10FT256BI-ND
LC4256V-10T100I-ND
LC4256V-10T144I-ND
LC4256V-10T176I-ND
LC4256V-3FT256AC-ND
LC4256V-3FT256BC-ND
LC4256V-3T100C-ND
LC4256V-3T144C-ND
LC4256V-3T176C-ND
2156-LC4256V-5FN256BC-LA-ND,LC4256V-5FN256BC-ND
LC4256V-5FT256AC-ND
LC4256V-5FT256AI-ND
LC4256V-5FT256BC-ND
LC4256V-5FT256BI-ND
LC4256V-5T100C-ND
LC4256V-5T100I-ND
LC4256V-5T144C-ND
LC4256V-5T144I-ND
LC4256V-5T176C-ND
LC4256V-5T176I-ND
LC4256V-75FN256BI-ND
LC4256V-75FT256AC-ND
LC4256V-75FT256AI-ND
LC4256V-75FT256BC-ND
LC4256V-75FT256BI-ND
LC4256V-75T100C-ND
LC4256V-75T100E-ND
LC4256V-75T100I-ND
LC4256V-75T144C-ND
LC4256V-75T144E-ND
LC4256V-75T144I-ND
LC4256V-75T176C-ND
LC4256V-75T176E-ND
LC4256V-75T176I-ND
LC4256ZC-45M132C-ND
LC4256ZC-45T100C-ND
LC4256ZC-45T176C-ND
LC4256ZC-75M132C-ND
LC4256ZC-75M132I-ND
LC4256ZC-75T100C-ND
LC4256ZC-75T100E-ND
LC4256ZC-75T100I-ND
LC4256ZC-75T176C-ND
LC4256ZC-75T176E-ND
LC4256ZC-75T176I-ND
LC4384V-10FT256I-ND
LC4384V-10T176I-ND
LC4384V-35FT256C-ND
LC4384V-35T176C-ND
LC4384V-5FT256C-ND
LC4384V-5FT256I-ND
LC4384V-5T176C-ND
LC4384V-5T176I-ND
LC4384V-75FT256C-ND
LC4384V-75FT256I-ND
LC4384V-75T176C-ND
LC4384V-75T176I-ND
LC4512V-10FT256I-ND
LC4512V-10T176I-ND
2156-LC4512V-35FN256C-LA-ND,LC4512V-35FN256C-ND
LC4512V-35FT256C-ND
LC4512V-35T176C-ND
LC4512V-5F256I-ND
220-1891-ND
LC4512V-5T176C-ND
LC4512V-5T176I-ND
LC4512V-75FT256C-ND
LC4512V-75FT256I-ND
LC4512V-75T176C-ND
LC4512V-75T176I-ND
LC4032V-75T44E-ND
LC4512V-35F256C-ND
LC4256V-3FTN256BC
LC4032V-75TN48C
LC4064V-5TN48I
LC4128V-75TN100C
LC4128V-10TN100I
LC4128V-10TN144I
LC4256ZE-7TN100I
LC4256V-75TN100C
LC4256V-75FTN256BC
LC4384V-75TN176C
LC4512V-10TN176I
LC4032ZE-7TN48C
LC4032V-10TN48I
LC4064ZE-7TN48C
LC4064V-10TN44I
LC4032V-25TN48C
LC4064V-10TN48I
LC4064V-75TN100C
LC4064V-10TN100I
LC4128ZC-75TN100C
LC4128V-75TN144C
LC4256ZE-7TN144I
LC4128V-75TN100I
LC4256V-10TN100I
LC4256V-5TN144C
LC4032ZE-7TN48I
LC4032V-75TN44C
LC4032V-10TN44I
LC4032V-75TN44I
LC4064ZE-5TN48C
LC4064ZE-7TN48I
LC4064ZC-75TN48C
LC4032V-75TN48I
LC4064ZE-5TN48I
LC4064V-75TN44C
LC4064ZE-7TN100C
LC4032V-25TN44C
LC4032V-5TN44I
LC4064V-75TN48C
LC4064V-75TN44I
LC4064V-75TN48I
LC4128ZE-7MN144C
LC4064V-75TN48E
LC4128ZE-5TN100C
LC4128ZE-7TN100I
LC4064V-75TN100E
LC4128ZE-7TN144I
LC4064V-25TN48C
LC4064V-25TN100C
LC4256ZE-7TN144C
LC4256ZE-5TN100C
LC4256ZC-75TN100C
LC4256ZE-5TN144C
LC4128V-5TN128C
LC4256ZC-75TN100I
LC4256V-75TN144C
LC4256V-10TN144I
LC4256V-75TN176C
LC4256V-10TN176I
LC4128V-27TN100C
LC4256V-5TN100C
LC4256V-5TN176C
LC4256V-75TN176I
LC4384V-10TN176I
LC4512V-75FTN256C
LC4032ZE-7MN64C
LC4032ZC-75TN48C
LC4064ZE-7MN64C
LC4064V-5TN48C
LC4128ZE-7TN100C
LC4064V-25TN44C
LC4128V-75TN128C
LC4128V-5TN100C
LC4256ZC-45TN100C
LC4256ZC-75MN132I
LC4256V-75TN100E
LC4512V-75TN176C
LC4256ZE-7TN100C
LC4032ZE-5TN48C
LC4032ZE-4TN48C
LC4032ZE-5TN48I
LC4032ZE-5MN64C
LC4032ZE-7MN64I
LC4032ZC-5TN48C
LC4032ZC-75TN48I
LC4032ZC-75MN56C
LC4032ZC-75TN48E
LC4032ZE-4MN64C
LC4032ZE-5MN64I
LC4032ZC-5MN56C
LC4032ZC-75MN56I
LC4032ZC-35TN48C
LC4032ZC-5TN48I
LC4032V-5TN44C
LC4032ZC-35MN56C
LC4032ZC-5MN56I
LC4064ZE-7UMN64C
LC4032V-75TN44E
LC4032V-5TN48C
LC4064ZE-4TN48C
LC4064ZE-5UMN64C
LC4064ZE-7UMN64I
LC4064ZE-5MN64C
LC4064ZE-7MN64I
LC4032V-75TN48E
LC4064ZE-4UMN64C
LC4064ZE-5UMN64I
LC4064ZC-75MN56C
LC4064ZE-4MN64C
LC4064ZE-5MN64I
LC4064ZE-7MN144C
LC4064ZC-75TN100C
LC4064ZE-5TN100C
LC4064ZE-7TN100I
LC4064ZE-5MN144C
LC4032V-5TN48I
LC4064ZE-7MN144I
LC4064ZC-5TN48C
LC4064ZC-75TN48I
LC4064ZE-4TN100C
LC4064ZE-5TN100I
LC4064ZE-4MN144C
LC4064ZE-5MN144I
LC4064ZC-75MN132C
LC4064ZC-5MN56C
LC4064ZC-75MN56I
LC4064ZC-75TN48E
LC4064ZC-5TN100C
LC4064ZC-75TN100I
LC4064ZC-75TN100E
LC4064ZC-37TN48C
LC4064ZC-5TN48I
LC4064V-5TN44C
LC4064ZC-5MN132C
LC4064ZC-75MN132I
LC4064ZC-37MN56C
LC4064ZC-5MN56I
LC4128ZE-7UMN132C
LC4064V-75TN44E
LC4128ZE-5MN144C
LC4128ZE-7MN144I
LC4128ZE-5UMN132C
LC4128ZE-7UMN132I
LC4064V-5TN100C
LC4064V-75TN100I
LC4128ZE-7TN144C
LC4064ZC-37TN100C
LC4064ZC-5TN100I
LC4128ZE-5TN144C
LC4064ZC-37MN132C
LC4064ZC-5MN132I
LC4064V-5TN44I
LC4128ZC-75MN132C
LC4064V-5TN100I
LC4128V-10TN128I
LC4256ZE-7MN144C
LC4256ZE-5MN144C
LC4256ZE-7MN144I
LC4256ZC-75TN176C
LC4128ZC-42TN100C
LC4128ZC-75TN100I
LC4128ZC-42MN132C
LC4128ZC-75MN132I
LC4128ZC-75TN100E
LC4256ZC-75MN132C
LC4128V-5TN144C
LC4128V-75TN144I
LC4128V-75TN128I
LC4128V-75TN100E
LC4128V-75TN128E
LC4256ZC-75TN100E
LC4256ZC-45TN176C
LC4256ZC-75TN176I
LC4128V-75TN144E
LC4256V-75FTN256AC
LC4256V-10FTN256AI
LC4256ZC-75TN176E
LC4128V-5TN100I
LC4128V-27TN128C
LC4128V-5TN128I
LC4256V-10FTN256BI
LC4256ZC-45MN132C
LC4128V-27TN144C
LC4128V-5TN144I
LC4256V-75TN100I
LC4256V-75TN144I
LC4256V-5FTN256AC
LC4256V-75FTN256AI
LC4256V-75TN144E
LC4256V-75TN176E
LC4256V-5FTN256BC
LC4256V-75FTN256BI
LC4256V-3TN100C
LC4256V-5TN100I
LC4256V-3TN144C
LC4256V-5TN144I
LC4384V-75FTN256C
LC4384V-10FTN256I
LC4256V-3TN176C
LC4256V-5TN176I
LC4256V-3FTN256AC
LC4256V-5FTN256AI
LC4256V-5FTN256BI
LC4384V-5TN176C
LC4384V-75TN176I
LC4384V-5FTN256C
LC4384V-75FTN256I
LC4512V-10FTN256I
LC4384V-35TN176C
LC4384V-5TN176I
LC4384V-35FTN256C
LC4384V-5FTN256I
LC4512V-5TN176C
LC4512V-75TN176I
LC4512V-5FTN256C
LC4512V-75FTN256I
LC4512V-35TN176C
LC4512V-5TN176I
LC4512V-35FTN256C
LC4512V-5FTN256I
LC4512V-5FT256C
LC4128V-5T144I
LC4064ZE-4TCN100C
LC4064ZE-5TCN100C
LC4064ZE-7TCN100C
LC4064ZE-5TCN100I
LC4064ZE-7TCN100I
LC4128ZE-5TCN100C
LC4128ZE-7TCN100C
LC4128ZE-7TCN100I
LC4032V-10T44I
LC4032V-10T48I
LC4032V-25T44C
LC4032V-25T48C
LC4032V-5T44C
LC4032V-5T44I
LC4032V-5T48C
LC4032V-5T48I
LC4032V-75T44C
LC4032V-75T44I
LC4032V-75T48C
LC4032V-75T48E
LC4032V-75T48I
LC4032ZC-35M56C
LC4032ZC-35T48C
LC4032ZC-5M56C
LC4032ZC-5M56I
LC4032ZC-5T48C
LC4032ZC-5T48I
LC4032ZC-75M56C
LC4032ZC-75M56I
LC4032ZC-75T48C
LC4032ZC-75T48E
LC4032ZC-75T48I
LC4064V-10T100I
LC4064V-10T44I
LC4064V-10T48I
LC4064V-25T100C
LC4064V-25T44C
LC4064V-25T48C
LC4064V-5T100C
LC4064V-5T100I
LC4064V-5T44C
LC4064V-5T44I
LC4064V-5T48C
LC4064V-5T48I
LC4064V-75T100C
LC4064V-75T100E
LC4064V-75T100I
LC4064V-75T44C
LC4064V-75T44E
LC4064V-75T44I
LC4064V-75T48C
LC4064V-75T48E
LC4064V-75T48I
LC4064ZC-37M132C
LC4064ZC-37M56C
LC4064ZC-37T100C
LC4064ZC-37T48C
LC4064ZC-5M132C
LC4064ZC-5M132I
LC4064ZC-5M56C
LC4064ZC-5M56I
LC4064ZC-5T100C
LC4064ZC-5T100I
LC4064ZC-5T48C
LC4064ZC-5T48I
LC4064ZC-75M132C
LC4064ZC-75M132I
LC4064ZC-75M56C
LC4064ZC-75M56I
LC4064ZC-75T100C
LC4064ZC-75T100E
LC4064ZC-75T100I
LC4064ZC-75T48C
LC4064ZC-75T48E
LC4064ZC-75T48I
LC4128V-10T100I
LC4128V-10T128I
LC4128V-10T144I
LC4128V-27T100C
LC4128V-27T128C
LC4128V-27T144C
LC4128V-5T100C
LC4128V-5T100I
LC4128V-5T128C
LC4128V-5T128I
LC4128V-5T144C
LC4128V-75T100C
LC4128V-75T100E
LC4128V-75T100I
LC4128V-75T128C
LC4128V-75T128E
LC4128V-75T128I
LC4128V-75T144C
LC4128V-75T144E
LC4128V-75T144I
LC4128ZC-42M132C
LC4128ZC-42T100C
LC4128ZC-75M132C
LC4128ZC-75M132I
LC4128ZC-75T100C
LC4128ZC-75T100E
LC4128ZC-75T100I
LC4256V-10FT256AI
LC4256V-10FT256BI
LC4256V-10T100I
LC4256V-10T144I
LC4256V-10T176I
LC4256V-3FT256AC
LC4256V-3FT256BC
LC4256V-3T100C
LC4256V-3T144C
LC4256V-3T176C
LC4256V-5FN256BC
LC4256V-5FT256AC
LC4256V-5FT256AI
LC4256V-5FT256BC
LC4256V-5FT256BI
LC4256V-5T100C
LC4256V-5T100I
LC4256V-5T144C
LC4256V-5T144I
LC4256V-5T176C
LC4256V-5T176I
LC4256V-75FN256BI
LC4256V-75FT256AC
LC4256V-75FT256AI
LC4256V-75FT256BC
LC4256V-75FT256BI
LC4256V-75T100C
LC4256V-75T100E
LC4256V-75T100I
LC4256V-75T144C
LC4256V-75T144E
LC4256V-75T144I
LC4256V-75T176C
LC4256V-75T176E
LC4256V-75T176I
LC4256ZC-45M132C
LC4256ZC-45T100C
LC4256ZC-45T176C
LC4256ZC-75M132C
LC4256ZC-75M132I
LC4256ZC-75T100C
LC4256ZC-75T100E
LC4256ZC-75T100I
LC4256ZC-75T176C
LC4256ZC-75T176E
LC4256ZC-75T176I
LC4384V-10FT256I
LC4384V-10T176I
LC4384V-35FT256C
LC4384V-35T176C
LC4384V-5FT256C
LC4384V-5FT256I
LC4384V-5T176C
LC4384V-5T176I
LC4384V-75FT256C
LC4384V-75FT256I
LC4384V-75T176C
LC4384V-75T176I
LC4512V-10FT256I
LC4512V-10T176I
LC4512V-35FN256C
LC4512V-35FT256C
LC4512V-35T176C
LC4512V-5F256I
LC4512V-5FT256I
LC4512V-5T176C
LC4512V-5T176I
LC4512V-75FT256C
LC4512V-75FT256I
LC4512V-75T176C
LC4512V-75T176I
LC4032V-75T44E
LC4512V-35F256C
mismatch
CPLD
FPGA
Ispmach 4000 commercial 4000z lc4128c-5t100c -751 industrial
part marking difference
different part number
2 part numbers
Thank you so much for the clarification! I hadn’t realized that the dual-marked chips operate at different maximum speeds at each temperature range.
