Pls help to check & provide washable information for below part.
Kindly advise whether this part can go thru washing process by using DI water. Thanks
Part# LA609-338848-001
MPN: SK520B
Manufacturer: SMC
MPN: SK520B
Manufacturer: SMC
Hi Digikey Engineering team,
Any update for the inquiry ?
The device in question is a diode in industry standard plastic/epoxy packaging, which are generally washable unless stated otherwise in the datasheet.
Examples of products likely to be non-washable include microphones, speakers, switches, and similar components that have internal parts exposed to the environment, and/or which would be capable of entrapping water or other washing agent that would be used.
