This Product Selection Guide contains information to help select products in the Fiber Optic Connector Assemblies category on DigiKey.com
Fiber Optic Connectors are the ends used to terminate optical fiber cable. The connector styles are DNP, ESCON, FC, FDDI, FSD, FSMA, LC, MPO, MT-RJ, MU, SC, SCRJ, SCRJ and Power Jack, SMA, ST, TNC, and VF-45. The mode options are multimode (OM1, OM2, OM3, OM4), POF, and Singlemode (OM1). These connectors accept fiber core diameters ranging from 3 µm to 1000 µm.
SelectionCharacteristics
Connector Style: Indicates a specific type of connector with which the assembly is designed to be used.
Connector Type: An indication of the type of body the device has.
Simplex/Duplex: Describes the number of optical fibers accommodated by a device.
Mode: Indicates the type of optical fiber with which a connector is designed for use.
Fiber Core Diameter: The diameter of the core that the connector can accept.
Fiber Cladding Diameter: The diameter of the cladding that the connector can accept.
Cable Diameter: Indicates the nominal diameter or diameter range of wire/cable materials with which a product is designed for use.
Fastening Type: The mating retention mechanism employed by the device.
Housing Color: The dominant color of the housing.
Boot Color: The color of the portion of the housing that provides strain relief and mechanical cable support.
Ingress Protection: IP (Ingress Protection) ratings such as (IP20, IP65, IP67, etc.) define how likely water and dirt will get into the system. The first number represents dirt and solid contaminants while the second represents water and liquids.
IP Ratings
| Solids | Liquids | |
| 1 | Protected against solids larger than 50mm. | Protected against vertically falling drops of water. Limited Ingress permitted. |
| 2 | Protected against solids larger than 12.5mm. | Protected against vertically falling drops of water with the enclosure tilted up to 15 degrees from vertical. Limited ingress permitted. |
| 3 | Protected against solids larger than 2.5mm. | Protected against spraying water up to 60 degrees from vertical. Limited ingress permitted for 3 minutes. |
| 4 | Protected against solids larger than 1mm. | Protected against water splashed from any direction. Limited ingress permitted. |
| 5 | Protected against dust. Limited ingress of dust permitted. | Will not affect operation of equipment 2-8 hours. Protected against jets of water. Limited ingress permitted. |
| 6 | Dust tight. No ingress of dust 2-8 hours. | Protected against powerful jets of water. Limited ingress permitted. |
| 7 | ______________________ | Protected against the effects of immersion in 15cm-1m for 30 minutes. |
| 8 | ______________________ | Continuous immersion in water up to 3m for long periods of time. |
| 9 | ______________________ | Protected against high pressure jets of hot water. (30 seconds) |
| 9K | ______________________ | Protected against high pressure jets of hot water. (2 minutes) |
Features: These are different capabilities or properties of the device such as a dust cap, keyed, or tunable.
ProductExamples
| MFR PART # | HFBR-4516Z |
| DIGIKEY PART # | 516-2077-ND |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | Fiber Optic Plug Connector Duplex 1000µm Gray |
| MFR PART # | 6828094-1 |
| DIGIKEY PART # | A122472-ND |
| MANUFACTURER | TE Connectivity AMP Connectors |
| DESCRIPTION | Fiber Optic Plug Connector LC Simplex Beige |
| MFR PART # | FLCSSCBUY |
| DIGIKEY PART # | 298-12680-ND |
| MANUFACTURER | Panduit Corp |
| DESCRIPTION | Fiber Optic Plug Connector LC Simplex 125µm Natural |
