I am running Debian Stretch with the 4.14.40-ti-r50 kernel and a U-Boot version of [U-Boot 2018.03-00002-gac9cce7c6a]
The problem that I am running into is that I am unable to control my GPIO’s after updating my Device Tree Overlay. I updated the DTO as per page 7 of this pdf.
The Skywire BeagleBone Black Cape is able to connect to the internet as intended, I just cannot control any of the other GPIO’s now. I have tried to manually controll the GPIO’s through terminal under the /sys/classes/gpio settings and it only displays 2 gpios that are not even on the BBB pin out diagram, and when I try to export the correct GPIO’s into this list, I am able to change the values but it will not send the signal over the GPIO. I even check to see if the GPIO’s are MUX’d, but non of them show as available. I am thinking it was when I updated the device tree overlay as per the user manual for the cape that caused this issue. I am needing the GPIOs to connect to sensors and LEDs but without control of the GPIOs, my program won’t work.
If you need any other log files, please let me know.
