Modular Connector Wiring Blocks
This Product Selection Guide contains information to help select products in the Modular Connector Wiring Blocks category on DigiKey.com
Modular connector wiring blocks are wiring solutions designed for rack, wall, cable, junction box, and frame mounting options, allowing for multiple wire pairs to be connected without having to strip off the insulation before making a connection. Commonly referred to as punch down connectors, they are selected by wire pair capacity, dimension, mounting features such as legs, panels or screw holes, as well as additional features such as lacing straps, label holders, mounting hardware, and shielding.
SelectionCharacteristics
Style: Indicates the configuration of the device.
Pair Number: Indicates the total number of connection pairs.
Length - Overall: Indicates the overall length of the wiring block.
Width - Overall: Indicates the overall width of the wiring block.
Depth - Overall: Indicates the overall depth of the wiring block.
Mounting Feature: A modifying feature to how the device is being attached.
Features: These are different capabilities or properties of the device such as label holder or mounting hardware.
ProductExamples
MFR PART # P110CB4-XY
DIGI-KEY PART # 298-16318-ND
MANUFACTURER Panduit Corp
DESCRIPTION 4 Pair Modular Wiring Block Connector 110 Block
DATASHEET Click Here
MFR PART # N237-001-SH
DIGI-KEY PART # TL1281-ND
MANUFACTURER Tripp Lite
DESCRIPTION Pair Modular Wiring Block Connector Screw Holes 110 Punch Down
MFR PART # J00060A0069
DIGI-KEY PART # 2269-J00060A0069-ND
MANUFACTURER Telegartner Inc
If you have any general questions on the specifications for selecting Modular Connector Wiring Blocks, please reply using the button below. If you have questions on specific Modular Connector Wiring Blocks please post those questions in the Connectors, Interconnects category.
