This Product Selection Guide contains information to help select products in the Rectangular Connector Accessories category on DigiKey.com
Rectangular connector accessories are items used with rectangular connector systems, which serve ancillary functions such as sealing of a connector assembly, mechanical fixation, avoidance of accidental un-mating, protection of un-mated connectors, cable strain relief, keying of connectors to discourage improper connections, facilitating system diagnostics, and others.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Number of Positions: Indicates the number of positions the device the accessory is designed for use with has.
Features: These are different capabilities or properties of the device such as wire size accepted, dust cap, or jackscrews.
ProductExamples
| MFR PART # | 281934-3 |
| DIGIKEY PART # | A123392-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Plug For |
| MFR PART # | 643251010 |
| DIGIKEY PART # | WM6347-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Connector Polarizing Device (Key, Plug, Post) For CMC Connectors |
| MFR PART # | W2S |
| DIGIKEY PART # | 1734-1037-ND |
| MANUFACTURER | TE Connectivity Deutsch Connectors |
| DESCRIPTION | Connector Wedgelock For DT Series Plugs |
| MFR PART # | 3505-8010 |
| DIGIKEY PART # | 3M155960-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Connector Retainer Clip For 2500 Series |
