Same issue here. It generates the right renders, but claims there’s no solder mask. I can quote with every single other service, JLCPCB, PCBWay, PCBCart, OSHPark, etc. But for some reason, I can never get DK Red to work. We work with drill origin in the top left for all our setups and pick and place machine. I don’t want to mess with that just to get a quote.
Welcome to the community.
If you would like you can direct message me your zip file, I can take a look.
If you click on my profile picture, it allows you to message me.
Hey @Kristof_2649. Thanks a ton for your reply and willingness to help!
I don’t see the “Message” button in your profile. Also clicked into your profile. Also tried two browsers. Not sure why it won’t let me message you.
Do you have an email address I can send the ZIP file to? Thanks!
That’s a new-user permissions issue, that should be fixed now…
To summarize the issue I found, there was a separate folder structure titled _MACOSX in the archive that had redundant versions of the layers, including soldermask. Deleting the redundant folder fixed the issue.
Oh, good catch. Thanks for taking a peek! I’ll give this a whirl again soon.
Here is a short write up on the Empty Soldermask error/fix:
Soldermask file is Empty in the Compressed File Error - Design Tools and Resources / DKRed and PCB Builder - DigiKey TechForum - An Electronic Component and Engineering Solution Forum
