Hello everyone,
I have recently purchased a beaglebone black and experimenting with IoT applications through connecting a SIMCOM 4G dongle through USB connection. I’m creating a Internet router which provides internet access to LAN clients via ETH0 and WAN access to beaglebone via LTE SIMCOM7600 dongle.
I observed two cases while operating LTE modem with beaglebone black
CASE 1:
With network interfaces configured as follows, Beaglebone black is connected to Internet, able to ping and appears in network interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
#auto eth0
iface eth0 inet static
address 192.168.4.1
netmask 255.255.255.0
gateway 192.168.4.1
#broadcast 192.168.4.255
#auto usb2
#iface usb2 inet dhcp
debian@beaglebone:~$ lsusb
Bus 001 Device 002: ID 1e0e:9011 Qualcomm / Option
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
debian@beaglebone:~$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.225.1 0.0.0.0 UG 0 0 0 usb2
192.168.6.0 0.0.0.0 255.255.255.0 U 0 0 0 usb1
192.168.7.0 0.0.0.0 255.255.255.0 U 0 0 0 usb0
192.168.225.0 0.0.0.0 255.255.255.0 U 0 0 0 usb2
192.168.225.1 0.0.0.0 255.255.255.255 UH 0 0 0 usb2
debian@beaglebone:~$ ping google.com
PING google.com(bom07s33-in-x0e.1e100.net (2404:6800:4009:826::200e)) 56 data bytes
64 bytes from bom07s33-in-x0e.1e100.net (2404:6800:4009:826::200e): icmp_seq=1 ttl=116 time=56.1 ms
64 bytes from bom07s33-in-x0e.1e100.net (2404:6800:4009:826::200e): icmp_seq=2 ttl=116 time=55.1 ms
^C
--- google.com ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 3ms
rtt min/avg/max/mdev = 55.121/55.613/56.105/0.492 ms
debian@beaglebone:~$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=112 time=63.9 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=112 time=42.4 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=112 time=40.5 ms
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 6ms
rtt min/avg/max/mdev = 40.480/48.917/63.897/10.621 ms
debian@beaglebone:~$ ifconfig
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 169.254.128.70 netmask 255.255.0.0 broadcast 169.254.255.255
inet6 fe80::42bd:32ff:fe25:179b prefixlen 64 scopeid 0x20<link>
ether 40:bd:32:25:17:9b txqueuelen 1000 (Ethernet)
RX packets 104 bytes 11848 (11.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 47 bytes 11189 (10.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 55
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 156 bytes 11660 (11.3 KiB)
TX packets 156 bytes 11660 (11.3 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.0 broadcast 192.168.7.255
ether 40:bd:32:25:17:9d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.0 broadcast 192.168.6.255
ether 40:bd:32:25:17:a1 txqueuelen 1000 (Ethernet)
usb2: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.225.35 netmask 255.255.255.0 broadcast 192.168.225.255
inet6 2409:4040:d89:3964:6c14:b5ff:fe69:1522 prefixlen 64 scopeid 0x0<global>
inet6 fe80::6c14:b5ff:fe69:1522 prefixlen 64 scopeid 0x20<link>
ether 6e:14:b5:69:15:22 txqueuelen 1000 (Ethernet)
RX packets 106 bytes 17328 (16.9 KiB)
TX packets 160 bytes 29392 (28.7 KiB)
CASE 2:
When network interfaces are configured as follows
auto lo
auto eth0
address 192.168.4.1
gateway 192.168.4.1
#auto usb2
default 0.0.0.0 0.0.0.0 U 0 0 0 eth0
link-local 0.0.0.0 255.255.0.0 U 0 0 0 eth0
192.168.4.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
PING google.com(bom07s26-in-x0e.1e100.net (2404:6800:4009:81c::200e)) 56 data bytes
64 bytes from bom07s26-in-x0e.1e100.net (2404:6800:4009:81c::200e): icmp_seq=1 ttl=57 time=59.1 ms
64 bytes from bom07s26-in-x0e.1e100.net (2404:6800:4009:81c::200e): icmp_seq=2 ttl=57 time=37.5 ms
64 bytes from bom07s26-in-x0e.1e100.net (2404:6800:4009:81c::200e): icmp_seq=3 ttl=57 time=35.8 ms
^C
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 35.773/44.119/59.078/10.603 ms
From 192.168.4.1 icmp_seq=1 Destination Host Unreachable
From 192.168.4.1 icmp_seq=2 Destination Host Unreachable
From 192.168.4.1 icmp_seq=3 Destination Host Unreachable
From 192.168.4.1 icmp_seq=4 Destination Host Unreachable
^C
6 packets transmitted, 0 received, +4 errors, 100% packet loss, time 60ms
pipe 4
inet 192.168.4.1 netmask 255.255.255.0 broadcast 192.168.4.255
RX packets 337 bytes 28714 (28.0 KiB)
TX packets 450 bytes 46013 (44.9 KiB)
device interrupt 55
RX packets 217 bytes 17829 (17.4 KiB)
TX packets 217 bytes 17829 (17.4 KiB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::78be:29ff:fecf:98a7 prefixlen 64 scopeid 0x20<link>
inet6 2409:4040:d87:122b:78be:29ff:fecf:98a7 prefixlen 64 scopeid 0x0<global>
ether 7a:be:29:cf:98:a7 txqueuelen 1000 (Ethernet)
RX packets 134 bytes 16568 (16.1 KiB)
RX errors 120 dropped 0 overruns 0 frame 0
TX packets 194 bytes 33283 (32.5 KiB)
debian@beaglebone:~$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
link/can
3: can1: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
link/can
4: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 40:bd:32:25:17:9b brd ff:ff:ff:ff:ff:ff
5: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 7a:be:29:cf:98:a7 brd ff:ff:ff:ff:ff:ff
6: usb1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
link/ether 40:bd:32:25:17:9d brd ff:ff:ff:ff:ff:ff
7: usb2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 40:bd:32:25:17:a1 brd ff:ff:ff:ff:ff:ff
debian@beaglebone:~$ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Communications, Driver=rndis_host, 480M
|__ Port 1: Dev 2, If 1, Class=CDC Data, Driver=rndis_host, 480M
|__ Port 1: Dev 2, If 2, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 2, If 3, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 2, If 4, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 2, If 5, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 2, If 6, Class=Vendor Specific Class, Driver=option, 480M
In second case, rndis interfaces stops to function , even-though it is visible in USB options and AT commands are working fine.
If anyone could recreate this issue to troubleshoot might help.
