This Product Selection Guide contains information to help select products in the Optoelectronics Accessories category on DigiKey.com
Supplementary items used with other devices in this category.
SelectionCharacteristics
Accessory Type: The type, style, or nature of the accessory.
ProductExamples
| MFR PART # | CAB-14574 |
| DIGIKEY PART # | 1568-1830-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | JST-SM PIGTAIL CONNECTOR (2-PIN) |
| MFR PART # | RTN_250 |
| DIGIKEY PART # | RTN_250-ND |
| MANUFACTURER | Visual Communications Company - VCC |
| DESCRIPTION | LITEPIPE SPRING RETAINER 4MM |
| MFR PART # | LSTC12-4A-RGB-AS |
| DIGIKEY PART # | 679-LSTC12-4A-RGB-AS-ND |
| MANUFACTURER | APEM Inc. |
| DESCRIPTION | RGB LED CONTROLLER |
