This Product Selection Guide contains information to help select products in the Circular Connector Accessories category on DigiKey.com
Circular Connector accessories are supplementary items used with circular connectors. The available accessory types are adapter, adjuster, alignment disc, anchor, back shell, blanking plug, cable clamp, cable grip, cable gland, cable seal, cap, coding ring, compression nut, EMI gasket, faceplate, handles, hood, nut, o-ring, sealing boot, sleeve, snap-ring, wall plate, and wire seal.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Shell Size - Insert: Describes the size of a connector or component thereof in terms of the size of the contact-bearing insert with which a product is compatible. Insert size designations are derived from various industry and military standards.
Material: Indicates the material composition of the device.
Features: These are different capabilities or properties of the device such as antistatic, a chain, or a gasket.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | 206509-1 |
| DIGIKEY PART # | A16067-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Plug, Keying White |
| MFR PART # | 1680539 |
| DIGIKEY PART # | 277-4154-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Connector Screw Plug M12 Black |
| MFR PART # | 2411-002-1805 |
| DIGIKEY PART # | 1734-1886-ND |
| MANUFACTURER | TE Connectivity Deutsch Connectors |
| DESCRIPTION | Connector Hex Nut 18 Black |
