This Product Selection Guide contains information to help select products in the Circular Connector Assemblies category on DigiKey.com
Circular Connectors or circular interconnects are plugs and receptacles that are made in a circular look with multiple pins or sockets. The characteristics are connector type, number of positions, shell size-insert, shell size MIL, mounting type, and fastening type. The connector types are distributor, h-distributor, insert, jack and plug, line drain, line source, panel drain, panel feed-through, plug and receptacle, plug, receptacle, t-distributor, and terminal outlet.
SelectionCharacteristics
Connector Type: Typically indicates the style, configuration and pin gender of the device.
Number of Positions: The total number and type, where applicable, of electrical conductors the device has.
Shell Size - Insert: Describes the size of a connector or component thereof in terms of the size of the contact-bearing insert with which a product is compatible. Insert size designations are derived from various industry and military standards.
Shell Size, MIL: Indicates connector housing size in terms of a military standard size designator. Not applicable to non-MIL spec derived connectors or all MIL-spec connector series.
Mounting Feature: A modifying feature to how the device is being attached.
Termination: Selection of termination style used to connect the device to a system, such as crimp, solder, or quick connect.
Fastening Type: The mating retention mechanism employed by the device.
Orientation: Indicates direction and keying of the insert relative to the housing.
Primary Material: Indicates the general material composition of the device.
Shell Material: Indicates the material composition of the device shell.
Shell Finish: Indicates the finish/plating material applied to the device shell.
Contact Finish - Mating: Indicates the finish/plating material applied to the mating ends of the device’s contacts.
Color: The dominant color of the device.
Ingress Protection: IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
IP Ratings
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Material Flammability Rating: Ensures compliance with the relevant UL Flammability Rating.
UL94 Small Scale Flammability - Relative Comparison
Image from UL FLAMMABILITY – WHAT IT MEANS IN THE UL PRODUCT RECOGNITION PROCESS (faa.gov) Please see their website for more information.
Features: These are different capabilities or properties of the device such as a backshell, dust cap, or slide lock.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference.
Current Rating (Amps): Typically this represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Voltage Rating: Typically this represents the maximum voltage rating to which a device will meet its given specifications. Exceeding this voltage rating may damage the device and other system components.
Cable Opening: Indicates the diameter of the aperture in a device for cable exit, or the range of cable diameters that can be accommodated.
ProductExamples
| MFR PART # | 5749181-1 |
| DIGIKEY PART # | 5749181-1-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | 4 Position Circular Connector Receptacle, Female Sockets Solder |
| MFR PART # | KPJX-PM-4S |
| DIGIKEY PART # | 2092-KPJX-PM-4S-ND |
| MANUFACTURER | Kycon, Inc. |
| DESCRIPTION | 4 (Power) Position Circular Connector Jack, Female Sockets Solder |
| MFR PART # | AAA3MPZ |
| DIGIKEY PART # | SC1533-ND |
| MANUFACTURER | Switchcraft Inc. |
| DESCRIPTION | 3 Position Circular Connector Receptacle, Male Pins Solder Cup |
| MFR PART # | KPPX-3P |
| DIGIKEY PART # | 2092-KPPX-3P-ND |
| DESCRIPTION | 3 (1 + 2 Power) Position Circular Connector Plug, Male Pins Solder Cup |
MediaLinks
Videos
Amphenol ICC MRD Series Locking Connectors – DigiKey Daily
Amphenol Sine Systems DuraMate AHDP Connectors – DigiKey Daily
Circular Hybrid Connector
Ecomate Circular Plastic Connectors
HR41A Circular Connectors
ITT Cannon KP Connectors
ITT Cannon MKJ Series
M17-M40 PRO series circular connectors
Motiongrade M23 and M40 Series
NorComp QUIK-LOQ Circular Connectors – DigiKey Daily
ODU Mini-Snap L and K Series
Phoenix Contact PRC Series Circular Connectors – DigiKey Daily
The Bulgin Buccaneer Range Making Quick and Easy Connections for Harsh Environments
Trim Trio Series
Articles
Articles related to Circular Connectors
TechForum
Circular Connector Terminology Clarification
Connector vs Connector Housing
What are S-Video and PS/2 connectors called on DigiKey?
