This Product Selection Guide contains information to help select products in the Backshells and Cable Clamps category on DigiKey.com
Circular connectors are interconnect products characterized by a cross section that is generally circular in shape and have contacts that are typically arranged on a polar coordinate system, rather than on a rectangular grid or coaxially. For products marketed as modular connector systems allowing configuration of a desired connector from a catalog of interoperable components, backshell and cable clamp components are respectively used to cover the non-mating end of the connector and to provide strain relief for attached cabling.
SelectionCharacteristics
Type: The type, style, or nature of the device.
Cable Opening: Indicates the diameter of the aperture in a device for cable exit, or the range of cable diameters that can be accommodated.
Diameter - Outside: Nominal outside diameter of the backshell.
Shell Size - Insert: Describes the size of a connector or component thereof in terms of the size of the contact-bearing insert with which a product is compatible. Insert size designations are derived from various industry and military standards.
Thread Size: A description of the threaded diameter and thread-per-inch/pitch the backshell is designed to mate to.
Cable Exit: Describes the orientation(s) with which a cable can exit the connector body, relative to the connector contacts.
Primary Material: Indicates the general material composition of the device.
Material: Indicates the specific material composition of the device.
Plating: Indicates the finish/plating material applied to the device.
Shielding: Whether or not the device possesses an electrically insulating barrier that helps to reduce or eliminate electromagnetic interference.
Color: The dominant color of the device.
Features: These are different capabilities or properties of the device such as a cable gland, clamp screws, or a grommet.
Ingress Protection: IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
IP Ratings
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
ProductExamples
| MFR PART # | 1-206062-7 |
| DIGIKEY PART # | A105209-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Black Connector Backshell, Cable Clamp 5/8-24 UNEF 11 |
| MFR PART # | M85049/38-13N |
| DIGIKEY PART # | APC1434-ND |
| MANUFACTURER | Amphenol Interconnect India |
| DESCRIPTION | Silver Connector Cable Clamp 13 |
| MFR PART # | 206512-5 |
| DIGIKEY PART # | A32502-ND |
| DESCRIPTION | Black Connector Backshell, Cable Clamp 1 3/8-18 UNEF 23 |
