BKN15SP010M-5 is a thermistor from a manufacturer/brand called Bright King (not to be confused with one of our vendors Kingbright) with the following main specifications:
| Specification Name | Value |
| Thermistor Type | NTC |
| Mounting Type | Through Hole, Axial |
| Nominal Diameter | 15mm |
| Nominal Resistance at 25ºC | 10 Ω's |
| Resistance Tolerance | 20% |
I found that Digi-Key part number 495-76261-1-ND MFG part number: B57234S0100M051
This is the closest alternative I could find for this product.
