Calibration
------Question for 10162308-001 Please Put your question below------
Good Morning DigiKey Team,
Can you provide the additional information such as a specific PN for calibrated tools.
I am needing this tool to be calibrated, but not sure if your tooling comes already calibrated or if I need to request a different PN to get the tool calibrated, and how much lead time that will add to the order.
Thank you for your assistance,
Kim Spaulding
Hello paul.warren,
I’m checking on this and will get back to you when I have some info on it. There is no documentation we have readily available about the calibration of this tool. I’ll reply back once I have more info.
any luck???
Unfortunately no.
I’ll update you as soon as I have some kind of reply from them.
Hi again Paul,
I’ve finally received some feedback from the supplier Amphenol ICC.
They informed me that after checking internally inventory of P/N 10162308-001 was not available for verification of an included calibration certificate, and that additional request(s) has been sent out relating to this matter and expect to receive a reply soon.
They did ask to provide the intended use of the resulting 18-20 awg termination. The crimped terminal is generally for use in a discrete situation, not inserted into a standard latch-housing they inform.
All right, I got another reply informing that the 10162308-001 hand tool does not come with a calibration certificate. The supplier also mentioned that companies that require their application tooling to be calibrated generally utilize the same calibration services they have contracted for their other tooling.
Sorry for the inconvenience Paul.
Regards,
IK
