I need to know if we can run PVI1050NSPBF though our DI wash?
Hello, and welcome to the forum. This part is moisture sensitive, so it’s unlikely that this will be viable for a water-based washed, even if it’s DI. Sometimes it’s viable, but for the high sensitivity level that this part is rated at, I doubt it would be a good fit.
We can reach out to the manufacturer for a direct statement if you need that, you can request it through applications.engineering@digikey.com via email. Hope this helps!
