This Product Selection Guide contains information to help select products in the Terminal Block Marker Strips category on DigiKey.com
Terminal blocks are commonly used to provide a convenient interconnection point between the pre-assembled portions of a device or system and the external field wiring to which it must be connected in the course of installation. Terminal block marker strips offer a convenient means of labelling or identifying individual terminal blocks to aid installation and maintenance, and are available with pre-printed legends or symbols, or blank to allow customization.
SelectionCharacteristics
Type: Indicates the style and configuration of the product.
Legend: Indicates the character, character range, or text that is pre-printed on a product or included in a product kit.
Pitch: Indicates the center-to-center spacing between adjacent pins.
Color: The dominant color of the product.
ProductExamples
| MFR PART # | 1050017:0011 |
| DIGIKEY PART # | 277-1529-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Connector Label, Snap In For CLIPLINE ST and UT Series |
| MFR PART # | 1828450000 |
| DIGIKEY PART # | 281-3512-ND |
| MANUFACTURER | Weidmüller |
| DESCRIPTION | Connector Label, Snap In For I, W and Z Series |
| MFR PART # | 86401012 |
| DIGIKEY PART # | 2160-86401012-ND |
| MANUFACTURER | Murrplastik Systems, Inc. |
| DESCRIPTION | Connector Label, Snap In For |
