This Product Selection Guide contains information to help select products in the Circular Connector Housings category on DigiKey.com
Circular connectors are interconnect products characterized by a cross section that is generally circular in shape and have contacts that are typically arranged on a polar coordinate system, rather than on a rectangular grid or coaxially. For products marketed as modular connector systems allowing configuration of a desired connector from a catalog of interoperable components, housing components are the portion of the connector into which contacts or contact insert assemblies are inserted, and to which supporting components such as backshells are attached.
SelectionCharacteristics
Connector Type: Indicates the style and configuration of the device.
Type: Indicates the type of contacts for which it is designed to be compatible.
Number of Positions: Indicates the total number of electrical conductors within the device and their type when applicable.
Shell Size - Insert: Describes the size of a connector or component thereof in terms of the size of the contact-bearing insert with which a product is compatible. Insert size designations are derived from various industry and military standards.
Shell Size, MIL: Indicates connector housing size in terms of a military standard size designator. Not applicable to non-MIL spec derived connectors or all MIL-spec connector series.
Contact Type: Indicates the termination type of contacts available for the housing.
Contact Size: Indicates the physical size of a contact, in terms of the size designation system used for the connector series in question.
Mounting Feature: A modifying feature to how the device is being attached.
Fastening Type: The mating retention mechanism employed by the device.
Orientation: Indicates direction and keying of the insert relative to the housing.
Primary Material: Indicates the general material composition of the device.
Shell Material: Indicates the material composition of the device shell.
Shell Finish: Indicates the finish/plating material applied to the device shell.
Housing Color: The dominant color of the housing of the device.
Ingress Protection: IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
IP Ratings
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Material Flammability Rating: Ensures compliance with the relevant UL Flammability Rating.
UL94 Small Scale Flammability - Relative Comparison
Image from UL FLAMMABILITY – WHAT IT MEANS IN THE UL PRODUCT RECOGNITION PROCESS (faa.gov) Please see their website for more information.
Features: These are different capabilities or properties of the device such as a dust cap, flame retardant, or self locking.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference.
ProductExamples
| MFR PART # | 1-967325-1 |
| DIGIKEY PART # | A106527-ND |
| MANUFACTURER | TE Connectivity Deutsch Connectors |
| DESCRIPTION | 4 Position Circular Connector Plug Housing Free Hanging (In-Line) Coupling Nut |
| MFR PART # | 206430-1 |
| DIGIKEY PART # | A1360-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | 4 Position Circular Connector Receptacle Housing Panel Mount |
| MFR PART # | 1432460 |
| DIGIKEY PART # | 277-12070-ND |
| MANUFACTURER | Phoenix Contact |
| DESCRIPTION | Position Circular Connector Insert Shell Panel Mount |
| MFR PART # | HR10A-7P-6SC(73) |
| DIGIKEY PART # | HR1666-ND |
| MANUFACTURER | Hirose Electric Co Ltd |
| DESCRIPTION | 6 Position Circular Connector Plug Housing Free Hanging (In-Line) Backshell, Cable Clamp, Strain Relief |
MediaLinks
Videos
Amphenol ICC MRD Series Locking Connectors – DigiKey Daily
Amphenol Sine Systems DuraMate AHDP Connectors – DigiKey Daily
Circular Hybrid Connector
Ecomate Circular Plastic Connectors
HR41A Circular Connectors
ITT Cannon KP Connectors
ITT Cannon MKJ Series
M17-M40 PRO series circular connectors
Motiongrade M23 and M40 Series
NorComp QUIK-LOQ Circular Connectors – DigiKey Daily
ODU Mini-Snap L and K Series
Phoenix Contact PRC Series Circular Connectors – Digi-Key Daily
The Bulgin Buccaneer Range Making Quick and Easy Connections for Harsh Environments
Trim Trio Series
Articles
Articles related to Circular Connectors
TechForum
Circular Connector Terminology Clarification
Connector vs Connector Housing
What are S-Video and PS/2 connectors called on DigiKey?
