This Product Selection Guide contains information to help select products in the Fiber Optic Connector Accessories category on DigiKey.com
Fiber optic connector accessories contain a variety of accessory types that are either used for a specific connector series or in general. Accessory types include device housing, adapter, alignment ring, blank panel, a block-out device, panel mount frame, loopback, housing carrier, dust cap, protective cap, coupler, retention clip, cap or cover, crimp ring, etc.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
Specifications: These are different capabilities or properties of the device such as a cable gland, chain, or multimode.
Material: Indicates the material composition of the device.
Color: The dominant color of the device.
ProductExamples
| MFR PART # | FDME8RG |
| DIGIKEY PART # | 298-12664-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Connector Enclosure For LC and SC Connectors |
| MFR PART # | 2226881-1 |
| DIGIKEY PART # | A121981-ND |
| MANUFACTURER | TE Connectivity Aerospace, Defense and Marine |
| DESCRIPTION | Connector Housing Carrier For Multi-Mode MT Ferrules |
| MFR PART # | 1918177-1 |
| DIGIKEY PART # | 1918177-1-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Connector Protective Cap For LC ODVA Compliant Connectors |
| MFR PART # | M29L2000 |
| DIGIKEY PART # | 1968-M29L2000-ND |
| MANUFACTURER | Amphenol Fiber Systems International |
| DESCRIPTION | Connector Contact For |
| MFR PART # | 1060051100 |
| DIGIKEY PART # | WM14147-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | Connector Loopback For MTP Connectors |
