Hi, I need a confirmation for Voltage rating tolerance on the above fuse holder. I’m looking to use the part in 85-265V AC circuit. The data sheet simply states 250V. Please advise if the fuse holder will operate at 265V AC.
Thank you.
Welcome to the TechForum, the manufacturer has the part UL rated to 300V per the datasheet.
Hi, thanks for the reply.
