This Product Selection Guide contains information to help select products in the Capacitor - Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: Indicates the type of accessory the device is as it relates to it’s function.
Device Size: Indicates the dimensions of the devices with which an accessory is intended for use.
Specifications: Where applicable. Indicates unique charactoristic(s) of the accessory.
ProductExamples
MFR PART # | VR10A |
DIGI-KEY PART # | 338-3604-ND |
MANUFACTURER | Cornell Dubilier Electronics (CDE) |
DESCRIPTION | MOUNTING CLAMP VERT 2.5IN DIA |
DATASHEET | Click Here |
MFR PART # | PYB7041 |
DIGI-KEY PART # | 399-11535-ND |
MANUFACTURER | KEMET |
DESCRIPTION | HARDWARE CAP NUTS NYLON |
