This Product Selection Guide contains information to help select products in the Backplane Connector Accessories category on DigiKey.com
Backplane connector accessories are items used with backplane connector systems, which serve ancillary functions such as sealing of a connector assembly, mechanical fixation, avoidance of accidental un-mating, protection of un-mated connectors, cable strain relief, keying to reduce the chance of improper connection, handles, and others.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: Where applicable, Indicates unique characteristic(s) of the accessory.
ProductExamples
| MFR PART # | 5223985-1 |
| DIGIKEY PART # | A101849-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Guide Pin For UPM Series 6-32 Thread |
| MFR PART # | 1650589-1 |
| DIGIKEY PART # | A102010-ND |
| DESCRIPTION | Connector Screw For Elcon Drawer M4 Thread |
| MFR PART # | 5223957-3 |
| DIGIKEY PART # | 5223957-3-ND |
| DESCRIPTION | Connector Guide Module For UPM Series |
| MFR PART # | 10037909-101LF |
| DIGIKEY PART # | 609-2101-ND |
| MANUFACTURER | Amphenol ICC (FCI) |
| DESCRIPTION | Connector Guide Module For Airmax VS® Series |
| MFR PART # | 213283-2 |
| DIGIKEY PART # | 213283-2-ND |
| DESCRIPTION | Connector Screw For High Durability Drawer Connector M4 Thread |
