Product Selection Guide : Table of Contents
Posts in this category are currently being built. If there is a category that is listed on this page and does not have an active link, it is currently on our backlog and should be available and live soon™.
Anti-Static, ESD, Clean Room Products
Audio Products
Battery Products
Boxes, Enclosures, Racks
Cable Assemblies
Cables, Wires
Cables, Wires - Management
Wire Ducts, Raceways
Capacitors
Circuit Protection
Transient Voltage Suppressors (TVS)
Computer Equipment
Connectors, Interconnects
AC Power Connectors
Backplane Connectors
Banana and Tip Connectors
Barrel Connectors
Blade Type Power Connectors
Card Edge Connectors
Circular Connectors
Coaxial - RF Connectors
Contacts
D-Sub, D-Shaped Connectors
FFC, FPC (Flat Flexible) Connectors
Fiber Optic Connectors
Heavy Duty Connectors
Keystone Connectors
Memory Connectors
Modular Connectors
Photovoltaic (Solar Panel) Connectors
Pluggable Connectors
Rectangular Connectors
Sockets for ICs and Transistors
Solid State Lighting Connectors
Terminal Blocks
Terminal Block Accessories
Terminals
USB, DVI, HDMI Connectors
Crystals, Oscillators, Resonators
Development Boards, Kits, Programmers
Discrete Semiconductors
Diodes
Rectifiers
Zener
Thyristors
Transistors
Bipolar (BJT)
FETs, MOSFETs
IGBTs
Embedded Computers
Fans, Thermal Management
Fans
Thermal
Filters
Hardware, Fasteners
Springs
Washers
Inductors, Coils, Chokes
Industrial Automation and Controls
Industrial Supplies
Dock and Warehouse
Electrical
Fans
HVAC
Maintenance
Office Equipment
Office Furniture
Outdoor Products
Product, Material Handling and Storage
Safety
Storage Containers & Bins
Workstation, Office Furniture and Equipment
Integrated Circuits
Clock/Timing
Data Acquisition
Embedded
Interface
Linear
Amplifiers
Logic
Memory
Power Management (PMIC)
Isolators
Optoisolators
Kits
Labels, Signs, Barriers, Identification
Line Protection, Distribution, Backups
Magnetics - Transformer, Inductor Components
MAKER/DIY, EDUCATIONAL
Memory Cards, Modules
Motors, Solenoids, Driver Boards/Modules
Networking Solutions
Optical Inspection Equipment
Optics
Optoelectronics
Potentiometers, Variable Resistors
Power Supplies - Board Mount
Power Supplies - External/Internal (off-board)
Prototyping, Fabrication Products
Relays
Resistors
RF and Wireless
Sensors, Transducers
Magnetic Sensors
Magnets
Motion Sensors
Optical Sensors
Position Sensors
Temperature Sensors
Soldering, Desoldering, Rework Products
Switches
Tapes, Adhesives
Test and Measurement
Tools
Transformers
産業用制御とオートメーションのインデックス
Industrial Control and Automation Index
Voltage Divider Calculations Involving Three or More Resistors
分圧器の基礎
DigiKey Purchasing Tips using myLists
Circuit Myths: MOSFETs Require No Gate Current
回路の神話:最大電力伝達定理
産業用制御盤におけるフライバック誘起EMIパルス
mikroBUSアプリケーションの開発とトラブルシューティングガイド
mikroBUS 應用程式開發與故障排除指南
SuperSpeed(SS)USB Cケーブルとはどのようなものですか?
소켓을 쓸 것인가 말 것인가: DIP IC 소켓에 대한 평가
DigiKeyのArduino Optaキット入門
DigiKey は、組み込み設計のラピッドプロトタイピングをどのようにサポートしますか?
C言語によるPLCプログラミングガイド:サイクルスキャン
部品の4桁のデートコードから電子機器の年代を判断する
Meet the 2N3904 and 2N3906 General-Purpose Transistors
分数馬力モータ制御用のSiemensのSMFスターターとMMSスイッチを検索する
什麼是耐脈衝(Pulse Withstanding) 晶片電阻器?
AC/DCコンバータはバッテリ充電に使うことができますか?
アルミ電解コンデンサに関する技術者の視点
自己バイアスパワートランジスタに5本の足があるのはなぜですか?
アルミ電解コンデンサについてのよくある質問
マイクロコントローラの超低電力(ULP)モード:スリープモードでエネルギーを節約
Guide to Development and Troubleshooting mikroBUS Applications
Hブリッジによるモータ駆動の動特性:電流スパイクの特定
Arduinoベースの純正弦波インバータのプロトタイプ
What is a Complementary Transistor Pair?
IGBTのタイプ入門:PT、NPT、FS、およびパワーエレクトロニクスの動向
電晶體功耗:區分環境溫度和外殼溫度
Process Meter First Steps: Source vs. Simulate Mode in a 4-20 mA Loop
Arduino Optaトレーナの配線:DigiKeyラボ
아두이노 우노 R4 미니마와 MIKROE의 히터 클릭 보드를 이용한 PID 제어기 예제
計算鋁電解電容器的使用壽命
耐パルスチップ(PWC)抵抗器とは何でしょうか?
Prototype an Arduino-based Pure Sine Wave Inverter
Meet the 2N7000 and 2N7002 Logic Level Switching MOSFETs
Meet the European BC107, BC547, and BC847 Transistors
Arduino Plug and Make Projects: Metronome
センサ/アクチュエータ端子台を使用した制御パネルの最適化
Introduction to Megger Insulation Resistance Tester for Motor and Cable Testing
How to move from theory to design of a PCB?
アルミ電解コンデンサの選択ガイド
Meet the 1N4001 to 1N4007 Family of Rectifier Diodes
カスタムポテンショメータ シャフトの長さとスタイル:オリジナルポテンショメータの構築
Why does my self-biasing power transistor have five legs?
Introduction to IGBT Types: PT, NPT, FS, plus Power Electronics Trends
Arduino Modulino Pixelsチュートリアル
Arduino Modulino Buttonsチュートリアル
電源トランスに関するエンジニアの視点
단일 양극성 트랜지스터의 선택 가이드
Arduino Modulino Distance Tutorial Featuring an STM ToF Sensor
トランジスタの許容損失:周囲温度とケース温度の違い
組み込みシステムにおけるラピッドプロトタイピング:アイデアからスケーラブルな生産へ
Arduino Modulino Pixels 教學
Oscilloscope Probe Compensation
Next Steps with Arduino UNO R4 and Renesas: Introducing the Seeed XIAO and Portenta C33
PLCとPACの選択ガイド
Calculating the Operational Life of an Aluminum Electrolytic Capacitor
IGBT 종류(PT, NPT, FS)에 대한 소개와 전력 전자의 동향
Transistor Power Dissipation: Differentiating Between Ambient and Case Temperatures
3つ以上の抵抗による分圧計算
Circuit Myths: Maximum Power Transfer Theorem
DigilentのAnalog Discovery 3とPro ADP2230の比較
Breadboard an Arduino Controlled BLDC Motor Driver
Arduino PWM制御によるブートストラップMOSFETドライバのブレッドボード
アルミニウム電解コンデンサの動作寿命を計算する
Arduino Plug and Makeプロジェクト:メトロノーム
양극성 접합 트랜지스터(BJT) FAQ: 자주 묻는 질문과 답변
Finding a Volume Control with Integral Power Switch
Getting started with DigiKey's Arduino Opta Kit
Arduino UNO R4のQwiicポート使用に関するヒント
Full-Bridge Rectifier Visualization Using LEDs and the Digilent Analog Discovery
尋找具有整合式電源開關的音量控制
AC-DC 컨버터를 사용해 배터리를 충전할 수 있나요?
Arduino Modulino Knob Tutorial
엔지니어의 관점에서 본 양극성 접합 트랜지스터(BJT)
Introduction to Current Measurement Using Hall-Effect Sensors
Pre-Biased Transistors: Save PCB Space and Lower BOM Line Count
FAQs for Aluminum Electrolytic Capacitors
What is a struct?
An Engineer's Perspective on Aluminum Electrolytic Capacitors
鉱石ラジオ用 1N34A ダイオードの代替品
An Engineer's Perspective on Power Transformers
Arduino Modulino Buzzerのチュートリアル
Modicon M221 Nano PLC用Schneider ElectricのTMH2GDBヒューマンマシンインターフェースの紹介
Bipolar Junction Transistor (BJT) FAQ: Answers to Common Questions
Comparing the Digilent Analog Discovery 3 with the Pro ADP2230
回路に関する誤解:MOSFETはゲート電流を必要としない
An Engineer's Perspective on Bipolar Junction Transistors (BJTs)
Arduino Opta Trainer Wiring: A DigiKey Lab
An Op Amp Learning Journey from Jellybean 741 to Rail-to-Rail Design
産業用スイッチを用いたロジックゲートの構築:DigiKeyラボ
Cleaning noise off a 24VAC power supply
Mastering X macros in C: An Arduino Programming Case Study
Can an AC to DC converter be used to charge a battery?
トランジスタのコンプリメンタリペアとは?
How does DigiKey support rapid prototyping for embedded designs?
Building Logic Gates Using Industrial Switches: A DigiKey Lab
Rapid Prototyping in Embedded Systems: From Idea to Scalable Production
Arduino Pro Tips: Improve the Serial Print Function Using the Variadic Print Function vsnprintf()
精密エンコーダのガイド:直交出力からホール効果出力まで
ジェリービーンズの紹介:汎用トランジスタ2N2222および2N2907
ヨーロッパのジェリービーンズの紹介:BC107、BC547、およびBC847トランジスタ
NTE123、NTE123A、およびNTE123APの代替品を検索する
PLCに関するエンジニアの視点
What is a SuperSpeed (SS) USB C cable?
Meet the 2N2222 and 2N2907 General-Purpose Transistors
Microcontroller Ultra-Low Power (ULP) Mode: Save Energy with Sleep
精密編碼器指南:從正交到霍爾
Fixing Jumping Arduino UNO R4 Servos for Smooth Motion
回路ブレーカの内部構造は? 熱トリップと磁気トリップの概要
젤리빈 부품을 소개합니다: MPSA06 및 MPSA56 트랜지스터
Arduino Modulino Buzzer Tutorial
三相モータスターターのコイルフライバックとサージ抑制
Custom Potentiometer Shaft Length and Style: Build Your Own Potentiometer
ジェリービーンズ741からレールツーレール設計まで - オペアンプ学習の道のり
An Engineer’s Perspective on Selecting Operational Amplifiers
Breadboard an Arduino-based H-bridge Motor Controller
Mapping DigiKey's OPTA PLC Trainer to the Arduino Academy ACE-100 Course
How to Select a Programmable Logic Controller (PLC) Using DigiKey's Parametric Tools
Arduino Proのヒント:Print可変長関数vsnprintf()を使用したSerial Print関数の改善
Breadboard a Bootstrapped MOSFET Motor Driver with Arduino PWM Control
트랜지스터의 전력 소모: 주변 온도와 케이스 온도의 구분
バイポーラトランジスタ(BJT)に関する技術者の視点
LEDとDigilentのAnalog Discoveryを用いたフルブリッジ整流器の可視化
バイポーラトランジスタ(BJT)のFAQ:よくある質問への回答
C言語によるPLCのプログラミング:デジタル I/Oの構造化処理のためのポインタの活用
ArduinoのUNO R4とRenesasの次のステップ:SeeedのXIAOとArduinoのPortenta C33の紹介
Locating Substitutions for the NTE123, NTE123A, and NTE123AP
ラッチングソレノイドの動作
UL 508A Resources (Landing Page)
客製化電位器軸長度和樣式:建立您自己的電位器
Selection Guide for Aluminum Electrolytic Capacitors
Substitution for the 1N34A Diode for Crystal Radios
To Socket or Not to Socket: Evaluating DIP IC Sockets
産業制御のための電子回路保護装置
シャントトリップ回路ブレーカの概要
モータスターターのソリッドステート過負荷リレーとは何ですか?
短絡電流定格(SCCR)とは何でしょうか?
New and Improved Power Supply on the Arduino UNO R4 Minima
Siemens LOGO! PLC:初期ネットワーク接続
PID Controller Example with Arduino Minima and MIKROE Heater Click
SCCRを理解する:制御盤と電力給電線の故障電流との整合
UL 508A産業用制御盤ヒューズの限流波高値に関するよくある質問
마이크로컨트롤러 초저전력 (ULP) 모드: 슬립 모드로 에너지 절약하기
Arduino and RC Servos Frequently Asked Questions
分流の公式とその導出
젤리빈 부품을 소개합니다: 2N7000 및 2N7002 로직 레벨 스위칭 MOSFET
Arduino Modulino Buttons Tutorial
회로 속설: 최대 전력 전달 정리
회로 속설: MOSFET은 게이트 전류가 필요 없다
Arduino Modulino Pixels Tutorial
왜 제가 사용하는 자기 바이어스(self-bias) 전력 트랜지스터는 다리가 다섯 개인가요?
産業用制御初心者のための現場ガイド
Fast PWM for the Arduino UNO R4 Minima and UNO R4 WiFi boards
Arduino UNO R4 WiFiの12 x 8 LEDディスプレイマトリックスの背後にある理論
オシロスコープのプローブ補正
What is SPARTN and how can it improve my GPS receiver’s performance?
MIKROE 홀 커런트 7 클릭 보드 소개
Selection Guide for Through Hole Resistors
Selection Guide for Power Transformers
Selection Guide for Integrated Switching Plus Linear Voltage Regulators
What is the difference between the MIKROE Click and the Snap board?
Theory behind the Arduino UNO R4 WiFi 12 x 8 LED Display Matrix
Selection Guide for FPGAs (Field Programmable Gate Array)
工業控制與自動化指南
Selection Guide for Discrete Indicating Light Emitting Diodes (LED)
Selection Guide for Power Relays Over 2 A
ジェリービーンズの紹介:MPSA06とMPSA56トランジスタ
Selection Guide for Embedded MCU and DSP Evaluation Boards
What is a Pulse Withstanding Chip (PWC) resistor?
Selection Guide for Single Bipolar Transistors
Bluetoothを使用したスマートフォンによるCrouzetのPLC制御
Determining the Age of Electronic Equipment Using a Component’s 4-digit Date Code
Arduino Uno R4 WiFi in Higher Education
M8およびM12丸型コネクタの異なるサイズのピン径
