This Product Selection Guide contains information to help select products in the Fiber Optics and Accessories category on DigiKey.com
Fiber Optics and Accessories are collections of tools and kits designed to be used with a fiber optic connection and/or termination. They range from cleaning and polishing kits to full termination tool kits for nearly all common connection styles and core sizes of fiber optic cabling.
SelectionCharacteristics
Type: The type, style, or nature of the accessory.
Specifications: This selection indicates the attributes which expound on a product’s abilities but are not a standard attribute universal to this product family.
Size / Dimension: The physical dimensions of the device.
ProductExamples
| MFR PART # | MCC-POC03M |
| DIGI-KEY PART # | 2805-MCC-POC03M-ND |
| MANUFACTURER | MicroCare Corporation |
| DESCRIPTION | Cleaner |
| MFR PART # | HFBR-4593Z |
| DIGI-KEY PART # | 516-2082-ND |
| MANUFACTURER | Broadcom Limited |
| DESCRIPTION | Polishing Kit |
| MFR PART # | FX-CT2 |
| DIGI-KEY PART # | 1110-2198-ND |
| MANUFACTURER | Panasonic Industrial Automation Sales |
| DESCRIPTION | Fiber Cutter |
| MFR PART # | 6704F |
| DIGI-KEY PART # | 6704F-ND |
| MANUFACTURER | Chemtronics |
| DESCRIPTION | Cleaner 4.00" L x 4.00" W (101.6mm x 101.6mm) |
| MFR PART # | FO1 |
| DIGI-KEY PART # | FO1-ND |
| MANUFACTURER | HellermannTyton |
