This Product Selection Guide contains information to help select products in the Terminal Accessories category on DigiKey.com
Connector terminal housings often require additional features and protections to complete an electrical connection system suitable for harsh environments or repetitive motion applications. Terminal accessories may include bushings, covers, lock plates, sealing plugs, enclosed splices, shields and wire seals. Accessories are designed for specific use with related products by the same manufacturer and in the same product series for ideal results.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | 746600145R |
| DIGIKEY PART # | 732-13713-2-ND - Tape & Reel (TR) |
| MANUFACTURER | Würth Elektronik |
| DESCRIPTION | Connector Bushing For REDCUBE Screw Terminals |
| MFR PART # | 1544316-1 |
| DIGIKEY PART # | A122547-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Plug, Sealing For PRONER Quick Connects |
| MFR PART # | 221-500 |
| DIGIKEY PART # | 2946-221-500-ND |
| MANUFACTURER | WAGO Corporation |
| DESCRIPTION | Connector Mounting Carrier For Splices |
| MFR PART # | 72-N2 |
| DIGIKEY PART # | 3M157387-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Connector Splice Enclosure Kit For Scotchlok™ Butt Splices |
| MFR PART # | C390G02341E3 |
| DIGIKEY PART # | 889-2510-ND |
| MANUFACTURER | Amphenol Tuchel Industrial |
| DESCRIPTION | Connector Cover For Radsok® Housings |
| MFR PART # | CLRCVR1-1 |
| DIGIKEY PART # | CLRCVR1-1-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Connector Cover For H-TAP Splices |
