Inquiries about the Through-hole LED lead length packed on Tape and Reel from Broadcom not being the same as the datasheet spec are a common question. Looking at HLMP-K105-J0002 as an example, the short lead length listed on datasheet (Package Outline C) is 24.1mm (min); however, the actual lead length may be shorter.
Verified by the manufacturer, The lead length dimension in the datasheet is for loose units packed in plastic bags. As above example, HLMP-K105-J0002 is taped & reel. The lead length is trimmed to fit in the tape therefore there is no need to specify the lead length.
The manufacturer also provides the below Application Note “Utilizing LED Lamps Packaged on Tape and Reel”.
av02-0872en-an_1021-15jul10.pdf (353.1 KB)
Applicable part numbers
| DK Part # | Mfr Part # |
| 516-HLMA-KL00-MQ000TR-ND,516-HLMA-KL00-MQ000CT-ND | HLMA-KL00-MQ000 |
| HLMP-0401-D0002-ND | HLMP-0401-D0002 |
| HLMP-0504-C0002-ND | HLMP-0504-C0002 |
| 516-1750-2-ND,516-1750-1-ND | HLMP-1301-E0002 |
| HLMP-1301-G0002-ND | HLMP-1301-G0002 |
| 516-HLMP-1321-G0002TR-ND,516-HLMP-1321-G0002CT-ND | HLMP-1321-G0002 |
| 516-HLMP-1340-J0002TR-ND,516-HLMP-1340-J0002CT-ND | HLMP-1340-J0002 |
| 516-HLMP-1401-D0002TR-ND,516-HLMP-1401-D0002CT-ND | HLMP-1401-D0002 |
| HLMP-1421-F0002-ND | HLMP-1421-F0002 |
| 516-HLMP-1440-H0002TR-ND,516-HLMP-1440-H0002CT-ND | HLMP-1440-H0002 |
| 516-3190-2-ND,516-3190-1-ND | HLMP-1503-C0002 |
| 516-3191-2-ND,516-3191-1-ND | HLMP-1503-D0002 |
| HLMP-1521-E0002-ND | HLMP-1521-E0002 |
| 516-HLMP-1540-H0002TR-ND,516-HLMP-1540-H0002CT-ND | HLMP-1540-H0002 |
| 516-1791-2-ND,516-1791-1-ND | HLMP-1700-B0002 |
| 516-3192-2-ND,516-3192-1-ND | HLMP-1719-A0002 |
| 516-1792-2-ND,516-1792-1-ND | HLMP-1790-A0002 |
| HLMP-3301-D0001-ND | HLMP-3301-D0001 |
| 516-2482-2-ND,516-2482-1-ND | HLMP-3301-D0002 |
| HLMP-3301-F0001-ND | HLMP-3301-F0001 |
| 516-2228-2-ND,516-2228-1-ND | HLMP-3301-F0002 |
| 516-3178-1-ND,516-3178-3-ND | HLMP-3301-F00DD |
| 516-2788-2-ND,516-2788-1-ND | HLMP-3316-I0002 |
| 516-2327-2-ND,516-2327-1-ND | HLMP-3351-D0002 |
| HLMP-3351-F00R1-ND | HLMP-3351-F00R1 |
| 516-3193-2-ND,516-3193-1-ND | HLMP-3401-E0002 |
| HLMP-3507-D0001-ND | HLMP-3507-D0001 |
| 516-1765-2-ND,516-1765-1-ND | HLMP-3507-D0002 |
| 516-3137-2-ND,516-3137-1-ND | HLMP-3519-F0002 |
| HLMP-3554-E0002-ND | HLMP-3554-E0002 |
| HLMP-3554-E00R1-ND | HLMP-3554-E00R1 |
| HLMP-3707-L0002-ND | HLMP-3707-L0002 |
| HLMP-3750-L0002-ND | HLMP-3750-L0002 |
| HLMP-3850-K0002-ND | HLMP-3850-K0002 |
| HLMP-3950-K0001-ND | HLMP-3950-K0001 |
| 516-HLMP-3950-K0002TR-ND,516-HLMP-3950-K0002CT-ND | HLMP-3950-K0002 |
| 516-HLMP-3962-F0002TR-ND,516-HLMP-3962-F0002CT-ND | HLMP-3962-F0002 |
| 516-3048-2-ND,516-3048-1-ND | HLMP-4000#002 |
| 516-2483-2-ND,516-2483-1-ND | HLMP-4700-C0002 |
| 516-HLMP-4719-A0002TR-ND,516-HLMP-4719-A0002CT-ND | HLMP-4719-A0002 |
| 516-HLMP-4740-A0002TR-ND,516-HLMP-4740-A0002CT-ND | HLMP-4740-A0002 |
| HLMP-6000-E001S-ND | HLMP-6000-E001S |
| 516-HLMP-6301TR-ND,516-HLMP-6301CT-ND | HLMP-6301 |
| 516-HLMP-6305-L001LTR-ND,516-HLMP-6305-L001LCT-ND | HLMP-6305-L001L |
| 516-HLMP-6400-JL000TR-ND,516-HLMP-6400-JL000CT-ND | HLMP-6400-JL000 |
| 516-HLMP-6500-JL000TR-ND,516-HLMP-6500-JL000CT-ND | HLMP-6500-JL000 |
| 516-HLMP-6502TR-ND,516-HLMP-6502CT-ND | HLMP-6502 |
| 516-HLMP-6804TR-ND,516-HLMP-6804CT-ND | HLMP-6804 |
| 516-HLMP-7020TR-ND,516-HLMP-7020CT-ND | HLMP-7020 |
| 516-HLMP-7044TR-ND,516-HLMP-7044CT-ND | HLMP-7044 |
| HLMP-AB64-TW0DD-ND | HLMP-AB64-TW0DD |
| 516-HLMP-AB65-TW0DDCT-ND,516-HLMP-AB65-TW0DDTB-ND | HLMP-AB65-TW0DD |
| HLMP-AB70-TWBDD-ND | HLMP-AB70-TWBDD |
| 516-HLMP-AB74-WXBDDCT-ND,516-HLMP-AB74-WXBDDTB-ND | HLMP-AB74-WXBDD |
| 516-3974-1-ND,516-3974-3-ND | HLMP-AB75-WXBDD |
| HLMP-AG01-K00DD-ND | HLMP-AG01-K00DD |
| HLMP-AG64-X10DD-ND | HLMP-AG64-X10DD |
| HLMP-AG65-X10DD-ND | HLMP-AG65-X10DD |
| 516-HLMP-AG70-120DDTB-ND | HLMP-AG70-120DD |
| HLMP-AG70-Z20DD-ND | HLMP-AG70-Z20DD |
| 516-HLMP-AG71-120DDTB-ND | HLMP-AG71-120DD |
| HLMP-AG71-Z20DD-ND | HLMP-AG71-Z20DD |
| HLMP-AG74-120DD-ND | HLMP-AG74-120DD |
| HLMP-AG75-120DD-ND | HLMP-AG75-120DD |
| HLMP-AH65-Z10DD-ND | HLMP-AH65-Z10DD |
| HLMP-AL65-23KDD-ND | HLMP-AL65-23KDD |
| HLMP-AL70-13KDD-ND | HLMP-AL70-13KDD |
| HLMP-AL70-13LDD-ND | HLMP-AL70-13LDD |
| HLMP-AL71-130DD-ND | HLMP-AL71-130DD |
| HLMP-AL71-13KDD-ND | HLMP-AL71-13KDD |
| HLMP-AL71-13LDD-ND | HLMP-AL71-13LDD |
| 516-HLMP-AM74-56CDDCT-ND,516-HLMP-AM74-56CDDTB-ND | HLMP-AM74-56CDD |
| 516-HLMP-BD07-P00DDTB-ND | HLMP-BD07-P00DD |
| HLMP-C025-P00DD-ND | HLMP-C025-P00DD |
| HLMP-C225-O00DD-ND | HLMP-C225-O00DD |
| HLMP-C423-L0002-ND | HLMP-C423-L0002 |
| 516-HLMP-C515-L0002TR-ND,516-HLMP-C515-L0002CT-ND | HLMP-C515-L0002 |
| 516-HLMP-C523-J0002TR-ND,516-HLMP-C523-J0002CT-ND | HLMP-C523-J0002 |
| HLMP-C615-G0001-ND | HLMP-C615-G0001 |
| HLMP-C625-P0002-ND | HLMP-C625-P0002 |
| 516-2275-1-ND,516-2275-3-ND | HLMP-CB1A-XY0DD |
| 516-HLMP-CB1B-XY0DDCT-ND,516-HLMP-CB1B-XY0DDTB-ND | HLMP-CB1B-XY0DD |
| HLMP-CB1G-XZ0DD-ND | HLMP-CB1G-XZ0DD |
| HLMP-CB1H-XZ0DD-ND | HLMP-CB1H-XZ0DD |
| 516-HLMP-CB2A-VW0DDCT-ND,516-HLMP-CB2A-VW0DDTB-ND | HLMP-CB2A-VW0DD |
| HLMP-CB2B-VW0DD-ND | HLMP-CB2B-VW0DD |
| HLMP-CB2G-UW0DD-ND | HLMP-CB2G-UW0DD |
| HLMP-CB2H-UW0DD-ND | HLMP-CB2H-UW0DD |
| 516-2800-1-ND,516-2800-3-ND | HLMP-CB3A-UV0DD |
| 516-HLMP-CB3B-UV0DDCT-ND,516-HLMP-CB3B-UV0DDTB-ND | HLMP-CB3B-UV0DD |
| HLMP-CB3G-TV0DD-ND | HLMP-CB3G-TV0DD |
| HLMP-CB3H-TV0DD-ND | HLMP-CB3H-TV0DD |
| 516-HLMP-CE17-350DDTB-ND | HLMP-CE17-350DD |
| 516-HLMP-CE17-35CDDTB-ND | HLMP-CE17-35CDD |
| HLMP-CE18-24CDD-ND | HLMP-CE18-24CDD |
| HLMP-CE18-24QDD-ND | HLMP-CE18-24QDD |
| HLMP-CE20-Z2CDD-ND | HLMP-CE20-Z2CDD |
| HLMP-CE20-Z2QDD-ND | HLMP-CE20-Z2QDD |
| HLMP-CE21-Z2CDD-ND | HLMP-CE21-Z2CDD |
| HLMP-CE21-Z2QDD-ND | HLMP-CE21-Z2QDD |
| HLMP-CE32-Y1CDD-ND | HLMP-CE32-Y1CDD |
| HLMP-CE32-Y1QDD-ND | HLMP-CE32-Y1QDD |
| HLMP-CE33-Y1CDD-ND | HLMP-CE33-Y1CDD |
| 516-HLMP-CE34-Y1CDDCT-ND,516-HLMP-CE34-Y1CDDTB-ND | HLMP-CE34-Y1CDD |
| 516-3529-1-ND,516-3529-3-ND | HLMP-CM1A-560DD |
| 516-3188-1-ND,516-3188-3-ND | HLMP-CM1G-350DD |
| HLMP-CM1H-350DD-ND | HLMP-CM1H-350DD |
| HLMP-CM2A-230DD-ND | HLMP-CM2A-230DD |
| 516-HLMP-CM2G-130DDCT-ND,516-HLMP-CM2G-130DDTB-ND | HLMP-CM2G-130DD |
| 516-3976-1-ND,516-3976-3-ND | HLMP-CM2H-130DD |
| 516-2802-1-ND,516-2802-3-ND | HLMP-CM3A-Z10DD |
| 516-HLMP-CM3A-Z1CDDTB-ND,516-HLMP-CM3A-Z1CDDCT-ND | HLMP-CM3A-Z1CDD |
| 516-HLMP-CM3B-Z10DDCT-ND,516-HLMP-CM3B-Z10DDTB-ND | HLMP-CM3B-Z10DD |
| 516-3052-1-ND,516-3052-3-ND | HLMP-CM3G-Y10DD |
| HLMP-CM3H-Y10DD-ND | HLMP-CM3H-Y10DD |
| HLMP-D101-J0002-ND | HLMP-D101-J0002 |
| HLMP-D105-M0002-ND | HLMP-D105-M0002 |
| HLMP-D150-C0002-ND | HLMP-D150-C0002 |
| HLMP-D155-F0002-ND | HLMP-D155-F0002 |
| HLMP-EG08-WZ0DD-ND | HLMP-EG08-WZ0DD |
| HLMP-EG08-X10DD-ND | HLMP-EG08-X10DD |
| HLMP-EG08-Z20DD-ND | HLMP-EG08-Z20DD |
| HLMP-EG10-X10DD-ND | HLMP-EG10-X10DD |
| HLMP-EG10-Y20DD-ND | HLMP-EG10-Y20DD |
| HLMP-EG15-QT0DD-ND | HLMP-EG15-QT0DD |
| HLMP-EG15-UX0DD-ND | HLMP-EG15-UX0DD |
| 516-2457-1-ND,516-2457-3-ND | HLMP-EG1A-Z10DD |
| 516-HLMP-EG1A-Z10DVCT-ND,516-HLMP-EG1A-Z10DVTB-ND | HLMP-EG1A-Z10DV |
| 516-3053-1-ND,516-3053-3-ND | HLMP-EG1B-Z10DD |
| HLMP-EG1B-Z10DV-ND | HLMP-EG1B-Z10DV |
| 516-3977-1-ND,516-3977-3-ND | HLMP-EG1G-Y10DD |
| 516-4266-1-ND,516-4266-3-ND | HLMP-EG1H-Y10DD |
| HLMP-EG1S-Z20DD-ND | HLMP-EG1S-Z20DD |
| HLMP-EG1T-Z20DD-ND | HLMP-EG1T-Z20DD |
| HLMP-EG24-PS0DD-ND | HLMP-EG24-PS0DD |
| HLMP-EG26-PS0DD-ND | HLMP-EG26-PS0DD |
| 516-2458-1-ND,516-2458-3-ND | HLMP-EG2A-XY0DD |
| 516-3530-1-ND,516-3530-3-ND | HLMP-EG2B-XY0DD |
| 516-3531-1-ND,516-3531-3-ND | HLMP-EG2G-XZ0DD |
| 516-3978-1-ND,516-3978-3-ND | HLMP-EG2H-XZ0DD |
| HLMP-EG2S-XZ0DD-ND | HLMP-EG2S-XZ0DD |
| HLMP-EG2T-XZ0DD-ND | HLMP-EG2T-XZ0DD |
| HLMP-EG2U-Z10DD-ND | HLMP-EG2U-Z10DD |
| HLMP-EG2V-Z10DD-ND | HLMP-EG2V-Z10DD |
| HLMP-EG30-NQ0DD-ND | HLMP-EG30-NQ0DD |
| HLMP-EG30-NR0DD-ND | HLMP-EG30-NR0DD |
| HLMP-EG30-PQ0DD-ND | HLMP-EG30-PQ0DD |
| HLMP-EG30-QT0DD-ND | HLMP-EG30-QT0DD |
| HLMP-EG30-RS0DD-ND | HLMP-EG30-RS0DD |
| HLMP-EG32-QT0DD-ND | HLMP-EG32-QT0DD |
| 516-2805-1-ND,516-2805-3-ND | HLMP-EG3A-WX0DD |
| 516-HLMP-EG3A-WX0DVCT-ND,516-HLMP-EG3A-WX0DVTB-ND | HLMP-EG3A-WX0DV |
| 516-3532-1-ND,516-3532-3-ND | HLMP-EG3B-WX0DD |
| HLMP-EG3B-WX0DV-ND | HLMP-EG3B-WX0DV |
| 516-3115-1-ND,516-3115-3-ND | HLMP-EG3G-VX0DD |
| 516-3533-1-ND,516-3533-3-ND | HLMP-EG3H-VX0DD |
| HLMP-EG3U-XY0DD-ND | HLMP-EG3U-XY0DD |
| HLMP-EG3V-XY0DD-ND | HLMP-EG3V-XY0DD |
| HLMP-EG55-GK0DD-ND | HLMP-EG55-GK0DD |
| HLMP-EG55-JK0DD-ND | HLMP-EG55-JK0DD |
| HLMP-EH08-Y20DD-ND | HLMP-EH08-Y20DD |
| HLMP-EH10-X10DD-ND | HLMP-EH10-X10DD |
| HLMP-EH10-Y20DD-ND | HLMP-EH10-Y20DD |
| HLMP-EH15-RU0DD-ND | HLMP-EH15-RU0DD |
| 516-HLMP-EH1A-Z10DDCT-ND,516-HLMP-EH1A-Z10DDTB-ND | HLMP-EH1A-Z10DD |
| HLMP-EH30-NR0DD-ND | HLMP-EH30-NR0DD |
| 516-4267-1-ND,516-4267-3-ND | HLMP-EH3A-WX0DD |
| HLMP-EH3B-WX0DD-ND | HLMP-EH3B-WX0DD |
| HLMP-EJ10-XZ0DD-ND | HLMP-EJ10-XZ0DD |
| HLMP-EJ15-SV0DD-ND | HLMP-EJ15-SV0DD |
| 516-2276-1-ND,516-2276-3-ND | HLMP-EJ30-NR0DD |
| HLMP-EJ37-R0PDD-ND | HLMP-EJ37-R0PDD |
| HLMP-EL08-VY0DD-ND | HLMP-EL08-VY0DD |
| HLMP-EL08-XYKDD-ND | HLMP-EL08-XYKDD |
| HLMP-EL10-VY0DD-ND | HLMP-EL10-VY0DD |
| HLMP-EL10-WXKDD-ND | HLMP-EL10-WXKDD |
| HLMP-EL10-WZ0DD-ND | HLMP-EL10-WZ0DD |
| HLMP-EL10-X1LDD-ND | HLMP-EL10-X1LDD |
| HLMP-EL15-PS0DD-ND | HLMP-EL15-PS0DD |
| HLMP-EL15-QT0DD-ND | HLMP-EL15-QT0DD |
| HLMP-EL15-UX0DD-ND | HLMP-EL15-UX0DD |
| HLMP-EL15-UXKDD-ND | HLMP-EL15-UXKDD |
| 516-HLMP-EL15-VY0DDCT-ND,516-HLMP-EL15-VY0DDTB-ND | HLMP-EL15-VY0DD |
| 516-HLMP-EL17-QTKDDCT-ND,516-HLMP-EL17-QTKDDTB-ND | HLMP-EL17-QTKDD |
| 516-3055-1-ND,516-3055-3-ND | HLMP-EL1A-Z1KDD |
| HLMP-EL1A-Z1KDV-ND | HLMP-EL1A-Z1KDV |
| HLMP-EL1A-Z1LDD-ND | HLMP-EL1A-Z1LDD |
| HLMP-EL1A-Z1LDV-ND | HLMP-EL1A-Z1LDV |
| 516-3534-1-ND,516-3534-3-ND | HLMP-EL1B-Z1KDD |
| HLMP-EL1B-Z1KDV-ND | HLMP-EL1B-Z1KDV |
| 516-HLMP-EL1B-Z1LDDCT-ND,516-HLMP-EL1B-Z1LDDTB-ND | HLMP-EL1B-Z1LDD |
| HLMP-EL1B-Z1LDV-ND | HLMP-EL1B-Z1LDV |
| 516-HLMP-EL1G-130DDCT-ND,516-HLMP-EL1G-130DDTB-ND | HLMP-EL1G-130DD |
| HLMP-EL1H-112DD-ND | HLMP-EL1H-112DD |
| HLMP-EL1S-Z20DD-ND | HLMP-EL1S-Z20DD |
| HLMP-EL1S-Z2KDD-ND | HLMP-EL1S-Z2KDD |
| HLMP-EL1S-Z2LDD-ND | HLMP-EL1S-Z2LDD |
| HLMP-EL1T-Z20DD-ND | HLMP-EL1T-Z20DD |
| HLMP-EL1T-Z2KDD-ND | HLMP-EL1T-Z2KDD |
| HLMP-EL1T-Z2LDD-ND | HLMP-EL1T-Z2LDD |
| HLMP-EL24-QT0DD-ND | HLMP-EL24-QT0DD |
| HLMP-EL24-TWKDD-ND | HLMP-EL24-TWKDD |
| HLMP-EL26-TUKDD-ND | HLMP-EL26-TUKDD |
| 516-HLMP-EL2A-YZKDDCT-ND,516-HLMP-EL2A-YZKDDTB-ND | HLMP-EL2A-YZKDD |
| HLMP-EL2A-YZLDD-ND | HLMP-EL2A-YZLDD |
| HLMP-EL2B-XYKDD-ND | HLMP-EL2B-XYKDD |
| HLMP-EL2B-YZKDD-ND | HLMP-EL2B-YZKDD |
| HLMP-EL2B-YZLDD-ND | HLMP-EL2B-YZLDD |
| HLMP-EL2S-XZ0DD-ND | HLMP-EL2S-XZ0DD |
| HLMP-EL2S-XZKDD-ND | HLMP-EL2S-XZKDD |
| HLMP-EL2S-XZLDD-ND | HLMP-EL2S-XZLDD |
| HLMP-EL2T-XZ0DD-ND | HLMP-EL2T-XZ0DD |
| HLMP-EL2T-XZKDD-ND | HLMP-EL2T-XZKDD |
| HLMP-EL2T-XZLDD-ND | HLMP-EL2T-XZLDD |
| HLMP-EL2U-Z10DD-ND | HLMP-EL2U-Z10DD |
| HLMP-EL2U-Z1KDD-ND | HLMP-EL2U-Z1KDD |
| HLMP-EL2U-Z1LDD-ND | HLMP-EL2U-Z1LDD |
| HLMP-EL2V-Z10DD-ND | HLMP-EL2V-Z10DD |
| HLMP-EL2V-Z1LDD-ND | HLMP-EL2V-Z1LDD |
| HLMP-EL30-PS0DD-ND | HLMP-EL30-PS0DD |
| HLMP-EL30-STKDD-ND | HLMP-EL30-STKDD |
| HLMP-EL30-SUKDD-ND | HLMP-EL30-SUKDD |
| HLMP-EL32-PQ0DD-ND | HLMP-EL32-PQ0DD |
| HLMP-EL32-SUKDD-ND | HLMP-EL32-SUKDD |
| 516-3189-1-ND,516-3189-3-ND | HLMP-EL3A-WXKDD |
| HLMP-EL3A-WXKDV-ND | HLMP-EL3A-WXKDV |
| 516-2808-1-ND,516-2808-3-ND | HLMP-EL3A-WXLDD |
| HLMP-EL3A-WXLDV-ND | HLMP-EL3A-WXLDV |
| 516-3535-1-ND,516-3535-3-ND | HLMP-EL3B-WXKDD |
| HLMP-EL3B-WXKDV-ND | HLMP-EL3B-WXKDV |
| HLMP-EL3B-WXLDD-ND | HLMP-EL3B-WXLDD |
| 516-HLMP-EL3G-VW0DDCT-ND,516-HLMP-EL3G-VW0DDTB-ND | HLMP-EL3G-VW0DD |
| 516-HLMP-EL3G-VX0DDCT-ND,516-HLMP-EL3G-VX0DDTB-ND | HLMP-EL3G-VX0DD |
| 516-HLMP-EL3G-VXK00TR-ND,516-HLMP-EL3G-VXK00CT-ND | HLMP-EL3G-VXK00 |
| HLMP-EL3G-VXKDD-ND | HLMP-EL3G-VXKDD |
| HLMP-EL3H-VV2DD-ND | HLMP-EL3H-VV2DD |
| HLMP-EL3H-VW0DD-ND | HLMP-EL3H-VW0DD |
| HLMP-EL3H-VX0DD-ND | HLMP-EL3H-VX0DD |
| HLMP-EL3S-VX0DD-ND | HLMP-EL3S-VX0DD |
| HLMP-EL3S-VXKDD-ND | HLMP-EL3S-VXKDD |
| HLMP-EL3S-VXLDD-ND | HLMP-EL3S-VXLDD |
| HLMP-EL3T-VX0DD-ND | HLMP-EL3T-VX0DD |
| HLMP-EL3T-VXKDD-ND | HLMP-EL3T-VXKDD |
| HLMP-EL3T-VXLDD-ND | HLMP-EL3T-VXLDD |
| HLMP-EL3U-XYKDD-ND | HLMP-EL3U-XYKDD |
| HLMP-EL3U-XYLDD-ND | HLMP-EL3U-XYLDD |
| HLMP-EL3V-XY0DD-ND | HLMP-EL3V-XY0DD |
| HLMP-EL3V-XYKDD-ND | HLMP-EL3V-XYKDD |
| HLMP-EL3V-XYLDD-ND | HLMP-EL3V-XYLDD |
| HLMP-EL55-GK0DD-ND | HLMP-EL55-GK0DD |
| HLMP-HB65-QU0DD-ND | HLMP-HB65-QU0DD |
| HLMP-HB65-QU0ZZ-ND | HLMP-HB65-QU0ZZ |
| HLMP-HB70-TVBDD-ND | HLMP-HB70-TVBDD |
| HLMP-HB74-UVBDD-ND | HLMP-HB74-UVBDD |
| 516-HLMP-HB75-UVBDDCT-ND,516-HLMP-HB75-UVBDDTB-ND | HLMP-HB75-UVBDD |
| 516-2459-1-ND,516-2459-3-ND | HLMP-HG64-VY0DD |
| 516-2809-1-ND,516-2809-3-ND | HLMP-HG65-VY0DD |
| HLMP-HG70-VX0DD-ND | HLMP-HG70-VX0DD |
| 516-HLMP-HG74-XY0DDCT-ND,516-HLMP-HG74-XY0DDTB-ND | HLMP-HG74-XY0DD |
| 516-3979-1-ND,516-3979-3-ND | HLMP-HG75-XY0DD |
| 516-HLMP-HL65-XYKDDTB-ND | HLMP-HL65-XYKDD |
| HLMP-HL70-XZ0DD-ND | HLMP-HL70-XZ0DD |
| HLMP-HL70-XZKDD-ND | HLMP-HL70-XZKDD |
| HLMP-HL71-XZ0DD-ND | HLMP-HL71-XZ0DD |
| HLMP-HL71-XZKDD-ND | HLMP-HL71-XZKDD |
| HLMP-HM71-23BDD-ND | HLMP-HM71-23BDD |
| 516-HLMP-HM74-34BDDTB-ND | HLMP-HM74-34BDD |
| HLMP-HM74-34CDD-ND | HLMP-HM74-34CDD |
| HLMP-HM75-34CDD-ND | HLMP-HM75-34CDD |
| HLMP-K101-I0002-ND | HLMP-K101-I0002 |
| 516-HLMP-K101-JK000TR-ND,516-HLMP-K101-JK000CT-ND | HLMP-K101-JK000 |
| 516-HLMP-K105-J0002TR-ND,516-HLMP-K105-J0002CT-ND | HLMP-K105-J0002 |
| 516-HLMP-K150-C0002TR-ND,516-HLMP-K150-C0002CT-ND | HLMP-K150-C0002 |
| HLMP-K155-D0002-ND | HLMP-K155-D0002 |
| HLMP-K401-E0002-ND | HLMP-K401-E0002 |
| HLMP-LB65-RU0DD-ND | HLMP-LB65-RU0DD |
| HLMP-LB71-TUBDD-ND | HLMP-LB71-TUBDD |
| HLMP-LG65-VY0DD-ND | HLMP-LG65-VY0DD |
| HLMP-LG71-XY000-ND | HLMP-LG71-XY000 |
| 516-4286-2-ND,516-4286-1-ND | HLMP-LG71-XZ0DD |
| 516-3980-1-ND,516-3980-3-ND | HLMP-LG75-XY0DD |
| 516-HLMP-LL65-XYKDDTB-ND | HLMP-LL65-XYKDD |
| HLMP-LL65-YZLDD-ND | HLMP-LL65-YZLDD |
| HLMP-LM71-Z30DD-ND | HLMP-LM71-Z30DD |
| HLMP-LM75-34CDD-ND | HLMP-LM75-34CDD |
| HLMP-NS30-J00DD-ND | HLMP-NS30-J00DD |
| 516-HLMP-P505-KL000TR-ND,516-HLMP-P505-KL000CT-ND | HLMP-P505-KL000 |
| 516-HLMP-Q106-S0011TR-ND,516-HLMP-Q106-S0011CT-ND | HLMP-Q106-S0011 |
| HLMP-QM00-S0011-ND | HLMP-QM00-S0011 |
| HLMP-RL10-MP0DD-ND | HLMP-RL10-MP0DD |
| 516-HLMP-RL20-MP0DDTB-ND | HLMP-RL20-MP0DD |
| HLMP-S501-D0002-ND | HLMP-S501-D0002 |
