This Product Selection Guide contains information to help select products in the Terminal Blocks - Accessories category on DigiKey.com
Terminal Block Accessories are supplementary items such as end caps, base strip, brackets, busbar, coding key, connecting link, dummy plug, lighting indicator, terminals, and a retaining clip plus many others used with terminal block connectors.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Number of Positions: Indicates the number of positions the device the accessory is designed for use with has.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | 387736408 |
| DIGIKEY PART # | WM23147-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Connector Cover For Beau Barrier Blocks |
| MFR PART # | 1597510000 |
| DIGIKEY PART # | 1597510000-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Connector Light Pipe For Omnimate SL Series |
| MFR PART # | 1803921 |
| DIGIKEY PART # | 277-5900-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Connector Cable Housing For COMBICON GMSTB, IC and MSTB Series |
| MFR PART # | 727-199 |
| DIGIKEY PART # | 2946-727-199-ND |
| MANUFACTURER | WAGO Corporation |
| DESCRIPTION | Connector Insulation Stop For DIN Rail Terminal Blocks |
